    4. Admin Adapter startet nicht mehr
      Smibser last edited by
      Ohne bewusst etwas verändert zu haben startet der admin Adapter nicht mehr.
      Hier der log vom startenden und gleich wieder terminierenden admin Adapter:
      admin.0 (21460) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v18.20.4, js-controller: 4.0.24
      admin.0 (21460) requesting all states
      admin.0 (21460) requesting all objects
      admin.0 (21460) received all objects
      admin.0 (21460) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
      admin.0 (21460) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      admin.0 (21460) get state error: Connection is closed.
      admin.0 (21460) get state error: DB closed
      admin.0 (21460) Cannot check node.js/npm version
      admin.0 (21460) terminating http server on port 8081
      • Adaptername: Admin
      • Link zu Adapterrepository: https://github.com/ioBroker/ioBroker.admin
      • Adapterversion: 6.3.5
      • js-controller Version: 4.0.24
      • Hardwaresystem: Raspberry Pi 4 Model B Rev 1.1
      • Arbeitsspeicher: 1.8GB
      • Festplattenart: SD-Karte
      • Betriebssystem: Raspbian GNU/Linux 10 (buster)
      • Nodejs-Version: v18.20.4
      • NPM-Version: 10.7.0
      Linux User bitte hier den Output von iob diag einfügen.
      			v.2025-02-23
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Installation: 		native
      Kernel: 		armv7l
      Userland: 		32 bit
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1000
      Display-Server: 	false
      Boot Target: 		multi-user.target
      Pending OS-Updates: 	1
      Pending iob updates: 	36
      Nodejs-Installation:
      /usr/bin/nodejs 	v18.20.4
      /usr/bin/node 		v18.20.4
      /usr/bin/npm 		10.7.0
      /usr/bin/npx 		10.7.0
      /usr/bin/corepack 	0.28.0
      nodeJS installation is correct
      MEMORY:
      Mem:           1.9G        994M        206M         20M        670M        757M
      Swap:           99M         81M         18M
      Total:         2.0G        1.1G        225M
      Active iob-Instances: 	14
      Active repo(s): stable
      ioBroker Core: 		js-controller 		4.0.24
      			admin 			6.3.5
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      Objects: 		9002
      States: 		6404
      Size of iob-Database:
      14M	/opt/iobroker/iobroker-data/objects.jsonl
      7.1M	/opt/iobroker/iobroker-data/objects.json.migrated
      7.1M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
      0	/opt/iobroker/iobroker-data/objects.json.broken
      3.3M	/opt/iobroker/iobroker-data/states.jsonl
      996K	/opt/iobroker/iobroker-data/states.json.migrated
      992K	/opt/iobroker/iobroker-data/states.json.bak.migrated
      0	/opt/iobroker/iobroker-data/states.json.broken
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      Thomas Braun Homoran haselchen 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Smibser last edited by
        @smibser
        Das hast du aber ganz lange 'nichts mehr verändert'.
        Alles hoffnungslos veraltet.
          Homoran Global Moderator Administrators @Smibser last edited by
          @smibser sagte in Admin Adapter startet nicht mehr:
          bitte die Langfassung!
          lassen aber schon schlimmes vermuten.
          Diese harmlos aussehende Zahl ist aber darin begründet, dass
          schon lange nicht mehr supported wird
          • haselchen
            haselchen Most Active @Smibser last edited by haselchen
            @smibser
            Zudem , dass alles veraltet ist , hast Du sehr wohl was verändert.
            Du hast einen Admin hinzugefügt.
            admin.0 und admin.1 sind vorhanden .
            iobroker stop admin.1
            iobroker del admin.1
            iobroker start admin.0
            Und dann solltest Du wieder auf die GUI kommen .
            Dann Backup und dann Neuinstallation.
              Homoran Global Moderator Administrators @haselchen last edited by
              @haselchen sagte in Admin Adapter startet nicht mehr:
              und beide auf port 8081.
              und beide nicht aktiv.
              @Smibser
              bitte die Langfassung von iob diag bevor du etwas änderst!
