    4. [gelöst] Homekit-Controller stürzt ab
    • Falk 0
      Falk 0 last edited by Falk 0
      ich kann seit neuestem den HomeKit-Adapter nicht mehr starten. Neuinstallation des Adapters hilft nicht. Fehlermeldung ist:
      SyntaxError: Invalid or unexpected token
          at wrapSafe (node:internal/modules/cjs/loader:1472:18)
          at Module._compile (node:internal/modules/cjs/loader:1501:20)
          at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
          at Module.load (node:internal/modules/cjs/loader:1275:32)
          at Module._load (node:internal/modules/cjs/loader:1096:12)
          at Module.require (node:internal/modules/cjs/loader:1298:19)
          at require (node:internal/modules/helpers:182:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/json-bigint/lib/stringify.js:1:17)
          at Module._compile (node:internal/modules/cjs/loader:1529:14)
      Node.js v20.19.3
      Irgendwelche Ideen?
      Danke!
      • Adaptername: HomeKit-Controller
      • Link zu Adapterrepository: https://github.com/Apollon77/ioBroker.homekit-controller
      • Adapterversion: 0.5.11
      • js-controller Version: 7.0.6
      • Admin Version: 7.6.17
      • Hardwaresystem: AMD64
      • Arbeitsspeicher: .32GB
      • Festplattenart: SSD, HDD
      • Betriebssystem: Ubuntu 22.04
      • Nodejs-Version: v20.19.3
      • NPM-Version: 10.8.2
      • Installationsart: Skript, Docker
      • Image, Docker genutzt: Ja
      • Ort, Name der Imagedatei: iobroker/iobroker:latest
      Linux User bitte hier den Output von *iob diag* einfügen.
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
      Hardware Vendor : System manufacturer
      Kernel          : x86_64
      Userland        : 64 bit
      Docker          : v10.0.0
      Virtualization  : docker
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       22:45:55 up 20:30,  0 user,  load average: 5.45, 5.83, 6.11
      CPU threads: 12
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
      Tue Jul  1 20:45:55 UTC 2025
      Tue Jul  1 22:45:55 CEST 2025
      CEST +0200
      Etc/UTC
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      sudo: unable to resolve host iobroker: Name or service not known
      HOME=/opt/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:             33G         28G        673M         12G         17G        4.8G
      Swap:           8.6G        1.6G        7.0G
      Total:           42G         30G        7.7G
      Active iob-Instances:   5
              32009 M total memory
              27396 M used memory
              14705 M active memory
              15284 M inactive memory
                642 M free memory
                222 M buffer memory
              16099 M swap cache
               8191 M total swap
               1515 M used swap
               6676 M free swap
      top - 22:45:55 up 20:30,  0 user,  load average: 5.45, 5.83, 6.11
      Tasks:  12 total,   1 running,  11 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 75.0 us,  0.0 sy,  0.0 ni, 25.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  32009.5 total,    642.5 free,  27396.1 used,  16322.0 buff/cache
      MiB Swap:   8192.0 total,   6676.7 free,   1515.2 used.   4613.4 avail Mem
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem     Type     Size  Used Avail Use% Mounted on
      overlay        overlay  193G  163G   21G  89% /
      tmpfs          tmpfs     64M     0   64M   0% /dev
      shm            tmpfs     64M     0   64M   0% /dev/shm
      /dev/nvme0n1p2 xfs      466G  321G  145G  69% /opt/iobroker
      /dev/nvme0n1p1 ext4     193G  163G   21G  89% /etc/hosts
      tmpfs          tmpfs     16G     0   16G   0% /proc/asound
      tmpfs          tmpfs     16G     0   16G   0% /proc/acpi
      tmpfs          tmpfs     16G     0   16G   0% /proc/scsi
      tmpfs          tmpfs     16G     0   16G   0% /sys/firmware
      tmpfs          tmpfs     16G     0   16G   0% /sys/devices/virtual/powercap
      Show mounted filesystems:
      TARGET           SOURCE        FSTYPE OPTIONS
      /opt/iobroker    /dev/nvme0n1p2[/iobroker/data]        xfs    rw,relatime,attr2,inode64,logbufs=8,logbsize=32k,noquota
      /etc/resolv.conf /dev/nvme0n1p1[/var/lib/docker/containers/a97a839325b1f7e222fce0b705848411da2c04b1800bc3f22ab5c3c88201cfa2/resolv.conf] ext4   rw,relatime,errors=remount-ro
      /etc/hostname    /dev/nvme0n1p1[/var/lib/docker/containers/a97a839325b1f7e222fce0b705848411da2c04b1800bc3f22ab5c3c88201cfa2/hostname]    ext4   rw,relatime,errors=remount-ro
      /etc/hosts       /dev/nvme0n1p1[/var/lib/docker/containers/a97a839325b1f7e222fce0b705848411da2c04b1800bc3f22ab5c3c88201cfa2/hosts]       ext4   rw,relatime,errors=remount-ro
      /var:
      16M     /var/
      14M     /var/lib/dpkg
      14M     /var/lib
      13M     /var/lib/dpkg/info
      1.9M    /var/cache
      /opt/iobroker/backups:
      18M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      148M    /opt/iobroker/iobroker-data/
      74M     /opt/iobroker/iobroker-data/files
