    4. [gelöst] Zigbee Adapter stürzt ab bei Aufruf
      Skippy07 last edited by Skippy07
      • Adaptername: Zigbee
      • Adapterversion: 2.0.5
      • js-controller Version: 7.0.6
      • Admin Version: 7.6.17
      • Hardwaresystem: i5-6500 CPU 3,2 GHz
      • Arbeitsspeicher: 16 GB
      • Festplattenart: SSD
      • Betriebssystem: Windows 11 Pro 23H2
      • Nodejs-Version: 22.17.0
      • NPM-Version: 10.9.2
      bei Aufruf des Zigbee Adapters stürzt dieser ab. Im Protokoll sind sind dann folgende Meldungen.
      host.MiniPC
      	2025-07-05 12:39:41.075	error	instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at Zigbee.<anonymous> (C:\ioBroker\node_modules\iobroker.zigbee\lib\seriallist.js:8:48)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at SerialList.onMessage (C:\ioBroker\node_modules\iobroker.zigbee\lib\seriallist.js:19:52)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at require (node:internal/modules/helpers:135:16)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at Module.require (node:internal/modules/cjs/loader:1487:12)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at Function._load (node:internal/modules/cjs/loader:1211:37)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1062:22)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at defaultResolveImpl (node:internal/modules/cjs/loader:1057:19)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: at Function._resolveFilename (node:internal/modules/cjs/loader:1401:15)
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: - C:\ioBroker\node_modules\iobroker.zigbee\main.js
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: - C:\ioBroker\node_modules\iobroker.zigbee\lib\seriallist.js
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: Require stack:
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[1]: Error: Cannot find module 'serialport'
      host.MiniPC
      	2025-07-05 12:39:41.074	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      zigbee.0
      	2025-07-05 12:39:40.443	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      	2025-07-05 12:39:40.435	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module 'serialport' Require stack: - C:\ioBroker\node_modules\iobroker.zigbee\lib\seriallist.js - C:\ioBroker\node_modules\iobroker.zigbee\main.js
      zigbee.0
      	2025-07-05 12:39:40.435	error	Error: Cannot find module 'serialport' Require stack: - C:\ioBroker\node_modules\iobroker.zigbee\lib\seriallist.js - C:\ioBroker\node_modules\iobroker.zigbee\main.js at Function._resolveFilename (node:internal/modules/cjs/loader:1401:15) at defaultResolveImpl (node:internal/modules/cjs/loader:1057:19) at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1062:22) at Function._load (node:internal/modules/cjs/loader:1211:37) at TracingChannel.traceSync (node:diagnostics_channel:322:14) at wrapModuleLoad (node:internal/modules/cjs/loader:235:24) at Module.require (node:internal/modules/cjs/loader:1487:12) at require (node:internal/modules/helpers:135:16) at SerialList.onMessage (C:\ioBroker\node_modules\iobroker.zigbee\lib\seriallist.js:19:52) at Zigbee.<anonymous> (C:\ioBroker\node_modules\iobroker.zigbee\lib\seriallist.js:8:48)
      zigbee.0
      	2025-07-05 12:39:40.433	error	unhandled promise rejection: Cannot find module 'serialport' Require stack: - C:\ioBroker\node_modules\iobroker.zigbee\lib\seriallist.js - C:\ioBroker\node_modules\iobroker.zigbee\main.js
      zigbee.0
      	2025-07-05 12:39:40.431	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Bis vor 2 Tagen ist mir dieses Problem nicht aufgefallen und es läuft auch sonst alles problemlos. Nur wenn ich den Zigbee Adapter selbst aufrufe sind die Probleme da und alle Kacheln mit den verschiedenen Geräten sind erstmal weg. Wenn ich den Adapter dann neu starte sind die Kacheln wieder da.
      Ich habe schon probiert alle Geräte zu deaktivieren, aber bei erneutem Aufruf des Adapters kommen wieder die Meldungen.
      Die Datei "seriallist.js" ist im Dateisystem vorhanden und lässt sich auch in "Notepad++" öffnen.
      Hat jemand eine Idee, wo das Problem sein könnte?
      VG Stefan
        Thomas Braun Most Active @Skippy07 last edited by
        @skippy07
        Da wir das Modul serialport neu gebaut werden müssen.
        Für Windows kann ich dir aber nichts genaueres sagen, wie das da geht.
        S 1 Reply Last reply Reply Quote -1
          Skippy07 @Thomas Braun last edited by
          @thomas-braun Danke für die Antwort.
          Was meinst Du mit Modul neu bauen? Das ist eine JS Datei. Ich habe aber mal die Datei aus einen Backup kopiert, das brachte aber wie vorab vermutet keine Änderung.
          Hat sonst noch jemand eine Idee?
            Homoran Global Moderator Administrators @Skippy07 last edited by
            @skippy07 sagte in Zigbee Adapter stürzt ab bei Aufruf:
            klar istces das, aber duese Datei wird passend für dein System gebaut.
            Wenn OS, node usw. nicht identisch sind klappt das eben gar nicht.
            Wenn die Datei damals schon defekt war auch nicht
              Das funktioniert nicht. Module (hier halt 'serialport') müssen binär gegen die entsprechenden anderen Pakete gebaut werden.
                iob url serialport
                im iobroker verzeichniss
                  Skippy07 @arteck last edited by
                  @arteck
                  Vielen Dank, jetzt funktioniert es wieder:
                  Danke auch an @Thomas-Braun und @Homoran
                  absturz error zigbee
