    4. [gelöst] Problem in der IOB DIAG
    • fuzzy1955
      fuzzy1955 last edited by fuzzy1955
      Hallo Leute,
      seit gestern erscheint bei meinem IOB-System in der DIAG folgende Meldung:
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      In der Langfassung von iob diag tauchen dann Fehler auf:
      ========== Start marking the full check here ===========
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.12.25+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       23:28:24 up 1 day,  1:33,  2 users,  load average: 0.80, 0.57, 0.50
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-06-26 23:28:24 CEST
                 Universal time: Thu 2025-06-26 21:28:24 UTC
                       RTC time: Thu 2025-06-26 21:28:24
                      Time zone: Europe/Vienna (CEST, +0200)
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      /home/iobroker/.diag.sh: line 461: [[: 20242 6083: syntax error in expression (error token is "6083")
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:             17G        2.1G         11G        7.6M        3.8G         14G
      Swap:           536M          0B        536M
      Total:           17G        2.1G         11G
      Active iob-Instances:   14
              16219 M total memory
               1981 M used memory
               1754 M active memory
               3171 M inactive memory
              10743 M free memory
                179 M buffer memory
               3442 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 23:28:24 up 1 day,  1:33,  2 users,  load average: 0.80, 0.57, 0.50
      Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  16219.7 total,  10743.7 free,   1981.9 used,   3621.7 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.  14237.7 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  7.9G     0  7.9G   0% /dev
      tmpfs          tmpfs     1.6G  7.3M  1.6G   1% /run
      /dev/mmcblk0p2 ext4       15G   11G  2.6G  82% /
      tmpfs          tmpfs     8.0G     0  8.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Wed Jun 25 21:54:43 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:C6:D1:C2 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=46767ad0-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Jun 25 21:54:46 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
      [Wed Jun 25 21:54:47 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.4G    /var/
      752M    /var/log
      751M    /var/log/journal/ce49b5c207f74de48fc362bf23ca73ba
      631M    /var/lib
      Archived and active journals take up 750.4M in the file system.
      /opt/iobroker/backups:
      102M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      594M    /opt/iobroker/iobroker-data/
      500M    /opt/iobroker/iobroker-data/files
      222M    /opt/iobroker/iobroker-data/files/vis-2
      89M     /opt/iobroker/iobroker-data/files/vis-2/static
      88M     /opt/iobroker/iobroker-data/files/vis-2/static/js
      44M     /opt/iobroker/iobroker-data/objects.jsonl
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.*
      Extended Pan ID:
      grep: /opt/iobroker/iobroker-data/zigbee_*/nvbackup.json: No such file or directory
      Pan ID:
      /home/iobroker/.diag.sh: line 713: printf: 0x: invalid hex number
      0
      Channel:
      Network Key:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.3
      /usr/bin/node           v20.19.3
      /usr/bin/corepack       0.32.0
      nodejs:
        Installed: 20.19.3-1nodesource1
        Candidate: 20.19.3-1nodesource1
        Version table:
       *** 20.19.3-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 60500)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
        system.adapter.echarts.0                : echarts               : raspberrypi                              - disabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
        system.adapter.emporia.0                : emporia               : raspberrypi                              - disabled
      + system.adapter.javascript.1             : javascript            : raspberrypi                              -  enabled
      + system.adapter.kecontact.0              : kecontact             : raspberrypi                              -  enabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.1                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.modbus.2                 : modbus                : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.0.100
      + system.adapter.sql.0                    : sql                   : raspberrypi                              -  enabled, port: 3306
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              - disabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspberrypi                              - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              - disabled
        system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: raspberrypi                              - disabled
      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name     │ url                                              │ auto upgrade │
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ true         │
      Active repo(s): stable
      Upgrade policy: minor
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "emporia"      : 0.0.12   , installed 0.1.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "kecontact"    : 3.1.0    , installed 3.1.0
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "shelly"       : 9.5.1    , installed 9.5.1
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-2-widgets-weather-and-heating": 0.10.4, installed 0.10.4
