    4. Nach Nodejs 22 Update - Adapter nicht updatefähig
      MCU last edited by
      nachdem ich ein Update von Nodejs auf Version 22 durchgeführt habe, werden andere Updates der Adapter nicht mehr umgesetzt.
      Update durchgeführt mit
      iob nodejs-update 22
      Hier der iob diag Auszug
      Script v.2025-03-08
      *** BASE SYSTEM ***
      Static hostname: iobrokerProd
            Icon name: computer-container
              Chassis: container ☐
       Virtualization: lxc
               Kernel: Linux 6.8.12-11-pve
         Architecture: x86-64
      OS is similar to:
      model name      : 11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
      23:45:39 up 1 day, 12 min,  2 users,  load average: 1.41, 1.40, 1.34
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
                    Local time: Thu 2025-06-26 23:45:39 CEST
                Universal time: Thu 2025-06-26 21:45:39 UTC
                      RTC time: n/a
                   NTP service: inactive
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      prox
      HOME=/home/prox
      GROUPS=prox sudo users iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:             17G        183M         11G        106K        5.2G         16G
      Swap:           536M        4.1K        536M
      Total:           17G        183M         12G
      Active iob-Instances:   1
             16384 M total memory
               174 M used memory
               253 M active memory
              4734 M inactive memory
             11237 M free memory
                 0 M buffer memory
              4971 M swap cache
               512 M total swap
                 0 M used swap
               511 M free swap
      top - 23:45:39 up 1 day, 12 min,  2 users,  load average: 1.41, 1.40, 1.34
      Tasks:  24 total,   1 running,  23 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  16384.0 total,  11235.9 free,    176.5 used,   4971.7 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.  16207.5 avail Mem
      *** FAILED SERVICES ***
       UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      * iobroker.service        loaded failed failed ioBroker Server
      3 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--150--disk--0 ext4       49G   22G   26G  46% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      //192.168.178.1/FRITZ.NAS        cifs      469G  359G  111G  77% /mnt/FritzNas
      udev                             devtmpfs   32G     0   32G   0% /dev/tty
      tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
      tmpfs                            tmpfs      13G  104K   13G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Show mounted filesystems:
      TARGET          SOURCE                           FSTYPE OPTIONS
      /               /dev/mapper/pve-vm--150--disk--0 ext4   rw,relatime,stripe=16
      `-/mnt/FritzNas //192.168.178.1/FRITZ.NAS        cifs   rw,nosuid,nodev,noexec,relatime,vers=3.0,cache=strict,upcall_target=app,username=admin,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,iocharset=utf8,soft,nounix,mapposix,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      /var:
      859M    /var/
      414M    /var/cache
      410M    /var/cache/apt
      334M    /var/cache/apt/archives
      289M    /var/log/journal/0e88ad35af7a4b138e9b16cc19b4668b
      Archived and active journals take up 42.2M in the file system.
      /opt/iobroker/backups:
      763M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.3G    /opt/iobroker/iobroker-data/
      528M    /opt/iobroker/iobroker-data/backup-objects
      443M    /opt/iobroker/iobroker-data/files
      69M     /opt/iobroker/iobroker-data/files/vis-2
      66M     /opt/iobroker/iobroker-data/files/vis
      1.2G    /opt/iobroker/iobroker-data/states.jsonl
      46M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      21M     /opt/iobroker/iobroker-data/jarvis/0/jarvis.0.devices.json
      19M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.b371dc6f.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0
      *** ZigBee Settings ***
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.17.0
      /usr/bin/node           v22.17.0
      /usr/bin/npm            10.9.2
      /usr/bin/npx            10.9.2
      /usr/bin/corepack       0.33.0
      nodejs:
       Installed: 22.17.0-1nodesource1
       Candidate: 22.17.0-1nodesource1
       Version table:
      *** 22.17.0-1nodesource1 1001
             500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
             100 /var/lib/dpkg/status
          22.16.0-1nodesource1 1001
          22.15.1-1nodesource1 1001
          22.15.0-1nodesource1 1001
          22.14.0-1nodesource1 1001
          22.13.1-1nodesource1 1001
          22.13.0-1nodesource1 1001
          22.12.0-1nodesource1 1001
          22.11.0-1nodesource1 1001
          22.10.0-1nodesource1 1001
          22.9.0-1nodesource1 1001
          22.8.0-1nodesource1 1001
          22.7.0-1nodesource1 1001
          22.6.0-1nodesource1 1001
          22.5.1-1nodesource1 1001
          22.5.0-1nodesource1 1001
          22.4.1-1nodesource1 1001
          22.4.0-1nodesource1 1001
          22.3.0-1nodesource1 1001
          22.2.0-1nodesource1 1001
          22.1.0-1nodesource1 1001
          22.0.0-1nodesource1 1001
          18.19.0+dfsg-6~deb12u2 500
             500 http://deb.debian.org/debian bookworm/main amd64 Packages
          18.19.0+dfsg-6~deb12u1 500
             500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobrokerProd        iobrokerProd (version: 7.0.7, hostname: iobrokerProd  , alive, uptime: 87015)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.1
      javascript:     9.0.6
      nodejs modules from github:     3
      +-- iobroker.hue-extended@2.0.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.hue-extended.git#1de8967c7f7150dfdc1c281899adc5d01777b050)
