    4. Pflege des Betriebssystems
    5. pnpm Fehler
    pnpm Fehler
    • Autodidakt
      Autodidakt last edited by Autodidakt
      Hallo allerseits.
      ich wollte gerade den Umstieg auf Zigbee2Mqtt wagen.
      Bei der Installation von
      npm install -g pnpm
      kommt folgende Fehlermeldung:
      pi@pi4-Master:~ $ npm install -g pnpm
      npm error code EACCES
      npm error syscall rename
      npm error path /usr/lib/node_modules/pnpm
      npm error dest /usr/lib/node_modules/.pnpm-H0EZVZtB
      npm error errno -13
      npm error Error: EACCES: permission denied, rename '/usr/lib/node_modules/pnpm' -> '/usr/lib/node_modules/.pnpm-H0EZVZtB'
      npm error     at async Object.rename (node:internal/fs/promises:782:10)
      npm error     at async moveFile (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/move-file.js:30:5)
      npm error     at async Promise.allSettled (index 0)
      npm error     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:337:11)
      npm error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:142:5)
      npm error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:149:5)
      npm error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:208:9)
      npm error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:67:5) {
      npm error   errno: -13,
      npm error   code: 'EACCES',
      npm error   syscall: 'rename',
      npm error   path: '/usr/lib/node_modules/pnpm',
      npm error   dest: '/usr/lib/node_modules/.pnpm-H0EZVZtB'
      npm error }
      npm error
      npm error The operation was rejected by your operating system.
      npm error It is likely you do not have the permissions to access this file as the current user
      npm error
      npm error If you believe this might be a permissions issue, please double-check the
      npm error permissions of the file and its containing directories, or try running
      npm error the command again as root/Administrator.
      npm error A complete log of this run can be found in: /home/pi/.npm/_logs/2025-06-22T11_48_20_659Z-debug-0.log
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@10.9.2
      2 info using node@v22.16.0
      3 silly config load:file:/usr/lib/node_modules/npm/npmrc
      4 silly config load:file:/home/pi/.npmrc
      5 silly config load:file:/usr/etc/npmrc
      6 verbose title npm install pnpm
      7 verbose argv "install" "--global" "pnpm"
      8 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs/2025-06-22T12_17_32_738Z-
      9 verbose logfile /home/pi/.npm/_logs/2025-06-22T12_17_32_738Z-debug-0.log
      10 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
      11 silly logfile start cleaning logs, removing 1 files
      12 silly logfile done cleaning log files
      13 silly idealTree buildDeps
      14 silly fetch manifest pnpm@*
      15 silly packumentCache full:https://registry.npmjs.org/pnpm cache-miss
      16 http fetch GET 200 https://registry.npmjs.org/pnpm 371ms (cache revalidated)
      17 silly packumentCache full:https://registry.npmjs.org/pnpm set size:5092597 disposed:false
      18 silly placeDep ROOT pnpm@10.12.1 OK for:  want: *
      19 silly reify mark retired [ '/usr/lib/node_modules/pnpm', '/usr/bin/pnpm', '/usr/bin/pnpx' ]
      20 silly reify moves {
      20 silly reify   '/usr/lib/node_modules/pnpm': '/usr/lib/node_modules/.pnpm-H0EZVZtB',
      20 silly reify   '/usr/bin/pnpm': '/usr/bin/.pnpm-JTllyBcj',
      20 silly reify   '/usr/bin/pnpx': '/usr/bin/.pnpx-MALdymCV'
      20 silly reify }
      21 verbose stack Error: EACCES: permission denied, rename '/usr/lib/node_modules/pnpm' -> '/usr/lib/node_modules/.pnpm-H0EZVZtB'
      21 verbose stack     at async Object.rename (node:internal/fs/promises:778:10)
      21 verbose stack     at async moveFile (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/move-file.js:30:5)
      21 verbose stack     at async Promise.allSettled (index 0)
      21 verbose stack     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:325:11)
      21 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:142:5)
      21 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
      21 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
      21 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5)
      22 error code EACCES
      23 error syscall rename
      24 error path /usr/lib/node_modules/pnpm
      25 error dest /usr/lib/node_modules/.pnpm-H0EZVZtB
      26 error errno -13
      27 error Error: EACCES: permission denied, rename '/usr/lib/node_modules/pnpm' -> '/usr/lib/node_modules/.pnpm-H0EZVZtB'
      27 error     at async Object.rename (node:internal/fs/promises:778:10)
      27 error     at async moveFile (/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/move-file.js:30:5)
      27 error     at async Promise.allSettled (index 0)
      27 error     at async [reifyPackages] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:325:11)
      27 error     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:142:5)
      27 error     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:150:5)
      27 error     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:207:9)
      27 error     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:74:5) {
      27 error   errno: -13,
      27 error   code: 'EACCES',
      27 error   syscall: 'rename',
      Was kann ich tun?
