    4. Cloud Adapter (free) und VIS anzeigen
    • rtwl
      rtwl last edited by
      Ich habe immer wieder das Problem, wenn ich mit iobroker.net (free version) auf meine VIS zugreife, dass meine Verbindung getrennt und für 5 min gesperrt wird, weil meine VIS zuviele Anfragen sendet.
      Im Log finde ich die entsprechenden Einträge:
      2025-02-22 20:54:18.371 - info: cloud.0 (321760) User accessed from cloud: 8qFfARIUw66wIGBiB1qK
      2025-02-22 20:54:26.387 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:54:50.282 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:54:50.301 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:54:50.306 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:54:50.319 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:54:50.345 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:54:50.356 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:54:50.491 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:54:50.494 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:55:13.552 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:55:13.728 - error: cloud.0 (321760) Admin instance not defined. Please specify the lovelace instance in settings
      2025-02-22 20:56:26.328 - error: cloud.0 (321760) Cloud says: Too many state updates
      2025-02-22 20:56:26.888 - info: cloud.0 (321760) Connection changed: disconnect
      2025-02-22 20:56:26.889 - info: cloud.0 (321760) Connection lost
      2025-02-22 20:57:26.903 - info: cloud.0 (321760) Trying to connect as system.user.admin to cloud
      2025-02-22 20:57:27.109 - error: cloud.0 (321760) Sending to many events. Account is blocked for 5 minutes. Please restart cloud adapter.
      2025-02-22 20:57:27.110 - info: cloud.0 (321760) Connection changed: disconnect
      Auch wenn im Log von Lovelace geschrieben wird, versichere ich euch, dass ich dieses lovelace nicht verwende.
      Neben den ganzen Basic widgets verwende ich noch den MaterialDesign, inventwo, icontwo, Bring!.
      Hier die Fehlermeldung die vor der 5 min sperre angezeigt wird:
      ich hab auch fast ausschließlich inventwo-Universal-Switch Widgets um zu navigieren, manche davon schreiben beim klicken auch einen eigenen Datenpunkt. Dabei erscheint auch selbe Fehlermeldung in der "cloud-vis" mit dem entsprechenden Datenpunkt unter 0_userdata.
      insgesamt ist mir klar, dass was das bedeutet, aber ich verstehe den Grund nicht.
      Zählt denn das schreiben/schalten/bedienen der VIS auch zu den max 20 Anfragen hinzu, die in der kostenlosen Cloud Version inkludiert sind?
