    4. iobroker nach zigbee installation nicht mehr ansprechbar
      w m 77 last edited by
      hat jemand eine Idee wie ich hier weiter komme ??
      ========== Start marking the full check here ===========
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer
                Kernel: Linux 6.6.74+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       20:34:32 up  4:10,  3 users,  load average: 2.01, 3.00, 3.38
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-03-03 20:34:32 CET
                 Universal time: Mon 2025-03-03 19:34:32 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            1.9G        837M        221M        1.2M        950M        1.1G
      Swap:           209M        262K        209M
      Total:          2.1G        837M        430M
      Active iob-Instances:   12
               1846 M total memory
                798 M used memory
                744 M active memory
                731 M inactive memory
                210 M free memory
                 41 M buffer memory
                864 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 20:34:32 up  4:10,  3 users,  load average: 2.01, 3.00, 3.38
      Tasks: 180 total,   2 running, 178 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   1846.8 total,    210.2 free,    799.2 used,    906.7 buff/cache
      MiB Swap:    200.0 total,    199.7 free,      0.2 used.   1047.6 avail Mem
      *** FAILED SERVICES ***
        UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
      * NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  660M     0  660M   0% /dev
      tmpfs          tmpfs     185M  1.3M  184M   1% /run
      /dev/mmcblk0p2 ext4       14G  7.8G  5.3G  60% /
      tmpfs          tmpfs     924M     0  924M   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   65M  446M  13% /boot/firmware
      tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
      [Mon Mar  3 16:24:11 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmiize=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=089bb4f7-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=AT
      [Mon Mar  3 16:24:26 2025] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
      [Mon Mar  3 16:24:28 2025] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.4G    /var/
      677M    /var/log/journal/4a8789595c9241c69387c9238a2f02df
      677M    /var/log
      292M    /var/cache
      Archived and active journals take up 676.4M in the file system.
      /opt/iobroker/backups:
      203M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.3G    /opt/iobroker/iobroker-data/
      1.3G    /opt/iobroker/iobroker-data/files
      980M    /opt/iobroker/iobroker-data/0_userdata.0
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.3
      /usr/bin/node           v20.18.3
      /usr/bin/corepack       0.30.0
      nodejs:
        Installed: 20.18.3-1nodesource1
        Candidate: 20.18.3-1nodesource1
        Version table:
       *** 20.18.3-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.2-1nodesource1 600
           20.18.1-1nodesource1 600
           20.18.0-1nodesource1 600
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 413)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.bydbatt.0                : bydbatt               : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 - disabled
        system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : iobroker                                 - disabled
      + system.adapter.g-homa.0                 : g-homa                : iobroker                                 -  enabled
        system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.opendtu.0                : opendtu               : iobroker                                 - disabled
        system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: ::
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 10.0.0.99, run as: admin
      + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Cannot read or parse /opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common//../node_modules/iobroker.zigbee2mqtt/io-package.json: /opt/iobroker/node_modules/iobroker.zigbee2mqtt/io-package.json: Unexpected end o
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "bydbatt"      : 1.1.0    , installed 1.1.0
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
      Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
      Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
      Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        7875
      States:         6378
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5655       667/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       52181      14177/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       52176      14177/iobroker.js-c
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       54979      14423/io.mqtt.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       54903      14390/io.sonoff.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          5657       667/sshd: /usr/sbin
      tcp6       0      0 :::1882                 :::*                    LISTEN      1001       52842      14354/io.shelly.0
