    4. [gelöst]yr.no Wetter Adapter "Error while requesting data"
      Darth2010 last edited by Darth2010
      Fehlerbeschreibung:
      Nachdem der DasWetter Adapter nicht mehr funktioniert, wollte ich yr.no Wetter ausprobieren.
      Nach der Installation, Konfiguration und Start des Adapter liefert das Log folgende Einträge:
      yr.0 81859	2025-03-20 16:21:52.106	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      yr.0 81859	2025-03-20 16:21:52.106	debug	Plugin sentry destroyed
      yr.0 81859	2025-03-20 16:21:52.105	debug	Update of data done, existing ...
      yr.0 81859	2025-03-20 16:21:52.105	info	Data updated.
      yr.0 81859	2025-03-20 16:21:52.105	info	Please check your settings!
      yr.0 81859	2025-03-20 16:21:52.104	info	Error while requesting data:
      yr.0 81859	2025-03-20 16:21:52.028	debug	Get forecast from: https://aa0465pwwdn1nx8wo.api.met.no/weatherapi/locationforecast/2.0/compact?lat=7&lon=53&altitude=74
      yr.0 81859	2025-03-20 16:21:28.685	debug	Delay execution by 23339ms to better spread API calls
      yr.0 81859	2025-03-20 16:21:28.684	debug	Configured version: {"val":"5.3.0","ack":true,"ts":1742481262686,"q":0,"from":"system.adapter.yr.0","user":"system.user.admin","lc":1742481262686}
      yr.0 81859	2025-03-20 16:21:28.669	info	longitude/longitude will be set by self-Config - longitude: 6.757311447027663 latitude: 50.73762218877986
      yr.0 81859	2025-03-20 16:21:28.649	info	starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v20.18.3, js-controller: 7.0.6
      yr.0 81859	2025-03-20 16:21:28.577	debug	Plugin sentry Do not initialize Plugin (enabled=false)
      yr.0 81859	2025-03-20 16:21:28.561	debug	States connected to redis: 127.0.0.1:6379
      yr.0 81859	2025-03-20 16:21:28.557	debug	States create User PubSub Client
      yr.0 81859	2025-03-20 16:21:28.556	debug	States create System PubSub Client
      yr.0 81859	2025-03-20 16:21:28.553	debug	Redis States: Use Redis connection: 127.0.0.1:6379
      yr.0 81859	2025-03-20 16:21:28.528	debug	Objects connected to redis: 127.0.0.1:6379
      yr.0 81859	2025-03-20 16:21:28.525	debug	Objects client initialize lua scripts
      yr.0 81859	2025-03-20 16:21:28.498	debug	Objects create User PubSub Client
      yr.0 81859	2025-03-20 16:21:28.497	debug	Objects create System PubSub Client
      yr.0 81859	2025-03-20 16:21:28.496	debug	Objects client ready ... initialize now
      yr.0 81859	2025-03-20 16:21:28.482	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
      Entsprechend enthalten die Datenpunkte des Adapters auch keine Daten:
      Wenn man den Link jedoch per Postman oder Browser abruft kommt ein "korrektes" JSON zurück:
      response.json
      Hat sonst noch jemand dieses Problem?