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Objects and States
      Objects:        2026
      States:         1665
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      106        7246       762/mariadbd
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          7333       888/smbd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7215       703/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          7334       888/smbd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31189      6083/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31194      6083/iobroker.js-co
      tcp        0      0 192.168.0.100:1882      0.0.0.0:*               LISTEN      1001       49289      8662/io.shelly.0
      tcp6       0      0 :::445                  :::*                    LISTEN      0          7331       888/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          7217       703/sshd: /usr/sbin
      tcp6       0      0 :::139                  :::*                    LISTEN      0          7332       888/smbd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       29611      6115/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       48458      8505/io.web.0
      udp        0      0 0.0.0.0:43875           0.0.0.0:*                           1001       48496      8569/io.kecontact.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        999        574/avahi-daemon: r
      udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       46073      8569/io.kecontact.0
      udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       46074      8569/io.kecontact.0
      udp        0      0 192.168.0.255:137       0.0.0.0:*                           0          6430       884/nmbd
      udp        0      0 192.168.0.100:137       0.0.0.0:*                           0          6429       884/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          6417       884/nmbd
      udp        0      0 192.168.0.255:138       0.0.0.0:*                           0          6432       884/nmbd
      udp        0      0 192.168.0.100:138       0.0.0.0:*                           0          6431       884/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          6418       884/nmbd
      udp        0      0 0.0.0.0:33484           0.0.0.0:*                           104        1001       574/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        1000       574/avahi-daemon: r
      udp6       0      0 :::57465                :::*                                104        1002       574/avahi-daemon: r
      udp6       0      0 fe80::7de6:a76b:229:546 :::*                                0          7358       651/NetworkManager
      2025-06-26 23:27:16.127  - error: host.raspberrypi No connection to databases possible, restart
      2025-06-26 23:27:16.131  - info: host.raspberrypi iobroker _restart
      2025-06-26 23:27:16.645  - info: host.raspberrypi iobroker Starting node restart.js
      2025-06-26 23:27:25.810  - info: host.raspberrypi iobroker.js-controller version 7.0.6 js-controller starting
      2025-06-26 23:27:25.812  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2025-06-26 23:27:25.812  - info: host.raspberrypi hostname: raspberrypi, node: v20.19.3
      2025-06-26 23:27:25.812  - info: host.raspberrypi ip addresses: 192.168.0.100 fdf3:7ab7:8f6:0:d7ac:9b82:4e10:8fea fe80::7de6:a76b:229d:d320
      2025-06-26 23:27:26.316  - info: host.raspberrypi-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
      2025-06-26 23:27:55.818  - error: host.raspberrypi No connection to databases possible, restart
      2025-06-26 23:27:55.823  - info: host.raspberrypi iobroker _restart
      2025-06-26 23:27:56.337  - info: host.raspberrypi iobroker Starting node restart.js
      2025-06-26 23:28:00.526  - info: host.raspberrypi iobroker.js-controller version 7.0.6 js-controller starting
      2025-06-26 23:28:00.528  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2025-06-26 23:28:00.529  - info: host.raspberrypi hostname: raspberrypi, node: v20.19.3
      2025-06-26 23:28:00.529  - info: host.raspberrypi ip addresses: 192.168.0.100 fdf3:7ab7:8f6:0:d7ac:9b82:4e10:8fea fe80::7de6:a76b:229d:d320
      2025-06-26 23:28:01.075  - info: host.raspberrypi-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
      2025-06-26 23:28:13.954  - info: shelly.0 (8662) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
      2025-06-26 23:28:30.539  - error: host.raspberrypi No connection to databases possible, restart
      2025-06-26 23:28:30.542  - info: host.raspberrypi iobroker _restart
      2025-06-26 23:28:31.041  - info: host.raspberrypi iobroker Starting node restart.js
      2025-06-26 23:28:35.346  - info: host.raspberrypi iobroker.js-controller version 7.0.6 js-controller starting
      2025-06-26 23:28:35.348  - info: host.raspberrypi Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2025-06-26 23:28:35.349  - info: host.raspberrypi hostname: raspberrypi, node: v20.19.3
      2025-06-26 23:28:35.349  - info: host.raspberrypi ip addresses: 192.168.0.100 fdf3:7ab7:8f6:0:d7ac:9b82:4e10:8fea fe80::7de6:a76b:229d:d320
      2025-06-26 23:28:35.937  - info: host.raspberrypi-Server  Error inMem-objects listening on port 9001: Error: listen EADDRINUSE: address already in use 127.0.0.1:9001
      iob diag has finished.
      Das System ist am letzten Stand:
      IOB v7.6.17
      js-controller v7.0.6
      sudo apt update
      sudo apt full-upgrade
      iob update
      iob upgrade self
      iob upgrade
      Restore des IOB von 3 Tage zuvor.
