    4. WebUI - Admin (8081) u. Visu (8082) - nicht erreichbar
    • von.cartman
      von.cartman last edited by von.cartman
      seit gestern abend funktioniert bei mir der WebUI nicht mehr.
      Wieder auf PC, noch am Mobilgeräten kann ich die Seiten nicht abrufen.
      Ich habe bereits verucht alles zu aktualisieren, leider ohne Erfolg.
      hier der iob diag Auszug.
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: Raspi
             Icon name: computer
                Kernel: Linux 6.6.62+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       11:01:42 up  4:22,  2 users,  load average: 3.80, 2.86, 1.91
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2025-05-14 11:01:42 CEST
                 Universal time: Wed 2025-05-14 09:01:42 UTC
                       RTC time: Wed 2025-05-14 09:01:42
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio www-data video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.4G        455M        7.0G        4.8M        1.1G        8.0G
      Swap:           536M          0B        536M
      Total:          9.0G        455M        7.5G
      Active iob-Instances:   1
               8052 M total memory
                435 M used memory
                455 M active memory
                639 M inactive memory
               6661 M free memory
                182 M buffer memory
                874 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 11:01:43 up  4:22,  2 users,  load average: 3.80, 2.86, 1.91
      Tasks: 141 total,   1 running, 140 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8052.2 total,   6661.4 free,    435.5 used,   1056.9 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   7616.7 avail Mem
      *** FAILED SERVICES ***
        UNIT           LOAD   ACTIVE SUB    DESCRIPTION
      * vsftpd.service loaded failed failed vsftpd FTP server
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      26 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     806M  4.7M  801M   1% /run
      /dev/mmcblk0p2 ext4       28G   11G   16G  41% /
      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
      tmpfs          tmpfs     806M     0  806M   0% /run/user/1000
      [Wed May 14 06:39:02 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=D8:3A:DD:B4:E1:00 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=4f2c0a0f-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Wed May 14 06:39:05 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
      [Wed May 14 06:39:07 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
      [Wed May 14 06:39:50 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm npm: corrupted in-inode xattr: bad e_name length
      [Wed May 14 06:39:53 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm npm: corrupted in-inode xattr: bad e_name length
      [Wed May 14 07:18:49 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm chown: corrupted in-inode xattr: bad e_name length
      [Wed May 14 07:18:57 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304209: comm chown: corrupted in-inode xattr: ea_inode specified without ea_inode feature enabled
      [Wed May 14 07:19:51 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm chown: corrupted in-inode xattr: bad e_name length
      [Wed May 14 07:19:59 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304209: comm chown: corrupted in-inode xattr: ea_inode specified without ea_inode feature enabled
      [Wed May 14 07:20:29 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_set_entry:1668: inode #304166: comm setfacl: corrupted xattr entries
      [Wed May 14 07:20:29 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm setfacl: corrupted in-inode xattr: bad e_name length
      [Wed May 14 07:20:29 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304209: comm setfacl: corrupted in-inode xattr: ea_inode specified without ea_inode feature enabled
      [Wed May 14 07:20:29 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm rm: corrupted in-inode xattr: bad e_name length
      [Wed May 14 07:32:23 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm chown: corrupted in-inode xattr: bad e_name length
      [Wed May 14 07:32:32 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304209: comm chown: corrupted in-inode xattr: ea_inode specified without ea_inode feature enabled
      [Wed May 14 07:33:08 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm chown: corrupted in-inode xattr: bad e_name length
      [Wed May 14 07:33:19 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304209: comm chown: corrupted in-inode xattr: ea_inode specified without ea_inode feature enabled
      [Wed May 14 07:33:54 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_set_entry:1668: inode #304166: comm setfacl: corrupted xattr entries
      [Wed May 14 07:33:54 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm setfacl: corrupted in-inode xattr: bad e_name length
      [Wed May 14 07:33:54 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304209: comm setfacl: corrupted in-inode xattr: ea_inode specified without ea_inode feature enabled
      [Wed May 14 07:33:54 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm rm: corrupted in-inode xattr: bad e_name length
      [Wed May 14 10:59:10 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm chown: corrupted in-inode xattr: bad e_name length
      [Wed May 14 10:59:18 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304209: comm chown: corrupted in-inode xattr: ea_inode specified without ea_inode feature enabled
      [Wed May 14 11:00:12 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm chown: corrupted in-inode xattr: bad e_name length
      [Wed May 14 11:00:25 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304209: comm chown: corrupted in-inode xattr: ea_inode specified without ea_inode feature enabled
      [Wed May 14 11:00:34 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_set_entry:1668: inode #304166: comm setfacl: corrupted xattr entries
      [Wed May 14 11:00:35 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm setfacl: corrupted in-inode xattr: bad e_name length
      [Wed May 14 11:00:35 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304209: comm setfacl: corrupted in-inode xattr: ea_inode specified without ea_inode feature enabled
      [Wed May 14 11:00:35 2025] EXT4-fs error (device mmcblk0p2): ext4_xattr_ibody_find:2235: inode #304211: comm rm: corrupted in-inode xattr: bad e_name length
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      3.9G    /var/
      2.8G    /var/log/journal/0d56a9beb4d64b288a038a2796e66e50
      2.8G    /var/log
      421M    /var/cache
      Archived and active journals take up 2.7G in the file system.
