    4. ESPHome Dashboard bleibt leer
      bernd33-1 last edited by
      das Dashboard wir bei mir nichtmehr angezeigt. Im Log kommt:
      esphome has an invalid jsonConfig: [{"instancePath":"/items/devices/items/encryptionKey","schemaPath":"#/definitions/passwordProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"freeSolo"},"message":"must NOT have additional properties"},{"instancePath":"/items/devices","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
      Version ESPHome v0.5.0-beta.10
      IOB läuft auf einem 64 Bit Raspi.
      Kann jemand mit der Fehlermeldung was anfangen und Tipps geben, wie ich das Dashboard wieder an den Start bekomme?
      LG, Bernd
        bernd33-1 @bernd33-1 last edited by
        @bernd33-1 Weitere Infos beim starten des ESPHome Adapters steht im Log:
        Fatal error starting ESPHomeDashboard |
        Error: Command failed with exit code 1: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install esphome==2025.2.1 pillow==10.2.0
        ERROR: Cannot install esphome==2025.2.1 and pillow==10.2.0 because these package versions have conflicting dependencies.[notice]
        A new release of pip is available: 24.3.1 -> 25.0.1[notice]
        To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip
        Die ganze Fehlermeldung steht im Spoiler.
        ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/topics/dependency-resolution/#dealing-with-dependency-conflictsLooking in indexes: https://pypi.org/simple, https://www.piwheels.org/simpleCollecting esphome==2025.2.1 Using cached https://www.piwheels.org/simple/esphome/esphome-2025.2.1-py3-none-any.whl (4.2 MB)
        Collecting pillow==10.2.0 Using cached pillow-10.2.0-cp311-cp311-manylinux_2_28_aarch64.whl.metadata (9.7 kB)Requirement already satisfied: cryptography==43.0.0 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (43.0.0)
        Requirement already satisfied: voluptuous==0.14.2 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (0.14.2)
        Requirement already satisfied: PyYAML==6.0.2 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (6.0.2)
        Requirement already satisfied: paho-mqtt==1.6.1 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (1.6.1)
        Requirement already satisfied: colorama==0.4.6 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (0.4.6)
        Requirement already satisfied: icmplib==3.0.4 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (3.0.4)
        Requirement already satisfied: tornado==6.4 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (6.4)
        Requirement already satisfied: tzlocal==5.2 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (5.2)
        Requirement already satisfied: tzdata>=2021.1 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (2023.4)
        Requirement already satisfied: pyserial==3.5 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (3.5)
        Requirement already satisfied: platformio==6.1.16 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (6.1.16)
        Requirement already satisfied: esptool==4.7.0 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (4.7.0)
        Requirement already satisfied: click==8.1.7 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (8.1.7)
        Collecting esphome-dashboard==20250212.0 (from esphome==2025.2.1) Using cached https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20250212.0-py3-none-any.whl (5.8 MB)Collecting aioesphomeapi==29.1.1 (from esphome==2025.2.1)
        Using cached aioesphomeapi-29.1.1-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (5.2 kB)Collecting zeroconf==0.145.1 (from esphome==2025.2.1)
        Using cached zeroconf-0.145.1-cp311-cp311-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (6.2 kB)Requirement already satisfied: puremagic==1.27 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (1.27)
        Requirement already satisfied: ruamel.yaml==0.18.6 in /home/iobroker/.cache/autopy/venv/esphome/lib/python3.11/site-packages (from esphome==2025.2.1) (0.18.6)Collecting esphome-glyphsets==0.1.0 (from esphome==2025.2.1)
        Using cached https://www.piwheels.org/simple/esphome-glyphsets/esphome_glyphsets-0.1.0-py3-none-any.whl (159 kB)INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements.
        This could take a while.
