    5. DahuaEvent und Telegram Bild
    • pseudoreal
      pseudoreal last edited by
      vor einigen Jahren habe ich hier mit Hilfe des Forums, das Dahua Event Script in ioBroker zum Laufen gebracht sowie ein Blockly geschrieben, dass mir beim Klingeln ein Bild verschickt. Das hat bis vor kurzem (10.3) auch hervorragend funktioniert. Ohne dass ich bewusst was geändert habe, kommt das Bild mittlerweile mit knapp 2minuten Verzögerung via Telegram an, obwohl das Log mir sagt, dass das Bild sofort weggeschickt wurde.
      Anbei erstmal das Script
      const DigestFetch = require('digest-fetch');
      const net = require('net');
      const fs = require('fs');
      const path = require('path');
      const md5 = require('md5');
      const mqtt = require('mqtt');
      * Class to abstract a dahua doorbell.
      * On instantiation it automatically connects with the doorbell, logs in and
      * subscribes to all events.
      * When an event is received, it forwards it to the MQTT broker so other systems
      * can received those events. This behavior is very generic, users need to listen
      * to those MQTT messages and create their own integrations using something like
      * node-red for instance.
      * In time this could be used to create a more user-friendly integration in home assistant,
      * but a doorbell is a complicated device and I don't know enough yet to decide how such
      * integration would look.
      class DahuaVTO {
        deviceType;
        serialNumber;
         * {Number} requestId
         * Our Request / Response ID that must be in all requests and initated by us.
         * This number auto-increments every time we send a message. Once we've logged in, every
         * response contains the request id of which it's a response of, se it could be used to
         * match responses with requests.
         * I haven't bothered to do so because ,for what I saw, we only care about response order
         * for the initial setup, and we do that on request at a time.
         * If we ever make requests in parallel and we need to associate response to each request,
         * we could use this. For not, it's just an auto-incremental number.
        requestId = 0;
        // Session ID will be returned after successful login
         * {Number} sessionId
         * When we try to log in on the doorbell we get a sessionId. From that point on every message
         * we send over the socket needs to have include the sessionID for the doorbell to recognize us.
        sessionId = 0;
        // Will be set after the login, but we initialize to 60s because it's a reasonable default
         * {Number} keepAliveInterval
         * The number of seconds we have to space our keepAlive messages so the doorbell doesn't close
         * the connection.
        keepAliveInterval = 60;
         * The ID returned by the `setInterval` call.
         * We keep a reference in case we want to cancel it (maybe in case of failure?)
        _keepAliveTimer;
         * TCP socket to communicate with the doorbell external unit.
        doorbellSocket;
         * MQTT client to publish (and maybe receive) messages.
        mqttClient;
        constructor() {
          this.dahua_host = "192.168.178.10";
          this.dahua_username = "admin";
          this.dahua_password = "password";
          this.mqtt_broker_host = "192.168.x.y";
          this.mqtt_broker_port = "1883";
          this.mqtt_broker_username = "admin";
          this.mqtt_broker_password = "admin";
          this.mqtt_broker_topic_prefix = "DahuaVTO";
          this.digestClient =  new DigestFetch(
            this.dahua_username,
            this.dahua_password
          this.getDeviceDetails().then(({ deviceType, serialNumber }) => {
            this.deviceType = deviceType;
            this.serialNumber = serialNumber;
            this.start();
         * Starts the app by:
         *    - Opening a TCP socket to the doorbell
         *    - Connecting to the MQTT broker
         *    - Authenticating with the doorbell and subscribing to events.
        start() {
          this.setupDoorbellSocket();
          this.setupMQTT();
          this.initLogin();
         * Makes a request to the doorbell using digest auth to retrieve the device's information.
         * The information is returned in plain text (not JSON) that we have to parse.
         * For now I think we only care about device type and serial number, which can be
         * used to disambiguate in case we have more than one doorbell.
        async getDeviceDetails() {
          return this.digestClient
            .fetch(
              `http://${this.dahua_host}/cgi-bin/magicBox.cgi?action=getSystemInfo`
            .then((r) => r.text())
            .then((text) => {
              const deviceDetails = text
                .trim()
                .split('\n')
                .reduce((obj, str) => {
                  const [key, val] = str.split('=');
                  obj[key] = val.trim();
                  return obj;
              return deviceDetails;
         * Saves a snapshot of the doorbells image into the given directory (defaults to /tmp/).
