    4. telegram
    telegram
      michihorn last edited by
      Hallöchen
      ich habe den Telegram Adapter 4.0.1 am laufen, leider verliert der Adapter immer mal wieder den Token.
      Aktuell läuft der Adapter, produziert aber viele Fehler, vielleicht hat jemand einen Tip für mich.
      elegram.0
      2025-05-09 10:45:05.822	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
      telegram.0
      2025-05-09 10:45:05.786	debug	Send message to [Michael]: "undefined"
      telegram.0
      2025-05-09 10:45:05.785	debug	Received command "send": {"caption":"Boot Bewegung 10:45:05","type":"photo"}
      telegram.0
      2025-05-09 10:45:05.783	silly	States system redis pmessage io.messagebox.system.adapter.telegram.0/io.messagebox.system.adapter.telegram.0:{"command":"send","message":{"caption":"Boot Bewegung 10:45:05","type":"photo"},"from":"system.adapter.javascript.0","_id":47698352}
      telegram.0
      2025-05-09 10:45:02.644	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
      telegram.0
      2025-05-09 10:45:02.616	debug	Send message to [Michael]: "undefined"
      telegram.0
      2025-05-09 10:45:02.616	debug	Received command "send": {"caption":"Doorbell Bewegung 10:45:02","type":"photo"}
      telegram.0
      2025-05-09 10:45:02.615	silly	States system redis pmessage io.messagebox.system.adapter.telegram.0/io.messagebox.system.adapter.telegram.0:{"command":"send","message":{"caption":"Doorbell Bewegung 10:45:02","type":"photo"},"from":"system.adapter.javascript.0","_id":47698351}
      telegram.0
      2025-05-09 10:44:55.837	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
      telegram.0
      2025-05-09 10:44:55.793	debug	Send message to [Michael]: "undefined"
      telegram.0
      2025-05-09 10:44:55.792	debug	Received command "send": {"caption":"Boot Bewegung 10:44:55","type":"photo"}
      telegram.0
      2025-05-09 10:44:55.790	silly	States system redis pmessage io.messagebox.system.adapter.telegram.0/io.messagebox.system.adapter.telegram.0:{"command":"send","message":{"caption":"Boot Bewegung 10:44:55","type":"photo"},"from":"system.adapter.javascript.0","_id":47698350}
      telegram.0
      2025-05-09 10:44:52.870	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
      telegram.0
      2025-05-09 10:44:52.766	debug	Send message to [Michael]: "undefined"
      telegram.0
      2025-05-09 10:44:52.765	debug	Received command "send": {"caption":"Doorbell Bewegung 10:44:52","type":"photo"}
      telegram.0
      2025-05-09 10:44:52.756	silly	States system redis pmessage io.messagebox.system.adapter.telegram.0/io.messagebox.system.adapter.telegram.0:{"command":"send","message":{"caption":"Doorbell Bewegung 10:44:52","type":"photo"},"from":"system.adapter.javascript.0","_id":47698349}
      telegram.0
      2025-05-09 10:44:45.814	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
      telegram.0
      2025-05-09 10:44:45.788	debug	Send message to [Michael]: "undefined"
      telegram.0
      2025-05-09 10:44:45.787	debug	Received command "send": {"caption":"Boot Bewegung 10:44:45","type":"photo"}
      telegram.0
      2025-05-09 10:44:45.780	silly	States system redis pmessage io.messagebox.system.adapter.telegram.0/io.messagebox.system.adapter.telegram.0:{"command":"send","message":{"caption":"Boot Bewegung 10:44:45","type":"photo"},"from":"system.adapter.javascript.0","_id":47698348}
      telegram.0
      2025-05-09 10:44:42.626	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
      telegram.0
      2025-05-09 10:44:42.598	debug	Send message to [Michael]: "undefined"
      telegram.0
      2025-05-09 10:44:42.597	debug	Received command "send": {"caption":"Doorbell Bewegung 10:44:42","type":"photo"}
      telegram.0
      2025-05-09 10:44:42.596	silly	States system redis pmessage io.messagebox.system.adapter.telegram.0/io.messagebox.system.adapter.telegram.0:{"command":"send","message":{"caption":"Doorbell Bewegung 10:44:42","type":"photo"},"from":"system.adapter.javascript.0","_id":47698347}
      telegram.0
      2025-05-09 10:44:35.810	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
      telegram.0
      2025-05-09 10:44:35.772	debug	Send message to [Michael]: "undefined"
      telegram.0
      2025-05-09 10:44:35.771	debug	Received command "send": {"caption":"Boot Bewegung 10:44:35","type":"photo"}
      telegram.0
      2025-05-09 10:44:35.770	silly	States system redis pmessage io.messagebox.system.adapter.telegram.0/io.messagebox.system.adapter.telegram.0:{"command":"send","message":{"caption":"Boot Bewegung 10:44:35","type":"photo"},"from":"system.adapter.javascript.0","_id":47698346}
      telegram.0