        The conflict is caused by: The user requested pillow==10.2.0 esphome 2025.2.1 depends on pillow==10.4.0
        To fix this you could try to:
        1. loosen the range of package versions you've specified
        2. remove package versions to allow pip to attempt to solve the dependency conflict |
          A new release of pip is available: 24.3.1 -> 25.0.1[notice] To update, run: /home/iobroker/.cache/autopy/venv/esphome/bin/python3 -m pip install --upgrade pip
          Using cached https://www.piwheels.org/simple/esphome/esphome-2025.2.1-py3-none-any.whl (4.2 MB)Collecting pillow==10.2.0 Using cached pillow-10.2.0-cp311-cp311-manylinux_2_28_aarch64.whl.metadata (9.7 kB)
          The conflict is caused by: The user requested pillow==10.2.0 esphome 2025.2.1 depends on pillow==10.4.0To fix this you could try to:
        3. loosen the range of package versions you've specified
        4. remove package versions to allow pip to attempt to solve the dependency conflict at makeError (file:///opt/iobroker/node_modules/autopy/node_modules/execa/lib/error.js:60:11)
          at handlePromise (file:///opt/iobroker/node_modules/autopy/node_modules/execa/index.js:124:26)
          at processTicksAndRejections (node:internal/process/task_queues:95:5)
          at $df9eabe9bda49ea8$export$e522f41234ab669a (file:///opt/iobroker/node_modules/autopy/src/index.ts:257:13)
          at Esphome.espHomeDashboard (/Users/nl69zh/Developer/community/opensource/ioBroker.esphome/main.js:180:7)
          at Esphome.onReady (/opt/iobroker/node_modules/iobroker.esphome/main.js:66:4)
        Ich hab dann pip lat Fehlermeldung installiert. Hat auch geklappt, jetzt steht:
        pi@e4310:~ $ python3 -m pip install --upgrade pip
        Defaulting to user installation because normal site-packages is not writeable
        Requirement already satisfied: pip in ./.local/lib/python3.9/site-packages (25.0.1)
        pi@e4310:~ $
        Trotzdem... wenn ich den ESPHome Adapter versuche zu starten, kommt immer noch die gleiche Fehlermeldung wie im Spoiler.
        Hat jemand Ideen?
        LG, Bernd
          bernd33-1 @bernd33-1 last edited by bernd33-1
          @bernd33-1 In der Fehlermeldung steht ja, welches Kommando er ausführen will:
          Startet man das von Hand, kommt die Fehlermeldung, dass ESPHome 2025.2.1 und pillow 10.2.0 "conflicting dependencies" haben. Man braucht pillow 10.4.0
          pi@e4310:~/.local/bin $ python3 -m pip install esphome==2025.2.1 pillow==10.2.0
          Requirement already satisfied: esphome==2025.2.1 in /usr/local/lib/python3.9/dist-packages (2025.2.1)
          Using cached pillow-10.2.0-cp39-cp39-manylinux_2_28_aarch64.whl.metadata (9.7 kB)
          Requirement already satisfied: cryptography==43.0.0 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (43.0.0)
          Requirement already satisfied: voluptuous==0.14.2 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (0.14.2)
          Requirement already satisfied: PyYAML==6.0.2 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (6.0.2)
          Requirement already satisfied: paho-mqtt==1.6.1 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (1.6.1)
          Requirement already satisfied: colorama==0.4.6 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (0.4.6)
          Requirement already satisfied: icmplib==3.0.4 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (3.0.4)
          Requirement already satisfied: tornado==6.4 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (6.4)
          Requirement already satisfied: tzlocal==5.2 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (5.2)
          Requirement already satisfied: tzdata>=2021.1 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (2025.1)
          Requirement already satisfied: pyserial==3.5 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (3.5)
          Requirement already satisfied: platformio==6.1.16 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (6.1.16)
          Requirement already satisfied: esptool==4.7.0 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (4.7.0)
          Requirement already satisfied: click==8.1.7 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (8.1.7)
          Requirement already satisfied: esphome-dashboard==20250212.0 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (20250212.0)
          Requirement already satisfied: aioesphomeapi==29.1.1 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (29.1.1)
          Requirement already satisfied: zeroconf==0.145.1 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (0.145.1)
          Requirement already satisfied: puremagic==1.27 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (1.27)
          Requirement already satisfied: ruamel.yaml==0.18.6 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (0.18.6)
          Requirement already satisfied: esphome-glyphsets==0.1.0 in /usr/local/lib/python3.9/dist-packages (from esphome==2025.2.1) (0.1.0)
          INFO: pip is looking at multiple versions of esphome to determine which version is compatible with other requirements. This could take a while.
