    4. Unraid , Iobroker und BT Dongle/Hardware einbinden
    • haselchen
      haselchen Most Active last edited by
      @crunchip
      Damit ich das Ganze eingrenzen kann, welche Hardware bzw. welchen Dongle hast Du (ausprobiert) ?
      Welche Anleitung hast Du abgearbeitet -> LXC ? Docker?
      crunchip 1 Reply Last reply Reply Quote -1
      • crunchip
        crunchip Forum Testing Most Active @haselchen last edited by
        @haselchen sagte in Unraid , Iobroker und BT Dongle/Hardware einbinden:
        Dongle
        https://amzn.eu/d/gNh4ahR
        als auch das interne eines geekom AS6
        docker Unraid
        • haselchen
          haselchen Most Active @crunchip last edited by
          @crunchip
          Und welche Anleitungen ?
          Sonst machen wir hier das doppelt 🥴😬
          • crunchip
            @haselchen offizielle docker/unraid und alles was ich als zwischenfetzen im Netz gefunden habe
            genau kann ichs dir nimmer wiedergeben
            bin aber jetzt erstmal wieder weg
            • haselchen
              @crunchip
              Hast Du das schon ausprobiert?
              Hello elgato. I recently deployed a container(theengs gateway) using onboard bluetooth(AX201) on unraid 6.12.10 , hope my deployment process could be your reference.
              The first thing you need to do is find the location of the bluetooth hardware, which is usually shown as a USB device. You can find it through Tools → SysDevs. For me it's /dev/bus/usb/001/005 and based on your screenshots, I'm guessing it's /dev/bus/usb/001/011
              When you confirm the hardware pass-through parameters, add the device to your container setting and mount /run/dbus
              Now you need bluez to providing the bluetooth protocol stack for unraid OS. It can be installed by nerd-tool plugin or un-get command.
              Once the installation is complete, you will find that the bluetooth service is not activated, because the bluetooth module is disabled by default. To enable it permanently, you need:
                  1. Delete the lines in the config/modprobe.d/bluetooth.conf file in the USB boot drive with “bluetooth” and “btusb”
                  2. Add "/etc/rc.d/rc.bluetooth restart" to the config/go script file in the USB boot drive
              If all goes well, bluetooth will be available for container after reboot.
              Forgive me for my lengthy statements. If you have any doubts about the details of the operation, please let me know.
              • crunchip
                @haselchen das ist ja der link den ich dir geschickt hatte, welchen ich kürzlich fand. Ausprobiert jedoch noch nicht.
                Komm auch heute wahrscheinlich nicht dazu, USV ist heut morgen ausgefallen😡
                und jetzt erst mal Gartenarbeit💪
                • haselchen
                  haselchen Most Active @crunchip last edited by haselchen
                  @crunchip
                  Mein Beileid zu Beidem 🙂
                  Ich doktor auch seit Stunden wie wild an einer BT Einbindung.
                  Kaum zu glauben, dass es bei Unraid nur zu einer VM Unterstützung kommt.
                  Alle anderen BT Bereiche werden komplett ausgeblendet.
                  Ich habs tatsächlich bisher auch nicht hinbekommen. Nicht im Docker, nicht in LXC.
                  Edit:
                  Never Ending Story. Ich mach mal nen Päuschen und guck , ob ich mich morgen nochmal nen Stündchen ransetze.
                  Scheint, als müsste man tatsächlich in Unraid permanent auf ne VM setzen.
                  • crunchip
                    sollte bei dir aber eigentlich funktionieren, dein Unraid läuft doch im Host Modus, oder?
                    • haselchen
                      @crunchip
                      Keine Chance.
                      Unraid und der Docker kennen nicht mal Bluetooth.
                      Selbst nach einer Installation.
                      Viele Befehle enden mit unknown command.
                      Selbst nachinstallieren bringt nix.
                      Einzig alleine eine VM aufsetzen hilft bei allen USB Geräten.
                      • crunchip
                        wie installiert?
                        vllt mittels un-get noch das ein oder andere Paket nachinstallieren
                        • haselchen
                          @crunchip
                          Glaub mir , hab auch alles durch 😉
                          Über 5 Stunden dran gesessen.
                          Hätte ich nicht gedacht .
                          „normale“ USB Geräte , kein Problem.
                          Bluetooth , unmöglich 😂
                          • crunchip
                            @haselchen liegt daran, Bluetooth kein USB Gerät, sondern zählt als Netzwerk Gerät
                            Aber trotzdem Danke für die Bemühungen
                            • haselchen
                              Erstaunlich, dass es doch recht wenig Infos gibt , BT dort einzubinden.
                              Jedenfalls bezüglich Docker und LXC.
                              Wenn ich was gefunden habe , wie Du wahrscheinlich, geht es immer um Bus ID und Device ID in der Konfig eintragen, zuzüglich /run/dbus.
                              Ich werde es auch weiterhin im Blick haben und probieren.
                              Alle Anderen hier sind gerne eingeladen , diesbezüglich mit eine Lösung zu suchen .
                              557