         * By default the file is named with a simple timestamp of the current time (YYYY-MM-DD-H-M-S.jpg)
        saveSnapshot(p = '/tmp/') {
          let now = new Date();
          let dateStr = `${now.getFullYear()}-${
            now.getMonth() + 1
          }-${now.getDate()}-${now.getHours()}-${now.getMinutes()}-${now.getSeconds()}`;
          let destination = path.join(p, `DoorBell_${dateStr}.jpg`);
          this.digestClient
            .fetch(`http://${this.dahua_host}/cgi-bin/snapshot.cgi`)
            .then((r) => {
              return r.buffer();
            .then((buf) => {
              fs.writeFile(destination, buf, 'binary', function (err) {
                if (err) {
                  log('Error saving snapshot to disk', err);
                } else {
                  log('Snapshot saved');
         * Creates the TCP socket connection with the doorbell on port 5000.
         * Setups the listener for when we receive data over that socket
         * Also setups other listeners for logging purposes mostly.
         * If something goes wrong, we close everything and try to start over again.
        setupDoorbellSocket() {
          let socket = new net.Socket({ readable: true, writable: true });
          socket.on('end', function () {
            log('Doorbell socket ended');
          socket.on('close', function () {
           log('Doorbell socket closed');
            clearInterval(this._keepAliveTimer);
          socket.on('data', this.receive.bind(this));
          socket.on('error', function (e) {
            log('Doorbell socket error', e);
            this.doorbellSocket.destroy(); // destroy the socket
            this.mqttClient.end(true); // End the mqtt connection right away.
            clearInterval(this._keepAliveTimer); // Stop sending keepalive requests
            this.start(); // Start over again.
          this.doorbellSocket = socket.connect({ port: 5000, host: this.dahua_host });
         * Configure an initialize the MQTT client.
         * It configures the "Last Will and Testament" (LWT), which is the message send to MQTT
         * if this client gets disconnected in an ungraceful way (e.g. a fatal error).
         * It also adds listeners that right now are only used for logging.
        setupMQTT() {
          this.mqttClient = mqtt.connect({
            host: this.mqtt_broker_host,
            port: this.mqtt_broker_port,
            username: this.mqtt_broker_username,
            password: this.mqtt_broker_password,
            will: {
              topic: `${this.mqtt_broker_topic_prefix}/lwt`,
              payload: 'connected',
              qos: 1,
          this.mqttClient.on('disconnect', function (packet) {
            log('MQTTDisconnect', packet);
          this.mqttClient.on('message', function (topic, message, packet) {
            log('MQTTMessage', { topic, message, packet });
         * Publishes to MQTT an event with the given name and payload.
         * @param {string} name
         * @param {object} payload
        publishToMQTT(name, payload) {
          let message = JSON.stringify(payload);
          this.mqttClient.publish(
            `${this.mqtt_broker_topic_prefix}/${name}/Event`,
            message
         * Sends a message with the given data to the doorbell's outside unit using the TCP socket.
         * @param {string} data
         * This is a fairly low level way of communication, so let's dive in.
         * We write binary to the socket, so we have to use buffers.
         * The first 32 bytes of the message are the header.
         * After the header we concat the actual message, which is a JSON string.
         * The header has some bits that are fixed and others that are the length of the message that will
         * come after.
         * I didn't reverse-engineered this myself but it works. Take it as gospel as I did.
        send(data) {
          let json = JSON.stringify(data);
          let buf = Buffer.alloc(32);
          let offset = buf.writeUInt32BE(0x20000000);
          offset = buf.writeUInt32BE(0x44484950, offset);
          offset = buf.writeDoubleBE(0, offset);
          offset = buf.writeUInt32LE(json.length, offset);
          offset = buf.writeUInt32LE(0, offset);
          buf = Buffer.concat([buf, Buffer.from(json)]);
          this.requestId += 1;
          this.doorbellSocket.write(buf);
         * Handles received messages from the TCP socket.
         * @param {Buffer} buf
         * The received messages are binary. Once discarded the first 32 bytes (the header),
         * the rest of the message is parsed as as a JSON string.
         * The header contains the length of the received response in bytes 16..20 and the expected
         * length of the response in bytes 24..28 in case we need it, but I haven't found a
         * reason to. Perhaps responses might be sent in several chunks? So far it doesn't seem to be
         * the case.
         * Since we always make requests in the exact same order, we know the first two responses are
         * for the authentication.
         * Subsequent responses can be either events or keepalive responses.
      receive(buf) {
        let str = buf.slice(32).toString();
          try {
            let obj = JSON.parse(str);
          if (this.requestId === 1) {
            this.handleFirstLoginPayload(obj);
          } else if (this.requestId === 2) {
            this.handleSecondLoginPayload(obj);
          } else if (obj.method === 'client.notifyEventStream') {
            this.handleEvents(obj.params.eventList);
          } else {
            this.handleGenericPayload(obj);
        } catch (e) {
          log("Failed to parse incoming message", e);
         * Sends the initial login request.
         * Note that does not include any password.