          Ok, dann so : python3 -m pip install esphome==2025.2.1 pillow==10.4.0
          Jetzt kommt er weiter aber am Ende kommt ein permission Problem 😥
          pi@e4310:~/.local/bin $ python3 -m pip install esphome==2025.2.1 pillow==10.4.0
          Requirement already satisfied: pillow==10.4.0 in /home/pi/.local/lib/python3.9/site-packages (10.4.0)
          Collecting cryptography==43.0.0 (from esphome==2025.2.1)
          Using cached cryptography-43.0.0-cp39-abi3-manylinux_2_28_aarch64.whl.metadata (5.4 kB)
          Collecting voluptuous==0.14.2 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/voluptuous/voluptuous-0.14.2-py3-none-any.whl (31 kB)
          Collecting PyYAML==6.0.2 (from esphome==2025.2.1)
          Using cached PyYAML-6.0.2-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (2.1 kB)
          Collecting paho-mqtt==1.6.1 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
          Collecting colorama==0.4.6 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/colorama/colorama-0.4.6-py2.py3-none-any.whl (25 kB)
          Collecting icmplib==3.0.4 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/icmplib/icmplib-3.0.4-py3-none-any.whl (30 kB)
          Collecting tornado==6.4 (from esphome==2025.2.1)
          Using cached tornado-6.4-cp38-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (2.5 kB)
          Collecting tzlocal==5.2 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/tzlocal/tzlocal-5.2-py3-none-any.whl (17 kB)
          Collecting tzdata>=2021.1 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/tzdata/tzdata-2025.1-py2.py3-none-any.whl (346 kB)
          Collecting pyserial==3.5 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/pyserial/pyserial-3.5-py2.py3-none-any.whl (90 kB)
          Collecting platformio==6.1.16 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/platformio/platformio-6.1.16-py3-none-any.whl (419 kB)
          Collecting esptool==4.7.0 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/esptool/esptool-4.7.0-py3-none-any.whl (370 kB)
          Collecting click==8.1.7 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/click/click-8.1.7-py3-none-any.whl (97 kB)
          Using cached aioesphomeapi-29.1.1-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (5.2 kB)
          Using cached zeroconf-0.145.1-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (6.2 kB)
          Collecting puremagic==1.27 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/puremagic/puremagic-1.27-py3-none-any.whl (40 kB)
          Collecting ruamel.yaml==0.18.6 (from esphome==2025.2.1)
          Using cached https://www.piwheels.org/simple/ruamel-yaml/ruamel.yaml-0.18.6-py3-none-any.whl (117 kB)
          Collecting freetype-py==2.5.1 (from esphome==2025.2.1)
          Downloading freetype_py-2.5.1-py3-none-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (6.3 kB)
          Collecting kconfiglib==13.7.1 (from esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/kconfiglib/kconfiglib-13.7.1-py2.py3-none-any.whl (145 kB)
          Collecting pyparsing>=3.0 (from esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/pyparsing/pyparsing-3.2.1-py3-none-any.whl (107 kB)
          Collecting argcomplete>=2.0.0 (from esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/argcomplete/argcomplete-3.5.3-py3-none-any.whl (43 kB)
          Collecting async-timeout==4.0.3 (from esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/async-timeout/async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
          Collecting aiohappyeyeballs>=2.3.0 (from aioesphomeapi==29.1.1->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/aiohappyeyeballs/aiohappyeyeballs-2.4.6-py3-none-any.whl (14 kB)
