    4. Backitup meldet Fehler einer eslintrc.json
    • Basti17683
      Basti17683 last edited by
      Liebe Community,
      ich finde den Fehler nicht. Mein Backitup Adapter macht alle 2 Tage Nachts ein Backup auf das lokale NAS. Seit einiger Zeit bekomme ich Meldungen dass in einem temporären Ordner "corrupted Files" liegen.
      Ich habe mal die Logstufe auf Debüt gesetzt und manuell ein Backup gestartet.
      2025-02-22 13:48:39.214 - info: backitup.0 (280) cleaned everything up...
      2025-02-22 13:48:39.214 - info: backitup.0 (280) terminating
      2025-02-22 13:48:39.215 - info: backitup.0 (280) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-02-22 13:48:39.716 - info: backitup.0 (280) terminating
      2025-02-22 13:48:39.761 - info: host.IOHost instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-02-22 13:48:43.103 - info: host.IOHost instance system.adapter.backitup.0 in version "3.0.31" started with pid 25120
      2025-02-22 13:48:44.419 - info: backitup.0 (25120) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 7.0.6
      2025-02-22 13:48:44.533 - info: backitup.0 (25120) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2025-02-22 13:49:10.765 - error: backitup.0 (25120) [iobroker/iobroker] host.IOHost One or more optional files are corrupted: host.IOHost /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/widgets/.eslintrc.json is not a valid json file
      2025-02-22 13:49:10.766 - error: backitup.0 (25120) [iobroker/iobroker] host.IOHost Please ensure that self-created JSON files are valid
      2025-02-22 13:49:22.229 - warn: backitup.0 (25120) [iobroker/clean] No older backup files are deleted, because this backup was started manually
      2025-02-22 13:49:49.581 - info: host.IOHost stopInstance system.adapter.backitup.0 (force=false, process=true)
      2025-02-22 13:49:49.584 - info: host.IOHost stopInstance system.adapter.backitup.0 send kill signal
      2025-02-22 13:49:49.584 - info: backitup.0 (25120) Got terminate signal TERMINATE_YOURSELF
      2025-02-22 13:49:49.584 - info: backitup.0 (25120) cleaned everything up...
      2025-02-22 13:49:49.585 - info: backitup.0 (25120) terminating
      2025-02-22 13:49:49.586 - info: backitup.0 (25120) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-02-22 13:49:50.087 - info: backitup.0 (25120) terminating
      2025-02-22 13:49:50.129 - info: host.IOHost instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-02-22 13:49:53.430 - info: host.IOHost instance system.adapter.backitup.0 in version "3.0.31" started with pid 25240
      2025-02-22 13:49:54.453 - info: backitup.0 (25240) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 7.0.6
      2025-02-22 13:49:54.484 - info: backitup.0 (25240) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2025-02-22 13:50:55.808 - info: host.IOHost stopInstance system.adapter.backitup.0 (force=false, process=true)
      2025-02-22 13:50:55.811 - info: host.IOHost stopInstance system.adapter.backitup.0 send kill signal
      2025-02-22 13:50:55.811 - info: backitup.0 (25240) Got terminate signal TERMINATE_YOURSELF
      2025-02-22 13:50:55.812 - info: backitup.0 (25240) cleaned everything up...