      Mfg
      Tom
        Thomas Braun Most Active @Autodidakt last edited by
        @autodidakt
        Der user 'pi' darf nicht nach /usr/lib/ schreiben, das darf nur root.
        nodemodule, die global verfügbar sein sollen muss also der root dort hinlegen.
        Wird dir aber auch angesagt:
        Also:
        sudo npm install -g pnpm
        Autodidakt 1 Reply Last reply Reply Quote 0
        • Autodidakt
          Autodidakt @Thomas Braun last edited by
          @thomas-braun Danke, wieder was gelernt...
          • Autodidakt
            Und schon kommt das nächste Problem.
            Zigbee2Mqtt will ums verrecken nicht starten.
            pi@pi4-Master:/opt/zigbee2mqtt $ pnpm start
            > zigbee2mqtt@2.4.0 start /opt/zigbee2mqtt
            > node index.js
            Starting Zigbee2MQTT without watchdog.
            [2025-06-23 16:21:03] info:     z2m: Logging to console, file (filename: log.log)
            [2025-06-23 16:21:04] info:     z2m: Starting Zigbee2MQTT version 2.4.0 (commit #bdb94da4)
            [2025-06-23 16:21:04] info:     z2m: Starting zigbee-herdsman (4.1.0)
            [2025-06-23 16:21:04] info:     zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"Itead","serialNumber":"ac315ae1c912ef1184ed6fb8bf9df066","pnpId":"usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_ac315ae1c912ef1184ed6fb8bf9df066-if00-port0","vendorId":"10c4","productId":"ea60"} => ember: 4
            [2025-06-23 16:21:04] info:     zh:ember: Using default stack config.
            [2025-06-23 16:21:04] info:     zh:ember: ======== Ember Adapter Starting ========
            [2025-06-23 16:21:04] info:     zh:ember:ezsp: ======== EZSP starting ========
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash: ======== ASH Adapter reset ========
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash: ASH COUNTERS since last clear:
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Total frames: RX=0, TX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Cancelled   : RX=0, TX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   DATA frames : RX=0, TX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   DATA bytes  : RX=0, TX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Retry frames: RX=0, TX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   ACK frames  : RX=0, TX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   NAK frames  : RX=0, TX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   nRdy frames : RX=0, TX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   CRC errors      : RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Comm errors     : RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Length < minimum: RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Length > maximum: RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Bad controls    : RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Bad lengths     : RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Bad ACK numbers : RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Out of buffers  : RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Retry dupes     : RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   Out of sequence : RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash:   ACK timeouts    : RX=0
            [2025-06-23 16:21:04] info:     zh:ember:uart:ash: ======== ASH stopped ========
            [2025-06-23 16:21:04] error:    zh:ember:uart:ash: Failed to init port with error Error: Error Resource temporarily unavailable Cannot lock port
            [2025-06-23 16:21:04] error:    z2m: Error while starting zigbee-herdsman
            [2025-06-23 16:21:04] error:    z2m: Failed to start zigbee-herdsman
            [2025-06-23 16:21:04] error:    z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
            [2025-06-23 16:21:04] error:    z2m: Exiting...
            [2025-06-23 16:21:04] error:    z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
                at EmberAdapter.initEzsp (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:666:19)
                at EmberAdapter.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1548:24)
                at Controller.start (/opt/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.1.0/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
                at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:71:27)
                at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:102:13)
                at start (/opt/zigbee2mqtt/index.js:149:5)
             ELIFECYCLE  Command failed with exit code 1.