          Collecting async-interrupt>=1.2.0 (from aioesphomeapi==29.1.1->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/async-interrupt/async_interrupt-1.2.2-py3-none-any.whl (8.9 kB)
          Collecting protobuf>=4 (from aioesphomeapi==29.1.1->esphome==2025.2.1)
          Downloading protobuf-5.29.3-cp38-abi3-manylinux2014_aarch64.whl.metadata (592 bytes)
          Collecting chacha20poly1305-reuseable>=0.13.2 (from aioesphomeapi==29.1.1->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/chacha20poly1305-reuseable/chacha20poly1305_reuseable-0.13.2-py3-none-any.whl (8.6 kB)
          Collecting noiseprotocol<1.0,>=0.3.1 (from aioesphomeapi==29.1.1->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/noiseprotocol/noiseprotocol-0.3.1-py3-none-any.whl (20 kB)
          Collecting cffi>=1.12 (from cryptography==43.0.0->esphome==2025.2.1)
          Downloading cffi-1.17.1-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (1.5 kB)
          Collecting bitstring>=3.1.6 (from esptool==4.7.0->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/bitstring/bitstring-4.3.0-py3-none-any.whl (71 kB)
          Collecting ecdsa>=0.16.0 (from esptool==4.7.0->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/ecdsa/ecdsa-0.19.0-py2.py3-none-any.whl (146 kB)
          Collecting reedsolo<1.8,>=1.5.3 (from esptool==4.7.0->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/reedsolo/reedsolo-1.7.0-py3-none-any.whl (32 kB)
          Collecting intelhex (from esptool==4.7.0->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/intelhex/intelhex-2.3.0-py2.py3-none-any.whl (50 kB)
          Collecting marshmallow==3.* (from platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/marshmallow/marshmallow-3.26.1-py3-none-any.whl (50 kB)
          Collecting pyelftools<1,>=0.27 (from platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/pyelftools/pyelftools-0.32-py3-none-any.whl (188 kB)
          Requirement already satisfied: requests==2.* in /usr/lib/python3/dist-packages (from platformio==6.1.16->esphome==2025.2.1) (2.25.1)
          Collecting semantic-version==2.10.* (from platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/semantic-version/semantic_version-2.10.0-py2.py3-none-any.whl (19 kB)
          Collecting tabulate==0.* (from platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/tabulate/tabulate-0.9.0-py3-none-any.whl (35 kB)
          Collecting ajsonrpc==1.2.* (from platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/ajsonrpc/ajsonrpc-1.2.0-py3-none-any.whl (22 kB)
          Collecting starlette<0.40,>=0.19 (from platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/starlette/starlette-0.39.2-py3-none-any.whl (73 kB)
          Collecting wsproto==1.* (from platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/wsproto/wsproto-1.2.0-py3-none-any.whl (24 kB)
          Collecting bottle==0.13.* (from platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/bottle/bottle-0.13.2-py2.py3-none-any.whl (104 kB)
          Collecting uvicorn<0.31,>=0.16 (from platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/uvicorn/uvicorn-0.30.6-py3-none-any.whl (62 kB)
          Collecting ruamel.yaml.clib>=0.2.7 (from ruamel.yaml==0.18.6->esphome==2025.2.1)
          Downloading ruamel.yaml.clib-0.2.12-cp39-cp39-manylinux2014_aarch64.whl.metadata (2.7 kB)
          Collecting ifaddr>=0.1.7 (from zeroconf==0.145.1->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/ifaddr/ifaddr-0.2.0-py3-none-any.whl (12 kB)
          Collecting packaging>=17.0 (from marshmallow==3.->platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/packaging/packaging-24.2-py3-none-any.whl (65 kB)
          Collecting h11<1,>=0.9.0 (from wsproto==1.
