    4. Einbindung von Geräten
    5. Fritz-DECT-Adapter
    Fritz-DECT-Adapter
    • U
      ULBE last edited by Homoran
      Beim Anmelden bekomme ich folgende Meldungen (aus dem IO-Protokoll kopiert, neueste Meldung oben) Anmeldung mit speziellem IOBroker-User und den Rechten "SmartHome" und als Admin-User gleich. Fritzbox 7590 mit aktueller SW (8.02). Was mache ich falsch?:
      fritzdect.0
      	2025-03-23 10:42:59.213	error	login not possible, check user and permissions
      fritzdect.0
      	2025-03-23 10:42:59.212	error	API err => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.0.1","port":80}}}
      fritzdect.0
      	2025-03-23 10:42:59.211	error	no response part in returned error message
      fritzdect.0
      	2025-03-23 10:42:59.210	error	API funct => login_SID
      fritzdect.0
      	2025-03-23 10:42:59.210	error	API msg => error calling executeCommand
      fritzdect.0
      	2025-03-23 10:42:59.208	error	--------------- error calling the fritzbox -----------
      fritzdect.0
      	2025-03-23 10:42:56.045	info	fritzdect uses USER: iobroker
      fritzdect.0
      	2025-03-23 10:42:56.002	info	fritzdect entered ready
      fritzdect.0
      	2025-03-23 10:42:55.975	info	starting. Version 2.5.11 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v20.17.0, js-controller: 7.0.6
      host.iobroker
      	2025-03-23 10:42:53.653	info	instance system.adapter.fritzdect.0 in version "2.5.11" started with pid 155170
      host.iobroker
      	2025-03-23 10:42:52.964	info	"system.adapter.fritzdect.0" enabled
      host.iobroker
      	2025-03-23 10:42:39.991	info	instance system.adapter.fritzdect.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      fritzdect.0
      	2025-03-23 10:42:39.873	info	terminating
      host.iobroker
      	2025-03-23 10:42:39.430	info	stopInstance system.adapter.fritzdect.0 send kill signal
      fritzdect.0
      	2025-03-23 10:42:39.370	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      fritzdect.0
      	2025-03-23 10:42:39.369	info	terminating
      fritzdect.0
      	2025-03-23 10:42:39.367	info	cleaned everything up...
      fritzdect.0
      	2025-03-23 10:42:39.365	info	Got terminate signal TERMINATE_YOURSELF
      host.iobroker
      	2025-03-23 10:42:39.355	info	stopInstance system.adapter.fritzdect.0 (force=false, process=true)
      host.iobroker
      	2025-03-23 10:42:39.354	info	"system.adapter.fritzdect.0" disabled
      M haselchen 2 Replies Last reply Reply Quote 0
        MCU @ULBE last edited by MCU
        @ulbe IP-Adresse der FritzBox?
        Und Logs bitte in Code-Tags setzen -> 37ffc753-df7a-426e-9bdf-e3ab6fb4ee29-image.png
        nutzen
        • haselchen
          haselchen Most Active @ULBE last edited by haselchen
          @ulbe
          Repo kurz auf Beta stellen, die 2.6.0 einspielen und dann wieder zurück auf Stable.
          Mit dem 8.0.2 Update der FB funktioniert dann FritzDect wieder.
          Edit: + natürlich @MCU ´s Hinweis
          U D 2 Replies Last reply Reply Quote 0
          • U
            ULBE @MCU last edited by
            @mcu 192.168.0.1
            • U
              ULBE @haselchen last edited by
              @haselchen said in Fritz-DECT-Adapter:
              @ulbe
              ... das verstehe ich nicht ...
              haselchen 1 Reply Last reply Reply Quote 1
              • haselchen
                @ulbe
                http:// davor , so wie es oben steht
                Und dann hier auf Beta
                Und dann wieder zurück auf Stable nach dem Update auf Version 2.6.0
                  dibide @haselchen last edited by dibide
                  @ulbe
                  Danke für den Tip - das hat super funktioniert!
                  • mcm1957
                    mcm1957 @dibide last edited by
                    @dibide said in Fritz-DECT-Adapter:
                    @ulbe
                    Na ja - LATEST sollte aber JETZT nicht mehr notwendig sein.
                    Die aktuelle Version 2-6.1 ist seit eca 14 Tagen bereits im STABLE Repository. Wenn du da kein Upodate angeboten bekommen hast, dann solltest du dein Sysetm überprüfen.
                    • JB_Sullivan
                      JB_Sullivan last edited by JB_Sullivan
                      Kann mir jemand sagen, was mir diese Warnmeldung mitteilen möchte und vor allen Dingen wie ich sie abgestellt bekomme?