      2025-02-22 13:50:55.813 - info: backitup.0 (25240) terminating
      2025-02-22 13:50:55.814 - info: backitup.0 (25240) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-02-22 13:50:56.316 - info: backitup.0 (25240) terminating
      2025-02-22 13:50:56.355 - info: host.IOHost instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-02-22 13:50:59.684 - info: host.IOHost instance system.adapter.backitup.0 in version "3.0.31" started with pid 25316
      2025-02-22 13:51:00.465 - debug: backitup.0 (25316) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2025-02-22 13:51:00.486 - debug: backitup.0 (25316) Objects client ready ... initialize now
      2025-02-22 13:51:00.487 - debug: backitup.0 (25316) Objects create System PubSub Client
      2025-02-22 13:51:00.487 - debug: backitup.0 (25316) Objects create User PubSub Client
      2025-02-22 13:51:00.513 - debug: backitup.0 (25316) Objects client initialize lua scripts
      2025-02-22 13:51:00.517 - debug: backitup.0 (25316) Objects connected to redis: 127.0.0.1:9001
      2025-02-22 13:51:00.535 - debug: backitup.0 (25316) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-02-22 13:51:00.543 - debug: backitup.0 (25316) States create System PubSub Client
      2025-02-22 13:51:00.544 - debug: backitup.0 (25316) States create User PubSub Client
      2025-02-22 13:51:00.558 - debug: backitup.0 (25316) States connected to redis: 127.0.0.1:9000
      2025-02-22 13:51:00.580 - debug: backitup.0 (25316) Plugin sentry Do not initialize Plugin (enabled=false)
      2025-02-22 13:51:00.673 - info: backitup.0 (25316) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v18.19.0, js-controller: 7.0.6
      2025-02-22 13:51:00.684 - debug: backitup.0 (25316) BackItUp has recognized a Docker system
      2025-02-22 13:51:00.724 - info: backitup.0 (25316) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2025-02-22 13:51:00.764 - debug: backitup.0 (25316) [iobroker] 10 48 02 */1 * *
      2025-02-22 13:51:00.770 - debug: backitup.0 (25316) cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.10.100/Public/IOBackup /opt/iobroker/backups"
      2025-02-22 13:51:01.048 - debug: backitup.0 (25316) mount successfully completed
      2025-02-22 13:51:03.057 - debug: backitup.0 (25316) detect backup file 1 from NAS: iobroker_2025_02_13-02_48_21_backupiobroker.tar.gz
      2025-02-22 13:51:03.057 - debug: backitup.0 (25316) detect backup file 2 from NAS: iobroker_2025_02_14-02_48_21_backupiobroker.tar.gz
      2025-02-22 13:51:03.058 - debug: backitup.0 (25316) detect backup file 3 from NAS: iobroker_2025_02_15-02_48_21_backupiobroker.tar.gz
      2025-02-22 13:51:03.058 - debug: backitup.0 (25316) detect backup file 4 from NAS: iobroker_2025_02_16-02_48_22_backupiobroker.tar.gz
      2025-02-22 13:51:03.058 - debug: backitup.0 (25316) detect backup file 5 from NAS: iobroker_2025_02_17-02_48_21_backupiobroker.tar.gz
      2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 6 from NAS: iobroker_2025_02_18-02_48_21_backupiobroker.tar.gz
      2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 7 from NAS: iobroker_2025_02_19-02_48_21_backupiobroker.tar.gz
      2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 8 from NAS: iobroker_2025_02_20-02_48_21_backupiobroker.tar.gz
      2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 9 from NAS: iobroker_2025_02_21-02_48_21_backupiobroker.tar.gz
      2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 10 from NAS: iobroker_2025_02_22-02_48_21_backupiobroker.tar.gz
      2025-02-22 13:51:03.059 - debug: backitup.0 (25316) detect backup file 11 from NAS: iobroker_2025_02_22-13_49_05_backupiobroker.tar.gz
      2025-02-22 13:51:03.060 - debug: backitup.0 (25316) detect last backup file: iobroker_2025_02_22-13_49_05_backupiobroker.tar.gz
      2025-02-22 13:51:10.711 - debug: backitup.0 (25316) mount activ... umount in 2 Seconds!!
      2025-02-22 13:51:10.747 - debug: backitup.0 (25316) Backup has started ...
      2025-02-22 13:51:10.750 - debug: backitup.0 (25316) [iobroker/mount] mount activ... umount is started before mount!!
      2025-02-22 13:51:10.763 - debug: backitup.0 (25316) [iobroker/mount] umount successfully completed
      2025-02-22 13:51:12.721 - debug: backitup.0 (25316) umount: device is busy... wait 5 Minutes!!
