    4. Weboberfläche nicht mehr erreichbar
    • Chenda
      Chenda last edited by
      Hi zusammen,
      leider kann ich die Weboberfläche nicht mehr erreichen.
      Ich habe mich auf dem Raspi per ssh eingeloggt und folgende Schritte gemacht:
      sudo apt update
      sudo apt upgrade
      sudo apt autoremove
      sudo apt autoclean
      iobroker update
      iobroker upgrade
      iob diag
      iob stop
      iob fix
      iob start
      iob diag
      sudo reboot
      Hat aber nicht geholfen. Auch mehrfaches fix hat nicht die Lösung gebracht.
      chenda@iobroker:~ $ iob diag
      *** iob diag is starting up, please wait ***
      iob diag needs to be updated. Please execute 'iobroker fix' first.
      ^C
      chenda@iobroker:~ $ iob start
      chenda@iobroker:~ $ iob fix
      library: loaded
      Library version=2024-10-22
      ioBroker or some processes are still running:
      507 iobroker.js-con
      711 io.admin.0
      720 io.javascript.0
      731 io.backitup.0
      744 io.deyeidc.0
      763 io.smartmeter.0
      770 io.nissan.0
      799 io.alexa2.0
      810 io.deyeidc.1
      825 io.deyeidc.2
      844 io.discovery.0
      855 io.go-e.0
      862 io.web.0
      868 io.vis-2.0
      884 io.trashschedul
      912 io.hs100.0
      Please stop them first and try again!
      chenda@iobroker:~ $ iob stop
      library: loaded
          Welcome to the ioBroker installation fixer!
          Script version: 205-02-02
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists... Done
      W: http://raspbian.raspberrypi.org/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
      [Invalid UTF-8]
      Authenticating as: ,,, (michael)
      Password: polkit-agent-helper-1: pam_authenticate failed: Authentication failure
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      chenda@iobroker:~ $ ```
        @chenda sagte in Weboberfläche nicht mehr erreichbar:
        iob diag
        wo ist der output davon?
        Chenda 1 Reply Last reply Reply Quote 0
        • Chenda
          Chenda @Homoran last edited by
          Anfang zweiter Codeblock
            Thomas Braun Most Active @Chenda last edited by
            Alleine die beiden Zeilen sagen mir schon, das das ganze unsauber von 'bullseye' auf 'bookworm' gehoben wurde.
            Das funktioniert so nicht. Installier da 'bookworm' komplett von Grund auf NEU.
              Homoran Global Moderator Administrators @Chenda last edited by
              da ist kein iob diag
              schon gar nicht die Langfassung
              • Chenda
                @homoran sagte in Weboberfläche nicht mehr erreichbar:
                Ja weil es nicht läuft:
                auch nicht nach iobroker fix - wie ich schon geschrieben habe.
                  @chenda dann dürfte dein System ziemlich verbigen sein.
                  Möglicherweise hilft die iob diag Spezialversion für Raspi von @Thomas-Braun
                  hab den Link gerade nicht parat.
                    Die aktuelle Version sollte trotz der Meldung durchlaufen. Abwarten.
                    • Chenda
                      Chenda @Thomas Braun last edited by
                      @thomas-braun sagte in Weboberfläche nicht mehr erreichbar:
                      Abwarten.
                      Nach einigem Warten lief die Diagnose doch durch. Ich sehe da aber nur einen kritischen Fehler, jedoch keinen Ansatzpunkt für das Problem, dass die Weboberfläche nicht erreichbar ist.