      +-- iobroker.jarvis@3.2.0-rc.17 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#65370bd2ad4617722447bcff04ba4dc6429bed9b)
      +-- iobroker.meross@1.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.meross.git#89166c86e032b777b634e9fbe1e42544de9c9fb0)
      Adapter State
       system.adapter.admin.0                  : admin                 : iobrokerProd                             -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
       system.adapter.alexa2.0                 : alexa2                : iobrokerProd                             -  enabled
       system.adapter.awattar.0                : awattar               : iobrokerProd                             -  enabled
       system.adapter.awtrix-light.0           : awtrix-light          : iobrokerProd                             - disabled
       system.adapter.backitup.0               : backitup              : iobrokerProd                             -  enabled
       system.adapter.birthdays.0              : birthdays             : iobrokerProd                             - disabled
       system.adapter.bring.0                  : bring                 : iobrokerProd                             -  enabled
       system.adapter.broadlink2.0             : broadlink2            : iobrokerProd                             -  enabled
       system.adapter.cameras.0                : cameras               : iobrokerProd                             -  enabled, port: 8200, bind: 127.0.0.1
       system.adapter.chromecast.0             : chromecast            : iobrokerProd                             -  enabled
       system.adapter.cloud.0                  : cloud                 : iobrokerProd                             -  enabled
       system.adapter.daswetter.0              : daswetter             : iobrokerProd                             - disabled
       system.adapter.devices.0                : devices               : iobrokerProd                             - disabled
       system.adapter.discovery.0              : discovery             : iobrokerProd                             - disabled
       system.adapter.dwd.0                    : dwd                   : iobrokerProd                             -  enabled
       system.adapter.echarts.0                : echarts               : iobrokerProd                             -  enabled
       system.adapter.email.0                  : email                 : iobrokerProd                             -  enabled
       system.adapter.fahrplan.0               : fahrplan              : iobrokerProd                             - disabled
       system.adapter.flexcharts.0             : flexcharts            : iobrokerProd                             -  enabled
       system.adapter.flot.0                   : flot                  : iobrokerProd                             - disabled
       system.adapter.fritzdect.0              : fritzdect             : iobrokerProd                             -  enabled
       system.adapter.fullybrowser.0           : fullybrowser          : iobrokerProd                             -  enabled
       system.adapter.history.0                : history               : iobrokerProd                             -  enabled
       system.adapter.history.1                : history               : iobrokerProd                             - disabled
       system.adapter.hue-extended.0           : hue-extended          : iobrokerProd                             -  enabled
       system.adapter.hue.0                    : hue                   : iobrokerProd                             - disabled, port: 443
       system.adapter.ical.0                   : ical                  : iobrokerProd                             -  enabled
       system.adapter.iot.0                    : iot                   : iobrokerProd                             -  enabled
       system.adapter.jarvis.0                 : jarvis                : iobrokerProd                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
       system.adapter.jarvis.1                 : jarvis                : iobrokerProd                             -  enabled
       system.adapter.jarvis.2                 : jarvis                : iobrokerProd                             -  enabled
       system.adapter.javascript.0             : javascript            : iobrokerProd                             -  enabled
       system.adapter.lovelace.0               : lovelace              : iobrokerProd                             - disabled, port: 8091, bind: 0.0.0.0, run as: admin
       system.adapter.meross.0                 : meross                : iobrokerProd                             -  enabled
       system.adapter.mqtt-client.0            : mqtt-client           : iobrokerProd                             -  enabled, port: 1883
       system.adapter.mqtt.0                   : mqtt                  : iobrokerProd                             -  enabled, port: 1885, bind: 0.0.0.0
       system.adapter.mqtt.1                   : mqtt                  : iobrokerProd                             - disabled, port: 1883, bind: 0.0.0.0
       system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobrokerProd                             -  enabled
       system.adapter.odl.0                    : odl                   : iobrokerProd                             -  enabled
       system.adapter.onvif.0                  : onvif                 : iobrokerProd                             - disabled, port: 8000
       system.adapter.onvif.1                  : onvif                 : iobrokerProd                             - disabled, port: 8000
       system.adapter.openweathermap.0         : openweathermap        : iobrokerProd                             -  enabled
       system.adapter.parser.0                 : parser                : iobrokerProd                             - disabled
