    4. fb-checkpresence
    fb-checkpresence
      michihorn last edited by michihorn
      Hallo
      ich beschäftige mich heute erstemal mit den fb-checkpresence Adapter
      Er bringt jede Menge warm Meldungen
      fb-checkpresence.0
      	2025-04-24 20:40:35.104	warn	The state "devices" will not longer exist in a future version. Please use "fb-devices.count" instead!
      fb-checkpresence.0
      	2025-04-24 20:40:35.103	warn	The state "activeDevices" will not longer exist in a future version. Please use "fb-devices.active" instead!
      fb-checkpresence.0
      	2025-04-24 20:40:35.103	warn	The state "blacklist" will not longer exist in a future version. Please use "blacklist.presence" instead!
      fb-checkpresence.0
      	2025-04-24 20:40:35.102	warn	The state "guest" will not longer exist in a future version. Please use "guest.presence" instead!
      fb-checkpresence.0
      	2025-04-24 20:40:35.100	warn	Then you should manually delete the old family member data points!
      fb-checkpresence.0
      	2025-04-24 20:40:35.100	warn	With this change in the adapter settings the new folder familyMembers will be created
      fb-checkpresence.0
      	2025-04-24 20:40:35.099	warn	In a future version some states are not more existent. Please disable the compatibility mode in the adapter settings by unchecking the box.
      fb-checkpresence.0
      	2025-04-24 20:40:35.070	warn	Layer3Forwarding1-GetDefaultConnectionService is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.069	warn	WANPPPConnection1-ForceTermination is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.068	warn	DeviceConfig1-Reboot is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.068	warn	X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.067	warn	X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.066	warn	DeviceInfo1-GetInfo is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.065	warn	WLANConfiguration3-GetSecurityKeys is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.064	warn	WLANConfiguration3-GetInfo is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.051	warn	WLANConfiguration3-SetEnable is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.050	warn	WANIPConnection1-GetInfo is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.049	warn	WANPPPConnection1-GetInfo is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.047	warn	WANCommonInterfaceConfig1-GetCommonLinkProperties is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.044	warn	Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.042	warn	Hosts1-X_AVM-DE_GetMeshListPath is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:40:35.041	warn	Hosts1-X_AVM-DE_GetHostListPath is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:37:32.802	warn	The state "fb-checkpresence.0.Noel" will not longer exist in a future version. Please use fb-checkpresence.0.Noel.presence" instead!
      fb-checkpresence.0
      	2025-04-24 20:37:32.500	warn	The state "fb-checkpresence.0.Michael" will not longer exist in a future version. Please use fb-checkpresence.0.Michael.presence" instead!
      fb-checkpresence.0
      	2025-04-24 20:37:32.260	warn	The state "fb-checkpresence.0.Heike" will not longer exist in a future version. Please use fb-checkpresence.0.Heike.presence" instead!
      fb-checkpresence.0
      	2025-04-24 20:37:31.356	warn	The state "devices" will not longer exist in a future version. Please use "fb-devices.count" instead!
      fb-checkpresence.0
      	2025-04-24 20:37:31.355	warn	The state "activeDevices" will not longer exist in a future version. Please use "fb-devices.active" instead!
      fb-checkpresence.0
      	2025-04-24 20:37:31.355	warn	The state "blacklist" will not longer exist in a future version. Please use "blacklist.presence" instead!
      fb-checkpresence.0
      	2025-04-24 20:37:31.354	warn	The state "guest" will not longer exist in a future version. Please use "guest.presence" instead!
      fb-checkpresence.0
      	2025-04-24 20:37:31.351	warn	Then you should manually delete the old family member data points!
      fb-checkpresence.0
      	2025-04-24 20:37:31.350	warn	With this change in the adapter settings the new folder familyMembers will be created
      fb-checkpresence.0
      	2025-04-24 20:37:31.349	warn	In a future version some states are not more existent. Please disable the compatibility mode in the adapter settings by unchecking the box.
      fb-checkpresence.0
      	2025-04-24 20:37:31.326	warn	Layer3Forwarding1-GetDefaultConnectionService is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:37:31.324	warn	WANPPPConnection1-ForceTermination is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:37:31.323	warn	DeviceConfig1-Reboot is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:37:31.323	warn	X_AVM-DE_HostFilter-GetWANAccessByIP is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:37:31.322	warn	X_AVM-DE_HostFilter-DisallowWANAccessByIP is not supported! Feature is deactivated!
      fb-checkpresence.0
      	2025-04-24 20:37:31.321	warn	DeviceInfo1-GetInfo is not supported! Feature is deactiv
      Weiterhin habe ich ein Handy und das vom Sohn und der Frau eingetragen. Ich bin present, Frau nicht obwohl WLAN an ist und auch keine Akku Stromsparfunktionen an sind und der Sohnemann ist tatsächlich nicht da. Ein und Ausschalten des WLAN am Handy meiner Frau brachte nur kurzfristig ein Presence.
      Gruß Michael
      • sigi234
        sigi234 Forum Testing Most Active @michihorn last edited by
        @michihorn
        Welche Version hast du installiert?
          michihorn @sigi234 last edited by
          @sigi234 sagte in fb-presence:
          Version 1.3.1 ist installiert
          • sigi234
            @michihorn sagte in fb-checkpresence:
            Ok, welche FB hast du mit welchen OS ?
            Deine Handys werden in der FB Richtig erkannt?
              @sigi234 Ich habe die FB 6660 Cable FW 7.58, ja die Handys werden erkannt
              • sigi234
                Hast du den compatibility mode deaktiviert?
                  @sigi234 Ja mal mit und mal ohne getestet.
                  • sigi234
                    sigi234 Forum Testing Most Active @michihorn last edited by sigi234
                    Ok, lösche den Ordner mal komplett und lass sie neu einlesen.
                    fb-presence