                      Copy text starting here:
                      ```bash
                                              v.2025-02-23
                       Static hostname: iobroker
                             Icon name: computer
                      Operating System: Raspbian GNU/Linux 12 (bookworm)
                                Kernel: Linux 6.1.21-v7+
                          Architecture: arm
                      Kernel:                 armv7l
                      Userland:               32 bit
                      User-ID:                1000
                      Display-Server:         false
                      Pending OS-Updates:     67
                      Pending iob updates:    0
                      Nodejs-Installation:
                      /usr/bin/nodejs         v20.19.0
                      /usr/bin/node           v20.19.0
                      /usr/bin/corepack       0.31.0
                      Recommended versions are nodejs 20.19.0 and npm 10.8.2
                      nodeJS installation is correct
                      MEMORY:
                      Mem:            966M        654M         91M        417K        277M        312M
                      Swap:           104M        104M          0B
                      Total:          1.1G        759M         91M
                      Active iob-Instances:   16
                      Upgrade policy: none
                      ioBroker Core:          js-controller           7.0.6
                                              admin                   7.4.10
                      Objects type: jsonl
                      States  type: jsonl
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      Objects:                2694
                      States:                 2194
                      Size of iob-Database:
                      13M     /opt/iobroker/iobroker-data/objects.jsonl
                      2.9M    /opt/iobroker/iobroker-data/states.jsonl
                      1560 CRITICAL ERRORS DETECTED!
                      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                      Operating System is the current Debian stable version codenamed 'bookworm'!
                      chenda@iobroker:~ $  sudo dmesg --level=emerg,alert,crit -T
                      [Mon Mar 17 21:15:04 2025] hwmon hwmon1: Undervoltage detected!
                      Dieser Fehler wird laut Zeitstempel etwa alle 10s geschrieben.
                      Das Problem mit der Spannung wundert mich in dem Fall zwar, ich das original Raspi Netzteil habe, aber dürfte meiner Ansicht nach nicht dazu führen, dass die Weboberfläche nicht erreichbar ist.
                      Ich mach jetzt nochmal ein Upgrade
                      chenda@iobroker:~ $ sudo apt update
                      Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
                      Building dependency tree... Done
                      81 packages can be upgraded. Run 'apt list --upgradable' to see them.
                      chenda@iobroker:~ $ sudo apt upgrade
                      Calculating upgrade... Done
                      The following packages were automatically installed and are no longer required:
                        libboost-program-options1.74.0 libcamera-apps-lite libcamera0 libdrm-nouveau2 libexif12
                        libfmt7 libgstreamer-plugins-base1.0-0 libgstreamer1.0-0 liborc-0.4-0 libtiff5 libunwind8
                        libwebp6
                      Use 'sudo apt autoremove' to remove them.
                      The following NEW packages will be installed:
                        dconf-cli firmware-intel-graphics firmware-intel-misc firmware-marvell-prestera
                        firmware-mediatek firmware-nvidia-graphics libdconf1 liblgpio1 libossp-uuid16 libvulkan1
                        mesa-libgallium mesa-vulkan-drivers python3-lgpio python3-pycryptodome python3-spidev uuid
                      The following packages have been kept back:
                        libcamera-apps-lite libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0
                        raspi-utils raspinfo
                      The following packages will be upgraded:
                        alsa-utils bluez bluez-firmware console-setup console-setup-linux dphys-swapfile dpkg
                        dpkg-dev firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree
                        firmware-realtek initramfs-tools initramfs-tools-core keyboard-configuration kms++-utils
                        libasound2 libasound2-data libatopology2 libbluetooth3 libc-bin libc-dev-bin libc-devtools
                        libc-l10n libc6 libc6-dbg libc6-dev libcairo-gobject2 libcairo-script-interpreter2 libcairo2
                        libcairo2-dev libdpkg-perl libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-omap1
                        libdrm-radeon1 libdrm2 libegl-mesa0 libgbm1 libgl1-mesa-dri libglapi-mesa libglx-mesa0
                        libgstreamer-plugins-base1.0-0 libkms++0 libnm0 libpam-chksshpwd libpam-modules
                        libpam-modules-bin libpam-runtime libpam0g libpam0g-dev libpixman-1-0 libpixman-1-dev
                        libssl3 libwayland-client0 libwayland-egl1 libwayland-server0 linux-libc-dev locales
                        network-manager openssl pi-bluetooth python3-gpiozero raspberrypi-net-mods
                        raspberrypi-sys-mods raspi-config raspi-gpio rpi-eeprom rpi-update userconf-pi zlib1g
                        zlib1g-dev
                      74 upgraded, 16 newly installed, 0 to remove and 7 not upgraded.
