    4. Admin-Adapter Chrome geht nicht mehr. Firefox läuft.
    • sissiwup
      sissiwup last edited by sissiwup
      • Adaptername: admin
      • Adapterversion: 7.6.17
      • js-controller Version: 7.0.6
      • Admin Version: 7.6.17
      • Hardwaresystem: Intel
      • Arbeitsspeicher: 16GB
      • Festplattenart: SSD
      • Betriebssystem: Debian
      • Nodejs-Version: v20.19.0
      • NPM-Version: 10.8.2
      • Installationsart: Skript ?
      • Image, Docker genutzt: Nein
      Linux User bitte hier den Output von iob diag einfügen.
      aktueller Stand mit sudo apt update etc habe ich gemacht
      iobroker fix ist auch durch (ohne Fehler)
      iobroker stop
      dann iob diag:
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: zotac
             Icon name: computer-desktop
               Chassis: desktop 🖥️
                Kernel: Linux 6.1.0-33-amd64
          Architecture: x86-64
       Hardware Vendor: ASRock
        Hardware Model: H81M-DGS
      Firmware Version: P2.00
      OS is similar to:
      model name	: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
      Docker          : false
      Virtualization  : none
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       19:21:13 up 44 days, 14:15,  2 users,  load average: 5.66, 4.95, 4.07
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      This system needs to be REBOOTED!
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-05-29 19:21:14 CEST
                 Universal time: Thu 2025-05-29 17:21:14 UTC
                       RTC time: Thu 2025-05-29 17:21:14
                    NTP service: n/a
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      wh
      JAVA_HOME=/usr/lib/jvm/java-8-oracle/jre/
      HOME=/home/wh
      GROUPS=wh cdrom floppy sudo audio dip www-data video plugdev users netdev lpadmin scanner iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Mem:             16G        8.6G        370M        125M        7.9G        7.8G
      Swap:            34G        4.4G         30G
      Total:           50G         12G         30G
      Active iob-Instances: 	1
              15669 M total memory
               8192 M used memory
               3182 M active memory
               9583 M inactive memory
                353 M free memory
                 91 M buffer memory
               7485 M swap cache
              32767 M total swap
               4156 M used swap
              28611 M free swap
      top - 19:21:14 up 44 days, 14:15,  2 users,  load average: 5.66, 4.95, 4.07
      Tasks: 613 total,   1 running, 612 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  7.1 us, 14.3 sy,  0.0 ni, 42.9 id, 35.7 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15669.8 total,    343.6 free,   8205.5 used,   7581.1 buff/cache
      MiB Swap:  32768.0 total,  28611.1 free,   4156.9 used.   7464.3 avail Mem
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * iobroker.service loaded failed failed ioBroker Server
      * minidlna.service loaded failed failed MiniDLNA lightweight DLNA/UPnP-AV server
      * named.service    loaded failed failed BIND Domain Name Server
      3 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                             Type      Size  Used Avail Use% Mounted on
      udev                                   devtmpfs  7.7G     0  7.7G   0% /dev
      tmpfs                                  tmpfs     1.6G  7.2M  1.6G   1% /run
      /dev/sda1                              ext4      917G  279G  600G  32% /
      tmpfs                                  tmpfs     7.7G  1.2M  7.7G   1% /dev/shm
      tmpfs                                  tmpfs     5.0M   16K  5.0M   1% /run/lock
      /dev/loop3                             squashfs  105M  105M     0 100% /snap/core/17200
      /dev/loop4                             squashfs   56M   56M     0 100% /snap/core18/2846
      /dev/loop5                             squashfs   56M   56M     0 100% /snap/core18/2855
      /dev/loop9                             squashfs   74M   74M     0 100% /snap/core22/1908
      /dev/loop12                            squashfs  128K  128K     0 100% /snap/hello-world/29
      /dev/loop13                            squashfs   10M   10M     0 100% /snap/nmap/3582
      /dev/loop14                            squashfs   10M   10M     0 100% /snap/nmap/3885
      /dev/loop1                             squashfs   56M   56M     0 100% /snap/certbot/4557
      /dev/loop0                             squashfs   56M   56M     0 100% /snap/certbot/4482
      /dev/sdb5                              ext4      234G  141G   82G  64% /mnt/data
      /dev/sdd1                              ext4      7.3T  5.9T  1.1T  85% /mnt/mybac
      /dev/sdc1                              ext4      3.6T  2.3T  1.2T  68% /mnt/media
      /dev/loop6                             squashfs   67M   67M     0 100% /snap/core24/888
      /dev/loop10                            squashfs   74M   74M     0 100% /snap/core22/1963
      /dev/loop8                             squashfs   64M   64M     0 100% /snap/core20/2571
      /dev/loop7                             squashfs  105M  105M     0 100% /snap/core/17210
      /dev/loop2                             squashfs   67M   67M     0 100% /snap/core24/988
      /dev/loop11                            squashfs   64M   64M     0 100% /snap/core20/2582
      tmpfs                                  tmpfs     1.6G   36K  1.6G   1% /run/user/0
      //192.168.1.91/myshare/backup/backitup cifs       14T  547G   14T   4% /opt/iobroker/backups
      Show mounted filesystems:
      TARGET                  SOURCE                                 FSTYPE   OPTIONS
      /                       /dev/sda1                              ext4     rw,relatime,errors=remount-ro
      |-/snap/core/17200      /dev/loop3                             squashfs ro,nodev,relatime,errors=continue
      |-/snap/core18/2846     /dev/loop4                             squashfs ro,nodev,relatime,errors=continue