         * The response to this request will be negative but that is expected, it will contain the
         * necessary information to login.
        initLogin() {
          this.send({
            magic: '0x1234',
            method: 'global.login',
            params: {
              clientType: '',
              ipAddr: '(null)',
              loginType: 'Direct',
              password: '',
              userName: this.dahua_username,
            session: 0,
         * Handles the response to the initial login request.
         * The response contains a session ID, a realm and a random, which in combination with
         * the username and the password are used to generate an MD5 password that is used
         * for logging in.
        handleFirstLoginPayload({ session, params: { random, realm } }) {
          this.sessionId = session;
          let randomHash = this.genMD5Hash(random, realm);
          this.send({
            id: 10000, // I assume this ID a high number just because we have to send something.
            magic: '0x1234', // No idea what this is
            session: this.sessionId,
            params: {
              password: randomHash,
              clientType: '',
              ipAddr: '(null)',
              authorityType: 'Default',
         * Handles the response to the second (and last) response to login request.
         * If successful, any subsequent message that includes the session id will be accepted for
         * as long as the socket is not closed.
         * To prevent the socket from closing we send a keepalive message every so often.
         * Also now that we're authenticated we subscribe to all events fired by the doorbell.
        handleSecondLoginPayload(obj) {
          if (obj.result) {
            log('Logging to Dahua Doorbell successful');
            this.keepAliveInterval = obj.params.keepAliveInterval - 5;
            this.attachEventManager();
            this.keepConnectionAlive();
          } else {
            log('Failed to login. Response was: ', obj);
         * Handles any response not handled by any other method. I believe only keepalive responses
         * will end up here, but added some logging just in case.
         * For now keepalive events are published to MQTT, but I don't see a good reason for that.
        handleGenericPayload(obj) {
          if (
            obj.result === true &&
            obj.params &&
            Object.hasOwnProperty.call(obj.params, 'timeout')
            log('Publish KeepAlive event');
            this.publishToMQTT('keepAlive', {
              deviceType: this.deviceType,
              serialNumber: this.serialNumber,
          } else {
            log(
              'handleGenericPayload# Cannot handle received payload',
              obj
         * Generates a MD5 digest of the username, password, realms and random to send as
         * password when logging in.
         * @param {*} random
         * @param {*} realm
        genMD5Hash(random, realm) {
          const base_credentials = `${this.dahua_username}:${realm}:${this.dahua_password}`;
          const pwddb_hash = md5(base_credentials).toUpperCase();
          const base_pass = `${this.dahua_username}:${random}:${pwddb_hash}`;
          return md5(base_pass).toUpperCase();
         * Sends the message to subscribe to all dorbell events.
        attachEventManager() {
          this.send({
            magic: '0x1234',
            method: 'eventManager.attach',
            params: {
              codes: ['All'],
         * Handles the events sent by the doorbell.
         * It just publishes those events along with some information of the device firing them
         * to MQTT
        handleEvents(events) {
          events.forEach((event) => {
            log(`Publish event ${event.Code} to MQTT`);
            this.publishToMQTT(event.Code, {
              Action: event.eventAction,
              Data: event.Data,
         * Sets up a function to be called periodically to keep the socket open by sending
         * keepalive messages.
         * @param {Number} delay (in seconds)
        keepConnectionAlive(delay) {
          this._keepAliveTimer = setInterval(() => {
            let keepAlivePayload = {
              method: 'global.keepAlive',
              magic: '0x1234',
              params: {
                timeout: delay,
                active: true,
            this.send(keepAlivePayload);
          }, this.keepAliveInterval * 1000);
         * Remotely triggers the relay 1 (e.g. to open an electric gate).
         * In my VTO 2202 F this also triggers the voice announcing the the door has been opened.