       system.adapter.pegelalarm.0             : pegelalarm            : iobrokerProd                             - disabled
       system.adapter.ping.0                   : ping                  : iobrokerProd                             -  enabled
       system.adapter.proxmox.0                : proxmox               : iobrokerProd                             -  enabled, port: 8006
       system.adapter.proxy.0                  : proxy                 : iobrokerProd                             -  enabled
       system.adapter.pushover.0               : pushover              : iobrokerProd                             -  enabled
       system.adapter.pvforecast.0             : pvforecast            : iobrokerProd                             - disabled
       system.adapter.rest-api.0               : rest-api              : iobrokerProd                             -  enabled, port: 8093, bind: 0.0.0.0 (SSL), run as: admin
       system.adapter.ring.0                   : ring                  : iobrokerProd                             -  enabled
       system.adapter.roadtraffic.0            : roadtraffic           : iobrokerProd                             - disabled
       system.adapter.rssfeed.0                : rssfeed               : iobrokerProd                             - disabled
       system.adapter.shelly.0                 : shelly                : iobrokerProd                             -  enabled, port: 1882, bind: 0.0.0.0
       system.adapter.simple-api.0             : simple-api            : iobrokerProd                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
       system.adapter.slideshow.0              : slideshow             : iobrokerProd                             -  enabled
       system.adapter.slideshow.1              : slideshow             : iobrokerProd                             -  enabled
       system.adapter.smartcontrol.0           : smartcontrol          : iobrokerProd                             - disabled
       system.adapter.snmp.0                   : snmp                  : iobrokerProd                             -  enabled
       system.adapter.sonoff.0                 : sonoff                : iobrokerProd                             -  enabled, port: 1883, bind: 0.0.0.0
       system.adapter.spotify-premium.0        : spotify-premium       : iobrokerProd                             - disabled
       system.adapter.tankerkoenig.0           : tankerkoenig          : iobrokerProd                             -  enabled
       system.adapter.telegram.0               : telegram              : iobrokerProd                             -  enabled, port: 8443, bind: 0.0.0.0
       system.adapter.telegram.1               : telegram              : iobrokerProd                             -  enabled, port: 8443, bind: 0.0.0.0
       system.adapter.terminal.0               : terminal              : iobrokerProd                             - disabled, port: 8088, bind: 0.0.0.0, run as: admin
       system.adapter.tr-064.0                 : tr-064                : iobrokerProd                             -  enabled
       system.adapter.trashschedule.0          : trashschedule         : iobrokerProd                             -  enabled
       system.adapter.tuya.0                   : tuya                  : iobrokerProd                             - disabled
       system.adapter.tvprogram.0              : tvprogram             : iobrokerProd                             - disabled
       system.adapter.tvspielfilm.0            : tvspielfilm           : iobrokerProd                             - disabled
       system.adapter.twinkly.0                : twinkly               : iobrokerProd                             -  enabled
       system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobrokerProd                             - disabled
       system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobrokerProd                             -  enabled
       system.adapter.vis-2.0                  : vis-2                 : iobrokerProd                             -  enabled
       system.adapter.vis-metro.0              : vis-metro             : iobrokerProd                             - disabled
       system.adapter.vis.0                    : vis                   : iobrokerProd                             -  enabled
       system.adapter.web.0                    : web                   : iobrokerProd                             -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
       system.adapter.web.1                    : web                   : iobrokerProd                             -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
       system.adapter.wifilight.0              : wifilight             : iobrokerProd                             -  enabled
       system.adapter.wled.0                   : wled                  : iobrokerProd                             -  enabled
       system.adapter.zigbee.0                 : zigbee                : iobrokerProd                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_48e2ca301045ec119c1e92fd6f14af06-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: beta
      Adapter    "admin"        : 7.7.1    , installed 7.7.1
      Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.3    , installed 3.3.0  [Updatable]
      Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
      Adapter    "bring"        : 1.9.1    , installed 1.9.1
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "cameras"      : 2.1.2    , installed 2.1.2
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "devices"      : 1.2.7    , installed 1.2.7
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "echarts"      : 2.0.6    , installed 2.0.6
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
      Adapter    "flexcharts"   : 0.4.1    , installed 0.4.1
