    4. keine Updates möglich
    • Negalein
      • js-controller Version: 7.0.6
      • Admin Version: 7.6.14
      • Nodejs-Version: 20.19.1
      • NPM-Version: 10.8.2
      Hallo
      Wollte gerade den Rest-API von 2.0.3 auf 2.1.0 updaten.
      Läuft normal durch, aber es bleibt bei 2.0.3 und das Update wird mir immer wieder vorgeschlagen.
      Selbes Spiel mit Sourceanalytix von 0.4.14 auf 0.4.15-alpha.
      $ iobroker upgrade rest-api@2.1.0 --debug
      Update rest-api from @2.0.3 to @2.1.0
      host.ioBroker Adapter "system.adapter.rest-api.0" is stopped.
      Installing iobroker.rest-api@2.1.0... (System call)
      npm error code ETARGET
      npm error notarget No matching version found for iobroker.rest-api@2.1.0.npm error notarget In most cases you or one of your dependencies are requestingnpm error notarget a package version that doesn't exist.
      npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-04-24T08_59_50_444Z-debug-0.log
      Updating objects from io-package.json for adapter "rest-api" with version "2.0.3"
      upload [11] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [10] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [9] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [8] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [6] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [5] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [4] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [3] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [2] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [1] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/rest-api.png rest-api.png image/png
      host.ioBroker Adapter "system.adapter.rest-api.0" is started
      Process exited with code 0
      bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container
        Virtualization: lxc
      Operating System: Ubuntu 22.04.5 LTS
                Kernel: Linux 5.15.30-2-pve
          Architecture: x86-64
      OS is similar to: debian
      model name      : Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       11:13:42 up 23 min,  2 users,  load average: 0.93, 0.72, 0.90
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-04-24 11:13:42 CEST
                 Universal time: Thu 2025-04-24 09:13:42 UTC
                       RTC time: n/a
                      Time zone: Europe/Vienna (CEST, +0200)
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      nega
      HOME=/home/nega
      GROUPS=nega adm dialout sudo users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             10G        4.7G        4.5G        0.0K        867M        5.4G
      Swap:           3.1G          0B        3.1G
      Total:           13G        4.7G        7.6G
      Active iob-Instances:   67
              10048 M total memory
               4668 M used memory
                389 M active memory
               4914 M inactive memory
               4512 M free memory
                  0 M buffer memory
                867 M swap cache
               3072 M total swap
                  0 M used swap
               3072 M free swap
      top - 11:13:43 up 23 min,  2 users,  load average: 0.93, 0.72, 0.90
      Tasks: 102 total,   1 running, 101 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  6.2 us,  1.5 sy,  0.0 ni, 90.8 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
      MiB Mem :  10048.0 total,   4511.6 free,   4669.0 used,    867.4 buff/cache
      MiB Swap:   3072.0 total,   3072.0 free,      0.0 used.   5379.0 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type   Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0 ext4    45G   29G   14G  68% /
      10.0.1.21:/volume1/Backups       nfs4    14T   12T  2.2T  85% /opt/iobroker/backups
      none                             tmpfs  492K  4.0K  488K   1% /dev
      tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs  3.2G  144K  3.2G   1% /run
      tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1001
      Show mounted filesystems:
      TARGET                  SOURCE                           FSTYPE OPTIONS
      /                       /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
      `-/opt/iobroker/backups 10.0.1.21:/volume1/Backups       nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
      /var:
      3.1G    /var/
      2.5G    /var/log
      2.4G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
      372M    /var/lib
      Archived and active journals take up 2.3G in the file system.