      tcp6       0      0 :::50000                :::*                    LISTEN      1001       53981      14466/io.g-homa.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       52945      14648/io.ws.0
      udp        0      0 0.0.0.0:51304           0.0.0.0:*                           104        4990       504/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4988       504/avahi-daemon: r
      udp6       0      0 :::35924                :::*                                104        4991       504/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        4989       504/avahi-daemon: r
      udp6       0      0 fe80::fd4e:3335:540:546 :::*                                0          6458       607/NetworkManager
      2025-03-03 20:35:52.298  - warn: modbus.1 (14339) [DevID_201] Poll error count: 1 code: {"errorCode":131,"exceptionCode":11,"message":"GATEWAY TARGET DEVICE FAILED TO RESPOND"}
      2025-03-03 20:35:46.948  - error: host.iobroker Caught by controller[0]: node:internal/modules/package_json_reader:93
      2025-03-03 20:35:46.948  - error: host.iobroker Caught by controller[0]:         throw error;
      2025-03-03 20:35:46.948  - error: host.iobroker Caught by controller[0]:         ^
      2025-03-03 20:35:46.949  - error: host.iobroker Caught by controller[0]: SyntaxError: Error parsing /opt/iobroker/node_modules/side-channel/package.json: Unexpected end of JSON input
      2025-03-03 20:35:46.949  - error: host.iobroker Caught by controller[0]:     at parse (<anonymous>)
      2025-03-03 20:35:46.949  - error: host.iobroker Caught by controller[0]:     at read (node:internal/modules/package_json_reader:80:16)
      2025-03-03 20:35:46.949  - error: host.iobroker Caught by controller[0]:     at readPackage (node:internal/modules/package_json_reader:141:10)
      2025-03-03 20:35:46.950  - error: host.iobroker Caught by controller[0]:     at resolveExports (node:internal/modules/cjs/loader:630:15)
      2025-03-03 20:35:46.950  - error: host.iobroker Caught by controller[0]:     at Module._findPath (node:internal/modules/cjs/loader:724:31)
      2025-03-03 20:35:46.950  - error: host.iobroker Caught by controller[0]:     at Module._resolveFilename (node:internal/modules/cjs/loader:1211:27)
      2025-03-03 20:35:46.951  - error: host.iobroker Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1051:27)
      2025-03-03 20:35:46.951  - error: host.iobroker Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1311:19)
      2025-03-03 20:35:46.951  - error: host.iobroker Caught by controller[0]:     at require (node:internal/modules/helpers:179:18)
      2025-03-03 20:35:46.951  - error: host.iobroker Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/qs/lib/stringify.js:3:22) {
      2025-03-03 20:35:46.952  - error: host.iobroker Caught by controller[0]:   path: '/opt/iobroker/node_modules/side-channel/package.json'
      2025-03-03 20:35:46.952  - error: host.iobroker Caught by controller[0]: }
      2025-03-03 20:35:46.953  - error: host.iobroker Caught by controller[0]: Node.js v20.18.3
      2025-03-03 20:35:46.954  - error: host.iobroker instance system.adapter.web.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-03-03 20:35:46.954  - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
      2025-03-03 20:36:02.376  - info: shelly.0 (14354) [Sys.timezone] 10.0.0.52 (shellyplus1pm / shellyplus1pm-fcb467ba5318 / shellyplus1pm#fcb467ba5318#1): Configured timezone "Europe/Vienna" and system timezone "Europe/Berlin" do not match. P
      2025-03-03 20:36:02.447  - warn: modbus.1 (14339) [DevID_1/holdingRegs/40314] Calculation of a scaleFactor which is based on another scaleFactor seems strange. Please check the config for address 40314 !
      2025-03-03 20:36:02.721  - warn: modbus.1 (14339) [DevID_201] Poll error count: 1 code: {"errorCode":131,"exceptionCode":11,"message":"GATEWAY TARGET DEVICE FAILED TO RESPOND"}
      2025-03-03 20:36:03.343  - info: javascript.0 (14271) script.js.leistungssteuerung: schalter 6 of
      2025-03-03 20:36:03.501  - info: host.iobroker instance system.adapter.admin.0 in version "7.4.10" started with pid 17168
      Meister Mopper crunchip 2 Replies Last reply Reply Quote 0
      • Meister Mopper
        Meister Mopper @w m 77 last edited by
        @w-m-77
        iob start admin
        crunchip W 2 Replies Last reply Reply Quote 0
        • crunchip
          crunchip Forum Testing Most Active @Meister Mopper last edited by
          @meister-mopper allerdings stimmt da auch anderweitig etwas nicht
            @w-m-77 sagte in iobroker nach zigbee installation nicht mehr ansprechbar:
            der WEB adapter schmeisst einen Fehler wasndas ??
            und
            da stimmt allgemein was nicht
              w m 77 @Meister Mopper last edited by w m 77
              @meister-mopper
              iob start admin
              , das hab ich schon versucht, leider mit wenig Erfolg 😞
              • crunchip
                crunchip Forum Testing Most Active @w m 77 last edited by
                bind: 10.0.0.99
                Ist das bewusst?
                  w m 77 @crunchip last edited by
                  @crunchip ja, hab ich so ausgewählt..