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
      Adapter    "hue"          : 3.16.2   , installed 3.16.2
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "iot"          : 3.5.2    , installed 3.5.0  [Updatable]
      Adapter    "jarvis"       : 3.2.0-rc.5, installed 3.2.0-rc.17
      Adapter    "javascript"   : 9.0.6    , installed 9.0.6
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "lovelace"     : 5.0.0    , installed 5.0.0
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
      Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
      Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
      Adapter    "odl"          : 5.0.0    , installed 5.0.0
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "openweathermap": 1.3.0   , installed 1.3.0
      Adapter    "parser"       : 2.3.1    , installed 2.3.1
      Adapter    "pegelalarm"   : 1.3.8    , installed 1.3.8
      Adapter    "ping"         : 1.7.9    , installed 1.7.9
      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
      Adapter    "proxy"        : 1.3.2    , installed 1.3.2
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
      Adapter    "rest-api"     : 3.0.1    , installed 3.0.1
      Adapter    "ring"         : 6.3.0    , installed 6.3.0
      Adapter    "roadtraffic"  : 1.2.0    , installed 1.2.0
      Adapter    "rssfeed"      : 3.5.2    , installed 3.5.2
      Adapter    "shelly"       : 10.0.0   , installed 10.0.0
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "slideshow"    : 0.2.1    , installed 0.2.1
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "snmp"         : 3.2.0    , installed 3.2.0
      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "spotify-premium": 1.5.3  , installed 1.5.3
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 4.0.0    , installed 3.3.0  [Updatable]
      Adapter    "tuya"         : 3.17.0   , installed 3.17.0
      Adapter    "tvprogram"    : 4.0.0    , installed 4.0.0
      Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
      Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
      Adapter    "virtualpowermeter": 1.5.0, installed 1.5.0
      Adapter    "vis-2"        : 2.12.10  , installed 2.12.10
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "web"          : 7.0.9    , installed 7.0.6  [Updatable]
      Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
      Adapter    "wled"         : 0.7.3    , installed 0.7.3
      Adapter    "ws"           : 3.0.19   , installed 3.0.19
      Adapter    "zigbee"       : 3.0.1    , installed 2.0.4  [Updatable]
      Objects and States
      Objects:        31681
      States:         24572
      Hit:2 http://security.debian.org bookworm-security InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          195711636  327/master
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          195717258  1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          195717260  1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          195711637  327/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          195714986  1/init
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          195717259  1/init
      udp6       0      0 :::111                  :::*                                0          195717261  1/init
      2025-06-26 23:43:29.518  - info: host.iobrokerProd instance system.adapter.trashschedule.0 terminated with code null ()
      2025-06-26 23:43:29.518  - warn: host.iobrokerProd instance system.adapter.twinkly.0 terminated due to SIGKILL
      2025-06-26 23:43:29.518  - info: host.iobrokerProd instance system.adapter.twinkly.0 terminated with code null ()
      2025-06-26 23:43:29.542  - info: host.iobrokerProd instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
      2025-06-26 23:43:29.543  - info: host.iobrokerProd instance system.adapter.jarvis.1 terminated with code 0 (NO_ERROR)
      2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.web.0 terminated due to SIGKILL
      2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.web.0 terminated with code null ()
      2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.web.1 terminated due to SIGKILL
      2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.web.1 terminated with code null ()
      2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.slideshow.0 terminated due to SIGKILL
      2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.slideshow.0 terminated with code null ()
      2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.telegram.0 terminated due to SIGKILL
      2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.telegram.0 terminated with code null ()
      2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.telegram.1 terminated due to SIGKILL
      2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.telegram.1 terminated with code null ()
      2025-06-26 23:43:29.547  - warn: host.iobrokerProd instance system.adapter.backitup.0 terminated due to SIGKILL
      2025-06-26 23:43:29.547  - info: host.iobrokerProd instance system.adapter.backitup.0 terminated with code null ()
      2025-06-26 23:43:29.549  - info: host.iobrokerProd instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2025-06-26 23:43:29.591  - warn: host.iobrokerProd instance system.adapter.jarvis.2 terminated due to SIGKILL
      2025-06-26 23:43:29.591  - info: host.iobrokerProd instance system.adapter.jarvis.2 terminated with code null ()
      2025-06-26 23:43:29.632  - info: host.iobrokerProd instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
      2025-06-26 23:43:31.804  - info: meross.0 (782) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-06-26 23:43:32.339  - info: host.iobrokerProd instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-06-26 23:43:32.339  - info: host.iobrokerProd All instances are stopped.