            Hier die Config
            version: 4
            mqtt:
              base_topic: zigbee2mqtt
              server: mqtt://localhost:1883
              user: xxxxxxxx
              password: xxxxxxxx
            serial:
              port: /dev/ttyUSB0
              adapter: ember
              baudrate: 115200
              rtscts: false
            advanced:
              log_level: info
              channel: 11
              network_key:
                - 223
                - 25
                - 181
                - 70
                - 48
                - 140
                - 164
                - 218
                - 20
                - 78
                - 112
                - 96
                - 167
                - 137
                - 205
                - 12
              pan_id: 53749
              ext_pan_id:
                - 230
                - 19
                - 60
                - 177
                - 44
                - 17
                - 21
                - 12
            frontend:
              enabled: true
              port: 8080
            homeassistant:
              enabled: false
            Muss ich evtl die Porteinstellung ändern?
              @autodidakt
              Bist du sicher, dass die Choose so installiert werden soll?
              • Autodidakt
                @thomas-braun Asolut nicht.
                Ich humpel hald jetz mal ein wenig hin und her.
                Ich brauche das Zigbee2Mqtt weil ich einen Feuchtesensor einbinden muss.
                Ich hab mich vor einiger zeit schon mal eingelesen, bin aber dann doch beim alten zigbee geblieben.
                Ich hab mich an die Anleitungen gehalten, die ich gefunden hab. Moquitto läuft schon mal.
                  Homoran Global Moderator Administrators @Autodidakt last edited by
                  @autodidakt sagte in pnpm Fehler:
                  im zigbee Adapter werkelt auch due zigbee²mqtt Engine!
                  Wwofü genau benötigst du Z2m?
                  was geht nicht mit dem Zigbee Adapter?
                  • Autodidakt
                    Autodidakt @Homoran last edited by
                    für den da.
                    https://www.zigbee2mqtt.io/devices/3RSM0147Z.html
                      @autodidakt und
                      @homoran sagte in pnpm Fehler:
                      • Autodidakt
                        Ich hab das wohl falsch verstanden. Ich dacht dafür brauch ich Z2M...
                        Dummer weise habe ich meinem Sonoff Zigbee 3.0 heute eine neue Firmware verpasst, nun läuft auch der Zigbee Adapter nicht mehr.🙄
                          @autodidakt womit wolltest du den z2m betreiben?
                          welchen Koordinator hast du denn noch?
                          • Autodidakt
                            Autodidakt @Homoran last edited by Autodidakt
                            @homoran Der Sonoff war mein Koordinator, oder täusch ich mich?
                            Mit dem wollte ich Z2M betreiben.
                              Homoran Global Moderator Administrators @Autodidakt last edited by Homoran
                              @autodidakt ....und jetzt hast du gar nichts mehr 😞 ?
                              Dann musdt du den sonoff wiederbeleben oder was anderes kaufen.
                              • Autodidakt
                                @homoran Ich versuch Ihn grade neu zu flashen. Ist aber nicht ganz einfach in dem ganzen Firmware-Gewirr.
                                Wenn das nichts wird, muss hald ein neuer her.
                                • Autodidakt
                                  Hallo nochmal.
                                  Ich habe jetzt einen neuen Stick (Zigbee 3.0 USB Dongle Plus) den Zigbee Adapter V3.0.1 neu installiert und versuche nun meine Geräte neu anzulernen.
                                  Leider kommt immer ein Herdsman Fehler.