          Downloading https://www.piwheels.org/simple/h11/h11-0.14.0-py3-none-any.whl (58 kB)
          Collecting bitarray<3.1,>=3.0.0 (from bitstring>=3.1.6->esptool==4.7.0->esphome==2025.2.1)
          Downloading bitarray-3.0.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (32 kB)
          Collecting pycparser (from cffi>=1.12->cryptography==43.0.0->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/pycparser/pycparser-2.22-py3-none-any.whl (117 kB)
          Requirement already satisfied: six>=1.9.0 in /usr/lib/python3/dist-packages (from ecdsa>=0.16.0->esptool==4.7.0->esphome==2025.2.1) (1.16.0)
          Collecting anyio<5,>=3.4.0 (from starlette<0.40,>=0.19->platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/anyio/anyio-4.8.0-py3-none-any.whl (96 kB)
          Collecting typing-extensions>=3.10.0 (from starlette<0.40,>=0.19->platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/typing-extensions/typing_extensions-4.12.2-py3-none-any.whl (37 kB)
          Collecting exceptiongroup>=1.0.2 (from anyio<5,>=3.4.0->starlette<0.40,>=0.19->platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/exceptiongroup/exceptiongroup-1.2.2-py3-none-any.whl (16 kB)
          Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5,>=3.4.0->starlette<0.40,>=0.19->platformio==6.1.16->esphome==2025.2.1) (2.10)
          Collecting sniffio>=1.1 (from anyio<5,>=3.4.0->starlette<0.40,>=0.19->platformio==6.1.16->esphome==2025.2.1)
          Downloading https://www.piwheels.org/simple/sniffio/sniffio-1.3.1-py3-none-any.whl (10 kB)
          Downloading aioesphomeapi-29.1.1-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (2.1 MB)
          ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.1/2.1 MB 9.4 MB/s eta 0:00:00
          Downloading cryptography-43.0.0-cp39-abi3-manylinux_2_28_aarch64.whl (3.8 MB)
          ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.8/3.8 MB 10.2 MB/s eta 0:00:00
          Downloading freetype_py-2.5.1-py3-none-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (1.1 MB)
          ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.1/1.1 MB 7.9 MB/s eta 0:00:00
          Downloading PyYAML-6.0.2-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (720 kB)
          ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 720.9/720.9 kB 6.4 MB/s eta 0:00:00
          Downloading tornado-6.4-cp38-abi3-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (435 kB)
          Downloading zeroconf-0.145.1-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (10.5 MB)
          ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 10.5/10.5 MB 13.9 MB/s eta 0:00:00
          Downloading cffi-1.17.1-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (447 kB)
          Downloading protobuf-5.29.3-cp38-abi3-manylinux2014_aarch64.whl (319 kB)
          Downloading ruamel.yaml.clib-0.2.12-cp39-cp39-manylinux2014_aarch64.whl (636 kB)
          ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 636.1/636.1 kB 3.6 MB/s eta 0:00:00
          Downloading bitarray-3.0.0-cp39-cp39-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (276 kB)
          Installing collected packages: reedsolo, pyserial, pyelftools, puremagic, paho-mqtt, intelhex, ifaddr, esphome-dashboard, bottle, bitarray, zeroconf, voluptuous, tzlocal, tzdata, typing-extensions, tornado, tabulate, sniffio, semantic-version, ruamel.yaml.clib, PyYAML, pyparsing, pycparser, protobuf, packaging, kconfiglib, icmplib, h11, freetype-py, exceptiongroup, esphome-glyphsets, ecdsa, colorama, click, bitstring, async-timeout, async-interrupt, argcomplete, ajsonrpc, aiohappyeyeballs, wsproto, uvicorn, ruamel.yaml, marshmallow, cffi, anyio, starlette, cryptography, platformio, noiseprotocol, esptool, chacha20poly1305-reuseable, aioesphomeapi, esphome
          ERROR: Could not install packages due to an OSError: [Errno 13] Permission denied: '/usr/local/bin/pyserial-miniterm'
          Consider using the --user option or check the permissions.
