    4. piVCCU3 funktioniert plötzlich nicht mehr
      HerrFrodo last edited by HerrFrodo
      ich verwende einen Raspi 4B mit der IOBroker / piVCCU3 Installation.
      Plötzlich seit heute Morgen funktioniert die piVCCU3 nicht mehr.
      Zuerst habe ich 2 Neustarts versucht - IOBroker läuft aber die piVCCU3 nicht:
      Unter "sudo pivccu-info" stand ganz unten "STOPPED"
      pi@raspberrypi:~ $ sudo pivccu-info
      piVCCU version: 3.79.6-93
      OS:             Debian GNU/Linux 11 (bullseye)
      Kernel:         6.1.21-v8+ aarch64
      Kernel modules: Available
      Raw UART dev:   Available
      Rasp.Pi UART:   Assigned to GPIO pins
      HMRF Hardware:  RPI-RF-MOD
       Connected via: GPIO@fe201000.serial (/dev/raw-uart)
       Board serial:  xxxxxxxxxx
       Radio MAC:     xxxxxxxxxx
      HMIP Hardware:  RPI-RF-MOD
       SGTIN:         xxxxxxxxxxxxxxxx
       Radio MAC:     xxxxxxxxxxxxxxxxxx
      State:          STOPPED
      pi@raspberrypi:~ $
      Dann habe ich über raspibackup einen restore auf die SSD von Raspi durchgeführt - piVCCU3 funktioniert immer noch nicht.
      Dann habe ich versucht piVCCU3 zu deinstallieren:
      Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64
      The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law.
      Last login: Thu May 29 10:42:54 2025 from 192.168.1.92
      Wi-Fi is currently blocked by rfkill.
      Use raspi-config to set the country before use.
      Connected via: GPIO@fe201000.serial (/dev/raw-uart) Board serial: 5A4993EE43 Radio MAC: 0xFFEE43 HMIP Hardware: RPI-RF-MOD Connected via: GPIO@fe201000.serial (/dev/raw-uart)
      SGTIN: 3014F711A0001F5A4993EE43
      Radio MAC: 0xBAE6D9
      State: STOPPED
      pi@raspberrypi:~ $ sudo apt remove pivccu3 Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages were automatically installed and are no longer required:
      arch-test cloud-image-utils debootstrap
      detect-radio-module distro-info fakechroot genisoimage
      libaio1 libdistro-info-perl libfakechroot liblxc1 libpam-cgfs liburing1 lxc lxc-templates lxcfs mmdebstrap qemu-utils uidmap wait-sysfs-notify Use 'sudo apt autoremove' to remove them.
      The following packages will be REMOVED:
      pivccu3
      0 upgraded, 0 newly installed, 1 to remove and 11 not upgraded.
      1 not fully installed or removed.
      After this operation, 0 B of additional disk space will be used.
      Do you want to continue? [Y/n] Y
      (Reading database ... 102434 files and directories currently installed.) Removing pivccu3 (3.79.6-93) ...
      Stop piVCCU ... Done
      Disable services ... Done
      Remove symlinks ... Done
      Setting up pivccu-modules-raspberrypi (2.0-19) ...
      sed: can't read /var/lib/piVCCU/dtb/config.txt: No such file or directory
      dpkg: error processing package pivccu-modules-raspberrypi (--configure):
      installed pivccu-modules-raspberrypi package post-installation script subprocess returned error exit status 2 Errors were encountered while processing:
      E: Sub-process /usr/bin/dpkg returned an error code (1) pi@raspberrypi:~ $ sudo apt install pivccu3 Reading package lists... Done Building dependency tree... Done Reading state information... Done The following NEW packages will be installed:
      pivccu3
      0 upgraded, 1 newly installed, 0 to remove and 11 not upgraded.
      Need to get 161 MB of archives.
      Err:1 https://apt.pivccu.de/piVCCU stable/main arm64 pivccu3 arm64 3.81.5-94 Could not connect to apt.pivccu.de:443 (2a01:4f8:10b:2e4d:6::8), connection timed out Could not connect to apt.pivccu.de:443 (94.130.64.242), connection timed out
      E: Failed to fetch https://apt.pivccu.de/piVCCU/pool/main/p/pivccu3/pivccu3-3.81.5-94-arm64.deb Could not connect to apt.pivccu.de:443 (2a01:4f8:10b:2e4d:6::8), connection timed out Could not connect to apt.pivccu.de:443 (94.130.64.242), connection timed out
      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
      pi@raspberrypi:~ $
      Und wieder zu installieren:
        pivccu3
      pi@raspberrypi:~ $
      Irgendwie kann die Seite apt.pivccu.de nicht erreicht werden und mit dpkg scheint es auch Probleme zu geben.