      2025-06-26 23:43:32.426  - info: host.iobrokerProd terminated
      iob diag has finished.
      [/s]
      Kennt jemand das Problem?
        Thomas Braun Most Active @MCU last edited by
        @mcu
        iob update
        iob upgrade
        sagt?
          MCU @Thomas Braun last edited by MCU
          Linux iobrokerProd 6.8.12-11-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-11 (2025-05-22T09:39Z) x86_64
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          Last login: Wed Jun 25 23:33:06 CEST 2025 on tty1
          prox@iobrokerProd:~$ iob update
          prox@iobrokerProd:~$ iob upgrade
          This upgrade of "zigbee" will introduce the following changes:
          -> 3.0.1:
          Fix for Ikea SOMRIG configuration raising 'definition.endpoint is not a function' error.
          Access to 'zigbee2mqtt options as settings in zigbee adapter (ALPHA Stage !)
          Fix for 'error: zigbee.0 (1118300) zigbee.0 already running' at adapter start (Alpha Stage)
          Updated hardware configuration panel - exchanged text buttons for buttons with icons.
          Limited states on device tiles to states which are read only or which can be modified sensibly via the device tile.
          -> 3.0.0:
          Breaking change: Start of zigbee subsystem requires configuration entry !!!
          Hardware configuration panel
          Update for external converter - detect /dist/ subfolder
          Update device image: use of icons defined in external converter (beta)
          -> 2.0.5:
          ZHC 23.6.0
          ZH 3.3.x
          removed extra logging
          fixed memory issue.
          Configure on Message - 5 attempts.
          update transmitPower
          fix crash in ZigbeeController.ByteArrayToString
          device designation for  devices without mapped model (allows use in groups and bindings)
          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
          Would you like to upgrade zigbee from @2.0.4 to @3.0.1 now? [(y)es, (n)o]:
          Nach Neustart vom System erhalte ich bei Update vom backitup
          $ iobroker upgrade backitup@3.3.3 --debug
          Update backitup from @3.3.0 to @3.3.3
          host.iobrokerProd Adapter "system.adapter.backitup.0" is stopped.
          NPM version: 10.9.2
          Installing iobroker.backitup@3.3.3... (System call)
          npm error code EBADENGINE
          npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-26T22_07_15_821Z-debug-0.log
          Updating objects from io-package.json for adapter "backitup" with version "3.3.0"
          upload [96] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/asset-manifest.json asset-manifest.json application/json
          upload [90] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/assets/zigbee2mqtt-tDEKhm15.png assets/zigbee2mqtt-tDEKhm15.png image/png
          upload [80] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/ConfigCustomBackItUpSet__mf_v__runtimeInit__mf_v__-Cy0TQlfU.js custom/assets/ConfigCustomBackItUpSet__mf_v__runtimeInit__mf_v__-Cy0TQlfU.js application/javascript
          upload [70] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/emotion-serialize.esm-BUa21YfQ.js custom/assets/emotion-serialize.esm-BUa21YfQ.js application/javascript
          upload [60] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/index-DHRZ46WI.js custom/assets/index-DHRZ46WI.js application/javascript
          upload [50] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/assets/virtualExposes-Bgb1mEhK.js custom/assets/virtualExposes-Bgb1mEhK.js application/javascript
          upload [40] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/custom/i18n/pt.json custom/i18n/pt.json application/json
          upload [30] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/history.jsonConfig.json5 history.jsonConfig.json5 application/json5
          upload [20] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
          upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
          upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/influxdb.jsonConfig.json5 influxdb.jsonConfig.json5 application/json5
          upload [17] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/iob.jsonConfig.json5 iob.jsonConfig.json5 application/json5
          upload [16] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/jsonConfig.json5 jsonConfig.json5 application/json5
          upload [15] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/main.jsonConfig.json5 main.jsonConfig.json5 application/json5
          upload [14] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/manifest.json manifest.json application/json
          upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
          host.iobrokerProd Adapter "system.adapter.backitup.0" is started
          Process exited with code 0
            @mcu
            Läuft doch...
              @thomas-braun siehe oben
                @thomas-braun Updateversuch auf der console
                This upgrade of "backitup" will introduce the following changes:
                -> 3.3.3:
                Translation updated
                Fix Grafana Backup & Restore
                Docu updated
                dependencies updated
                -> 3.3.2:
                Base Topic for z2m Remote Backup added
                -> 3.3.1:
                Fix z2m Remote Backup
                Would you like to upgrade backitup from @3.3.0 to @3.3.3 now? [(y)es, (n)o]: y
                NPM version: 10.9.2
                upload [13] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/mysql.jsonConfig.json5 mysql.jsonConfig.json5 application/json5
                upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
                upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
                upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
                upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
                upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
                upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
                upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
                prox@iobrokerProd:~$ iob version backitup
                3.3.0
                  @mcu
                  Bitte immer vollständige Ein- wie Ausgaben zeigen.