          Egal... dann mit sudo python3 -m pip install esphome==2025.2.1 pillow==10.4.0
          pi@e4310:~/.local/bin $ sudo python3 -m pip install esphome==2025.2.1 pillow==10.4.0
          Downloading https://www.piwheels.org/simple/esphome/esphome-2025.2.1-py3-none-any.whl (4.2 MB)
          |████████████████████████████████| 4.2 MB 1.2 MB/s
          Collecting pillow==10.4.0
          Downloading pillow-10.4.0-cp39-cp39-manylinux_2_28_aarch64.whl (4.4 MB)
          |████████████████████████████████| 4.4 MB 1.9 MB/s
          Downloading https://www.piwheels.org/simple/voluptuous/voluptuous-0.14.2-py3-none-any.whl (31 kB)
          Downloading https://www.piwheels.org/simple/puremagic/puremagic-1.27-py3-none-any.whl (40 kB)
          |████████████████████████████████| 40 kB 518 kB/s
          Downloading https://www.piwheels.org/simple/paho-mqtt/paho_mqtt-1.6.1-py3-none-any.whl (75 kB)
          |████████████████████████████████| 75 kB 772 kB/s
          Downloading https://www.piwheels.org/simple/colorama/colorama-0.4.6-py2.py3-none-any.whl (25 kB)
          Downloading https://www.piwheels.org/simple/tzdata/tzdata-2025.1-py2.py3-none-any.whl (346 kB)
          |████████████████████████████████| 346 kB 12.2 MB/s
          Downloading https://www.piwheels.org/simple/esphome-glyphsets/esphome_glyphsets-0.1.0-py3-none-any.whl (159 kB)
          |████████████████████████████████| 159 kB 9.8 MB/s
          |████████████████████████████████| 107 kB 1.5 MB/s
          |████████████████████████████████| 43 kB 422 kB/s
          Downloading https://www.piwheels.org/simple/ruamel-yaml/ruamel.yaml-0.18.6-py3-none-any.whl (117 kB)
          |████████████████████████████████| 117 kB 786 kB/s
          Downloading https://www.piwheels.org/simple/esphome-dashboard/esphome_dashboard-20250212.0-py3-none-any.whl (5.8 MB)
          |████████████████████████████████| 5.8 MB 2.8 MB/s
          |████████████████████████████████| 3.8 MB 11.8 MB/s
          |████████████████████████████████| 145 kB 931 kB/s
          Downloading https://www.piwheels.org/simple/esptool/esptool-4.7.0-py3-none-any.whl (370 kB)
          |████████████████████████████████| 370 kB 3.4 MB/s
          Downloading https://www.piwheels.org/simple/click/click-8.1.7-py3-none-any.whl (97 kB)
          |████████████████████████████████| 97 kB 2.1 MB/s
          |████████████████████████████████| 435 kB 16.7 MB/s
          |████████████████████████████████| 2.1 MB 12.7 MB/s
          |████████████████████████████████| 10.5 MB 44 kB/s
          Downloading https://www.piwheels.org/simple/icmplib/icmplib-3.0.4-py3-none-any.whl (30 kB)
          Downloading https://www.piwheels.org/simple/tzlocal/tzlocal-5.2-py3-none-any.whl (17 kB)
          Downloading https://www.piwheels.org/simple/platformio/platformio-6.1.16-py3-none-any.whl (419 kB)
          |████████████████████████████████| 419 kB 1.7 MB/s
          |████████████████████████████████| 720 kB 9.5 MB/s
          |████████████████████████████████| 1.1 MB 10.5 MB/s
          |████████████████████████████████| 319 kB 13.1 MB/s
          |████████████████████████████████| 447 kB 12.8 MB/s