      Weiß jemand einen Rat?
      Danke und viele Grüße!
        @Homoran hast Du hier bitte einen Tip für mich?
          pi@raspberrypi:~ $ sudo apt update
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
          Get:3 http://security.debian.org/debian-security bullseye-security InRelease [27                         .1 kB]
          Get:4 http://archive.raspberrypi.org/debian bullseye InRelease [39.0 kB]
          Get:5 https://apt.grafana.com stable InRelease [7661 B]
          Get:6 https://repos.influxdata.com/debian stable InRelease [6907 B]
          Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
          Get:8 http://security.debian.org/debian-security bullseye-security/main arm64 Pa                         ckages [366 kB]
          Get:9 http://security.debian.org/debian-security bullseye-security/main armhf Pa                         ckages [363 kB]
          Get:10 http://security.debian.org/debian-security bullseye-security/main Transla                         tion-en [245 kB]
          Get:11 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [330 k                         B]
          Get:12 http://archive.raspberrypi.org/debian bullseye/main arm64 Packages [323 k                         B]
          Get:13 https://repos.influxdata.com/debian stable/main arm64 Packages [16.4 kB]
          Err:14 https://apt.pivccu.de/piVCCU stable InRelease
            Could not connect to apt.pivccu.de:443 (2a01:4f8:10b:2e4d:6::8), connection ti                         med out Could not connect to apt.pivccu.de:443 (94.130.64.242), connection timed                          out
          Fetched 1769 kB in 31s (57.3 kB/s)
          13 packages can be upgraded. Run 'apt list --upgradable' to see them.
          W: Failed to fetch https://apt.pivccu.de/piVCCU/dists/stable/InRelease  Could no                         t connect to apt.pivccu.de:443 (2a01:4f8:10b:2e4d:6::8), connection timed out Co                         uld not connect to apt.pivccu.de:443 (94.130.64.242), connection timed out
          W: Some index files failed to download. They have been ignored, or old ones used                          instead.
          pi@raspberrypi:~ $
          pi@raspberrypi:~ $ sudo apt upgrade
          Calculating upgrade... Done
          The following packages will be upgraded:
            grafana libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dbg libc6-dev locales nodejs
            pivccu-modules-dkms pivccu3 python3-pkg-resources
          13 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          Need to get 375 MB of archives.
          After this operation, 109 MB of additional disk space will be used.
          Get:1 http://archive.raspberrypi.org/debian bullseye/main arm64 libc6-dbg arm64 2.31-13+rpt2+rpi1+deb11u12 [6746 kB]
          Get:2 http://security.debian.org/debian-security bullseye-security/main arm64 python3-pkg-resources all 52.0.0-4+deb11u2 [190 kB]
          Get:3 https://deb.nodesource.com/node_18.x nodistro/main arm64 nodejs arm64 18.20.8-1nodesource1 [28.9 MB]
          Get:4 http://archive.raspberrypi.org/debian bullseye/main arm64 libc-devtools arm64 2.31-13+rpt2+rpi1+deb11u12 [246 kB]
          Get:5 http://archive.raspberrypi.org/debian bullseye/main arm64 libc6-dev arm64 2.31-13+rpt2+rpi1+deb11u12 [2031 kB]
          Get:6 http://archive.raspberrypi.org/debian bullseye/main arm64 libc-dev-bin arm64 2.31-13+rpt2+rpi1+deb11u12 [273 kB]
          Get:7 http://archive.raspberrypi.org/debian bullseye/main arm64 libc6 arm64 2.31-13+rpt2+rpi1+deb11u12 [2458 kB]
          Get:8 http://archive.raspberrypi.org/debian bullseye/main arm64 libc-bin arm64 2.31-13+rpt2+rpi1+deb11u12 [743 kB]
          Get:9 http://archive.raspberrypi.org/debian bullseye/main arm64 libc-l10n all 2.31-13+rpt2+rpi1+deb11u12 [865 kB]
          Get:10 http://archive.raspberrypi.org/debian bullseye/main arm64 locales all 2.31-13+rpt2+rpi1+deb11u12 [4086 kB]
          Get:11 https://apt.grafana.com stable/main arm64 grafana arm64 12.0.1 [168 MB]
          Ign:12 https://apt.pivccu.de/piVCCU stable/main arm64 pivccu-modules-dkms all 1.0.85
          Err:13 https://apt.pivccu.de/piVCCU stable/main arm64 pivccu3 arm64 3.81.5-94
            Unable to connect to apt.pivccu.de:https:
          Err:12 https://apt.pivccu.de/piVCCU stable/main arm64 pivccu-modules-dkms all 1.0.85
          Fetched 215 MB in 33s (6524 kB/s)
          E: Failed to fetch https://apt.pivccu.de/piVCCU/pool/main/p/pivccu-modules-dkms/pivccu-modules-dkms-1.0.85.deb  Could not connect to apt.pivccu.de:443 (2a01:4f8:10b:2e4d:6::8), connection timed out Could not connect to apt.pivccu.de:443 (94.130.64.242), connection timed out
          E: Failed to fetch https://apt.pivccu.de/piVCCU/pool/main/p/pivccu3/pivccu3-3.81.5-94-arm64.deb  Unable to connect to apt.pivccu.de:https:
          pi@raspberrypi:~ $
          Offenbar ist die Seite apt.pivccu.de nicht mehr erreichbar.