      /opt/iobroker/backups:
      2.6G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      6.1G    /opt/iobroker/iobroker-data/
      3.9G    /opt/iobroker/iobroker-data/history
      1.6G    /opt/iobroker/iobroker-data/files
      323M    /opt/iobroker/iobroker-data/backup-objects
      299M    /opt/iobroker/iobroker-data/files/vis.0
      68M     /opt/iobroker/iobroker-data/states.jsonl
      39M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
      32M     /opt/iobroker/iobroker-data/files/vis.0/VIS/Background/Starfield 7.mp4
      32M     /opt/iobroker/iobroker-data/files/vis-2.0/VIS/Background/Starfield 7.mp4
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.1
      /usr/bin/node           v20.19.1
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.1-1nodesource1
        Candidate: 20.19.1-1nodesource1
        Version table:
       *** 20.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.9~dfsg-1ubuntu3.6 500
              500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
              500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
           12.22.9~dfsg-1ubuntu3 500
              500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 1384)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.14
      javascript:     8.9.1
      nodejs modules from github:     11
      +-- iobroker.e-control-at-fuel@0.1.6-beta.2 (git+ssh://git@github.com/xXBJXx/ioBroker.e-control-at-fuel.git#a9e5d6999622e789e01cac85f27a771fb41dc566)
      +-- iobroker.enigma2@2.2.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.enigma2.git#fc9f068008e05aabb09683728e17cedb4d79fbd0)
      +-- iobroker.fitbit-fitness@0.5.0 (git+ssh://git@github.com/Chris-656/ioBroker.fitbit-fitness.git#36a426abe0f6999aed316dd1bc6aba0d21150f4a)
      +-- iobroker.ford@1.0.5 (git+ssh://git@github.com/TA2k/ioBroker.ford.git#b205174cf0485a3751dbaaf31bed79a5345a19f8)
      +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
      +-- iobroker.samsung@0.6.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung.git#43d8a6ef3b5af0d6dfe276870f560353d52d0838)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#375dc3d6d53d8322071e7d172137fef1f5849370)
      | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
      +-- iobroker.vis-knob@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.vis-knob.git#a1dc9e3758987a921c893c0d63497e742d5c3526)
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      + system.adapter.alexa2.1                 : alexa2                : ioBroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.bayernluft.0             : bayernluft            : ioBroker                                 -  enabled
        system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
        system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
        system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
        system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
        system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 - disabled
        system.adapter.devices.0                : devices               : ioBroker                                 - disabled
        system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
      + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
      + system.adapter.enigma2.0                : enigma2               : ioBroker                                 -  enabled
        system.adapter.enigma2.1                : enigma2               : ioBroker                                 - disabled
      + system.adapter.eventlist.0              : eventlist             : ioBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : ioBroker                                 - disabled
        system.adapter.fitbit-fitness.0         : fitbit-fitness        : ioBroker                                 - disabled
        system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
      + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
        system.adapter.fontui.0                 : fontui                : ioBroker                                 -  enabled
        system.adapter.ford.0                   : ford                  : ioBroker                                 - disabled
      + system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
        system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : ioBroker                                 -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
      + system.adapter.harmony.1                : harmony               : ioBroker                                 -  enabled
      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
        system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 32543
      + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
      + system.adapter.iot.1                    : iot                   : ioBroker                                 -  enabled
        system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
      + system.adapter.lg-thinq.0               : lg-thinq              : ioBroker                                 -  enabled
      + system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
      + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
      + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
        system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 - disabled
        system.adapter.mytime.0                 : mytime                : ioBroker                                 - disabled
      + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
      + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
        system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
      + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
        system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 -  enabled
        system.adapter.pegelalarm.1             : pegelalarm            : ioBroker                                 -  enabled
      + system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
        system.adapter.places.0                 : places                : ioBroker                                 - disabled
      + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
      + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
        system.adapter.proxy.0                  : proxy                 : ioBroker                                 -  enabled
      + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0 (SSL), run as: rest
      + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
      + system.adapter.schedule-switcher.0      : schedule-switcher     : ioBroker                                 -  enabled
      + system.adapter.seq.0                    : seq                   : ioBroker                                 -  enabled, port: 443
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shrdzm.0                 : shrdzm                : ioBroker                                 - disabled
      + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
      + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
      + system.adapter.switchbot-hub.0          : switchbot-hub         : ioBroker                                 -  enabled
      + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
      + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
      + system.adapter.telegram-menu.0          : telegram-menu         : ioBroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.telegram.1               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tractive-gps.0           : tractive-gps          : ioBroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
        system.adapter.vesync.0                 : vesync                : ioBroker                                 - disabled
        system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
        system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
        system.adapter.vis-knob.0               : vis-knob              : ioBroker                                 - disabled
        system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
        system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
      + system.adapter.wireguard.0              : wireguard             : ioBroker                                 -  enabled
        system.adapter.xbox.0                   : xbox                  : ioBroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): Beta (latest)
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: Beta (latest)
      Adapter    "admin"        : 7.6.14   , installed 7.6.14
      Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.2.0    , installed 3.2.0
      Adapter    "bayernluft"   : 3.0.0    , installed 3.0.0
      Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
      Adapter    "bring"        : 1.9.1    , installed 1.9.1
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "devices"      : 1.2.1    , installed 1.2.1
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "doorbird"     : 3.0.0    , installed 3.0.0
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
      Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fitbit-fitness": 0.5.0   , installed 0.5.0
      Adapter    "followthesun" : 0.5.2    , installed 0.5.2
      Adapter    "ford"         : 1.0.4    , installed 1.0.5
      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
      Adapter    "fronius-solarweb": 0.1.1 , installed 0.1.1
      Adapter    "fuelpricemonitor": 0.4.2 , installed 0.4.2
      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "hs100"        : 3.0.4    , installed 3.0.4
      Adapter    "hue"          : 3.16.2   , installed 3.16.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "iot"          : 3.5.0    , installed 3.5.0
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "jarvis"       : 3.2.0-rc.5, installed 3.2.0-rc.5
      Adapter    "javascript"   : 8.9.1    , installed 8.9.1
      Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
      Adapter    "lg-thinq"     : 1.1.0    , installed 1.1.0
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "linux-control": 1.1.5    , installed 1.1.6
      Adapter    "logparser"    : 2.3.0    , installed 2.3.0
      Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
      Adapter    "mytime"       : 1.4.0    , installed 1.4.0
      Adapter    "nina"         : 0.0.26   , installed 0.0.26
      Adapter    "node-red"     : 6.0.7    , installed 6.0.7
      Adapter    "notification-manager": 1.3.0, installed 1.3.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "octoprint"    : 6.0.0    , installed 6.0.0
      Adapter    "parser"       : 2.3.1    , installed 2.3.1
      Adapter    "pegelalarm"   : 1.3.8    , installed 1.3.8
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "places"       : 1.2.0    , installed 1.2.0
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "rest-api"     : 2.1.0    , installed 2.0.3  [Updatable]
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "schedule-switcher": 0.0.10, installed 0.0.10
      Adapter    "seq"          : 0.3.0    , installed 0.3.0
      Adapter    "shelly"       : 9.4.1    , installed 9.4.1
      Adapter    "shrdzm"       : 0.2.0    , installed 0.2.0
      Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
      Adapter    "simple-api"   : 3.0.6    , installed 3.0.6
      Adapter    "snmp"         : 3.2.0    , installed 3.2.0
      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
      Adapter    "sourceanalytix": 0.4.15-alpha.1, installed 0.4.14 [Updatable]
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tapo"         : 0.4.8    , installed 0.4.8
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "telegram-menu": 2.2.4    , installed 2.2.4
      Adapter    "tractive-gps" : 2.1.0    , installed 2.1.0
      Adapter    "trashschedule": 4.0.0    , installed 4.0.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vesync"       : 0.0.9    , installed 0.0.9
      Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
      Adapter    "vis-2-widgets-collection": 1.7.9, installed 1.7.9
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.5 [Updatable]
      Adapter    "vis-weather"  : 2.5.11   , installed 2.5.11
      Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.9    , installed 7.0.9
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "wireguard"    : 1.8.0    , installed 1.8.0
      Adapter    "ws"           : 3.0.19   , installed 3.0.19
      Adapter    "xbox"         : 1.1.2    , installed 1.1.2
      Objects and States
      Objects:        36188
      States:         35113
      Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
      Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 10.0.1.202:8100         0.0.0.0:*               LISTEN      1000       1408917016 1455/io.doorbird.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1408899876 297/master
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        1408900266 114/systemd-resolve
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1408905785 695/node-red
      tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       1408909335 915/io.hm-rpc.0
      tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       1408908487 941/io.hm-rpc.1
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1408900552 120/iobroker.js-con
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1408902180 120/iobroker.js-con
      tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1000       1408909571 967/io.hm-rpc.2
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1408899774 146/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1408896938 1/init
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1001       1409029962 2649/sshd: nega@pts
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1001       1409029961 2649/sshd: nega@pts
      tcp6       0      0 :::61991                :::*                    LISTEN      1000       1408906194 863/io.harmony.1
      tcp6       0      0 :::8093                 :::*                    LISTEN      1000       1408955646 2174/io.rest-api.0
      tcp6       0      0 :::8084                 :::*                    LISTEN      1000       1408923940 1615/io.socketio.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1408922961 1600/io.simple-api.