      Infos zum System:
      • Adaptername: yr.no Wetter
      • Adapterversion: 5.3.0
      • js-controller Version: 7.0.6
      • Admin Version: 7.4.10
      • Hardwaresystem: Proxmox LXC mit 1 Cores, 4 GB RAM und 10 GB SSD auf (Lenovo ThinkCentre M700 Tiny i5-6500T 4x2.5GHz mit 16 GB RAM)
      • Arbeitsspeicher: 4GB
      • Festplattenart: SSD
      • Betriebssystem: Ububtu 22.04
      • Nodejs-Version: v20.18.3
      • NPM-Version: 10.8.2
      • Installationsart: Skript
      • Image, Docker genutzt: Nein
      iob diag:
      ========== Start marking the full check here ===========
      bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
      Static hostname: iobroker-master
            Icon name: computer-container
              Chassis: container
       Virtualization: lxc
      Operating System: Ubuntu 22.04.5 LTS
               Kernel: Linux 6.8.12-8-pve
         Architecture: x86-64
      OS is similar to: debian
      model name      : Intel(R) Core(TM) i5-6500T CPU @ 2.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      16:31:43 up 23 days,  8:53,  2 users,  load average: 2.70, 1.62, 1.34
      CPU threads: 1
      *** LIFE CYCLE STATUS ***
      Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
      *** TIME AND TIMEZONES ***
                    Local time: Thu 2025-03-20 16:31:43 CET
                Universal time: Thu 2025-03-20 15:31:43 UTC
                      RTC time: n/a
                   NTP service: inactive
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      darth
      HOME=/home/darth
      GROUPS=darth sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video redis
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            4.1G        2.9G        973M        5.0M        243M        1.2G
      Swap:             0B          0B          0B
      Total:          4.1G        2.9G        973M
      Active iob-Instances:   28
              4096 M total memory
              2879 M used memory
              1476 M active memory
              1546 M inactive memory
               972 M free memory
                 0 M buffer memory
               243 M swap cache
                 0 M total swap
                 0 M used swap
                 0 M free swap
      top - 16:31:43 up 23 days,  8:53,  2 users,  load average: 2.70, 1.62, 1.34
      Tasks:  60 total,   1 running,  59 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  6.7 sy,  0.0 ni, 93.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   4096.0 total,    972.0 free,   2879.9 used,    244.1 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   1211.1 avail Mem
      *** FAILED SERVICES ***
       UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--110--disk--0 ext4      9.8G  7.1G  2.2G  77% /
      /dev/mapper/pve-root             ext4       94G   55G   35G  62% /shared
      none                             tmpfs     492K  4.0K  488K   1% /dev
      efivarfs                         efivarfs  128K  101K   23K  82% /sys/firmware/efi/efivars
      tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs     3.2G  144K  3.2G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      log2ram                          tmpfs     500M  4.7M  496M   1% /var/log
      log2ram                          tmpfs     500M  252K  500M   1% /opt/iobroker/log
      tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1001
      Show mounted filesystems:
      TARGET                  SOURCE                                              FSTYPE OPTIONS
      /                       /dev/mapper/pve-vm--110--disk--0                    ext4   rw,relatime,stripe=16
      |-/var/hdd.log          /dev/mapper/pve-vm--110--disk--0[/var/log]          ext4   rw,relatime,stripe=16
      |-/shared               /dev/mapper/pve-root[/home/darth/shared]            ext4   rw,relatime,errors=remount-ro
      `-/opt/iobroker/hdd.log /dev/mapper/pve-vm--110--disk--0[/opt/iobroker/log] ext4   rw,relatime,stripe=16
      /var:
      1.2G    /var/
      934M    /var/lib
      582M    /var/lib/redis
      220M    /var/cache
      213M    /var/lib/apt/lists
      Archived and active journals take up 512.0K in the file system.