          Wurde der Betrieb eingestellt oder gab es einen Angriff?
          Kommuniziert meine piVCCU3 heimlich mit dieser Seite????
            Thomas Braun Most Active @HerrFrodo last edited by
            @herrfrodo sagte in piVCCU3 funktioniert plötzlich nicht mehr:
            Der Server kann halt momentan nicht erreicht werden. Musst du mal bei pivccu schauen, ob da was bekannt ist.
            Von dort holt sich ganz unheimlich dein System die entsprechenden Updates.
            Anhand der weiteren Paketquellen kann ich dir aber schon mal sagen, dass dir die Kiste gerade absäuft.
            Bring das auf RaspberryOS 12 'Bookworm' (per Neuinstallation) und aktualisiere auch dein nodejs auf Version 20.
              Homoran Global Moderator Administrators @HerrFrodo last edited by
              nein!
              auf dieser Seite liegen die Installationsquellen
              Die ist korrekt.
              aber vielleicht nicht erreichbar.
              müsstest du mal mit ping oder traceroute testen.
              Hat aber nichts mit dem laufenden Betrieb zu tun.
                @Homoran & @Thomas-Braun
                Es ist nur sehr seltsam, dass so ganz plötzlich "ohne Updates und upgrades" die piVCCU3 nicht mehr funktioniert.
                  @herrfrodo
                  Das fragst du aber besser in einem Forum für pivccu.
                  Hier geht es um den ioBroker und der funktioniert ja offenbar.
                    HerrFrodo @Thomas Braun last edited by
                    ioBroker funktioniert gut.
                    Ich dachte nur ihr hättet einen Tip, warum die piVCCU3 so plötzlich nicht mehr funktioniert und selbst mit einem tagealten Backup nicht (zu einem Zeitpunkt als noch alles ging)
                      defekt?
                      Die haben so etwas sn sich, dass die plötzlich auftreten.
                      Hast du mal geprüft warum apt.pivccu nicht erreichbar ist?
                      H Thomas Braun 2 Replies Last reply Reply Quote 1
                        HerrFrodo @Homoran last edited by HerrFrodo
                        @homoran sagte in piVCCU3 funktioniert plötzlich nicht mehr:
                        Nein, aber offenbar antwortet Herr Reinert schon seit geraumer Zeit auch in Git nicht auf Issues. Vielleicht wurde einfach alles abgeschaltet..... wie sollte ich das prüfen?
                          Es gibt keinen auflösbaren Eintrag mehr im DNS und das Routing kann nicht funktionieren:
                          [thomas@roamer ~]$ nslookup pivccu.de
                          Server:         192.168.178.1
                          Address:        192.168.178.1#53
                          Non-authoritative answer:
                          *** Can't find pivccu.de: No answer
                          Da muss sich pivccu drum kümmern.
                            so schlimm ist es ja nicht
                            vor 3 Wochen hat er noch issues bearbeitet!
                              @Thomas-Braun
                              Wenn ich mit Backitup einen Backup von IOBroker mache, kann ich den nach Neuinstallation einspielen und alle Adapter und Instanzen etc. sind noch vorhanden?
                              So wie es aussieht muss ich auf die Debmatic umsteigen....und sinnvoll wäre eine Neuinstallation für den Raspi.
                                Das ist der Sinn und Zweck von Backups.