      /opt/iobroker/backups:
      325M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.2G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2c00cdf9a5a4ed11826484582981d5c7-if00-port0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.15.0
      /usr/bin/node           v22.15.0
      /usr/bin/npm            10.9.2
      /usr/bin/npx            10.9.2
      /usr/bin/corepack       0.32.0
      nodejs:
        Installed: 22.15.0-1nodesource1
        Candidate: 22.15.0-1nodesource1
        Version table:
       *** 22.15.0-1nodesource1 600
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           22.14.0-1nodesource1 600
           22.13.1-1nodesource1 600
           22.13.0-1nodesource1 600
           22.12.0-1nodesource1 600
           22.11.0-1nodesource1 600
           22.10.0-1nodesource1 600
           22.9.0-1nodesource1 600
           22.8.0-1nodesource1 600
           22.7.0-1nodesource1 600
           22.6.0-1nodesource1 600
           22.5.1-1nodesource1 600
           22.5.0-1nodesource1 600
           22.4.1-1nodesource1 600
           22.4.0-1nodesource1 600
           22.3.0-1nodesource1 600
           22.2.0-1nodesource1 600
           22.1.0-1nodesource1 600
           22.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      Temp directories causing deletion problem: 1
      Some problems detected, please run iob fix
      Errors in npm tree: 0
      No problems detected
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      Raspi               Raspi (version: 7.0.6, hostname: Raspi         , alive, uptime: 38)
      slave               slave (version: 7.0.6, hostname: slave         , alive, uptime: 7)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.3
      javascript:     8.8.3
      nodejs modules from github:     4
      +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
      +-- iobroker.mercedesme@0.3.7 (git+ssh://git@github.com/TA2k/ioBroker.mercedesme.git#2ef51a64577c1b40b6f074305cabead3b350bf2b)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
      Adapter State
        system.adapter.admin.0                  : admin                 : Raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : Raspi                                    -  enabled
        system.adapter.daswetter.0              : daswetter             : Raspi                                    -  enabled
        system.adapter.devices.0                : devices               : Raspi                                    -  enabled
        system.adapter.discovery.0              : discovery             : Raspi                                    -  enabled
        system.adapter.doorbird.0               : doorbird              : Raspi                                    -  enabled
        system.adapter.doorio.0                 : doorio                : slave                                    -  enabled, port: 8100
        system.adapter.govee-local.0            : govee-local           : Raspi                                    - disabled
        system.adapter.govee.0                  : govee                 : Raspi                                    - disabled
        system.adapter.ical.0                   : ical                  : Raspi                                    -  enabled
        system.adapter.icons-freepic.0          : icons-freepic         : Raspi                                    -  enabled
        system.adapter.icons-smarthome.0        : icons-smarthome       : Raspi                                    -  enabled
        system.adapter.iot.0                    : iot                   : Raspi                                    -  enabled
        system.adapter.javascript.0             : javascript            : Raspi                                    -  enabled
        system.adapter.knx.0                    : knx                   : Raspi                                    -  enabled, bind: 127.0.0.1
        system.adapter.mercedesme.0             : mercedesme            : Raspi                                    -  enabled
        system.adapter.mielecloudservice.0      : mielecloudservice     : Raspi                                    -  enabled
        system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : Raspi                                    -  enabled, port: 16021
        system.adapter.nanoleaf-lightpanels.1   : nanoleaf-lightpanels  : Raspi                                    -  enabled, port: 16021
        system.adapter.openknx.0                : openknx               : Raspi                                    -  enabled
        system.adapter.samsung.0                : samsung               : Raspi                                    -  enabled
        system.adapter.scenes.0                 : scenes                : Raspi                                    -  enabled
        system.adapter.shelly.0                 : shelly                : Raspi                                    -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : Raspi                                    -  enabled, port: 1881, bind: 0.0.0.0
        system.adapter.smartthings.0            : smartthings           : Raspi                                    -  enabled
        system.adapter.telegram.0               : telegram              : Raspi                                    - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.tradfri.0                : tradfri               : Raspi                                    -  enabled
        system.adapter.trashschedule.0          : trashschedule         : Raspi                                    -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: Raspi                                    -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: Raspi                                    -  enabled
        system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: Raspi                                    -  enabled
        system.adapter.vis-2.0                  : vis-2                 : Raspi                                    -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : Raspi                                    -  enabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : Raspi                                    -  enabled
        system.adapter.vis-material.0           : vis-material          : Raspi                                    -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : Raspi                                    -  enabled
        system.adapter.vis-weather.0            : vis-weather           : Raspi                                    -  enabled
