    4. [gelöst] fritz dect meldet fehler
    • Ben1983
      Ben1983 last edited by Ben1983
      Hallo, seit heute habe ich dieses Problem:
      im log kommt dauernd.
      2025-03-08 17:14:08.265 - info: host.pioBroker "system.adapter.fritzdect.0" enabled
      2025-03-08 17:14:08.599 - info: host.pioBroker instance system.adapter.fritzdect.0 in version "2.5.11" started with pid 1345
      2025-03-08 17:14:09.171 - debug: fritzdect.0 (1345) Redis Objects: Use Redis connection: 127.0.0.1:6379
      2025-03-08 17:14:09.187 - debug: fritzdect.0 (1345) Objects client ready ... initialize now
      2025-03-08 17:14:09.188 - debug: fritzdect.0 (1345) Objects create System PubSub Client
      2025-03-08 17:14:09.189 - debug: fritzdect.0 (1345) Objects create User PubSub Client
      2025-03-08 17:14:09.266 - debug: fritzdect.0 (1345) Objects client initialize lua scripts
      2025-03-08 17:14:09.268 - debug: fritzdect.0 (1345) Objects connected to redis: 127.0.0.1:6379
      2025-03-08 17:14:09.276 - debug: fritzdect.0 (1345) Redis States: Use Redis connection: 127.0.0.1:6379
      2025-03-08 17:14:09.278 - debug: fritzdect.0 (1345) States create System PubSub Client
      2025-03-08 17:14:09.279 - debug: fritzdect.0 (1345) States create User PubSub Client
      2025-03-08 17:14:09.283 - debug: fritzdect.0 (1345) States connected to redis: 127.0.0.1:6379
      2025-03-08 17:14:09.336 - info: fritzdect.0 (1345) starting. Version 2.5.11 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v20.18.2, js-controller: 7.0.6
      2025-03-08 17:14:09.351 - info: fritzdect.0 (1345) fritzdect entered ready
      2025-03-08 17:14:09.365 - info: fritzdect.0 (1345) fritzdect uses USER: iobroker
      2025-03-08 17:14:10.395 - info: fritzdect.0 (1345) checking user permissions
      2025-03-08 17:14:10.776 - debug: fritzdect.0 (1345) raw perm =>{"session":true,"rights":"Dial2App2HomeAuto2BoxAdmin2Phone2"}
      2025-03-08 17:14:10.777 - info: fritzdect.0 (1345) the rights are : {"Rights":{"Name":["Dial","App","HomeAuto","BoxAdmin","Phone"],"Access":["2","2","2","2","2"]}}
      2025-03-08 17:14:10.777 - info: fritzdect.0 (1345) start creating global values
      2025-03-08 17:14:10.777 - info: fritzdect.0 (1345) ____________________________________________
      2025-03-08 17:14:10.778 - info: fritzdect.0 (1345) create Main object global channel list
      2025-03-08 17:14:10.782 - info: fritzdect.0 (1345) finished creating global values
      2025-03-08 17:14:10.782 - info: fritzdect.0 (1345) start creating devices/groups
      2025-03-08 17:14:10.787 - debug: fritzdect.0 (1345) onStateChange => state fritzdect.0.global.statdevices changed: [] (ack = true)
      2025-03-08 17:14:11.330 - debug: fritzdect.0 (1345) devices
      2025-03-08 17:14:11.330 - debug: fritzdect.0 (1345) [{"id":"20000","functionbitmask":"0","manufacturer":"0x0000","present":"0","txbusy":"0","name":""},{"identifier":"11630 0266486","id":"16","functionbitmask":"35712","fwversion":"04.27","manufacturer":"AVM","productname":"FRITZ!Smart Energy 200","present":"1","txbusy":"0","name":"Freigabe Schreibtisch","switch":{"state":"1","mode":"manuell","lock":"0","devicelock":"0"},"simpleonoff":{"state":"1"},"powermeter":{"voltage":"235231","power":"6860","energy":"273816"},"temperature":{"celsius":"265","offset":"0"}},{"identifier":"11630 0263665","id":"17","functionbitmask":"35712","fwversion":"04.27","manufacturer":"AVM","productname":"FRITZ!Smart Energy 200","present":"1","txbusy":"0","name":"Freigabe Getränkekühlschrank","switch":{"state":"1","mode":"manuell","lock":"0","devicelock":"0"},"simpleonoff":{"state":"1"},"powermeter":{"voltage":"236017","power":"0","energy":"481346"},"temperature":{"celsius":"185","offset":"0"}},{"identifier":"09995 0884647","id":"18","functionbitmask":"3146016","fwversion":"05.38","manufacturer":"AVM","productname":"FRITZ!Smart Control 440","present":"1","txbusy":"0","name":"Vierfachtaster","battery":"100","batterylow":"0","temperature":{"celsius":"235","offset":"0"},"humidity":{"rel_humidity":"32"}}]
      2025-03-08 17:14:11.330 - info: fritzdect.0 (1345) CREATE Devices 4
      2025-03-08 17:14:11.331 - debug: fritzdect.0 (1345) ======================================
      2025-03-08 17:14:11.331 - debug: fritzdect.0 (1345) TRYING on : {"id":"20000","functionbitmask":"0","manufacturer":"0x0000","present":"0","txbusy":"0","name":""}
      2025-03-08 17:14:11.333 - debug: fritzdect.0 (1345) issue creating devices calling createDataTypeError: Cannot read properties of undefined (reading 'replace')
