    4. Back IT UP
    Back IT UP
      Smartuser_1 last edited by
      ich bekomme einen Fehler beim Backup und kann diesen nicht zuordnen. Was könnte der Grund sein ?
      Danke für Eure Unterstützung. Vg
      12:40:35.458DEBUGgrafanaCreated dashboard directory
      12:40:35.501DEBUGgrafanaCreated dashboards_manually_restore directory
      12:40:35.525DEBUGgrafanaCreated datasource directory
      12:40:35.545DEBUGgrafanastart Grafana request ...
      12:40:35.589DEBUGgrafanaGrafana is available ... Status: 200
      12:40:35.844DEBUGgrafanastart Grafana backup compress ...
      12:40:35.854DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
      12:40:35.993DEBUGgrafanaGrafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
      **12:40:35.995ERRORgrafanacannot found Grafana Backup files**
      12:40:36.028DEBUGgrafanadone
      12:40:40.965DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2025_02_23-12_40_35_V_backupiobroker.tar.gz
      12:40:40.969DEBUGjavascriptsdone
      12:40:41.845DEBUGcifsCopy iobroker_2025_02_23-12_40_21_V_backupiobroker.tar.gz...
      12:40:41.868ERRORcifsError: EACCES: permission denied, open '/iobroker_2025_02_23-12_40_21_V_backupiobroker.tar.gz'
      12:40:41.870DEBUGcifsCopy influxDB_2025_02_23-12_40_31_V_backupiobroker.tar.gz...
      12:40:41.872ERRORcifsError: EACCES: permission denied, open '/influxDB_2025_02_23-12_40_31_V_backupiobroker.tar.gz'
      12:40:41.874DEBUGcifsCopy javascripts_2025_02_23-12_40_35_V_backupiobroker.tar.gz...
      12:40:41.879ERRORcifsError: EACCES: permission denied, open '/javascripts_2025_02_23-12_40_35_V_backupiobroker.tar.gz'
      12:40:41.912DEBUGcifsdone
      12:40:42.436ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
      12:40:42.474DEBUGcleandone
      12:40:42.590DEBUGhistoryHTMLnew history html values created
      12:40:42.626DEBUGhistoryHTMLdone
        Thomas Braun Most Active @Smartuser_1 last edited by
        @smartuser_1 sagte in Back IT UP:
        Wie sehen die Rechte denn da aus? Liegt da ein gemountetes Dateisystem?
          Smartuser_1 @Thomas Braun last edited by
          ja, da liegt ein gemountetes Dateisystem (Laufwerk auf einer WD-MyCloudmirror).
          Der Zugriff auf der WD ist lesend und schreibend für den User freigegeben. Die Files werden auch teilweise auf der WD geschrieben, allerdings fehlt "Grafana".
          Vg
            @smartuser_1
            CIFS/SMB? NFS? Was anderes?
            Wie sehen die Rechte konkret aus?
            ls -l /opt/iobroker/backups/
            sagt?
              @thomas-braun said in Back IT UP:
              -rw-rw-r--+ 1 iobroker iobroker 1790862 Feb  7 18:24 iobroker_2025_02_07-18_24_02_Pi5_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker 1791381 Feb  8 02:48 iobroker_2025_02_08-02_48_20_Pi5_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker     135 Feb  7 18:24 javascripts_2025_02_07-18_24_06_Pi5_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker     136 Feb  8 02:48 javascripts_2025_02_08-02_48_24_Pi5_backupiobroker.tar.gz
                @smartuser_1
                Da ist das NAS gemountet? Mit welchem Protokoll hängst du das ein?
                  auf der NAS habe ich SMB 3 hinterlegt und im Adapter auch.
                    @smartuser_1
                    Setz das mal auf 3.1.1
                      habe im Adapter jetzt 3.1.1 eingestellt, es kommen leider immer doch die Fehler:
                      17:19:07.728ERRORgrafanaError on Grafana Dashboard Request: AxiosError: Request failed with status code 500
                      17:19:13.820ERRORcifsError: EACCES: permission denied, open '/iobroker_2025_02_23-17_18_58_V_backupiobroker.tar.gz'
                      17:19:13.824DEBUGcifsCopy influxDB_2025_02_23-17_19_03_V_backupiobroker.tar.gz...
                      17:19:13.851ERRORcifsError: EACCES: permission denied, open '/influxDB_2025_02_23-17_19_03_V_backupiobroker.tar.gz'
                      17:19:13.852DEBUGcifsCopy javascripts_2025_02_23-17_19_07_V_backupiobroker.tar.gz...
                      17:19:13.855DEBUGcifsdone
                      17:19:14.415ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
                        mount
                        ls -la /opt/iobroker/backups/influxDB_2025_02_23-17_19_03_V_backupiobroker.tar.gz
                        sagt?
                          ... habe es gerade getestet:
                          ls: cannot access '/opt/iobroker/backups/influxDB_2025_02_23-17_19_03_V_backupiobroker.tar.gz': No such file or directory
                          und die Abfrage ls -l auf das gemountete Laufwerk (inkl. der alten Daten vom Raspberrypi4):
                          uld@raspberrypi5:~/Backup/share $ ls -l
                          total 4373328
                          -rwxr-xr-x 1 root root     3060 Dec 12  2022 '01 at.csv'
                          -rwxr-xr-x 1 root root    31046 Dec 14  2022  grafana_2022_12_14-20_05_16_backupiobroker.tar.gz
                          -rwxr-xr-x 1 root root    31047 Dec 15  2022  grafana_2022_12_15-02_41_33_V_backupiobroker.tar.gz
                          -rwxr-xr-x 1 root root    31092 Dec 22  2022  grafana_2022_12_22-02_41_35_V_backupiobroker.tar.gz
                            @smartuser_1
                            Die Dateien dürften aber eigentlich auch nicht dem root gehören.
                            491