      /opt/iobroker/backups:
      96M     /opt/iobroker/backups/
      4.0K    /opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      406M    /opt/iobroker/iobroker-data/
      219M    /opt/iobroker/iobroker-data/files
      137M    /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      27M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      12M     /opt/iobroker/iobroker-data/objects.json.migrated
      12M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      9.9M    /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.3
      /usr/bin/node           v20.18.3
      /usr/bin/corepack       0.30.0
      nodejs:
       Installed: 20.18.3-1nodesource1
       Candidate: 20.18.3-1nodesource1
       Version table:
      *** 20.18.3-1nodesource1 1001
             500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
             100 /var/lib/dpkg/status
          20.18.2-1nodesource1 1001
          20.18.1-1nodesource1 1001
          20.18.0-1nodesource1 1001
          20.17.0-1nodesource1 1001
          20.16.0-1nodesource1 1001
          20.15.1-1nodesource1 1001
          20.15.0-1nodesource1 1001
          20.14.0-1nodesource1 1001
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          12.22.9~dfsg-1ubuntu3.6 500
             500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
             500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
          12.22.9~dfsg-1ubuntu3 500
             500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      iobroker-master     iobroker-master (version: 7.0.6, hostname: iobroker-master, alive, uptime: 2019220)
      iobroker-slave-Flur iobroker-slave-Flur (version: 7.0.6, hostname: iobroker-slave-Flur, alive, uptime: 4174563)
      Core adapters versions
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     1
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker-master                          -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
       system.adapter.alias-manager.0          : alias-manager         : iobroker-master                          -  enabled
       system.adapter.backitup.0               : backitup              : iobroker-master                          - disabled
       system.adapter.cloud.0                  : cloud                 : iobroker-master                          - disabled
       system.adapter.daswetter.0              : daswetter             : iobroker-master                          - disabled
       system.adapter.device-reminder.0        : device-reminder       : iobroker-master                          - disabled
       system.adapter.discovery.0              : discovery             : iobroker-master                          - disabled
      + system.adapter.email.0                  : email                 : iobroker-master                          -  enabled
       system.adapter.feiertage.0              : feiertage             : iobroker-master                          -  enabled
       system.adapter.flot.0                   : flot                  : iobroker-master                          - disabled
       system.adapter.hikvision-alarmserver.0  : hikvision-alarmserver : iobroker-master                          - disabled, port: 7070, bind: 192.168.12.34
       system.adapter.history.0                : history               : iobroker-master                          - disabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker-master                          -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
       system.adapter.ical.0                   : ical                  : iobroker-master                          -  enabled
       system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-master                          - disabled
      + system.adapter.javascript.0             : javascript            : iobroker-master                          -  enabled
      + system.adapter.jeelink.0                : jeelink               : iobroker-slave-Flur                      -  enabled
       system.adapter.lgtv.0                   : lgtv                  : iobroker-master                          - disabled
       system.adapter.linux-control.0          : linux-control         : iobroker-master                          - disabled
      + system.adapter.logparser.0              : logparser             : iobroker-master                          -  enabled
       system.adapter.material.0               : material              : iobroker-master                          - disabled
       system.adapter.mobile.0                 : mobile                : iobroker-master                          - disabled
      + system.adapter.modbus.0                 : modbus                : iobroker-master                          -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker-master                          -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker-master                          -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.nut.0                    : nut                   : iobroker-master                          -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker-master                          -  enabled
      + system.adapter.plenticore.0             : plenticore            : iobroker-master                          -  enabled, port: 80
      + system.adapter.proxmox.0                : proxmox               : iobroker-master                          -  enabled, port: 8006
      + system.adapter.proxmox.1                : proxmox               : iobroker-master                          -  enabled, port: 8006
      + system.adapter.proxmox.2                : proxmox               : iobroker-master                          -  enabled, port: 8006
      + system.adapter.scenes.0                 : scenes                : iobroker-master                          -  enabled
       system.adapter.schoolfree.0             : schoolfree            : iobroker-master                          -  enabled
       system.adapter.shelly.0                 : shelly                : iobroker-master                          - disabled, port: 1883, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : iobroker-master                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartmeter.0             : smartmeter            : iobroker-master                          -  enabled