      Der IOB fix zeigt folgendes:
      iob fix
      library: loaded
      Library version=2024-10-22
      ioBroker or some processes are still running:
      6083 iobroker.js-con
      6115 io.admin.0
      6183 io.backitup.0
      8505 io.web.0
      8520 io.vis-2.0
      8536 io.sql.0
      8558 io.javascript.1
      8569 io.kecontact.0
      8588 io.modbus.0
      8606 io.email.0
      8624 io.modbus.1
      8662 io.shelly.0
      18691 io.javascript.0
      18724 io.modbus.2
      Please stop them first and try again!
      Was ist die Ursache dafür und welche Schritte sind da notwendig? Vorweg danke für eure Unterstützung!
        Thomas Braun Most Active @fuzzy1955 last edited by
        @fuzzy1955 sagte in Problem in der IOB DIAG:
        iob stop
        iob fix
        sudo apt update
        sudo reboot
        Dann nochmal schauen was iob diag sagt.
        fuzzy1955 1 Reply Last reply Reply Quote 0
        • fuzzy1955
          fuzzy1955 @Thomas Braun last edited by
          @thomas-braun sagte in Problem in der IOB DIAG:
          Dasselbe wie zuletzt:
          * Some output is masked. For full results please use 'iob diag --unmask' *
          Thomas Braun ? 2 Replies Last reply Reply Quote 0
            @fuzzy1955
            Äh? Das ist der 'Anleitungstext', der bei jedem Aufruf kommt.
              A Former User @fuzzy1955 last edited by
              @fuzzy1955
              der Any Key ist nicht die Shift-Taste..
              • fuzzy1955
                Pardon, ich war in Eile. Das ist der vollständige Inhalt:
                Script v.2025-03-08
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 20:34:18 up 20:30,  2 users,  load average: 0.27, 0.20, 0.09
                CPU threads: 4
                Current issues:
                               Local time: Fri 2025-06-27 20:34:18 CEST
                           Universal time: Fri 2025-06-27 18:34:18 UTC
                                 RTC time: Fri 2025-06-27 18:34:18
                              NTP service: active
                          RTC in local TZ: no
                pi
                HOME=/home/pi
                GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev gpio i2c spi iobroker
                iobroker
                HOME=/home/iobroker
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:             17G        2.1G         13G        7.6M        1.3G         14G
                Swap:           536M          0B        536M
                Total:           17G        2.1G         14G
                Active iob-Instances:   16
                         2019 M used memory
                         1800 M active memory
                          937 M inactive memory
                        13108 M free memory
                          126 M buffer memory
                         1085 M swap cache
                          511 M total swap
                            0 M used swap
                          511 M free swap
                top - 20:34:18 up 20:30,  2 users,  load average: 0.27, 0.20, 0.09
                Tasks: 198 total,   1 running, 197 sleeping,   0 stopped,   0 zombie
                MiB Mem :  16219.7 total,  13108.8 free,   2019.0 used,   1211.2 buff/cache
                MiB Swap:    512.0 total,    512.0 free,      0.0 used.  14200.6 avail Mem
                *** FILESYSTEM ***
                /dev/mmcblk0p2 ext4       15G   11G  2.5G  82% /
                [Fri Jun 27 00:03:42 2025] Kernel command line: reboot=w coherent_pool=1M 8250.n        r_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=f        ake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:C6:D1:C2 vc_mem.mem_base        =0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 roo        t=PARTUUID=46767ad0-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Fri Jun 27 00:03:45 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8        -424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                [Fri Jun 27 00:03:46 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87        a2-cd44114eb820 r/w. Quota mode: none.
