    4. [Fehler] RegExp Range out of order in character class
    • hg6806
      hg6806 Most Active last edited by
      Ja, irgendwie ist mein System gecrashed, da dachte ich das liegt an einer korrupten SD Karte.
      Also, Backup neu aufgespielt und wieder uPnP installiert und konfiguriert und wieder gecrashed.
      D.h. Admin läuft aber kein VIS. Hier die Fehlermeldung:
      host.ioBroker-Pi3	2017-10-22 09:23:25.510	error	instance system.adapter.web.0 terminated with code 0 (OK)
      Caught	2017-10-22 09:23:25.509	error	by controller[0]: at process._tickCallback (internal/process/next_tick.js:104:9)
      Caught	2017-10-22 09:23:25.509	error	by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:73:7)
      Caught	2017-10-22 09:23:25.509	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io/lib/socket.js:503:12
      Caught	2017-10-22 09:23:25.509	error	by controller[0]: at Socket.emit (events.js:191:7)
      Caught	2017-10-22 09:23:25.508	error	by controller[0]: at emitTwo (events.js:106:13)
      Caught	2017-10-22 09:23:25.508	error	by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:943:25)
      Caught	2017-10-22 09:23:25.508	error	by controller[0]: at subscribe (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:285:42)
      Caught	2017-10-22 09:23:25.507	error	by controller[0]: at RegExp (native)
      Caught	2017-10-22 09:23:25.506	error	by controller[0]: SyntaxError: Invalid regular expression: /upnp\.0\.DENON:[AVR-3311]\.MediaRenderer\.Alive/: Range out of order in character class
      web.0	2017-10-22 09:23:25.422	info	terminating
      web.0	2017-10-22 09:23:25.390	info	terminated http server on port 8082
      web.0	2017-10-22 09:23:25.388	info	terminating http server on port 8082
      web.0	2017-10-22 09:23:25.385	error	at process._tickCallback (internal/process/next_tick.js:104:9)
      web.0	2017-10-22 09:23:25.385	error	at _combinedTickCallback (internal/process/next_tick.js:73:7)
      web.0	2017-10-22 09:23:25.385	error	at /opt/iobroker/node_modules/iobroker.web/node_modules/socket.io/lib/socket.js:503:12
      web.0	2017-10-22 09:23:25.385	error	at Socket.emit (events.js:191:7)
      web.0	2017-10-22 09:23:25.385	error	at emitTwo (events.js:106:13)
      web.0	2017-10-22 09:23:25.385	error	at Socket. (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:943:25)
      web.0	2017-10-22 09:23:25.385	error	at subscribe (/opt/iobroker/node_modules/iobroker.web/node_modules/iobroker.socketio/lib/socket.js:285:42)
      web.0	2017-10-22 09:23:25.385	error	at RegExp (native)
      web.0	2017-10-22 09:23:25.385	error	SyntaxError: Invalid regular expression: /upnp\.0\.DENON:[AVR-3311]\.MediaRenderer\.Alive/: Range out of order in character class
      web.0	2017-10-22 09:23:25.384	error	uncaught exception: Invalid regular expression: /upnp\.0\.DENON:[AVR-3311]\.MediaRenderer\.Alive/: Range out of order in character class
      Vielleicht kann jemand etwas damit anfangen.
      Habe den Adapter gestoppt, auch das Script und neu gebootet, Fehler bleibt bestehen.
      • AlCalzone
        @hg6806:
        /upnp.0.DENON:[AVR-3311].MediaRenderer.Alive/: Range out of order in character class `
        Da hat der Entwickler vergessen, die eckigen Klammern zu escapen.
        • hg6806
          ? was meinst du damit?
          • Jey Cee
            @AlCalzone:
            @hg6806:
            /upnp.0.DENON:[AVR-3311].MediaRenderer.Alive/: Range out of order in character class Da hat der Entwickler vergessen, die eckigen Klammern zu escapen.
            Ja das dachte ich mir auch, leider weiss ich nicht wo.
            Aber was mich irritiert:
            @hg6806:
            Habe den Adapter gestoppt, auch das Script und neu gebootet, Fehler bleibt bestehen. `
            Und was noch merkwürdig ist, ich selbst hab ebenfalls ein Gerät wo im Namen Eckige Klammern vorkommen und hatte das Problem noch nie.
            @hg6806: Kannst du bitte mal den Log level des Adapters auf "debug" stellen und das log bereit stellen. Dann finde ich hoffentlich die stelle an der es hackt.
            • AlCalzone
              @Jey Cee:
              Ja das dachte ich mir auch, leider weiss ich nicht wo. `
              Na, die eckigen Klammern 😉
              falsch: /upnp\.0\.DENON:[AVR-3311]\.MediaRenderer\.Alive/
              richtig: /upnp\.0\.DENON:[AVR-3311]\.MediaRenderer\.Alive/
              Oder um ganz sicher zu gehen:
              /upnp\.0\.DENON\:[AVR\-3311]\.MediaRenderer\.Alive/
              • Jey Cee
                :roll: das war mir schon klar, nur wo in dem Code des Adapters das Problem sitzt.
                Im Code des Adapters baue ich nirgendwo eine solche RegExp zusammen.
                • AlCalzone
                  Mögliche Zeilen:
                  https://github.com/Jey-Cee/ioBroker.upn … n.js#L1597
                  https://github.com/Jey-Cee/ioBroker.upn ... n.js#L1340
                  https://github.com/Jey-Cee/ioBroker.upn ... n.js#L1650
                    @AlCalzone:
                    @hg6806:
                    Habe es gemacht jetzt:
                    https://github.com/ioBroker/ioBroker.so … 48824eL266
                    • hg6806
                      So, System neu aufgesetzt. Lag dann wohl doch nicht an der SD Karte, wobei ich das Thema auch mal angehen werde.
                      Wo liegt denn jetzt der Fehler an mir oder dem Adapter?
                      Der Log Level stand auf Debug. Mehr habe ich leider nicht mehr 😞
                        @hg6806:
                        Der Log Level stand auf Debug. Mehr habe ich leider nicht mehr 😞 `
                        Mach mal:
                        cd /opt/iobroker/node_modules/iobroker.web
                        npm i iobroker.socketio@1.8.5 --production
                        cd /opt/iobroker
                        iobroker restart web
                        • hg6806
                          Erledigt, socket IO Adapter steht im Admin komischerweise trotz Aktualisierung noch immer auf 1.8.3
                          1152