      2025-02-22 13:51:20.748 - debug: backitup.0 (25316) [iobroker/mount] cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.10.100/Public/IOBackup /opt/iobroker/backups"
      2025-02-22 13:51:20.865 - debug: backitup.0 (25316) [iobroker/mount] mount successfully completed
      2025-02-22 13:51:20.866 - debug: backitup.0 (25316) [iobroker/mount] done
      2025-02-22 13:51:25.208 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost 5397 objects saved
      2025-02-22 13:51:25.448 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost 4668 states saved
      2025-02-22 13:51:25.449 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost Validating backup ...
      2025-02-22 13:51:25.450 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost "config.json" is valid
      2025-02-22 13:51:25.451 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost "objects.jsonl" exists
      2025-02-22 13:51:25.451 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost "states.jsonl" exists
      2025-02-22 13:51:25.743 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost JSONL lines are valid
      2025-02-22 13:51:25.750 - error: backitup.0 (25316) [iobroker/iobroker] host.IOHost One or more optional files are corrupted: host.IOHost /opt/iobroker/node_modules/iobroker.js-controller/tmp/backup/files/vis/widgets/.eslintrc.json is not a valid json file
      2025-02-22 13:51:25.751 - error: backitup.0 (25316) [iobroker/iobroker] host.IOHost Please ensure that self-created JSON files are valid
      2025-02-22 13:51:25.751 - debug: backitup.0 (25316) [iobroker/iobroker] host.IOHost The backup is valid!
      2025-02-22 13:51:32.914 - debug: backitup.0 (25316) [iobroker/iobroker] Backup created: /opt/iobroker/backups/iobroker_2025_02_22-13_51_21_backupiobroker.tar.gz
      2025-02-22 13:51:32.916 - debug: backitup.0 (25316) [iobroker/iobroker] This backup can only be restored with js-controller version 7.0 or higher
      2025-02-22 13:51:33.939 - debug: backitup.0 (25316) [iobroker/iobroker] done
      2025-02-22 13:51:35.908 - debug: backitup.0 (25316) [iobroker/yahka] found yahka database: yahka.0
      2025-02-22 13:51:35.909 - debug: backitup.0 (25316) [iobroker/yahka] done
      2025-02-22 13:51:36.061 - debug: backitup.0 (25316) [iobroker/nodered] Created nodered tmp directory
      2025-02-22 13:51:36.151 - debug: backitup.0 (25316) [iobroker/nodered] Node-Red tmp copy finish
      2025-02-22 13:51:36.196 - debug: backitup.0 (25316) [iobroker/nodered] Backup created: /opt/iobroker/backups/nodered.0_2025_02_22-13_51_36_backupiobroker.tar.gz
      2025-02-22 13:51:36.197 - debug: backitup.0 (25316) [iobroker/nodered] Try deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
      2025-02-22 13:51:36.254 - debug: backitup.0 (25316) [iobroker/nodered] node-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
      2025-02-22 13:51:36.254 - debug: backitup.0 (25316) [iobroker/nodered] found node-red database: node-red.0
      2025-02-22 13:51:36.255 - debug: backitup.0 (25316) [iobroker/nodered] done
      2025-02-22 13:51:36.856 - debug: backitup.0 (25316) [iobroker/cifs] used copy path: /Public/IOBackup
      2025-02-22 13:51:36.857 - debug: backitup.0 (25316) [iobroker/cifs] done
      2025-02-22 13:51:37.459 - warn: backitup.0 (25316) [iobroker/clean] No older backup files are deleted, because this backup was started manually
      2025-02-22 13:51:37.459 - debug: backitup.0 (25316) [iobroker/clean] done
      2025-02-22 13:51:37.615 - debug: backitup.0 (25316) [iobroker/historyHTML] new history html values created
      2025-02-22 13:51:37.660 - debug: backitup.0 (25316) [iobroker/historyHTML] done
      2025-02-22 13:51:37.821 - debug: backitup.0 (25316) [iobroker/historyJSON] new history json values created
      2025-02-22 13:51:37.821 - debug: backitup.0 (25316) [iobroker/historyJSON] done
      2025-02-22 13:51:37.977 - debug: backitup.0 (25316) [iobroker/umount] mount active, umount is started ...