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      9.8M    /opt/iobroker/iobroker-data/files/homekit-controller.admin/static/js/main.f592ece1.js
      8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
      6.9M    /opt/iobroker/iobroker-data/states.jsonl
      3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.3
      /usr/bin/node           v20.19.3
      /usr/bin/corepack       0.32.0
      nodejs:
        Installed: 20.19.3-1nodesource1
        Candidate: 20.19.3-1nodesource1
        Version table:
       *** 20.19.3-1nodesource1 100
              100 /var/lib/dpkg/status
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1051)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     "javascript" not found
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
        system.adapter.homekit-controller.0     : homekit-controller    : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.net-tools.0              : net-tools             : iobroker                                 - disabled
      + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "homekit-controller": 0.5.11, installed 0.5.11
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
      Adapter    "tibberlink"   : 5.0.0    , installed 5.0.0
      Objects and States
      Objects:        584
      States:         496
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 5
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:39107           0.0.0.0:*               LISTEN      0          14321      -
      tcp        0      0 0.0.0.0:56091           0.0.0.0:*               LISTEN      130        39788      -
      tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      1000       57607      -
      tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      1000       50864      -
      tcp        0      0 0.0.0.0:5080            0.0.0.0:*               LISTEN      1000       44744021   -
      tcp        0      0 192.168.17.1:445        0.0.0.0:*               LISTEN      0          34714      -
      tcp        0      0 192.168.17.1:53         0.0.0.0:*               LISTEN      1000       44744007   -
      tcp        0      0 192.168.17.1:139        0.0.0.0:*               LISTEN      0          34715      -
      tcp        0      0 0.0.0.0:4000            0.0.0.0:*               LISTEN      0          47068      -
      tcp        0      0 0.0.0.0:36531           0.0.0.0:*               LISTEN      0          46085      -
      tcp        0      0 0.0.0.0:2443            0.0.0.0:*               LISTEN      0          47073      -
      tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          26363      -
      tcp        0      0 0.0.0.0:2080            0.0.0.0:*               LISTEN      0          47072      -
      tcp        0      0 192.168.17.1:1883       0.0.0.0:*               LISTEN      1883       51427      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54551      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54550      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54549      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54548      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54547      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54546      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54545      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54544      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54543      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54542      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54541      -
      tcp        0      0 0.0.0.0:3001            0.0.0.0:*               LISTEN      101        54529      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54540      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54539      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54538      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54537      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54536      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54535      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54534      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54533      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54532      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54531      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54530      -
      tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      101        54528      -
      tcp        0      0 0.0.0.0:2900            0.0.0.0:*               LISTEN      0          47074      -
      tcp        0      0 127.0.0.1:9500          0.0.0.0:*               LISTEN      1000       64977595   -
      tcp        0      0 127.0.0.1:9501          0.0.0.0:*               LISTEN      1000       64983011   -
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          21020      -
      tcp        0      0 0.0.0.0:32768           0.0.0.0:*               LISTEN      0          48736      -
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          39698      -
      tcp        0      0 0.0.0.0:32400           0.0.0.0:*               LISTEN      1000       50862      -