          Requirement already satisfied: reedsolo<1.8,>=1.5.3 in /usr/local/lib/python3.9/dist-packages (from esptool==4.7.0->esphome==2025.2.1) (1.7.0)
          |████████████████████████████████| 71 kB 86 kB/s
          |████████████████████████████████| 146 kB 3.1 MB/s
          Collecting intelhex
          |████████████████████████████████| 50 kB 1.6 MB/s
          |████████████████████████████████| 73 kB 514 kB/s
          |████████████████████████████████| 104 kB 15.0 MB/s
          |████████████████████████████████| 188 kB 2.5 MB/s
          |████████████████████████████████| 50 kB 627 kB/s
          |████████████████████████████████| 62 kB 352 kB/s
          |████████████████████████████████| 65 kB 645 kB/s
          |████████████████████████████████| 636 kB 10.0 MB/s
          |████████████████████████████████| 58 kB 616 kB/s
          |████████████████████████████████| 276 kB 14.0 MB/s
          |████████████████████████████████| 117 kB 887 kB/s
          |████████████████████████████████| 96 kB 779 kB/s
          Installing collected packages: pycparser, typing-extensions, sniffio, exceptiongroup, cffi, packaging, ifaddr, h11, cryptography, click, bitarray, anyio, zeroconf, wsproto, uvicorn, tabulate, starlette, semantic-version, ruamel.yaml.clib, PyYAML, pyelftools, protobuf, noiseprotocol, marshmallow, intelhex, ecdsa, colorama, chacha20poly1305-reuseable, bottle, bitstring, async-timeout, async-interrupt, ajsonrpc, aiohappyeyeballs, voluptuous, tzlocal, tzdata, tornado, ruamel.yaml, pyparsing, puremagic, platformio, pillow, paho-mqtt, kconfiglib, icmplib, freetype-py, esptool, esphome-glyphsets, esphome-dashboard, argcomplete, aioesphomeapi, esphome
          Attempting uninstall: pillow
          Found existing installation: Pillow 8.1.2
          Not uninstalling pillow at /usr/lib/python3/dist-packages, outside environment /usr
          Can't uninstall 'Pillow'. No files were found to uninstall.
          Successfully installed PyYAML-6.0.2 aioesphomeapi-29.1.1 aiohappyeyeballs-2.4.6 ajsonrpc-1.2.0 anyio-4.8.0 argcomplete-3.5.3 async-interrupt-1.2.2 async-timeout-4.0.3 bitarray-3.0.0 bitstring-4.3.0 bottle-0.13.2 cffi-1.17.1 chacha20poly1305-reuseable-0.13.2 click-8.1.7 colorama-0.4.6 cryptography-43.0.0 ecdsa-0.19.0 esphome-2025.2.1 esphome-dashboard-20250212.0 esphome-glyphsets-0.1.0 esptool-4.7.0 exceptiongroup-1.2.2 freetype-py-2.5.1 h11-0.14.0 icmplib-3.0.4 ifaddr-0.2.0 intelhex-2.3.0 kconfiglib-13.7.1 marshmallow-3.26.1 noiseprotocol-0.3.1 packaging-24.2 paho-mqtt-1.6.1 pillow-10.4.0 platformio-6.1.16 protobuf-5.29.3 puremagic-1.27 pycparser-2.22 pyelftools-0.32 pyparsing-3.2.1 ruamel.yaml-0.18.6 ruamel.yaml.clib-0.2.12 semantic-version-2.10.0 sniffio-1.3.1 starlette-0.39.2 tabulate-0.9.0 tornado-6.4 typing-extensions-4.12.2 tzdata-2025.1 tzlocal-5.2 uvicorn-0.30.6 voluptuous-0.14.2 wsproto-1.2.0 zeroconf-0.145.1
          Oh wie geil. Läuft durch. Aber sudo.... da machen sich die Linuxer immer ins Hemd. Ob das funktioniert? Ne... natürlich nicht. Bei jedem Start vom ESPHome Adapter kommt die gleiche Fehlermeldung wie aus dem 1. Spoiler weiter oben.