                  Und bitte auf die Spoiler verzichten, die Klickerei nervt.
                    @thomas-braun Hab bei iob upgrade die anderen Adapter mit N nicht upgegradet`, nur bei backitup mit Y.
                    Habe nochmal
                    iob stop
                    iob fix
                    laufen lassen, dann
                    3.3.0
                    prox@iobrokerProd:~$ iob upgrade backitup@3.3.3
                    -> 3.3.3:
                    Translation updated
                    Docu updated
                    -> 3.3.2:
                    -> 3.3.1:
                    NPM version: 10.9.2
                    3.3.0
                      @mcu
                      cd /opt/iobroker
                      npm ls
                      npm i --dry-run
                        @thomas-braun sagte in Nach Nodejs 22 Update - Adapter nicht updatefähig:
                        npm ls
                        prox@iobrokerProd:~$ cd /opt/iobroker
                        prox@iobrokerProd:/opt/iobroker$ npm ls
                        [sudo] password for prox:
                        iobroker.inst@3.0.0 /opt/iobroker
                        +-- @emnapi/runtime@1.3.1 extraneous
                        +-- @iobroker-javascript.0/axios@npm:axios@1.10.0
                        +-- @iobroker-javascript.0/cheerio@npm:cheerio@1.1.0
                        +-- @iobroker-javascript.0/decompress-targz@npm:decompress-targz@4.1.1
                        +-- @iobroker-javascript.0/decompress@npm:decompress@4.2.1
                        +-- @iobroker-javascript.0/form-data@npm:form-data@4.0.3
                        +-- @iobroker-javascript.0/html-pdf@npm:html-pdf@3.0.1
                        +-- @iobroker-javascript.0/html2json@npm:html2json@1.0.2
                        +-- @iobroker-javascript.0/hue-push-client@npm:hue-push-client@1.0.5
                        +-- @iobroker-javascript.0/jsdom@npm:jsdom@26.1.0
                        +-- @iobroker-javascript.0/node-ipc@npm:node-ipc@12.0.0
                        +-- @iobroker-javascript.0/puppeteer@npm:puppeteer@24.10.2
                        +-- @iobroker-javascript.0/uuid@npm:uuid@11.1.0
                        +-- @iobroker-javascript.0/xml2js@npm:xml2js@0.6.2
                        +-- @iobroker-javascript.0/xmldom@npm:xmldom@0.6.0
                        +-- iobroker.admin@7.7.1
                        +-- iobroker.alexa2@3.26.7
                        +-- iobroker.awattar@1.0.6
                        +-- iobroker.awtrix-light@2.0.0
                        +-- iobroker.backitup@3.3.0
                        +-- iobroker.birthdays@4.0.0
                        +-- iobroker.bring@1.9.1
                        +-- iobroker.broadlink2@2.3.0
                        +-- iobroker.cameras@2.1.2
                        +-- iobroker.chromecast@4.0.0
                        +-- iobroker.cloud@5.0.1
                        +-- iobroker.daswetter@3.2.3
                        +-- iobroker.devices@1.2.7
                        +-- iobroker.discovery@5.0.0
                        +-- iobroker.dwd@2.8.5
                        +-- iobroker.echarts@2.0.6
                        +-- iobroker.email@2.0.4
                        +-- iobroker.fahrplan@1.4.1
                        +-- iobroker.flexcharts@0.4.1
                        +-- iobroker.flot@1.12.0
                        +-- iobroker.fritzdect@2.6.2
                        +-- iobroker.fullybrowser@3.1.1
                        +-- iobroker.history@3.0.1
                        +-- iobroker.hue@3.16.2
                        +-- iobroker.ical@1.16.2
                        +-- iobroker.iot@3.5.0
                        +-- iobroker.javascript@9.0.6
                        +-- iobroker.js-controller@7.0.7
                        +-- iobroker.lovelace@5.0.0
                        +-- iobroker.mqtt-client@3.0.0
                        +-- iobroker.mqtt@6.1.4
                        +-- iobroker.notificationforandroidtv@3.0.4
                        +-- iobroker.odl@5.0.0
                        +-- iobroker.onvif@1.1.4
                        +-- iobroker.openweathermap@1.3.0
                        +-- iobroker.parser@2.3.1
                        +-- iobroker.pegelalarm@1.3.8
                        +-- iobroker.ping@1.7.9
                        +-- iobroker.proxmox@2.4.0
                        +-- iobroker.proxy@1.3.2
                        +-- iobroker.pushover@4.1.0
                        +-- iobroker.pvforecast@5.0.0