      tcp        0      0 0.0.0.0:45075           0.0.0.0:*               LISTEN      0          35288      -
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          34507      -
      tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      1000       44744009   -
      tcp        0      0 127.0.0.1:33963         0.0.0.0:*               LISTEN      1000       59737      -
      tcp        0      0 0.0.0.0:9990            0.0.0.0:*               LISTEN      1000       56978      -
      tcp        0      0 0.0.0.0:9982            0.0.0.0:*               LISTEN      100        53760      -
      tcp        0      0 0.0.0.0:9981            0.0.0.0:*               LISTEN      100        53757      -
      tcp        0      0 0.0.0.0:42623           0.0.0.0:*               LISTEN      0          37577      -
      tcp        0      0 127.0.0.1:3551          0.0.0.0:*               LISTEN      0          38804      -
      tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      1000       52655      -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       64978793   -
      tcp6       0      0 :::8000                 :::*                    LISTEN      0          54424      -
      tcp6       0      0 :::6443                 :::*                    LISTEN      9001       28514182   -
      tcp6       0      0 :::6080                 :::*                    LISTEN      9001       28514183   -
      tcp6       0      0 :::38421                :::*                    LISTEN      0          37579      -
      tcp6       0      0 :::5007                 :::*                    LISTEN      9001       28516510   -
      tcp6       0      0 fe80::eee7:a7ff:fe06:53 :::*                    LISTEN      1000       44744011   -
      tcp6       0      0 :::3389                 :::*                    LISTEN      1000       28515551   -
      tcp6       0      0 :::3306                 :::*                    LISTEN      999        52071      -
      tcp6       0      0 :::2049                 :::*                    LISTEN      0          37571      -
      tcp6       0      0 :::34163                :::*                    LISTEN      0          14331      -
      tcp6       0      0 :::33949                :::*                    LISTEN      0          35298      -
      tcp6       0      0 :::80                   :::*                    LISTEN      0          55391      -
      tcp6       0      0 :::111                  :::*                    LISTEN      0          28608      -
      tcp6       0      0 :::22                   :::*                    LISTEN      0          39700      -
      tcp6       0      0 :::49803                :::*                    LISTEN      130        39794      -
      tcp6       0      0 127.0.0.1:37665         :::*                    LISTEN      9001       28503601   -
      tcp6       0      0 127.0.0.1:8101          :::*                    LISTEN      9001       28501507   -
      tcp6       0      0 fdb3:ffe:b116:9b7b:e:53 :::*                    LISTEN      1000       44744015   -
      tcp6       0      0 :::60443                :::*                    LISTEN      0          35278      -
      tcp6       0      0 192.168.17.1:9124       :::*                    LISTEN      9001       28646390   -
      tcp6       0      0 :::9443                 :::*                    LISTEN      0          49846      -
      tcp6       0      0 :::9125                 :::*                    LISTEN      9001       28647305   -
      tcp6       0      0 :::9000                 :::*                    LISTEN      0          49848      -
      udp        0      0 0.0.0.0:32410           0.0.0.0:*                           1000       61602      -
      udp        0      0 0.0.0.0:32412           0.0.0.0:*                           1000       61603      -
      udp        0      0 0.0.0.0:32413           0.0.0.0:*                           1000       53081      -
      udp        0      0 0.0.0.0:32414           0.0.0.0:*                           1000       61601      -
      udp        0      0 127.0.0.1:53            0.0.0.0:*                           1000       44744008   -
      udp        0      0 192.168.17.1:53         0.0.0.0:*                           1000       44744006   -
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       44744003   -
      udp        0      0 192.168.17.1:49254      0.0.0.0:*                           1000       53088      -
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          23957      -
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           1000       44744821   -
      udp        0      0 192.168.17.255:137      0.0.0.0:*                           0          34680      -
      udp        0      0 192.168.17.1:137        0.0.0.0:*                           0          34679      -
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          39821      -
      udp        0      0 192.168.17.255:138      0.0.0.0:*                           0          34682      -
      udp        0      0 192.168.17.1:138        0.0.0.0:*                           0          34681      -