        openDoor() {
            .fetch(
              `http://${this.dahua_host}/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote`
            .then((r) => {
              if (r.ok) {
                log('Door relay triggered');
              } else {
                log('Error triggering the door relay', e);
            .catch(e => log('Connection error triggering the door relay',e));
        // requestMissedCallsLog() {
        //   this.send({
        //     id: this.requestId,
        //     magic: '0x1234',
        //     method: 'RecordFinder.factory.create',
        //     params: {
        //       name: 'VideoTalkMissedLog',
        //     session: this.sessionId,
        // requestMissedCallsLog2(findToken) {
        //   this.send({
        //     magic: '0x1234',
        //     method: 'RecordFinder.startFind',
        //     object: findToken,
        //     params: { condition: null },
        // requestMissedCallsLog3(findToken) {
        //   this.send({
        //     magic: '0x1234',
        //     method: 'RecordFinder.doFind',
        //     params: { count: 3 }, // Number of calls to show
      exports.default = DahuaVTO;
      new DahuaVTO();
      dann das blockly
      Hier die fehlerhaften Logs und was auch beim klingeln kommt:
      2025-03-13 18:21:33.335 - error: javascript.0 (26445) script.js.common.Dahua.DahuaEvent: SyntaxError: Unexpected non-whitespace character after JSON at position 238
      2025-03-13 18:21:33.336 - error: javascript.0 (26445) at JSON.parse ()
      2025-03-13 18:21:33.336 - error: javascript.0 (26445) at DahuaVTO.receive (script.js.common.Dahua.DahuaEvent:285:20)
      2025-03-13 18:21:33.336 - error: javascript.0 (26445) at Socket.emit (node:events:518:28)
      2025-03-13 18:21:33.336 - error: javascript.0 (26445) at Socket.emit (node:domain:489:12)
      2025-03-13 18:21:33.336 - error: javascript.0 (26445) at addChunk (node:internal/streams/readable:561:12)
      2025-03-13 18:21:33.336 - error: javascript.0 (26445) at readableAddChunkPushByteMode (node:internal/streams/readable:512:3)
      2025-03-13 18:21:33.336 - error: javascript.0 (26445) at Socket.Readable.push (node:internal/streams/readable:392:5)
      2025-03-13 18:21:33.336 - error: javascript.0 (26445) at TCP.onStreamRead (node:internal/stream_base_commons:191:23)
      2025-03-13 18:21:33.537 - error: host.iobroker Caught by controller[0]: SyntaxError: Unexpected non-whitespace character after JSON at position 238
      2025-03-13 18:21:33.538 - error: host.iobroker Caught by controller[0]: at JSON.parse ()
      2025-03-13 18:21:33.538 - error: host.iobroker Caught by controller[0]: at DahuaVTO.receive (script.js.common.Dahua.DahuaEvent:286:20)
      2025-03-13 18:21:33.538 - error: host.iobroker Caught by controller[0]: at Socket.emit (node:events:518:28)
      2025-03-13 18:21:33.538 - error: host.iobroker Caught by controller[0]: at Socket.emit (node:domain:489:12)
      2025-03-13 18:21:33.538 - error: host.iobroker Caught by controller[0]: at addChunk (node:internal/streams/readable:561:12)
      2025-03-13 18:21:33.538 - error: host.iobroker Caught by controller[0]: at readableAddChunkPushByteMode (node:internal/streams/readable:512:3)
      2025-03-13 18:21:33.538 - error: host.iobroker Caught by controller[0]: at Socket.Readable.push (node:internal/streams/readable:392:5)
      2025-03-13 18:21:33.538 - error: host.iobroker Caught by controller[0]: at TCP.onStreamRead (node:internal/stream_base_commons:191:23)
      2025-03-13 18:21:33.538 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-03-13 18:21:33.538 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
      Auch kommt immer mal wieder als Warnung:
      script.js.common.Dahua.DahuaEvent: clearInterval() => not found
      script.js.common.Dahua.DahuaEvent: Unknown severity level "[object Object]" by log of [handleGenericPayload# Cannot handle received payload]
      wie beschrieben, ich kann mich nicht erinnern, dass ich was in den vergangenen 10 Tagen geändert hätte, aber es nervt halt, dass das Bild zu spät ankommt.
      Bin für jede Idee zu haben....
        superflip @pseudoreal last edited by
        @pseudoreal interessant - an dem arbeite ich auch gerade. - auch wenn ich deine konkrete Frage leider nicht beantworten kann, schildere ich dir mal mein Setup, dass doch ein bisschen anders ist.
        Ich hab aktuell 2 Dahua VTOs, eine funktioniert mit ONVIF, die 2. krieg ich ums verrecken nicht mit ONVIF in iobroker. Allerdings selbst mit ONVIF kriege ich es nicht hin (ich arbeite mit Node-RED), dass das abgespeicherte Bild auch ein Bild ist ... hab schon Stunden damit verbracht, das hinzubekommen.
        Direkt auf die Kamera möchte ich sowieso nicht zugreifen, da ich dafür die admin-Credentials verwenden müsste und das will ich eigentlich nicht. (leider kann man keinen 2. User hinzufügen mit weniger Rechten hinzufügen)
        Somit mache ich gerade den Umweg über die Synology Surveillance Station mit dem Befehl: synology.0.SurveillanceStation.getSnapshotCamera
        ... da wird dann auch das richtige Standbild abgespeichert, welches ich auch mit Telegram verschicken kann - das geht eigentlich bei mir immer sehr flot.
        Für die Übergabe beim Klingeln habe ich mir als Docker Container dahuavto2mqtt installiert (direkt auf dem iobroker Device). Damit will (das hab ich noch nicht) dann auf den Wert mqtt.0.Dahua-Tor.VideoMotion.Event triggern oder beim Klingeln muss ich noch schauen, welcher Wert hier wirklich der richtige ist.
        ... werden den Thread weiterverfolgen, sofern hier noch jemand Input liefert.