                        +-- iobroker.rest-api@3.0.1
                        +-- iobroker.ring@6.3.0
                        +-- iobroker.roadtraffic@1.2.0
                        +-- iobroker.rssfeed@3.5.2
                        +-- iobroker.shelly@10.0.0
                        +-- iobroker.simple-api@3.0.7
                        +-- iobroker.slideshow@0.2.1
                        +-- iobroker.smartcontrol@2.0.1
                        +-- iobroker.snmp@3.2.0
                        +-- iobroker.socketio@7.0.8
                        +-- iobroker.sonoff@3.2.1
                        +-- iobroker.spotify-premium@1.5.3
                        +-- iobroker.tankerkoenig@3.4.0
                        +-- iobroker.telegram@4.1.0
                        +-- iobroker.terminal@1.0.0
                        +-- iobroker.tr-064@4.3.0
                        +-- iobroker.trashschedule@3.3.0
                        +-- iobroker.tuya@3.17.0
                        +-- iobroker.tvprogram@4.0.0
                        +-- iobroker.tvspielfilm@2.1.0
                        +-- iobroker.twinkly@1.0.14
                        +-- iobroker.virtualpowermeter@1.5.0
                        +-- iobroker.vis-2-widgets-material@1.4.10
                        +-- iobroker.vis-2@2.12.10
                        +-- iobroker.vis-metro@1.2.0
                        +-- iobroker.vis@1.5.6
                        +-- iobroker.web@7.0.6
                        +-- iobroker.wifilight@2.0.3
                        +-- iobroker.wled@0.7.3
                        +-- iobroker.ws@3.0.19
                        `-- iobroker.zigbee@2.0.4
                        prox@iobrokerProd:/opt/iobroker$ npm i --dry-run
                        npm error engine Unsupported engine
                        npm error engine Not compatible with your version of node/npm: ring-client-api@13.1.0
                        npm error notsup Not compatible with your version of node/npm: ring-client-api@13.1.0
                        npm error notsup Required: {"node":"^18 || ^20"}
                        npm error notsup Actual:   {"npm":"10.9.2","node":"v22.17.0"}
                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-06-26T22_35_49_020Z-debug-0.log
                        Problem wurde auch gemeldet
                        https://github.com/iobroker-community-adapters/ioBroker.ring/issues/820
                        mcuiobroker created this issue in iobroker-community-adapters/ioBroker.ring
                        closed Support of node.js 22 missing #820
                        T OliverIO 2 Replies Last reply Reply Quote 1
                          ticaki Developer @MCU last edited by ticaki
                          @mcu
                          Hab’s nicht ganz gelesen, bei meinem Update auf 22 hab ich yahka entfernen müssen da backitup sich nicht updaten lies wenn es installiert ist - da ist ein veraltetes packet in den deps von yahka. Frag mich nicht wieso das was mit backitup zutun hat.😅
                          Thomas Braun ? 2 Replies Last reply Reply Quote 0
                            Thomas Braun Most Active @ticaki last edited by
                            @ticaki sagte in Nach Nodejs 22 Update - Adapter nicht updatefähig:
                            Nichts direkt. Allerdings macht der Paketmanager npm nichts mehr, wenn da eine nicht auflösbare Konstellation auftaucht.
                            Also Trouble bei yahaka verhindert ein Update von backitup (oder anderen Adaptern).
                              A Former User @ticaki last edited by
                              @ticaki
                              Downgrade Yahka auf die 1.0.3 und es läuft unter node 22
                                MCU @Guest last edited by MCU
                                Fazit?
                                Wenn ein Adapter nicht für die aktuelle Nodejs Version (hier:22) aktuell gehalten wird, kann man ioBroker-Adapter nicht mehr updaten?
                                Der nicht korrekte Adapter muss dann deinstalliert werden!
                                Habe es mal bei chatGPT eingegeben:
                                ⚙️ Warum schlägt ein einzelnes Adapter-Upgrade unter Node.js 22 fehl?
                                📦 Hintergrund: Node.js + native Module
                                Viele ioBroker-Adapter (z. B. modbus, zigbee, mqtt, shelly) nutzen sogenannte native Node-Module (geschriebene C++-Addons). Diese Module sind kompiliert gegen eine bestimmte Node-ABI-Version, z. B. für Node.js 18 oder 20.