      + system.adapter.smartmeter.1             : smartmeter            : iobroker-master                          -  enabled
      + system.adapter.socketio.0               : socketio              : iobroker-master                          -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker-master                          -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : iobroker-master                          -  enabled, port: 3306
       system.adapter.synology.0               : synology              : iobroker-master                          - disabled, port: 5001
      + system.adapter.tr-064.0                 : tr-064                : iobroker-master                          -  enabled
      + system.adapter.unifi.0                  : unifi                 : iobroker-master                          -  enabled
       system.adapter.viessmann.0              : viessmann             : iobroker-master                          - disabled, port: 3002
       system.adapter.vis-history.0            : vis-history           : iobroker-master                          - disabled
       system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-master                          - disabled
       system.adapter.vis.0                    : vis                   : iobroker-master                          - disabled
      + system.adapter.web.0                    : web                   : iobroker-master                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
       system.adapter.yr.0                     : yr                    : iobroker-master                          - disabled
       system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker-master                          - disabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name            │ url                                                     │ auto upgrade │
      │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "daswetter"    : 3.2.2    , installed 3.2.2
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Adapter    "jeelink"      : 1.2.5    , installed 1.2.5
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee2mqtt"  : 3.0.2    , installed 3.0.2
      Objects and States
      Objects:        6615
      States:         5438
      2025-03-20 16:21:28.557  - debug: yr.0 (81859) States create User PubSub Client
      2025-03-20 16:21:28.561  - debug: yr.0 (81859) States connected to redis: 127.0.0.1:6379
      2025-03-20 16:21:28.577  - debug: yr.0 (81859) Plugin sentry Do not initialize Plugin (enabled=false)
      2025-03-20 16:21:28.649  - info: yr.0 (81859) starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v20.18.3, js-controller: 7.0.6
      2025-03-20 16:21:28.669  - info: yr.0 (81859) longitude/longitude will be set by self-Config - longitude: 6.457311447027663 latitude: 50.63762218877986
      2025-03-20 16:21:28.684  - debug: yr.0 (81859) Configured version: {"val":"5.3.0","ack":true,"ts":1742481262686,"q":0,"from":"system.adapter.yr.0","user":"system.user.admin","lc":1742481262686}
      2025-03-20 16:21:28.685  - debug: yr.0 (81859) Delay execution by 23339ms to better spread API calls
      2025-03-20 16:21:52.028  - debug: yr.0 (81859) Get forecast from: https://aa0465pwwdn1nx8wo.api.met.no/weatherapi/locationforecast/2.0/compact?lat=5&lon=6.&altitude=255
      2025-03-20 16:21:52.104  - info: yr.0 (81859) Error while requesting data:
      2025-03-20 16:21:52.105  - info: yr.0 (81859) Please check your settings!
      2025-03-20 16:21:52.105  - info: yr.0 (81859) Data updated.
      2025-03-20 16:21:52.105  - debug: yr.0 (81859) Update of data done, existing ...
      2025-03-20 16:21:52.106  - debug: yr.0 (81859) Plugin sentry destroyed
      2025-03-20 16:21:52.106  - info: yr.0 (81859) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      MOD-EDIT: private Daten entfernt
      Darth
      Homoran FredF T 4 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Darth2010 last edited by
        @darth2010 Das dürfte kein Bug von ioBroker sein!
        ich bin zwar nicht das Maß aller Dinge 😁
        aber bei mir ist alles aktuell
          @darth2010 sagte in yr.no Wetter Adapter "Error while requesting data":
          bitte die settings zeigen!
          Geokordinaten unkenntlich machen
          • FredF
            FredF Most Active Forum Testing @Darth2010 last edited by FredF
            Falsche Werte für Längen- und Breitenrad in den Instanzeinstellungen verwendet?
            Homoran D 2 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @FredF last edited by
              @fredf sagte in yr.no Wetter Adapter "Error while requesting data":
              Falsche Werte
              falls du die Geokoordinaten mrinst, die habe ich entfernt
              FredF mcm1957 2 Replies Last reply Reply Quote 0
              • FredF
                FredF Most Active Forum Testing @Homoran last edited by
                @homoran Ach so...
                • mcm1957
                  mcm1957 @Homoran last edited by
                  @Darth2010
                  Also bei mir tut der Adapter was er soll.
                  Allerdings sind deinem Log unsinnige Geokoordinaten drinnen:
                    Darth2010 @FredF last edited by
                    @fredf
                    Hab beispielhaft die Geo-Daten von Berlin genommen, daher kein Problem, kann jeder sehen und ausprobieren.
                    Homoran mcm1957 2 Replies Last reply Reply Quote 0
                      Homoran Global Moderator Administrators @mcm1957 last edited by
                      @mcm1957 sagte in yr.no Wetter Adapter "Error while requesting data":
                      @homoran sagte in yr.no Wetter Adapter "Error while requesting data":
                      Falsche Werte
                        hab ich ja nicht gewusst
                        • mcm1957
                          mcm1957 @Darth2010 last edited by
                          @darth2010
                          Also in der URL stehen da sicher nicht die Geodaten von Berlin...