      |-/snap/core18/2855     /dev/loop5                             squashfs ro,nodev,relatime,errors=continue
      |-/snap/core22/1908     /dev/loop9                             squashfs ro,nodev,relatime,errors=continue
      |-/snap/hello-world/29  /dev/loop12                            squashfs ro,nodev,relatime,errors=continue
      |-/snap/nmap/3582       /dev/loop13                            squashfs ro,nodev,relatime,errors=continue
      |-/snap/nmap/3885       /dev/loop14                            squashfs ro,nodev,relatime,errors=continue
      |-/snap/certbot/4557    /dev/loop1                             squashfs ro,nodev,relatime,errors=continue
      |-/snap/certbot/4482    /dev/loop0                             squashfs ro,nodev,relatime,errors=continue
      |-/mnt/data             /dev/sdb5                              ext4     rw,relatime,errors=remount-ro
      |-/var/ftp              /dev/sdb5[/ftp]                        ext4     rw,relatime,errors=remount-ro
      |-/mnt/mybac            /dev/sdd1                              ext4     rw,relatime,errors=remount-ro
      |-/mnt/media            /dev/sdc1                              ext4     rw,relatime,errors=remount-ro
      |-/snap/core20/2582     /dev/loop11                            squashfs ro,nodev,relatime,errors=continue
      |-/snap/core/17210      /dev/loop7                             squashfs ro,nodev,relatime,errors=continue
      |-/snap/core24/888      /dev/loop6                             squashfs ro,nodev,relatime,errors=continue
      |-/snap/core24/988      /dev/loop2                             squashfs ro,nodev,relatime,errors=continue
      |-/snap/core20/2571     /dev/loop8                             squashfs ro,nodev,relatime,errors=continue
      |-/snap/core22/1963     /dev/loop10                            squashfs ro,nodev,relatime,errors=continue
      `-/opt/iobroker/backups //192.168.1.91/myshare/backup/backitup cifs     rw,relatime,vers=2.0,cache=strict,username=wh,uid=1008,forceuid,gid=1009,forcegid,addr=192.168.1.91,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=1
      /var:
      202G	/var/
      92G	/var/lib
      71G	/var/lib/influxdb/data/unifi/autogen
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      111G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.1G	/opt/iobroker/iobroker-data/
      878M	/opt/iobroker/iobroker-data/files
      617M	/opt/iobroker/iobroker-data/files/javascript.admin
      560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
      25M	/opt/iobroker/iobroker-data/objects.jsonl
      24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      8.4M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** ZigBee Settings ***
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.19.2
      /usr/bin/node 		v20.19.2
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.31.0
      nodejs:
        Installed: 20.19.2-1nodesource1
        Candidate: 20.19.2-1nodesource1
        Version table:
       *** 20.19.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      zotac               zotac (version: 7.0.6, hostname: zotac         , alive, uptime: 31)
      Core adapters versions
      js-controller: 	7.0.6
      admin: 		7.6.17
      javascript: 	8.8.3
      nodejs modules from github: 	0
      Adapter State
        system.adapter.admin.0                  : admin                 : zotac                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : zotac                                    -  enabled
        system.adapter.broadlink2.0             : broadlink2            : zotac                                    -  enabled
        system.adapter.dwd.0                    : dwd                   : zotac                                    -  enabled
        system.adapter.fritzbox.0               : fritzbox              : zotac                                    -  enabled
        system.adapter.hm-rega.0                : hm-rega               : zotac                                    -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : zotac                                    -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : zotac                                    -  enabled, port: 0
        system.adapter.hm-rpc.2                 : hm-rpc                : zotac                                    -  enabled, port: 0
        system.adapter.hm-rpc.3                 : hm-rpc                : zotac                                    -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : zotac                                    -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: zotac                                    - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : zotac                                    - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : zotac                                    - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : zotac                                    - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : zotac                                    - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : zotac                                    - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : zotac                                    - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : zotac                                    - disabled
        system.adapter.javascript.0             : javascript            : zotac                                    -  enabled
        system.adapter.mqtt.0                   : mqtt                  : zotac                                    -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.node-red.0               : node-red              : zotac                                    -  enabled, port: 1880, bind: 192.168.1.13
        system.adapter.pvforecast.0             : pvforecast            : zotac                                    -  enabled
        system.adapter.scenes.0                 : scenes                : zotac                                    -  enabled