                                Wenn du ein Adapter-Update machst, dann passiert:
                                ioBroker nutzt npm → installiert Adapter inkl. package.json
                                npm prüft automatisch:
                                alle Abhängigkeiten
                                ob native Addons kompiliert werden müssen
                                Ist ein Abhängigkeitsmodul nicht kompatibel mit Node.js 22 → npm install schlägt fehl → Adapter-Update komplett abgebrochen
                                Und dabei prüft npm nicht nur das Zielmodul, sondern auch die Abhängigkeiten des gesamten Adapter-Trees, inklusive aller peer dependencies oder optionals.
                                💥 Typisches Beispiel:
                                Du willst hm-rega updaten, aber:
                                ein indirektes Abhängigkeitsmodul wie node-serialport ist noch nicht kompatibel mit Node.js 22
                                npm kann es nicht bauen → npm install schlägt komplett fehl → Adapter wird nicht aktualisiert
                                🔐 Warum kann ioBroker das nicht umgehen?
                                ioBroker selbst verwendet keine eigene Abhängigkeitsverwaltung – er nutzt npm install nativ. Das ist gewollt, da ioBroker-Adapter auf package.json-Basis gepflegt werden.
                                Der Update-Prozess ist also immer so etwas wie:
                                cd /opt/iobroker/node_modules/iobroker.adaptername
                                npm install iobroker.adaptername@latest
                                Wenn das fehlschlägt (egal bei welchem Modul), stoppt der gesamte Update-Prozess.
                                🧩 Lösungsideen (theoretisch):
                                📦 Adapter in isolierte Container packen (→ wäre Overhead)
                                💡 Adapter einzeln in eigene node_modules-Kontexte installieren (aber npm unterstützt das nicht gut)
                                🛠 iobroker könnte ein eigenes Paketmanagement nutzen (aber aktuell zu aufwendig)
                                EDIT
                                Da wäre dann die Frage, kann man das vorher durch einen Befehl prüfen lassen , bevor man das nodejs-update macht?
                                Bzw. Info an die Entwickler immer nur >={letzte geprüfte Nodejs-Version} in der packgae.json zu verwenden und nicht spezielle Angaben =20 || = 22.
                                • OliverIO
                                  OliverIO @MCU last edited by
                                  @mcu
                                  Das bedeutet halt es ist nur 18 oder 20 zulässig.
                                  Sonst nix
                                    MCU @OliverIO last edited by MCU
                                    @oliverio Wäre ja auch für einen Adapter (hier: ring) dann ok. Aber das dadurch auch das Update für andere Adapter scheitert, ist mir neu.
                                    EDIT
                                    Bedeutet dann, wenn die Abhängigkeiten aller genutzten Adapter nicht gepflegt wird, mit deren genutzten Abhängigkeiten, APIs usw., kann man ioBroker, in der ,für jeden unterschiedlichen, Ausprägung, nicht mehr komplett nutzen.
                                    • OliverIO
                                      @mcu
                                      Wir hatten da letztens schon einen komischen Fall. Ich glaube das was @ticaki erwähnte. Das müsste sich mal jemand anschauen der viel Ahnung von npm hat.
                                      Homoran T 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @OliverIO last edited by
                                        @oliverio sagte in Nach Nodejs 22 Update - Adapter nicht updatefähig:
                                        @mcu
                                        muss mal suchen, wenn es interessiert.
                                        @thomas-braun hatte sich da durch die npm Abhängigkeiten durchgekämpft
                                          ticaki Developer @OliverIO last edited by
                                          @mcu
                                          Ja das war ich, der das ansprochen hatte. Ist halt blöd das man nicht sofort beim nodejs-update eine Fehlermeldung bekommt, sondern irgendwann später mal.
                                            Thomas Braun Most Active @ticaki last edited by Thomas Braun
                                            Im aktuellen Code (aber noch nicht released) ist zumindest ein rudimentärer Check drin.
                                            Da wird nach dem nodejs-Ugrade ein
                                            cd /opt/iobroker
                                            npm i --dry-run
                                            ausgeführt und Fehler/Inkompaibilitäten werden dann ausgespuckt. Sieht dann im günstigsten Fall so aus:
                                            echad@chet:/opt/iobroker $ npm i --dry-run
                                            up to date in 6s
                                            248 packages are looking for funding
                                              run `npm fund` for details
                                            Im ungünstigen Fall kannst du eine ellenlange Liste mit Meldungen bekommen.
                                            489