      2025-05-09 10:44:32.767	silly	Objects user redis pmessage */cfg.o.script.js.SYSTEM.Motion_Doorbell:{"_id":"script.js.SYSTEM.Motion_Doorbell","type":"script","common":{"name":"Motion_Doorbell","expert":true,"engineType":"Javascript/js","enabled":true,"engine":"system.adapter.javascript.0","source":"/*****Bewegung Doorbell ****************************************************\r\n* Mai 2025\r\n* Adapter: \r\n* geä:\r\n*************************************************************************/\r\n\r\nconst idmotion = \"reolink.1.sensor.motion\"\r\nconst camurl = 'http://192.168.188.122/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=admin&password=roadking04&width=800&height=600'\r\n\r\non({ id: idmotion, change:\"any\" }, function (obj) {\r\n if (obj.state.val == true) {\r\n log(\"Motion Doorbell\")\r\n\r\n httpGet(camurl, { responseType: 'arraybuffer' }, async (err, response) => {\r\n if (!err) {\r\n writeFile('vis.0', '/Doorbell/Doorbell.jpg', response.data, (err) => {\r\n if (err) {\r\n console.error(err);\r\n }\r\n });\r\n } else {\r\n console.error(err);\r\n }\r\n });\r\n }\r\n readFile('vis.0', '/Doorbell/Doorbell.jpg', function (err, img) {\r\n var ereignis_text = formatDate(new Date(obj.state.ts), \"hh:mm:ss\");\r\n sendTo(\"telegram.0\", {\r\n text: img,\r\n caption: \"Doorbell Bewegung \" + ereignis_text,\r\n type: \"photo\"\r\n });\r\n delFileAsync('vis.0', '/Doorbell/Doorbell.jpg')\r\n });\r\n \r\n});","debug":false,"verbose":false},"native":{},"from":"system.adapter.admin.0","user":"system.user.admin","ts":1746780272756,"acl":{"object":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      Ich möchte erwähnen, das bis gersten, diese Fehlermeldung nicht vorhanden war. Zwischendurch habe ich nun den Adapter mal neu installiert.
      Michael
      haus-automatisierung 2 Replies Last reply Reply Quote 0
      • haus-automatisierung
        haus-automatisierung Developer Most Active @michihorn last edited by
        @michihorn sagte in telegram:
        Das passiert eigentlich nur, wenn man die Instanz per setObject z.B. aus Scripts heraus regelmäßig neustartet. Was man nie tun sollte, ...
          michihorn @haus-automatisierung last edited by
          @haus-automatisierung Das tue ich bewusst nicht, bislang hatte ich die Fehlermeldung nicht. Ich habe einen zweiten IOB für mein privates Haus laufen, mit der selben Installation, dort habe ich den fehler nicht
            Aber nicht mit dem gleichen Token, sondern einem zusätzlichen Bot, oder? Das gleiche Token für mehrere Instanzen nutzen funktioniert nicht.
              Zeig am besten mal, wie genau Du die Nachricht zusammenbaust und sendest.
                @haus-automatisierung Nee, das ist klar es war ein eigener Token 😉
                  michihorn @haus-automatisierung last edited by michihorn
                  * Mai 2025
                  * Adapter:
                  * geä:
                  const idmotion = "reolink.1.sensor.motion"
                  const camurl = 'http://192.168.188.122/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=admin&password=rxxxxxg04&width=800&height=600'
                  on({ id: idmotion, change:"any" }, function (obj) {
                      log("Motion Doorbell")
                          if (!err) {
                                  if (err) {
                                      console.error(err);
                          } else {
                              console.error(err);
                          var ereignis_text = formatDate(new Date(obj.state.ts), "hh:mm:ss");
                          sendTo("telegram.0", {
                              text: img,
                              caption: "Doorbell Bewegung " + ereignis_text,
                              type: "photo"
                  Aktuell ist das jetzt die Fehlermeldung
                  elegram.0
                  	2025-05-09 12:12:09.035	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:12:03.582	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:59.114	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:53.525	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:49.124	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:48.590	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:40.331	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:36.294	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:30.005	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:23.893	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:19.774	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:13.677	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:10.434	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:11:04.927	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:10:59.677	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:10:53.561	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:10:49.077	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:10:44.206	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  telegram.0
                  	2025-05-09 12:10:42.514	error	Failed sending [chatId - 6105180270]: Error: ETELEGRAM: 400 Bad Request: message text is empty
                  OliverIO haus-automatisierung 2 Replies Last reply Reply Quote 0
                  • OliverIO
                    OliverIO @michihorn last edited by OliverIO
                    @michihorn
                    Da ist ein Zeitfehler drin.
                    Httpget
                    Und Readfile wird relativ zeitnah hintereinander ändernaufgerufen.
                    Es ist nicht gesichert, das die callbacks genau auch so in der Reihenfolge fertig sind.
                    D.h. Das Bild das du mit HTTPget abrufst ist wahrscheinlich noch nicht vorhanden, wenn du den readfile/telegram Befehl aufrufst.