                `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                2.4G    /var/
                752M    /var/log
                631M    /var/lib
                598M    /opt/iobroker/iobroker-data/
                47M     /opt/iobroker/iobroker-data/objects.jsonl
                26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41c        ee985.js.map
                USB-Devices by-id:
                USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                zigbee.X
                Extended Pan ID:
                *** MASKED ***
                Pan ID:
                *** MASKED ***
                Channel:
                *** MASKED ***
                Network Key:
                *** MASKED ***
                nodejs:
                  Version table:
                        500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 73821)
                admin:          7.6.17
                javascript:     8.9.2
                Adapter State
                + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                + system.adapter.emporia.0                : emporia               : raspberrypi                              -  enabled
                + instance is alive
                Objects and States
                Objects:        1970
                States:         1645
                Pending Updates: 0
                tcp        0      0 192.168.0.100:1882      0.0.0.0:*               LISTEN      1001       142937     2605/io.shelly.0
                tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      106        2950       754/mariadbd
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8223       674/iobroker.js-con
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8218       674/iobroker.js-con
                tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          6281       881/smbd
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5726       695/sshd: /usr/sbin
                tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          6280       881/smbd
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       7314       1036/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8817       1378/io.web.0
                tcp6       0      0 :::139                  :::*                    LISTEN      0          6279       881/smbd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          5728       695/sshd: /usr/sbin
                tcp6       0      0 :::445                  :::*                    LISTEN      0          6278       881/smbd
                udp        0      0 0.0.0.0:50192           0.0.0.0:*                           104        2881       565/avahi-daemon: r
                udp        0      0 0.0.0.0:59433           0.0.0.0:*                           1001       9814       1259/io.kecontact.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2879       565/avahi-daemon: r
                udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       7566       1259/io.kecontact.0
                udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       7567       1259/io.kecontact.0
                udp        0      0 192.168.0.255:137       0.0.0.0:*                           0          3058       876/nmbd
                udp        0      0 192.168.0.100:137       0.0.0.0:*                           0          3057       876/nmbd
                udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          3045       876/nmbd
                udp        0      0 192.168.0.255:138       0.0.0.0:*                           0          3060       876/nmbd
                udp        0      0 192.168.0.100:138       0.0.0.0:*                           0          3059       876/nmbd
                udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          3046       876/nmbd
                udp6       0      0 :::5353                 :::*                                104        2880       565/avahi-daemon: r
                udp6       0      0 :::56308                :::*                                104        2882       565/avahi-daemon: r
                udp6       0      0 fe80::7de6:a76b:229:546 :::*                                0          5897       642/NetworkManager
                2025-06-27 09:34:31.903  - error: shelly.0 (2605) [MQTT] Unable to get mqttprefix of client with id "shellypro0110pm-8813bfd960b4"
                2025-06-27 09:34:43.376  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
                2025-06-27 09:35:43.512  - info: admin.0 (1036) <== Disconnect system.user.admin from ::ffff:192.168.0.20 admin
                2025-06-27 09:35:43.512  - info: web.0 (1378) <== Disconnect system.user.admin from ::ffff:192.168.0.20
                2025-06-27 09:43:25.974  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                2025-06-27 10:55:25.983  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                2025-06-27 12:07:25.988  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                2025-06-27 13:19:25.986  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                2025-06-27 14:30:46.126  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
                2025-06-27 14:30:58.146  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
                2025-06-27 14:31:25.979  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                2025-06-27 14:39:32.186  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
                2025-06-27 14:40:04.204  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
                2025-06-27 14:40:10.223  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
                2025-06-27 14:40:11.106  - error: shelly.0 (2605) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'replace')
                2025-06-27 14:40:11.106  - error: shelly.0 (2605) [MQTT] Unable to get mqttprefix of client with id "shellypro0110pm-8813bfd960b4"
                2025-06-27 14:41:02.242  - info: shelly.0 (2605) [MQTT] Device with client id "shellypro0110pm-8813bfd960b4" connected from 192.168.0.103!
                2025-06-27 15:43:25.988  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                2025-06-27 16:55:25.991  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                2025-06-27 18:07:25.988  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                2025-06-27 19:19:25.991  - info: javascript.0 (1078) script.js.common.SQLBereinigen: MySQL-DB wurde bereinigt (Nullwerte gelöscht).
                  @fuzzy1955
                  Und um was geht es dir? Ist doch alles tutti.
                  • fuzzy1955
                    fuzzy1955 @Thomas Braun last edited by fuzzy1955
                    Anlass war, dass der IOB aus heiterem Himmel stoppte und auch nach mehreren Versuchen nicht mehr gestartet hat. Der Admin-Adapter lief immer auf einen Fehler. Leider habe ich davon keine Aufzeichnungen mehr. Ich spielte daraufhin ein Backup von 3 Tagen zuvor ein, das System lief wieder, aber diese Meldung irritierte mich:
                    • fuzzy1955
                      fuzzy1955 @Guest last edited by
                      @neuschwansteini 😊
                        Homoran Global Moderator Administrators @fuzzy1955 last edited by
                        @fuzzy1955 sagte in [gelöst] Problem in der IOB DIAG:
                        die gibt es seit ewigen Zeiten und ist eine Anleitung, was man beachten soll, bevor man weitermacht, damit der Output auch für die Helferlein vernünftig lesbar wird.
                        fuzzy1955 1 Reply Last reply Reply Quote 1
                        • fuzzy1955
                          fuzzy1955 @Homoran last edited by
                          @homoran sagte in [gelöst] Problem in der IOB DIAG:
                          Ups ... wieder was gelernt. Danke!
                          281