                      Adapter Version 2.6.2
                      fritzdect.0
                      12376	2025-05-14 21:03:42.461	warn	State value to set for "fritzdect.0.DECT_087610221797.energy_stats.datatimed" has value "1747249422456" greater than max "2147483648"
                      fritzdect.0
                      12376	2025-05-14 21:03:42.321	warn	State value to set for "fritzdect.0.DECT_087610221797.energy_stats.datatimem" has value "1747249422307" greater than max "2147483648"
                      • Codierknecht
                        Codierknecht Developer Most Active @JB_Sullivan last edited by
                        @jb_sullivan sagte in Fritz-DECT-Adapter:
                        Na das ist einfach: Der Wert ist zu groß für den Datenpunkt (bzw. dessen konfiguriertes Maximum).
                        Da wird wohl ein Timestamp mit Millisekunden in einen DP geschrieben der nur Sekundengenau ist.
                        Schreibst Du den DP selbst?
                        Ansonsten kann das nur der Entwickler/Maintainer des Adapters. Am besten machst Du dazu ein Issue auf GitHub auf.
                        JB_Sullivan 1 Reply Last reply Reply Quote 0
                        • JB_Sullivan
                          JB_Sullivan @Codierknecht last edited by
                          @codierknecht
                          OK, nein den schreibe ich nicht selbst, den holt der Adapter aus der Fritzbox von einer schaltbaren Steckdose ab.
                          Das interessante ist, das diese Warnungen seit 3-4 Tagen erst da sind, das Adapter Update aber schon deutlich länger zurück liegt
                          Codierknecht haselchen 2 Replies Last reply Reply Quote 0
                          • Codierknecht
                            Und was hat sich vor 3-4 Tagen verändert? Irgendeine Einstellung?
                            • haselchen
                              haselchen Most Active @JB_Sullivan last edited by
                              @jb_sullivan
                              Adapter anhalten
                              Besagte Datenpunkte löschen
                              Adapter starten
                              Die DP werden wieder „richtig“ angelegt .
                              JB_Sullivan W wcag22 4 Replies Last reply Reply Quote 0
                              • JB_Sullivan
                                JB_Sullivan @haselchen last edited by
                                @haselchen sagte in Fritz-DECT-Adapter:
                                @jb_sullivan
                                Adapter anhalten
                                Adapter starten
                                Vielen Dank - das hat geholfen 👍👍
                                  DerLockjaw @JB_Sullivan last edited by
                                  Ich bekomme seit einigen Wochen keine aktualisierte Werte mehr in den Objekten. Adapter: v2.6.1, Fritz!Box 8.02.
                                  Im Protokoll vom ioBroker taucht z.B. nach einem Adapter-Neustart auf:
                                  fritzdect.0
                                  	2025-06-01 15:17:25.662	debug	{"identifier":"11657 0351352","id":"16","functionbitmask":"35712","fwversion":"04.27","manufacturer":"AVM","productname":"FRITZ!Smart Energy 210","present":"1","txbusy":"0","name":"E-HeizungWasser","switch":{"state":"1","mode":"manuell","lock":"0","devicelock":"0"},"simpleonoff":{"state":"1"},"powermeter":{"voltage":"226136","power":"1989010","energy":"3301268"},"temperature":{"celsius":"245","offset":"0"}}
                                  Energy ist hier der korrekte aktuelle Wert 3301268.
                                  Aber der Wert unter Objekte lautet auf 3027985 und stammt laut Zeitstempel vom 21.04.2025. Es gibt keinen Wert im ganzen fritzdect.0-Zweig der aktueller ist - außer state. Aber state setze ich mit einem Programm und das Steuern funktioniert auch.
                                  Ich habe mal Testweise den nicht so wichtigen Wert "Voltage" gelöscht (vorher Adapter pausiert). Er wird beim Neustart nicht neu erstellt und fehlt jetzt.
                                  Was kann ich tun?
                                    DerLockjaw @DerLockjaw last edited by
                                    @derlockjaw Hat sich erstmal erledigt. Ein Downgrade des Adapters hat das Problem beseitigt.
                                    • mcm1957
                                      mcm1957 @DerLockjaw last edited by
                                      @derlockjaw
                                      Hast du ein Issue im Adapter Repository angelegt?
                                      Ohne Issue erwarte bitte nicht dass jemand sichvdes Problems annimmt ...
                                        Wolf1997 @haselchen last edited by Wolf1997
                                        @haselchen Vielen Dank!
                                        Bei mir trat diese Fehlermeldung gestern plötzlich auf. Tausende Warnungen.
                                        Mit deinem Tip ist jetzt alles wieder i.O.!
                                        Copy to Clipboard
                                        fritzdect.0
                                        fritzdect.0
                                          @jb_sullivan
                                          Adapter anhalten
                                          Adapter starten
                                          • wcag22
                                            wcag22 @haselchen last edited by
                                            @haselchen
                                            Nur zur Info:
                                            Der Fehler "größer als" betraf bei mir nur den DP "Monatsertrag".
                                            Der Tipp hat bei mir nicht geholfen.
                                            Nach Downgrade auf 2.6.1 wieder ok,
                                            wieder auf 2.6.2: gleicher Fehler.
                                            Auch hier half der Tip nicht.
                                            Jetzt läuft wieder 2.6.1 und alles ist ok.
                                            23
                                            2263