                    Daher auch die Meldung mit undefined oder message empty.
                    Wenn du auf die Verwendung der callback Versionen der Funktionen verzichtest und mit await arbeitest, wird es viel logischer von der Abarbeitung her.
                      haus-automatisierung Developer Most Active @michihorn last edited by haus-automatisierung
                      @michihorn Das geht so nicht, Du übergibst die Daten aus readFile direkt an Telegam. Also Binärdaten. Der Telegram-Adapter kann damit aber nicht umgehen und hätte gerne einen Pfad. Dafür habe ich die Funktion createTempFile eingebaut.
                      Und @OliverIO hat auch Recht - am besten mit einem weiteren Trigger auf geändert Bild-Dateien reagieren (oder sich den Umweg über das Datei-Management von ioBroker komplett sparen, wenn Du die Datei eh direkt wieder löschen willst).
                      Vorschlag 1)
                      const idmotion = 'reolink.1.sensor.motion';
                      const camurl = 'http://192.168.188.122/cgi-bin/api.cgi?cmd=Snap&channel=0&rs=wuuPhkmUCeI9WG7C&user=admin&password=rxxxxxg04&width=800&height=600';
                      on({ id: idmotion, change: 'any' }, (obj) => {
                          log('Motion Doorbell'):
                              if (!err) {
                                      if (err) {
                                          console.error(err);
                              } else {
                                  console.error(err);
                      onFile('vis.0', '/Doorbell/*.jpg', true, async (id, fileName, size, data, mimeType) => {
                        const ereignis_text = formatDate(new Date(), 'hh:mm:ss');
                        sendToAsync('telegram.0', {
                            text: createTempFile(fileName, data),
                            caption: `Doorbell Bewegung ${ereignis_text}`,
                            type: 'photo'
                      Vorschlag 2:
                                if (!err) {
                                    const ereignis_text = formatDate(new Date(obj.state.ts), 'hh:mm:ss');
                                        text: createTempFile(fileName, response.data),
                                        type: 'photo'
                                } else {
                                    console.error(err);
                      OliverIO M 3 Replies Last reply Reply Quote 1
                      • OliverIO
                        OliverIO @haus-automatisierung last edited by OliverIO
                        Ein File handle sollte gemäß Doku auch gehen.
                        Vgl. Beispiel
                        https://github.com/iobroker-community-adapters/ioBroker.telegram/blob/master/docs/en/README.md#explicit-types-of-messages
                        sendTo('telegram.0', 'send', {
                            text: fs.readFileSync('/opt/path/picture.png'),
                            type: 'photo'
                          michihorn @OliverIO last edited by
                          @oliverio Ja stimmt, zumindest machmal, aber jetzt weiß ich ja woran es gelegen hat. Danke
                            @haus-automatisierung Danke für die Überarbeitung des Scriptes, ich habe jetzt mal die Variante eingebaut. Danke
                              @haus-automatisierung sagte in telegram:
                              Das Script moniert den fileName
                              javascript.0	15:04:31.098	error
                              ReferenceError: fileName is not defined
                              javascript.0	15:04:31.099	error
                                  at Object.<anonymous> (script.js.SYSTEM.Motion_Doorbell:26:40)
                              • OliverIO
                                @michihorn
                                Ok, Du hast überhaupt keine Ahnung von JavaScript?
                                Filename ist eine variable in der der Dateiname zu deinem Bild steht.
                                Also entweder die Daten die aus dem httprequest kommen als Datei speichern oder besser doch wieder das file handle wie in deinem ursprünglichen Beispiel übergeben.
                                Kann es leider nicht selbst nachstellen.
                                  michihorn @OliverIO last edited by michihorn
                                  @oliverio Ich lerne jeden Tag dazu. Es ist noch kein Meister vom Himmel gefallen. 😉
                                  Die Variante2 von Hausautomatik habe ich so übernommen. Die Variable fileName war nicht in der Definition angegeben und es ist nicht klar wo wird die Variable "gefüllt", ergo moppert das Script. Leider gibt es auch keine Sendung per Telegram. Ich schaue mir das später nochmal an. Danke erstmal
                                  • OliverIO
                                    @michihorn
                                    Trage da einfach mal anstatt dessen
                                    createTempFile('telegram-image.png', response.data)
                                    Ein.
                                      @oliverio sagte in telegram:
                                      und wo wird telegram-image.png "gefüllt"? Mit response.data?
                                      haus-automatisierung OliverIO 2 Replies Last reply Reply Quote 0
                                        @michihorn Ist die Doku der Funktion unvollständig?
                                          @haus-automatisierung Aus meiner Sicht schon, ich werde mich am Montag mal in Ruhe damit beschäftigen.
                                          Viele Grüße 😉
                                          • OliverIO
                                            @michihorn
                                            Das ist nur der temporäre Dateiname.
                                            Gefüllt wird das durch diese Funktion.
                                            Der Inhalt kommt von response.data
                                            531