      2025-02-22 13:51:42.989 - debug: backitup.0 (25316) [iobroker/umount] umount successfully completed
      2025-02-22 13:51:42.990 - debug: backitup.0 (25316) [iobroker/umount] done
      2025-02-22 13:51:44.046 - debug: backitup.0 (25316) [iobroker/telegram] done
      2025-02-22 13:51:45.351 - debug: backitup.0 (25316) [iobroker/notification] done
      2025-02-22 13:51:45.613 - debug: backitup.0 (25316) [iobroker] exec: done
      Nach dem File habe ich im gesamten System unter /opt/iobroker gesucht. Das existiert nicht. Hat einer einen Anhaltspunkt was ich da noch probieren kann damit meine Backups wieder ohne Fehler durchlaufen?
      Vielen Dank
      • simatec
        simatec Developer Most Active @Basti17683 last edited by
        @basti17683 Hast du auch mit dem Punkt vorm Dateinamen gesucht? Das ist sehr wichtig
        • Basti17683
          @simatec
          Hallo und danke dass du dich dem ganzen so schnell angenommen hast.
          Ich habe mit dem Punkt voran gesucht.
          Mit "find / .eslintrc.json" sucht er ja das gesamte System durch
          Ergebnis nachdem er 5 Minuten Dateien über den Bildschirm hat fliegen lassen:
          Das ganze läuft auf einem QNAP Nas in einem Docker Container. Und das seit 2 Jahren echt stabil ohne Probleme
          Fällt dir sonst noch was ein?
          • simatec
            @basti17683 durchsuche mal nur das iob Volume und dann am besten mit Rechten, die auch Zugriff auf das Volume gewähren
            Basti17683 1 Reply Last reply Reply Quote 0
            • Basti17683
              Basti17683 @simatec last edited by
              @simatec
              Da bringt er einige aus dem gesamten Container Ordner in welchem IoBroker und InfluxDB laufen.
              Aber keines davon befindet sich in einem tmp Backup Ordner. Gesucht wurde mit dem einzigen Benutzer auf der Station der selbstverständlich Admin Rechte hat
              • simatec
                @basti17683 die ist es...
                Basti17683 1 Reply Last reply Reply Quote 1
                • Basti17683
                  Basti17683 @simatec last edited by Basti17683
                  @simatec
                  Die kann ich bedenkenlos raus löschen? Mehr als das etwas in der Visu nicht mehr funktioniert kann nicht passieren oder?
                  PS: Die Datei ist in meiner Vis2 Instanz ebenfalls vorhanden, mit der gab es aber beim Backup scheinbar keine Probleme
                    Homoran Global Moderator Administrators @Basti17683 last edited by
                    @basti17683 sagte in Backitup meldet Fehler einer eslintrc.json:
                    wenn du dich nicht traust, dann benenn sie doch um
                    • Basti17683
                      Basti17683 @Homoran last edited by
                      @homoran Wenn man sich lang genug mit Dingen beschäftigt kann es passieren dass man den Wald vor lauter Bäumen icht mehr sieht.
                      Danke, Datei umbenannt und manuell ein Backup ausgeführt -> keinen Fehler mehr bekommen.
                      Kann jemand etwas zum Hintergrund sagen? Warum ist diese exakt gleiche Datei im Ordner VIS2/Widgets kein Problem beim speichern, aber im Ordner VIS/Widgets schon?
                        Thomas Braun Most Active @Basti17683 last edited by
                        Ist sie das? Hast du mal einen hash über beide Dateien gezogen?
                        • Basti17683
                          Basti17683 @Thomas Braun last edited by
                          @thomas-braun said in Backitup meldet Fehler einer eslintrc.json:
                          Nein noch nicht - aber ich werde mal schauen wie man das macht, dann hole ich das nach 🙂 Wichtig ist dass es jetzt scheinbar ohne Fehler wieder funktioniert. 🙂
                            @basti17683
                            So zum Beispiel:
                            https://de.simeononsecurity.com/guides/how-to-get-hashes-of-files-on-linux/
                            838