      2025-03-08 17:14:11.333 - error: fritzdect.0 (1345) try/catch createDevices TypeError: Cannot read properties of undefined (reading 'replace')
      2025-03-08 17:14:11.333 - error: fritzdect.0 (1345) --------------- error calling the fritzbox -----------
      2025-03-08 17:14:11.333 - error: fritzdect.0 (1345) iob err => undefined
      2025-03-08 17:14:11.333 - info: fritzdect.0 (1345) finished creating devices/groups (if any)
      2025-03-08 17:14:11.333 - info: fritzdect.0 (1345) templates are used(false)
      2025-03-08 17:14:11.333 - info: fritzdect.0 (1345) start creating templates
      2025-03-08 17:14:11.855 - debug: fritzdect.0 (1345) __________________________
      2025-03-08 17:14:11.856 - debug: fritzdect.0 (1345) templates
      2025-03-08 17:14:11.856 - debug: fritzdect.0 (1345) []
      2025-03-08 17:14:11.856 - info: fritzdect.0 (1345) finished creating templates (if any)
      2025-03-08 17:14:11.856 - info: fritzdect.0 (1345) routines are used(false)
      2025-03-08 17:14:11.856 - info: fritzdect.0 (1345) start creating routines
      2025-03-08 17:14:12.405 - debug: fritzdect.0 (1345) __________________________
      2025-03-08 17:14:12.405 - debug: fritzdect.0 (1345) routines
      2025-03-08 17:14:12.405 - debug: fritzdect.0 (1345) []
      2025-03-08 17:14:12.406 - info: fritzdect.0 (1345) finished creating routines (if any)
      2025-03-08 17:14:12.406 - info: fritzdect.0 (1345) start initial updating devices/groups
      2025-03-08 17:14:12.406 - debug: fritzdect.0 (1345) __________________________
      2025-03-08 17:14:12.406 - debug: fritzdect.0 (1345) updating Devices / Groups
      2025-03-08 17:14:12.975 - debug: fritzdect.0 (1345) devices
      2025-03-08 17:14:12.975 - debug: fritzdect.0 (1345) [{"id":"20000","functionbitmask":"0","manufacturer":"0x0000","present":"0","txbusy":"0","name":""},{"identifier":"11630 0266486","id":"16","functionbitmask":"35712","fwversion":"04.27","manufacturer":"AVM","productname":"FRITZ!Smart Energy 200","present":"1","txbusy":"0","name":"Freigabe Schreibtisch","switch":{"state":"1","mode":"manuell","lock":"0","devicelock":"0"},"simpleonoff":{"state":"1"},"powermeter":{"voltage":"235231","power":"6860","energy":"273816"},"temperature":{"celsius":"265","offset":"0"}},{"identifier":"11630 0263665","id":"17","functionbitmask":"35712","fwversion":"04.27","manufacturer":"AVM","productname":"FRITZ!Smart Energy 200","present":"1","txbusy":"0","name":"Freigabe Getränkekühlschrank","switch":{"state":"1","mode":"manuell","lock":"0","devicelock":"0"},"simpleonoff":{"state":"1"},"powermeter":{"voltage":"236017","power":"0","energy":"481346"},"temperature":{"celsius":"185","offset":"0"}},{"identifier":"09995 0884647","id":"18","functionbitmask":"3146016","fwversion":"05.38","manufacturer":"AVM","productname":"FRITZ!Smart Control 440","present":"1","txbusy":"0","name":"Vierfachtaster","battery":"100","batterylow":"0","temperature":{"celsius":"235","offset":"0"},"humidity":{"rel_humidity":"32"}}]
      2025-03-08 17:14:12.975 - debug: fritzdect.0 (1345) update Devices 4
      2025-03-08 17:14:12.975 - debug: fritzdect.0 (1345) _____________________________________________
      2025-03-08 17:14:12.975 - debug: fritzdect.0 (1345) updating Device
      2025-03-08 17:14:12.976 - error: fritzdect.0 (1345) try/catch issue updating device in updateDevices TypeError: Cannot read properties of undefined (reading 'replace')
      2025-03-08 17:14:12.976 - debug: fritzdect.0 (1345) groups
      2025-03-08 17:14:12.976 - debug: fritzdect.0 (1345) []
      2025-03-08 17:14:12.976 - info: fritzdect.0 (1345) finished initial updating devices/groups
      2025-03-08 17:14:12.976 - info: fritzdect.0 (1345) going over to cyclic polling, messages to poll activity only in debug-mode
      Homoran haselchen 2 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Ben1983 last edited by
        @ben1983 sagte in fritz dect meldet fehler:
        seit heute
        hast du ein fritzbox update gehabt?
        Ben1983 1 Reply Last reply Reply Quote 0
        • haselchen
          haselchen Most Active @Ben1983 last edited by
          @ben1983
          https://forum.iobroker.net/topic/78890/fritzdect-adapter-fehler-alle-10-sekunden-im-log?page=1
          Vermutlich wird ein Update des Adapters Dein Problem beheben.
          • Ben1983
            Ben1983 @Homoran last edited by
            @homoran Ja, heute morgen
