    4. Unable to update node.js v20.19.1 to v20.19.2
    • G
      ggansde last edited by
      Folgende Fehlermeldung erscheint:
      rm: cannot remove '/etc/apt/keyrings/nodesource.gpg 2> /dev/null': No such file or directory
      Waiting for ioBroker to shut down - Give me a minute...
      Removing dfsg-nodejs
      *** These repos are active on your system:
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://repos.influxdata.com/debian stable InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 https://repos.influxdata.com/debian bullseye InRelease
      Reading package lists... Done
      *** Installing ca-certificates, curl and gnupg, just in case they are missing.
      *** Creating new /etc/apt/sources.list.d/nodesource.list and pinning source
      deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
      Package: nodejs
      Pin: origin deb.nodesource.com
      Pin-Priority: 1001
      *** These repos are active after the adjustments:
      Get:6 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
      Get:7 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [11.4 kB]
      Fetched 23.5 kB in 1s (16.4 kB/s)
      Installing nodejs now!
      Installing nodejs!
      COMPATIBILITY CHECK IN PROGRESS
      add fsevents 2.3.3
      added 1 package in 5s
      102 packages are looking for funding
        run `npm fund` for details
      We tried our best to fix your nodejs. Please run iob diag again to verify.
      *** RESTARTING ioBroker NOW! ***
       Please refresh or restart your browser in a few moments.
      pi@iobroker:~ $ node -v
      v20.19.1
        Thomas Braun Most Active @ggansde last edited by Thomas Braun
        @ggansde
        Innerhalb einer Major-Version macht man das auch nicht über iob nodejs-update sondern über den Paketmanager deines Systems.
        sudo apt update
        sudo apt full-upgrade
        liefert?
        Edit: Ich sehe gerade, da war zuvor die Quelle von nodesource gar nicht angelegt. Vermutlich hattest/hast du da die dfsg-Version am Wickel (oder eine am Paketmanager vorbei gezirkelte Installation).
        Schau mal per
        iob diag
        nach der konkreten Situation.