        system.adapter.simple-api.0             : simple-api            : zotac                                    -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.sonoff.0                 : sonoff                : zotac                                    -  enabled, port: 2883, bind: 0.0.0.0
        system.adapter.sql.0                    : sql                   : zotac                                    -  enabled
        system.adapter.telegram.0               : telegram              : zotac                                    -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.trashschedule.0          : trashschedule         : zotac                                    -  enabled
        system.adapter.vis-bars.0               : vis-bars              : zotac                                    - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : zotac                                    - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : zotac                                    - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : zotac                                    - disabled
        system.adapter.vis-history.0            : vis-history           : zotac                                    - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : zotac                                    - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : zotac                                    - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : zotac                                    - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : zotac                                    - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : zotac                                    - disabled
        system.adapter.vis-map.0                : vis-map               : zotac                                    - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : zotac                                    - disabled
        system.adapter.vis-material-webfont.0   : vis-material-webfont  : zotac                                    - disabled
        system.adapter.vis-material.0           : vis-material          : zotac                                    - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : zotac                                    - disabled
        system.adapter.vis-metro.0              : vis-metro             : zotac                                    - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : zotac                                    - disabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : zotac                                    - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : zotac                                    - disabled
        system.adapter.vis-weather.0            : vis-weather           : zotac                                    - disabled
        system.adapter.vis.0                    : vis                   : zotac                                    -  enabled
        system.adapter.web.0                    : web                   : zotac                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : zotac                                    -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name          │ url                                                     │ auto upgrade │
      │ 0       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
      │ 1       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
      │ 2       │ 'stable'      │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 3       │ 'beta'        │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): live-stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: live-stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "solarviewdatareader": 1.2.1, installed 1.2.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "vis-weather"  : 2.5.11   , installed 2.5.11
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee2mqtt"  : 3.0.3    , installed 3.0.3
      Objects and States
      Objects: 	14022
      States: 	11542
      Thomas Braun A 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @sissiwup last edited by Thomas Braun
        @sissiwup sagte in Admin-Adapter Chrome geht nicht mehr. Firefox läuft.:
        Und die Ausgabe von iob diag ist nicht vollständig.
        Was ist das überhaupt für ein seltsames System, mit den ganzen snaps da?
        sissiwup 1 Reply Last reply Reply Quote 0
          AlexHaxe @sissiwup last edited by
          @sissiwup Dein Chrome läuft nicht zufällig auf MacOS? Falls ja, schau mal hier: https://forum.iobroker.net/topic/77977/gelöst-chrome-auf-mac-öffnet-keine-lokalen-webseiten
          sissiwup 1 Reply Last reply Reply Quote 1
          • sissiwup
            @thomas-braun sagte in Admin-Adapter Chrome geht nicht mehr. Firefox läuft.:
            ja, aber das ist nur der neue Kernel der bei den Updates mitgekommen ist.
            Da dran lag es nicht. Ich habe bei Chrome den Cache gelöscht,
            jetzt geht es wieder.
            Aber Danke für den schnellen Service ...
            • sissiwup
              sissiwup @Thomas Braun last edited by
              die Ausgabe habe ich am Ende abgeschnitten, da das Forum sie sonst als zu lang angesehen hat.
              Ist ein kleiner linux-Server mit allerhand docker etc.
              • sissiwup
                sissiwup @AlexHaxe last edited by
                @alexhaxe sagte in Admin-Adapter Chrome geht nicht mehr. Firefox läuft.:
                ja, ist Chrome auf Mac. Lief aber bis zum Update von admin ohne Probleme.
                  @sissiwup said in Admin-Adapter Chrome geht nicht mehr. Firefox läuft.:
                  trotzdem würde ich die Lösung aus dem verlinkten Thread zumindest prüfen, weil entweder trifft es nicht zu, und dann hat man es zumindest ausgeschlossen, oder es löst das Problem.
                  • mcm1957
                    mcm1957 @AlexHaxe last edited by
                    Und da war auch eine MAC Einstellung schuld:
                    https://forum.iobroker.net/topic/81183/iobroker-geht-im-chrome-nicht-mehr/37