                                  debmatic ist auch nicht erreichbar.....krass
                                  pi@raspberrypi:~ $ sudo apt install debmatic
                                  E: Unable to locate package debmatic
                                  pi@raspberrypi:~ $ ^C
                                  pi@raspberrypi:~ $ wget -qO - https://debmatic.debian.net/debmatic/public.key | sudo apt-key add -
                                  echo "deb https://debmatic.debian.net/debmatic stable main" | sudo tee /etc/apt/sources.list.d/debmatic.list
                                  Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
                                  gpg: no valid OpenPGP data found.
                                  pi@raspberrypi:~ $ curl -fsSL https://debmatic.debian.net/debmatic/public.key | gpg --dearmor | sudo tee /usr/share/keyrings/debmatic-archive-keyring.gpg > /dev/null
                                  curl: (6) Could not resolve host: debmatic.debian.net
                                    Thomas Braun Most Active @HerrFrodo last edited by Thomas Braun
                                    @herrfrodo
                                    Keine Ahnung wo du die Befehle für das Repo her hast, auf
                                    https://github.com/alexreinert/debmatic/blob/master/docs/setup/raspberrypi.md
                                    steht jedenfalls was anderes...
                                    Nutzt dir aber im Moment nichts, denn:
                                    echad@chet:~ $ nslookup debmatic.de
                                    Server:         100.100.100.100
                                    Address:        100.100.100.100#53
                                    *** Can't find debmatic.de: No answer
                                    echad@chet:~ $
                                    debmatic.de ist also auch nicht erreichbar.
                                      Wildbill last edited by
                                      @HerrFrodo Es scheint, als hätte es die Server von Alex Reinert mal wieder vom Netz gebröselt, deshalb ist PiVCCU und Debmatic nicht erreichbar. Kommt bzw. kam immer wieder mal vor. Er hat das dann meistens zeitnah wieder repariert.
                                      Wenn es Dir arg brisant ist und Du kein Backup mehr hast, in dem Du PiVCCU lauffähig hast, bleibt Dir für eine Neuinstallation momentan eben noch Raspberrymatic. ist im Prinzip alles das Gleiche, nur halt ein wenig anders.
                                      Ansonsten warten, bis PiVCCU oder Debmatic wieder online ist.
                                      Gruss, Jürgen
                                        HerrFrodo @Wildbill last edited by
                                        @wildbill
                                        Seltsam ist, dass ich von jedem Tag einen Backup habe, wie z.B. von Vorgestern und die piVCCU3 läuft nicht. Irgendwie funkt die nach Hause und findet nichts.....jedenfalls wurden keine updates oder upgrades gemacht.
                                        Ich habe nun auf einem 2. P4 Raspberrymatic installiert und einen Backup von Backitup eingespielt und alles schein super zu funktionieren.
                                        Das waren nun 10h Ärger am Vatertag und ich konnte diese Zeit nicht mit meinen Kindern verbringen.
                                        ioBroker bleibt nun auf dem einen Pi4 und Raspberrymatic auf dem anderen Pi4.
                                        Homoran W 2 Replies Last reply Reply Quote 0
                                          was willst du uns damit sagen?
                                            Wildbill @HerrFrodo last edited by
                                            @herrfrodo Die PiVCCU läuft auch ohne Zugriff auf apt.pivccu.de, da das gar nicht aufgerufen wird. Meine PiVCCU3 hat heute beim allmonatlichen Update leider auch nicht updaten können, weil der Zugriff beim apt-Befehl eben ins Leere lief. Aber die restlichen Dinge vom Betriebssystem sind wieder auf Stand und nach einem Neustart ist sie ganz normal hochgefahren. Da wird allenfalls im Hintergrund mal geschaut, ob es eine neue Version gibt und die dann auf der Startseite eben angezeigt. Aber wenn das nicht läuft, funktioniert PiVCCU trotzdem.
                                            Hat es Dir vielleicht hardwaremäßig was verbogen? Beim Schauen, warum es nicht läuft den Raspi zu stark bewegt, das USB-Kabel gelockert, oder das Modul etwas vom Header gerutscht?
                                            Was kommt, wenn Du nach Einspielen des Backup mal
                                            sudo systemctl status pivccu
                                            oder
                                            sudo systemctl status pivccu3
                                            falls es eine PivCCU3 ist eingibst? Lässt sie sich evetl mit
                                            sudo systemctl start pivccu3
                                            starten?
                                            Gruss, Jürgen
                                            1671