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1408903253 415/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1408925317 1698/io.web.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1408899877 297/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1408899785 146/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1408896940 1/init
      tcp6       0      0 :::3000                 :::*                    LISTEN      1000       1408916152 1347/io.fullybrowse
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1408911979 1172/io.shelly.0
      udp        0      0 0.0.0.0:40715           0.0.0.0:*                           1000       1408911080 1135/io.snmp.0
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        1408900265 114/systemd-resolve
      udp        0      0 10.0.1.202:68           0.0.0.0:*                           105        1408898780 102/systemd-network
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1408896939 1/init
      udp        0      0 0.0.0.0:35909           0.0.0.0:*                           1000       1408911081 1135/io.snmp.0
      udp        0      0 0.0.0.0:37009           0.0.0.0:*                           1000       1408909103 1135/io.snmp.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       1408906195 863/io.harmony.1
      udp6       0      0 :::111                  :::*                                0          1408896941 1/init
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) rssi: -78
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fwMainController: Rev2.0
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fwWiFi: WS32240427
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) on: true
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) temperatureIn: 30.0
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) temperatureOut: 31.1
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) temperatureFresh: 17.3
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) relativeHumidityIn: 27.0
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) relativeHumidityOut: 29.6
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) absoluteHumidityIn: 8.2
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) absoluteHumidityOut: 9.5
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) efficiency: 92.1
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) humidityTransport: -371
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fanSpeedIn: 05
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fanSpeedOut: 05
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fanSpeedAntiFreeze: 00
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isAntiFreezeActive: false
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isFixedSpeedActive: false
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isDefrostModeActive: false
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isLandlordModeActive: false
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isCrossVentilationActive: false
      2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isTimerActive: false
      2025-04-24 11:14:11.886  - debug: shuttercontrol.0 (1118) outsidetemperature changed: 0_userdata.0.Wetterstation.Aussentemperatur | Value: 9.61°C
      2025-04-24 11:14:11.935  - info: simple-api.0 (1600) State value to set for "0_userdata.0.Wetterstation.Regen_Woche" has to be type "number" but received type "string"
      2025-04-24 11:14:12.015  - info: simple-api.0 (1600) State value to set for "0_userdata.0.Wetterstation.Regen_Event" has to be type "number" but received type "string"
      • Asgothian
        Asgothian Developer @Negalein last edited by
        @negalein
        Die 2.1.0 ist laut npmjs auf NPM nicht veröffentlicht.
        Da würde mich interessieren was du als Kanal für Deine Update-Vorschläge eingestellt hast.
        A.
        • Negalein
          Negalein Global Moderator @Asgothian last edited by Negalein
          @asgothian sagte in keine Updates möglich:
          den Beta
            Thomas Braun Most Active @Negalein last edited by Thomas Braun
            Interessant. Heute morgen hatte ich was ähnliches mit dem sainlogic-Adapter. Hängt auch in einem Update-Loop.
            Kann aber erst heute abend mal genauer schauen.
            Fahre auch das Beta-Repo.
            Edit:
            Hängt evtl. damit zusammen:
            https://forum.iobroker.net/topic/80841/beschreibung-bei-einigen-adaptern-verschwunden/8
            • haus-automatisierung
              haus-automatisierung Developer Most Active last edited by
              Im Falle der rest-api ist die Deploy-Action nicht ausgeführt worden: https://github.com/ioBroker/ioBroker.rest-api/actions/runs/13568640534
              Das heißt, auf GitHub steht zwar 2.1.0, aber das Paket ist nie auf npm angekommen.
              FYI @mcm1957
              mcm1957 2 Replies Last reply Reply Quote 0
              • mcm1957
                mcm1957 @haus-automatisierung last edited by
                Bitte einmal auf "NACH UPDATES SUCHEN" klicken um das Repo neu zu laden.
                Der morgendliche Repobuild hatte Probleme (GitHub Workflow konnte auf Github Repos nicht zugreifen bzw. hat diese nicht gefunden 😞 ) und hat dabei offensichtlich tw. Schrott ins Repo gestellt.
                Ich habe ca. 11:45 einen neuen Build durchgeführt. Die aktuellen Repodaten sollten wieder OK sein.
                Negalein 1 Reply Last reply Reply Quote 2
                • Negalein
                  Negalein Global Moderator @mcm1957 last edited by
                  @mcm1957 sagte in keine Updates möglich:
                  Rest-Api 2.1.0 und Sourceanalytix 0.4.15-alpha scheinen nun nicht mehr auf.
                  Rest blieb bei 2.0.3 & SA bei 0.4.14
                  • mcm1957
                    @haus-automatisierung said in keine Updates möglich:
                    FYI @mcm1957
                    Dake,
                    Muss sich @Bluefox ansehen. Hab ihn gepingt.