                  • crunchip
                    mit welcher Meldung?
                    iob start admin --debug
                    ggf kommen deine Probleme auch daher
                    • mcm1957
                      mcm1957 @w m 77 last edited by mcm1957
                      @w-m-77
                      Also da ist was ziemlich faul:
                      Die Zigbee Installation selbst ist da schief gelaufen. Aus welcher Quelle hast du denn ZigBee installiert? Ich würd in jedem Fall mal versuchen den Adapter neu zu (re-)installieren.
                      Außerdem schreibst du dass das Problem nach der Installtion von Zigbee aufgetreten ist. Die defekten Files gehören aber zu zigbee2mqtt. Was hast du genau imstalliert?
                      Der Diskspace ist dir nicjht zufällig bei der Installation augegangen? Derzeit sond zwar 40% frei - aber es gab schon user die es nicht für wichtig empfunden haben zu schreiben, dass sie ein Installtionsproblem hatte und nachher erst Platz geschaffen haben ...
                        w m 77 @mcm1957 last edited by
                        @mcm1957
                        stimmt da war ich wohl etwas ungenau in der Ausfürhrung ...war im Detail der "Zigbee2mqtt" adapter direkt über die IOB Oberfläche
                        den verfügbaren Speicherplatz habe ich vor der installation nicht kontrolliert... allerdings danach auch nicht aufgeräumt..
                        reinstallieren über die Konsole.. wie müsste das aussehen??
                        Thomas Braun 1 Reply Last reply Reply Quote 1
                          Thomas Braun Most Active @w m 77 last edited by
                          @w-m-77
                          iob update
                          iob upgrade zigbee2mqtt@3.0.2 --debug
                          versuchen, wenn du auf stable unterwegs bist.
                          • crunchip
                            crunchip Forum Testing Most Active last edited by crunchip
                            @thomas-braun sagte in iobroker nach zigbee installation nicht mehr ansprechbar:
                            upgrade
                            ist das nicht eher install, bzw add , da der Adapter ja gar nicht installiert ist
                            unabhängig davon,
                            bewusst?, das dieser aber nicht eigenständig läuft, ist hoffentlich bekannt
                              Thomas Braun Most Active @crunchip last edited by Thomas Braun
                              @crunchip
                              Wenn ich
                              richtig interpretiere ist der Adapter schon installiert. Wenn auch irgendwie 'krumm'.
                              Edit: Hast wohl Recht, der Adapter taucht oben im iob diag nicht auf.
                              • crunchip
                                crunchip Forum Testing Most Active @Thomas Braun last edited by
                                @thomas-braun sehe ich jedoch nicht so
                                dann müsste er ja da gelistet sein, oder nicht?
                                  @crunchip
                                  Das ist wohl eine krumme/unvollständige Installation.
                                  sollte ja auch nicht auftauchen.
                                    w m 77 @Thomas Braun last edited by Homoran
                                    pi@iobroker:~ $ iob upgrade zigbee2mqtt@3.0.2 --debug
                                    Cannot upgrade: /opt/iobroker/node_modules/iobroker.zigbee2mqtt/io-package.json: Unexpected end of JSON input
                                    pi@iobroker:~ $ iob install zigbee2mqtt@3.0.2 --debug
                                    adapter "zigbee2mqtt" already installed. Use "upgrade" to upgrade to a newer version.
                                      @w-m-77
                                      Und deinstallieren geht vermutlich auch nicht?
                                      • mcm1957
                                        mcm1957 @Thomas Braun last edited by
                                        schätze das ist der seltene Fall wo die Leiche mit npm oder rm weg muss. Bin nur am Handy. Ev kannst du ha die richtigen Befehle vorschlagen.
                                        Danje.
                                          Versuch mal
                                          cd /opt/iobroker && npm uninstall iobroker.zigbee2mqtt
                                          W 2 Replies Last reply Reply Quote 1
                                            w m 77 @Thomas Braun last edited by w m 77
                                            Herzlichen Dank Thomas !!👏
                                            läuft wieder ... jetzt werd ich mich mal mit folgendem Thema beschäftigen: wie kann man am besten externe Backups erstellen und auf einem neuen System wiederherstellen ...
                                            p.s: !!ich hoffe meine kleine Kaffeespende kommt den mir helfenden Händen irgendwie zu gute!!
                                            1695