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          39822      -
      udp        0      0 172.17.0.1:49967        0.0.0.0:*                           1000       53096      -
      udp        0      0 192.168.20.1:33651      0.0.0.0:*                           1000       53090      -
      udp        0      0 192.168.20.1:50052      0.0.0.0:*                           1000       53095      -
      udp        0      0 127.0.0.1:1022          0.0.0.0:*                           0          39779      -
      udp        0      0 192.168.18.2:33865      0.0.0.0:*                           1000       53089      -
      udp        0      0 239.255.255.250:1900    0.0.0.0:*                           100        48651      -
      udp        0      0 0.0.0.0:1901            0.0.0.0:*                           1000       53092      -
      udp        0      0 0.0.0.0:35101           0.0.0.0:*                           130        39785      -
      udp        0      0 192.168.20.1:51617      0.0.0.0:*                           1000       53085      -
      udp        0      0 127.0.0.1:52576         0.0.0.0:*                           1000       53082      -
      udp        0      0 0.0.0.0:36463           0.0.0.0:*                           0          14316      -
      udp        0      0 192.168.17.1:53447      0.0.0.0:*                           1000       53093      -
      udp        0      0 172.17.0.1:37068        0.0.0.0:*                           1000       53086      -
      udp        0      0 0.0.0.0:38004           0.0.0.0:*                           0          35283      -
      udp        0      0 192.168.18.2:55479      0.0.0.0:*                           1000       53084      -
      udp        0      0 192.168.18.2:39921      0.0.0.0:*                           1000       53094      -
      udp        0      0 0.0.0.0:42024           0.0.0.0:*                           0          37576      -
      udp        0      0 0.0.0.0:43171           0.0.0.0:*                           0          14336      -
      udp        0      0 172.17.0.1:43689        0.0.0.0:*                           1000       53091      -
      udp        0      0 192.168.17.1:44918      0.0.0.0:*                           1000       53083      -
      udp        0      0 0.0.0.0:45251           0.0.0.0:*                           100        53814      -
      udp        0      0 127.0.0.1:45419         0.0.0.0:*                           1000       53087      -
      udp6       0      0 :::48969                :::*                                9001       28772514   -
      udp6       0      0 :::49122                :::*                                0          37578      -
      udp6       0      0 fdb3:ffe:b116:9b7b:e:53 :::*                                1000       44744014   -
      udp6       0      0 fe80::eee7:a7ff:fe06:53 :::*                                1000       44744010   -
      udp6       0      0 :::111                  :::*                                0          22636      -
      udp6       0      0 :::123                  :::*                                1000       44744506   -
      udp6       0      0 :::50667                :::*                                9001       28658771   -
      udp6       0      0 :::50668                :::*                                0          35293      -
      udp6       0      0 :::1900                 :::*                                9001       28624896   -
      udp6       0      0 :::1900                 :::*                                9001       28624895   -
      udp6       0      0 :::1900                 :::*                                9001       28624894   -
      udp6       0      0 :::1902                 :::*                                9001       28530834   -
      udp6       0      0 :::52525                :::*                                9001       63115862   -
      udp6       0      0 :::52640                :::*                                9001       28514847   -
      udp6       0      0 192.168.18.2:52826      :::*                                9001       28630018   -
      udp6       0      0 :::5353                 :::*                                9001       28656388   -
      udp6       0      0 :::5353                 :::*                                9001       28517416   -
      udp6       0      0 :::5353                 :::*                                9001       28508136   -
      udp6       0      0 :::5353                 :::*                                9001       28514228   -
      udp6       0      0 :::54814                :::*                                0          14326      -
      udp6       0      0 :::5683                 :::*                                9001       28663430   -
      udp6       0      0 :::55082                :::*                                9001       28768524   -
      udp6       0      0 :::6767                 :::*                                9001       28503948   -
      udp6       0      0 :::7090                 :::*                                9001       28777486   -
