    4. Pflege des Betriebssystems
    5. Js-Controller lässt sich nicht auf 7.x upgraden
    • SunkHD
      SunkHD last edited by SunkHD
      • js-controller Version: 4.0.24
      • Admin Version: 7.4.10
      • Hardwaresystem: Pi4 ...
      • Arbeitsspeicher: 8GB
      • Festplattenart: SD-Karte
      • Betriebssystem: Raspberry 32 Bit (lite)
      • Nodejs-Version: 22.14.0
      • NPM-Version: 11.1.0
      • Installationsart: Skript
      ```bash
      			v.2025-02-23
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 5.15.84-v7l+
            Architecture: arm
      Installation: 		native
      Kernel: 		armv7l
      Userland: 		32 bit
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1000
      Display-Server: 	false
      Boot Target: 		multi-user.target
      Pending OS-Updates: 	0
      Pending iob updates: 	13
      This system needs to be REBOOTED NOW!
      Nodejs-Installation:
      /usr/bin/nodejs 	v22.14.0
      /usr/bin/node 		v22.14.0
      /usr/bin/npm 		11.1.0
      /usr/bin/npx 		11.1.0
      /usr/bin/corepack 	0.31.0
      Recommended versions are nodejs 20.18.3 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            7.9G        1.3G        5.4G         35M        1.2G        6.3G
      Swap:            99M        3.0M         96M
      Total:          8.0G        1.3G        5.5G
      Active iob-Instances: 	20
      Active repo(s): stable
      ioBroker Core: 		js-controller 		4.0.24
      			admin 			7.4.10
      ioBroker Status: 	iobroker is running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects: 		2708
      States: 		2224
      Size of iob-Database:
      12M	/opt/iobroker/iobroker-data/objects.jsonl
      2.1M	/opt/iobroker/iobroker-data/states.jsonl
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      === Mark text until here for copying ===
      ich versuche gerade mein system auf den neusten Stand zu bringen um es anschließend auf eine neue 64Bit version umzuziehen per Backup adapter.
      Leider lässt sich der JS-Controller nicht auf die neuste Version bringen:
      npm warn ERESOLVE overriding peer dependency
      npm warn While resolving: @iobroker/adapter-core@3.2.3
      npm warn Found: @iobroker/types@5.0.19
      npm warn node_modules/iobroker.iot/node_modules/@iobroker/types
      npm warn   @iobroker/types@"^5.0.19" from iobroker.iot@3.3.0
      npm warn     iobroker.iot@"3.3.0" from the root project
      npm warn
      npm warn Could not resolve dependency:
      npm warn peer @iobroker/types@">=6.0.11" from @iobroker/adapter-core@3.2.3
      npm warn node_modules/iobroker.iot/node_modules/@iobroker/adapter-core
      npm warn   @iobroker/adapter-core@"^3.0.4" from iobroker.iot@3.3.0
      npm warn
      npm warn Conflicting peer dependency: @iobroker/types@7.0.6
      npm warn node_modules/@iobroker/types
      npm error code EBADENGINE
      npm error engine Unsupported engine
      npm error engine Not compatible with your version of node/npm: ring-client-api@11.7.3
      npm error notsup Not compatible with your version of node/npm: ring-client-api@11.7.3
      npm error notsup Required: {"node":"^16 || ^18"}
      npm error notsup Actual:   {"npm":"11.1.0","node":"v22.14.0"}
      oder kann ich auch so bedenkenlos umziehen?
      grüße Max
      Edit:
      Ich denke ich muss ein Upgrade auf Debian 12 durchführen oder?
      Hab das system nach dieser Anleitung geupgradet
        arteck Developer Most Active @SunkHD last edited by
        @sunkhd sagte in Js-Controller lässt sich nicht auf 7.x upgraden:
        lesen kannst du aber ??
        SunkHD 1 Reply Last reply Reply Quote 0
        • SunkHD
          SunkHD @arteck last edited by
          @arteck ne xD hab ich erst überlesen, deswegen mein Edit ganz unten. Update läuft gerade noch
            Thomas Braun Most Active @SunkHD last edited by
            @sunkhd
            Installier das System komplett von Grundauf neu.
            Du fährst ein 32Bit-System und ein in-line-Upgrade auf Bookworm ist nicht möglich.
            SunkHD 2 Replies Last reply Reply Quote 0
              @sunkhd
              Und nodejs@22 ist zu neu. Für den
              ist sogar die empfohlene nodejs@20 zu neu, das Ding will maximal 18 haben. Wo kommt
              ring-client-api
              her?
              cd /opt/iobroker && npm ls ring-client-api
              • SunkHD
                SunkHD @Thomas Braun last edited by
                @thomas-braun möchte ich ja. aber kann ich mein Backup vom alten System einspielen? das wäre echt Arbeit alles wieder zum laufen zu bringen
                  Das würde ich erst senkrecht aufstellen und dann mit der stabilen Basis umziehen.
                  • SunkHD
                    @thomas-braun said in Js-Controller lässt sich nicht auf 7.x upgraden:
                    cd
                    ├─┬ iobroker.ham@5.3.1 (git+ssh://git@github.com/ioBroker/ioBroker.ham.git#6a73ba47abc87c927187f2b9354e2edd028cf2e5)
                    │ └─┬ homebridge-ring@11.7.1
                    │   └── ring-client-api@11.7.1
                    └─┬ iobroker.ring@3.2.2
                      └── ring-client-api@11.7.3
                    kommt vom homebridge Adapter
                    • SunkHD
                      @thomas-braun okay
                        iobroker.ring
                        Der blockt auch. Schmeiß beide Adapter temporär raus und dann schaust du nacher ob du die wieder draufbekommst.
