    4. IOT Cannot read properties of undefined
    • Negalein
      Hallo
      Mir ist heute bei einer von 2 IOT-Instanzen der untere Fehler aufgefallen.
      Diese Instanz wird auch nicht mehr grün.
      Ich werde aus dem Log nicht schlau.
      IOT 3.5.1
      Admin 7.6.18
      Node 20.19.1
      NPM 10.8.2
      Controller: 7.0.6
      iot.1 2025-06-02 18:09:07.801	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      iot.1 2025-06-02 18:09:07.801	debug	Plugin sentry destroyed
      iot.1 2025-06-02 18:09:07.801	info	terminating
      iot.1 2025-06-02 18:09:07.781	error	Cannot read properties of undefined (reading 'iot.1')
      iot.1 2025-06-02 18:09:07.781	error	TypeError: Cannot read properties of undefined (reading 'iot.1') at getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:40:47) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2571:41) at processImmediate (node:internal/timers:485:21)
      iot.1 2025-06-02 18:09:07.781	error	uncaught exception: Cannot read properties of undefined (reading 'iot.1')
      iot.1 2025-06-02 18:09:07.169	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.1 2025-06-02 18:09:07.037	info	starting. Version 3.5.1 in /opt/iobroker/node_modules/iobroker.iot, node: v20.19.1, js-controller: 7.0.6
      iot.1 2025-06-02 18:09:06.714	debug	Plugin sentry Initialize Plugin (enabled=true)
      iot.1 2025-06-02 18:08:35.067	info	Connection changed: connect "laura_xxxxxxxxx"
      iot.1 2025-06-02 18:08:34.832	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      iot.1 2025-06-02 18:08:34.832	debug	Plugin sentry destroyed
      iot.1 2025-06-02 18:08:34.831	info	terminating
      iot.1 2025-06-02 18:08:34.819	error	Cannot read properties of undefined (reading 'iot.1')
      iot.1 2025-06-02 18:08:34.819	error	TypeError: Cannot read properties of undefined (reading 'iot.1') at getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:40:47) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2571:41) at processImmediate (node:internal/timers:485:21)
      iot.1 2025-06-02 18:08:34.818	error	uncaught exception: Cannot read properties of undefined (reading 'iot.1')
      iot.1 2025-06-02 18:08:34.160	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.1 2025-06-02 18:08:34.055	info	starting. Version 3.5.1 in /opt/iobroker/node_modules/iobroker.iot, node: v20.19.1, js-controller: 7.0.6
      iot.1 2025-06-02 18:08:33.747	debug	Plugin sentry Initialize Plugin (enabled=true)
      iot.1 2025-06-02 18:08:01.817	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      iot.1 2025-06-02 18:08:01.817	debug	Plugin sentry destroyed
      iot.1 2025-06-02 18:08:01.817	info	terminating
      iot.1 2025-06-02 18:08:01.807	error	Cannot read properties of undefined (reading 'iot.1')
      iot.1 2025-06-02 18:08:01.807	error	TypeError: Cannot read properties of undefined (reading 'iot.1') at getSmartName (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:40:47) at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.iot/lib/alexaSmartHomeV2.js:2571:41) at processImmediate (node:internal/timers:485:21)
      iot.1 2025-06-02 18:08:01.806	error	uncaught exception: Cannot read properties of undefined (reading 'iot.1')
      iot.1 2025-06-02 18:08:01.237	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      iot.1 2025-06-02 18:08:01.068	info	starting. Version 3.5.1 in /opt/iobroker/node_modules/iobroker.iot, node: v20.19.1, js-controller: 7.0.6
      iot.1 2025-06-02 18:08:00.705	debug	Plugin sentry Initialize Plugin (enabled=true)
        Lucky_ESA Developer Most Active @Negalein last edited by
        @negalein Schau mal hier
        • Negalein
          Negalein Global Moderator @Lucky_ESA last edited by
          @lucky_esa
          Danke, hatte ich nicht gefunden.
          Ich benötige den Hacken aktiv wegen 2 Konten.
          Sonst schaltet mir die Kleine zuviel.
            @negalein sagte in IOT Cannot read properties of undefined:
            @lucky_esa
            Ein Issue wurde auch schon erstellt.