                            und Was da stand waren andere
                              Darth2010 @Homoran last edited by Darth2010
                              Ja ist mir beim Antworten auch aufgefallen 😧 .
                              Hier die Adapter Settings:
                              @mcm1957
                              Und noch mal das Log dazu:
                              yr.082737	2025-03-20 17:35:32.093	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              yr.082737	2025-03-20 17:35:32.093	debug	Plugin sentry destroyed
                              yr.082737	2025-03-20 17:35:32.092	debug	Update of data done, existing ...
                              yr.082737	2025-03-20 17:35:32.092	info	Data updated.
                              yr.082737	2025-03-20 17:35:32.092	info	Please check your settings!
                              yr.082737	2025-03-20 17:35:32.091	info	Error while requesting data:
                              yr.082737	2025-03-20 17:35:32.015	debug	Get forecast from: https://aa0465pwwdn1nx8wo.api.met.no/weatherapi/locationforecast/2.0/compact?lat=52.52437&lon=13.41053&altitude=74
                              yr.082737	2025-03-20 17:35:12.132	debug	Delay execution by 19883ms to better spread API calls
                              yr.082737	2025-03-20 17:35:12.131	debug	Configured version: {"val":"5.3.0","ack":true,"ts":1742481262686,"q":0,"from":"system.adapter.yr.0","user":"system.user.admin","lc":1742481262686}
                              yr.082737	2025-03-20 17:35:12.119	info	longitude/longitude will be set by self-Config - longitude: 13.41053 latitude: 52.52437
                              yr.082737	2025-03-20 17:35:12.096	info	starting. Version 5.3.0 in /opt/iobroker/node_modules/iobroker.yr, node: v20.18.3, js-controller: 7.0.6
                              yr.082737	2025-03-20 17:35:12.021	debug	Plugin sentry Do not initialize Plugin (enabled=false)
                              yr.082737	2025-03-20 17:35:12.006	debug	States connected to redis: 127.0.0.1:6379
                              yr.082737	2025-03-20 17:35:12.002	debug	States create User PubSub Client
                              yr.082737	2025-03-20 17:35:12.001	debug	States create System PubSub Client
                              yr.082737	2025-03-20 17:35:11.998	debug	Redis States: Use Redis connection: 127.0.0.1:6379
                              yr.082737	2025-03-20 17:35:11.972	debug	Objects connected to redis: 127.0.0.1:6379
                              yr.082737	2025-03-20 17:35:11.969	debug	Objects client initialize lua scripts
                              yr.082737	2025-03-20 17:35:11.941	debug	Objects create User PubSub Client
                              yr.082737	2025-03-20 17:35:11.941	debug	Objects create System PubSub Client
                              yr.082737	2025-03-20 17:35:11.940	debug	Objects client ready ... initialize now
                              yr.082737	2025-03-20 17:35:11.921	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
                                ticaki Developer @Darth2010 last edited by ticaki
                                @darth2010
                                das Wetter geht noch mal muss die api anpassen, wie das geht steht in einem issue auf GitHub beim adapter
                                  ich habe sllerdings deutsch und bei compact nicht den Haken
                                    Shame on me ... nachdem ich api.met.no im Pihole für ioBroker freigeschaltet habe läuft auch alles 😖.
                                    Aber vielen Dank für eure blitzschnellen Antworten.
                                    Manchmal braucht man einfach Sparrings-Partner um einen anderen Blickwinkel zu bekommen.
                                    Danke und Gruß
                                    Darth
                                    Meister Mopper 1 Reply Last reply Reply Quote 2
                                    • Meister Mopper
                                      Meister Mopper @Darth2010 last edited by
                                      Shame on me ... nachdem ich api.met.no im Pihole für ioBroker freigeschaltet habe läuft auch alles .
                                      Na ja, erfahrene pihole-Nutzer suchen bei Fehlern als Erstes dort.
                                      wetter yr adapter
                                      848