                        Drück aber nodejs auf v 20:
                        iob nodejs-update 20
                        • SunkHD
                          war ein bissel voreilig, das update von Bookworm ist jetzt fertig.
                          pi@raspberrypi:~ $ cat /etc/debian_version
                          12.9
                            Das funktioniert aber nicht richtig.
                            Kannst du NUR NEUINSTALLIEREN.
                            • SunkHD
                              hab das update durchgeführt. Version bleibt jedoch auf 22
                              pi@raspberrypi:~ $ nodejs -v
                              v22.14.0
                              • SunkHD
                                SunkHD @Thomas Braun last edited by SunkHD
                                @thomas-braun okay verstehe. (das upgrade lief leider schon bevor du geantwortet hattest)
                                  @sunkhd
                                  Keine Ahnung was du da für eine verfummelte Kiste hast...
                                  Meldungen zu
                                  sehen wie aus?
                                  • SunkHD
                                    ioBroker nodejs fixer 2025-02-23
                                    You requested to install latest version from nodejs v20 tree.
                                    Your current setup is:
                                    /usr/bin/npm 		11.1.0
                                    /usr/bin/npx 		11.1.0
                                    We found these nodejs versions available for installation:
                                    nodejs:
                                      Installed: 22.14.0-1nodesource1
                                      Candidate: 22.14.0-1nodesource1
                                      Version table:
                                     *** 22.14.0-1nodesource1 100
                                            100 /var/lib/dpkg/status
                                         20.18.3-1nodesource1 600
                                            500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                                         20.18.2-1nodesource1 600
                                         20.18.1-1nodesource1 600
                                         20.18.0-1nodesource1 600
                                         20.17.0-1nodesource1 600
                                         20.16.0-1nodesource1 600
                                         20.15.1-1nodesource1 600
                                         20.15.0-1nodesource1 600
                                         20.14.0-1nodesource1 600
                                         20.13.1-1nodesource1 600
                                         20.13.0-1nodesource1 600
                                         20.12.2-1nodesource1 600
                                         20.12.1-1nodesource1 600
                                         20.12.0-1nodesource1 600
                                         20.11.1-1nodesource1 600
                                         20.11.0-1nodesource1 600
                                         20.10.0-1nodesource1 600
                                         20.9.0-1nodesource1 600
                                         20.8.1-1nodesource1 600
                                         20.8.0-1nodesource1 600
                                         20.7.0-1nodesource1 600
                                         20.6.1-1nodesource1 600
                                         20.6.0-1nodesource1 600
                                         20.5.1-1nodesource1 600
                                         20.5.0-1nodesource1 600
                                         20.4.0-1nodesource1 600
                                         20.3.1-1nodesource1 600
                                         20.3.0-1nodesource1 600
                                         20.2.0-1nodesource1 600
                                         20.1.0-1nodesource1 600
                                         20.0.0-1nodesource1 600
                                         18.19.0+dfsg-6~deb12u2+rpi1 500
                                            500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
                                    Nothing to do - Your installation is using the correct paths.
                                    You are running nodejs v22.14.0. Do you want to install latest version from nodejs v.20 tree?
                                    Press <y> to continue or any other key to quit
                                    Trying to fix your installation now. Please be patient.
                                    rm: cannot remove '/usr/share/keyrings/nodesource.gpg'$'\n''/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
                                    Waiting for ioBroker to shut down - Give me a minute...
                                    Removing dfsg-nodejs
                                    *** These repos are active on your system:
                                    Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                                    Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
                                    Hit:3 https://download.docker.com/linux/raspbian bookworm InRelease
                                    Hit:4 https://repo.homebridge.io stable InRelease
                                    Reading package lists... Done
                                    W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                                    W: Skipping acquire of configured file 'non-free-firmware/binary-armhf/Packages' as repository 'http://raspbian.raspberrypi.org/raspbian bookworm InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
                                    W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en' as repository 'http://raspbian.raspberrypi.org/raspbian bookworm InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
                                    W: Skipping acquire of configured file 'non-free-firmware/dep11/Components-armhf.yml' as repository 'http://raspbian.raspberrypi.org/raspbian bookworm InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
                                    *** Installing ca-certificates, curl and gnupg, just in case they are missing.
                                    *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
                                    deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                                    Package: nodejs
                                    Pin: origin deb.nodesource.com
                                    Pin-Priority: 1001
                                    *** These repos are active after the adjustments:
                                    Get:5 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                                    Get:6 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [10.6 kB]
                                    Fetched 22.8 kB in 1s (16.8 kB/s)
                                    Installing nodejs now!
                                    Installing the nodejs!
                                    We tried our best to fix your nodejs. Please run iob diag again to verify.
                                    *** RESTARTING ioBroker NOW! ***
                                     Please refresh or restart your browser in a few moments.
                                    • SunkHD
                                      @thomas-braun hab jetzt nochmal versucht Js-Controller 7.X zu installieren, diesmal hat es geklappt.
                                        @sunkhd
                                        Dann zieh jetzt die
                                        nach.
                                        • SunkHD
                                          @thomas-braun erledigt. jetzt backup durchführen?
                                          917