      udp6       0      0 192.168.20.1:40768      :::*                                9001       28630017   -
      udp6       0      0 :::58694                :::*                                130        39791      -
      udp6       0      0 :::42348                :::*                                9001       28766206   -
      udp6       0      0 :::42792                :::*                                0          46090      -
      udp6       0      0 192.168.17.1:42988      :::*                                9001       28630019   -
      2025-07-01 22:46:18.229  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.power[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/power]
      2025-07-01 22:46:18.229  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.lastMeterConsumption[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/lastMeterConsumption]
      2025-07-01 22:46:18.230  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.accumulatedConsumption[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/accumulatedConsumption]
      2025-07-01 22:46:18.230  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.accumulatedProduction[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/accumulatedProduction]
      2025-07-01 22:46:18.231  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.accumulatedConsumptionLastHour[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/accumulatedConsumptionLastHour]
      2025-07-01 22:46:18.231  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.accumulatedProductionLastHour[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/accumulatedProductionLastHour]
      2025-07-01 22:46:18.232  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.accumulatedCost[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/accumulatedCost]
      2025-07-01 22:46:18.233  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.accumulatedReward[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/accumulatedReward]
      2025-07-01 22:46:18.233  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.currency[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/currency]
      2025-07-01 22:46:18.234  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.minPower[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/minPower]
      2025-07-01 22:46:18.235  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.averagePower[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/averagePower]
      2025-07-01 22:46:18.235  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.maxPower[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/maxPower]
      2025-07-01 22:46:18.236  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.powerConsumption[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/powerConsumption]
      2025-07-01 22:46:18.237  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.powerProduction[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/powerProduction]
      2025-07-01 22:46:18.238  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.minPowerProduction[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/minPowerProduction]
      2025-07-01 22:46:18.239  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.maxPowerProduction[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/maxPowerProduction]
      2025-07-01 22:46:18.239  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.lastMeterProduction[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/lastMeterProduction]
      2025-07-01 22:46:18.241  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.powerFactor[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/powerFactor]
      2025-07-01 22:46:18.242  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.signalStrength[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/signalStrength]
      2025-07-01 22:46:18.242  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.voltagePhase1[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/voltagePhase1]
      2025-07-01 22:46:18.242  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.voltagePhase2[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/voltagePhase2]
      2025-07-01 22:46:18.243  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.voltagePhase3[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/voltagePhase3]
      2025-07-01 22:46:18.245  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.currentL1[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/currentL1]
      2025-07-01 22:46:18.245  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.currentL2[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/currentL2]
      2025-07-01 22:46:18.245  - info: mqtt.0 (221) send2Server tibberlink.0.Homes.e8ad9431-9b86-4916-8169-c2f122ef95f4.LiveMeasurement.currentL3[iobroker/tibberlink/0/Homes/e8ad9431-9b86-4916-8169-c2f122ef95f4/LiveMeasurement/currentL3]
      Falk 0 1 Reply Last reply Reply Quote 0
      • Falk 0
        Falk 0 @Falk 0 last edited by
        Nach einem kompletten Restart der Maschine zeigt sich das Problem nicht mehr.
