    4. SQL Adampter verbindet sich nicht
      Bastler 1 last edited by
      ich musste meinen iobroker neu aufstezen. Dank Backup j fast kein Problem. Nach der anleitung von @haus-automatisierung habe ich dann Maridb neu installiert Benutzer angelegt und Rechte vergeben. lief alles ohne Fehlermeldungen durch. Als ich ich die neuen Zugangsdaten in den SQL-Adapter eingegeben habe verbindet diese sich nun nicht mehr. Wenn ich die Verbindung teste wird mir "AggregateError" angezeit. Wo liegt jetzt mein Fehler?
      Gruß Rene
        arteck Developer Most Active @Bastler 1 last edited by
        @bastler-1
        steht im LOG mehr ??
          Bastler 1 @arteck last edited by Bastler 1
          @arteck ausser dem erstgenannten nur noch das:
          sql has an invalid jsonConfig: [{"instancePath":"/items/dbTab/items/_testConnection/type","schemaPath":"#/definitions/componentType/enum","keyword":"enum","params":{"allowedValues":["accordion","alive","autocomplete","autocompleteSendTo","certificate","certificates","checkLicense","checkbox","chips","color","coordinates","cron","custom","datePicker","deviceManager","divider","file","fileSelector","func","header","icon","image","imageSendTo","infoBox","instance","interface","ip","jsonEditor","language","number","oauth2","objectId","panel","password","pattern","port","qrCode","room","select","selectSendTo","sendTo","setState","slider","state","staticImage","staticInfo","staticLink","staticText","table","text","textSendTo","timePicker","user","uuid"]},"message":"must be equal to one of the allowed values"},{"instancePath":"/items/dbTab","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
          Als ich gerade noch mals einen Benutzer anlegen wollte kam folgenede Fehlermeldung:
          ERROR 1290 (HY000): The MariaDB server is running with the --skip-grant-tables option so it cannot execute this statement
          was hab ich jetzt kaputt gemacht???????
            so nachdem ich gefühlt google leergesucht habe, habe ich eine Lösung gefunden.
            warum auch immer war "MYSQLD_OPTS" mit "--skip-grant-tables" aktiviert.
            Nach einem
            sudo systemctl set-environment MYSQLD_OPTS=""
            gefolgt von einem
            sudo service mysql restart
            ging der Adapter auf grün. Ich konnte mich mit HEIDISQL auf die DB verbinden. Das DB-Backup wird gerade eingespielt.
            Thema hat damit für mich erledigt.
            Gruß Rene
              Homoran Global Moderator Administrators @Bastler 1 last edited by
              @bastler-1 sagte in SQL Adampter verbindet sich nicht:
              das klingt nicht nach ioBroker, und auch nicht nach Noob-Niveau.
              ist das jetzt SQL pur, oder der Adapter?
                arteck Developer Most Active @Homoran last edited by
                @homoran das ist mysql kofiguration
                  Homoran Global Moderator Administrators @arteck last edited by
                  @arteck
                  Danke!
                  dann schieb ich mal.