                                  zigbee.0
                                  2025-06-25 11:06:24.603	warn	ELEVATED:I02 (a0ca) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:24.602	warn	ELEVATED:I02 (a0ca) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:24.601	warn	ELEVATED:I01 (a0ca) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined'
                                  zigbee.0
                                  2025-06-25 11:06:24.598	warn	ELEVATED:I02 (a0c2) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:24.597	warn	ELEVATED:I02 (a0c2) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:24.596	warn	ELEVATED:I01 (a0c2) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined'
                                  zigbee.0
                                  2025-06-25 11:06:24.592	warn	ELEVATED:I02 (a0c0) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  zigbee.0
                                  2025-06-25 11:06:24.592	warn	ELEVATED:I01 (a0c0) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined'
                                  zigbee.0
                                  2025-06-25 11:06:24.591	warn	ELEVATED:I02 (a0b3) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:24.590	warn	ELEVATED:I02 (a0b3) value generated '168' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:24.589	warn	ELEVATED:I01 (a0b3) message received '{"linkquality":168}' from device ffffb40e060599a0 type 'undefined'
                                  zigbee.0
                                  2025-06-25 11:06:24.587	warn	ELEVATED:I01 (a0ca) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":171,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":97,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-06-25 11:06:24.578	warn	ELEVATED:I01 (a0c2) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":15},"linkquality":168,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":96,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-06-25 11:06:24.576	warn	ELEVATED:I01 (a0c0) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":168,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":95,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-06-25 11:06:24.565	warn	ELEVATED:I01 (a0b3) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":2869},"linkquality":168,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":94,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-06-25 11:06:09.592	warn	ELEVATED:I02 (661d) value generated '174' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  zigbee.0
                                  2025-06-25 11:06:09.591	warn	ELEVATED:I01 (661d) message received '{"linkquality":174}' from device ffffb40e060599a0 type 'undefined'
                                  zigbee.0
                                  2025-06-25 11:06:09.578	warn	ELEVATED:I02 (6611) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:09.576	warn	ELEVATED:I02 (6611) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:09.575	warn	ELEVATED:I01 (6611) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined'
                                  zigbee.0
                                  2025-06-25 11:06:09.574	warn	ELEVATED:I02 (660e) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:09.573	warn	ELEVATED:I02 (660e) value generated '171' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:09.573	warn	ELEVATED:I01 (660e) message received '{"linkquality":171}' from device ffffb40e060599a0 type 'undefined'
                                  zigbee.0
                                  2025-06-25 11:06:09.566	warn	ELEVATED:I01 (661d) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryPercentageRemaining":200},"linkquality":174,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":93,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-06-25 11:06:09.553	warn	ELEVATED:I01 (6611) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"batteryVoltage":15},"linkquality":171,"groupID":0,"cluster":"genPowerCfg","meta":{"zclTransactionSequenceNumber":92,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-06-25 11:06:09.551	warn	ELEVATED:I01 (660e) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":0},"linkquality":171,"groupID":0,"cluster":"msRelativeHumidity","meta":{"zclTransactionSequenceNumber":91,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  zigbee.0
                                  2025-06-25 11:06:09.393	warn	ELEVATED:I02 (6568) value generated '174' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:09.392	warn	ELEVATED:I02 (6568) value generated '174' from device ffffb40e060599a0 for 'Link quality'
                                  zigbee.0
                                  2025-06-25 11:06:09.391	warn	ELEVATED:I01 (6568) message received '{"linkquality":174}' from device ffffb40e060599a0 type 'undefined'
                                  zigbee.0
                                  2025-06-25 11:06:09.385	warn	ELEVATED:I01 (6568) Zigbee Event of Type attributeReport from device 0xffffb40e060599a0, incoming event: {"type":"attributeReport","data":{"measuredValue":2869},"linkquality":174,"groupID":0,"cluster":"msTemperatureMeasurement","meta":{"zclTransactionSequenceNumber":88,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                                  Irgendwo steckt wohl noch was fest. Gibt es eine Möglichkeit Zigbee komplett mit allem zu entfernen und neu zu beginnen?
                                  Failed to open the network: Error: SRSP - ZDO - mgmtPermitJoinReq after 6000ms at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/waitress.js:47:23) at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:263:41 at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:26) at Znp.requestZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:257:27) at func (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:322:32) at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/dist/utils/queue.js:29:26) at ZStackAdapter.sendZdoInternal (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:341:60) at ZStackAdapter.sendZdo (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:263:27) at ZStackAdapter.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:176:24) at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:249:32)
                                  Mfg
                                  Tom
                                  460