          Die einzige Möglichkeit, um das ESPHome Dashboard zu bekommen, ist in der Konfig des Adapters auf eine alte Version des Dashboards zu gehen. Letzte lauffähige Version: 2024.11.0
          Na ja... wieder ein Samstag für den IOB und Linux 🤣
            @bernd33-1 sagte in ESPHome Dashboard bleibt leer:
            lies nochmal was da steht
            bei mir läuft die
            du musst nur das machen was da steht..
            ein secret file anlegen.. die esp home verarbeitung hat sich hier geändert
            DOKU hilft
            B W 2 Replies Last reply Reply Quote 0
              bernd33-1 @arteck last edited by
              @arteck 🙂 Ich hab ein Secret Datei. ABER... hab die unter dem alten Dashboard nochmal gesavet und siehe da, nun tut auch das neue Dashboard.
              Besten Dank für deinen Hinweis!
              LG, Bernd
                wibear @arteck last edited by wibear
                @arteck
                Hallo, ich habe dieselbe Fehlermeldung. In der Instanz habe ich unter Allgemeine Einstellungen nichts eingetragen und Geräteerkennung ist aktiviert. Was muss ich noch bitte eintragen?
                v0.5.0-beta.8
                In "secrets" habe ich folgendes:
                esphome:
                friendly_name: TEST_ESP
                esp8266:
                board: esp01_1m
                Enable logging
                logger:
                Enable Home Assistant API
                api:
                encryption:
                key: "zgW+NakJZWs82Vxck0Zqu1p00qJrrCbjdFiy6srAPoc="
                ota:
                password: "161fe29c4d0f2927ff2ab18751a8bd3c"
                wifi:
                ssid: !secret meineSSID
                password: !secret meinPW
                captive_portal:
                Danke und Grüße
                  arteck Developer Most Active @wibear last edited by
                  @wibear wie kommst du auf den müll
                  das ist eine secret datei.. was machen die definitionen des esp da drin....
                  # Your Wi-Fi SSID and password
                  wifi_ssid:
                  wifi_password:
                  mqtt_broker:
                  mqtt_port:
                  mqtt_username:
                  mqtt_password:
                  web_username:
                  seckey:
                  mit den enstprechenden eingaben reicht vollkommen aus
                    @arteck
                    Danke für die schnelle Antwort.
                    Meine yaml:
                    Ich bekomme diese Fehlermeldung:
                    Was läuft da falsch?
                    arteck R 2 Replies Last reply Reply Quote 0
                      arteck Developer Most Active @wibear last edited by arteck
                      @wibear
                      ist jetzt nicht dein ernst....
                      die yaml correliert mit der secret also musst du die secret füllen mit den werten und diese dann in der yaml nutzen
                      also in secret
                      wifi_ssid:  blahh
                      wifi_password: blahbla
                      seckey: sadfsdfgsdgfsgsgsdfgdfg
                      in der yaml greifst du nur die variablen ab
                      networks:
                          ssid:       !secret wifi_ssid
                          password:   !secret wifi_password
                      api:
                        encryption:
                          key: !secret seckey
                      na jetzt ??? ansonsten less dich in die materie ein..
                      und mach bitte keine screeshots von textfiles.. damit kann man nix anfangen und ich fange jetzt nicht an die sachen abzutippen
                        Ralf 2 @wibear last edited by
                        @wibear
                        Du wirfst dort mehrere YAML in ein File.
                        Die secret.yaml rufst du im Dashboard oben rechts auf, darauf verweist du dann in deiner Sensor.yaml:
                        389