        system.adapter.vis.0                    : vis                   : Raspi                                    -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : Raspi                                    -  enabled
        system.adapter.web.0                    : web                   : Raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yahka.0                  : yahka                 : Raspi                                    -  enabled
        system.adapter.zigbee.0                 : zigbee                : slave                                    -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2c00cdf9a5a4ed11826484582981d5c7-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.6.3
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "doorbird"     : 3.0.0    , installed 3.0.0
      Adapter    "govee-local"  : 0.2.8    , installed 0.2.7  [Updatable]
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
      Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
      Adapter    "iot"          : 3.3.0    , installed 3.4.5
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "knx"          : 2.0.30   , installed 2.0.30
      Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
      Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
      Adapter    "openknx"      : 0.9.0    , installed 0.9.0
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 9.2.0    , installed 9.2.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-2-widgets-weather-and-heating": 0.10.4, installed 0.10.4
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "vis-weather"  : 2.5.11   , installed 2.5.11
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Objects and States
      Objects:        15800
      States:         11895
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5610       610/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       257440     95009/iobroker.js-c
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       260134     95009/iobroker.js-c
      udp        0      0 0.0.0.0:41838           0.0.0.0:*                           104        888        490/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        886        490/avahi-daemon: r
      2025-05-14 11:02:16.763  - error: host.Raspi Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
      2025-05-14 11:02:16.763  - error: host.Raspi Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
      2025-05-14 11:02:16.763  - error: host.Raspi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1487:12)
      2025-05-14 11:02:16.763  - error: host.Raspi Caught by controller[0]:     at require (node:internal/modules/helpers:135:16)
      2025-05-14 11:02:16.763  - error: host.Raspi Caught by controller[0]: Node.js v22.15.0
      2025-05-14 11:02:16.763  - error: host.Raspi instance system.adapter.admin.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-05-14 11:02:16.763  - info: host.Raspi Restart adapter system.adapter.admin.0 because enabled
      2025-05-14 11:02:20.073  - info: host.Raspi instance system.adapter.vis-inventwo.0 in version "3.3.4" started with pid 96096
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]: /opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:   throw new Error("Cannot resolve adapter class");
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:   ^
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]: Error: Cannot resolve adapter class
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at resolveAdapterConstructor (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:96:9)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/@iobroker/adapter-core/build/cjs/utils.js:101:17)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1730:14)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at Object..js (node:internal/modules/cjs/loader:1895:10)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1465:32)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1282:12)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1487:12)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]:     at require (node:internal/modules/helpers:135:16)
      2025-05-14 11:02:20.252  - error: host.Raspi Caught by controller[0]: Node.js v22.15.0
      2025-05-14 11:02:20.252  - error: host.Raspi instance system.adapter.vis-inventwo.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-05-14 11:02:20.252  - info: host.Raspi Restart adapter system.adapter.vis-inventwo.0 because enabled
        Homoran Global Moderator Administrators @von.cartman last edited by Homoran
        @von-cartman sagte in WebUI - Admin (8081) u. Visu (8082) - nicht erreichbar:
        im Anhang der iob diag Auszug
        bitte keinen Anhang und keinen Auszug!
        die gesamte Langfassung hier in code-tags posten
        EDIT:
        So weit ich das auf dem Handy entziffern kann ist dein Dateisystem geschrottet
        von.cartman 1 Reply Last reply Reply Quote 0
        • von.cartman
          von.cartman @Homoran last edited by von.cartman
          @homoran Danke für die Schnelle einschäzung,
          aber 2 Fragen:
          1. woran erkenne ich es?
          2. Wie kann ich so etwas in Zukunft vorbeugen?
          EDIT:
          bzw. 3:
          3) kann ich die Instalation irgendwie noch retten bzw. aufs neues Sysem Übertragen?
          Homoran Codierknecht 2 Replies Last reply Reply Quote 0
            wenn du es wie gewünscht und verlinkt, in code-tags postest, kann ich es dir zitieren.
            Das ist auch ein Grund für dieses Vorgehen.
            Hast du ja auch gelesen.
            • Codierknecht
              Codierknecht Developer Most Active @von.cartman last edited by
              An sowas:
              und sowas:
              Hast Du dem Pi mal hart den Stecker gezogen? Stromausfall?
              Sowas mögen die nicht.
              Auch eine möglichst hochwertige SD-Karte ist vorteilhaft.
              • von.cartman
                von.cartman @Codierknecht last edited by
                @homoran sagte in WebUI - Admin (8081) u. Visu (8082) - nicht erreichbar:
                Hatte ich Probleme beim speichern von diesen Post, deshalb habe ich es als Anhang.
                Aber Danke für Hinweis, Bereits geändert.
                @codierknecht sagte in WebUI - Admin (8081) u. Visu (8082) - nicht erreichbar:
                Nein, und kein Stromausfall.
                hast Du ein Vorschlag für eine gute bzw sehr gute.?