                      Need to get 267 MB of archives.
                      After this operation, 217 MB of additional disk space will be used.
                      Do you want to continue? [Y/n] y
                      Homoran Thomas Braun ? 3 Replies Last reply Reply Quote 0
                        Homoran Global Moderator Administrators @Chenda last edited by Homoran
                        nein 1560 kritische Fehler
                        weil das nur die Ultrakurzfassung ist, steht außerdem nur wenig drin.
                        In der Langfassung steht erheblich mehr
                          @chenda
                          1GB RAM ist zu wenig, insbesondere wenn da auch noch offenbar eine graphische Oberfläche mitgeschleppt wird.
                          Ich würde da mal auf potentere Hardware gehen.
                          Näheres kann man der Langfassung entnehmen.
                          Und die Spannungsversorgung ist zu schwach.
                          • Chenda
                            Wie schon geschrieben ist es der eine undervoltage Fehler, der ca. alle 10s geschrieben wird. Daher halt 1560 mal.
                            Ich verstehe nicht, was das mit dem Fehlerbild zu tun hat? Bisher lief es doch auch. Ist durch ein Update die Anforderung an die Hardware gestiegen?
                              @chenda
                              Dann ist da auch alle 10 Sekunden zu wenig Spannung...
                              Jetzt aber halt nicht mehr. Ist die Eigenschaft von Fehlern, das die oft 'plötzlich' auftauchen.
                              • Chenda
                                Das ist klar -- aber das hat doch dann nix mit dem RAM etc. zu tun.
                                Evtl. könnte es mit dem undervoltage zu tun haben.
                                Nach dem Upgrade nochmal eine Diagnose gemacht:
                                ```bash
                                                        v.2025-02-23
                                       Icon name: computer
                                    Architecture: arm
                                Kernel:                 armv7l
                                Userland:               32 bit
                                User-ID:                1000
                                Pending OS-Updates:     0
                                MEMORY:
                                Mem:            966M        687M        119M        1.0M        220M        279M
                                Swap:           104M        104M          0B
                                Total:          1.1G        792M        119M
                                                        admin                   7.4.10
                                Objects type: jsonl
                                States  type: jsonl
                                Objects:                2694
                                States:                 2194
                                3.2M    /opt/iobroker/iobroker-data/states.jsonl
                                1553 CRITICAL ERRORS DETECTED!
                                Da steht doch drin, dass iobroker läuft und web Interface auch.
                                Netzteil kann ich mal austauschen, sobald ich ein neues habe.
                                Aber soll das nicht erreichbare Web Interface echt mit dem Netzteil zusammenhängen?
                                  @chenda
                                  Die Langfassung ist gefragt.
                                    A Former User @Chenda last edited by
                                    doch, dein Raspi hat mehrere Probleme, das schlimmste ist das kaputte Netzteil, wirf das weg und mach endlich n neues mit der richtigen Leistung (mind.3,5A) dran. Vorher braucht man hier nicht weiter zu suchen, wenn dauernd die Spannung zusammenbricht, kann der keinen Task richtig starten. Ausserdem geht das auch auf die SD-Karte, die wird wahrscheinlich auch n Hau weg haben.
                                    Mal ganz abgesehen davon, dass 1GB Raspi mindestens 10 Jahre alt ist und heutzutage ausgedient hat..
                                    Dann das upgrade mit 32bit auf Bookworm, was sowieso verbogen sein muss.
                                    Kurz gesagt:
                                    Kauf ne neue potente Hardware, die auf das, was du da machen moechtest, zugeschnitten ist, und installier Debian Bookworm in der 64bit Version darauf neu.
                                    Dann die eine Zeile fuer iobroker zum installieren, Backup zurueck spielen, und fertig ist die Sache.
                                      wieder nur die Summary!
                                      das wirklich wichtige steht in der Langfassung.
                                      Die bisher genannten kommen on top und können Auslöser für den wahren Grund sein, der hier nicht zu sehen ist.
                                      427
