    4. Pflege des Betriebssystems
    5. Update Adapter Worx Landroid v3.2.0 auf 3.2.6 Axios Fehler
      Powertrain01 last edited by
      Ich bekomme das Update vom Worx adapter nicht hin bekomme immer einen Axios Fehler das er Axiom 1.9.0 nicht findet.
      Job update und uprgade habe ich schon mehrfach gemacht ebenso Lob fix
      ich hab auch schon nodes 20 neu installieren lasen.
      hier mal die ausgabe vom iob diag:
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : 32 bit
      Systemuptime and Load:
       08:53:30 up 13 days, 19:57,  2 users,  load average: 1.01, 1.74, 2.16
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-07-13 08:53:31 CEST
                 Universal time: Sun 2025-07-13 06:53:31 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.3G        2.2G        4.5G        1.1M        1.7G        6.1G
      Swap:           209M          0B        209M
      Total:          8.5G        2.2G        4.8G
      Active iob-Instances:   36
               7898 M total memory
               2080 M used memory
                888 M active memory
               2471 M inactive memory
               4336 M free memory
                333 M buffer memory
               1334 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 08:53:31 up 13 days, 19:57,  2 users,  load average: 1.25, 1.77, 2.17
      Tasks: 165 total,   1 running, 164 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 11.1 us, 22.2 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7898.7 total,   4335.0 free,   2082.4 used,   1668.0 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5816.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      56 CRITICAL ERRORS DETECTED!
      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
      *** FILESYSTEM ***
      /dev/root      ext4       59G   17G   40G  30% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
      tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
      /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      [Sun Jun 29 12:55:55 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:D7:62:FF vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=3c507973-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Sun Jun 29 12:55:56 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Sun Jun 29 12:55:56 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Sun Jun 29 12:55:59 2025] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      Show mounted filesystems:
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      2.1G    /var/
      1.5G    /var/log/journal/8e58b1ab43b84d8f9f6cff709545957b
      1.5G    /var/log
      230M    /var/lib
      Archived and active journals take up 1.4G in the file system.
      /opt/iobroker/backups:
      610M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.6G    /opt/iobroker/iobroker-data/
      1.2G    /opt/iobroker/iobroker-data/files
      635M    /opt/iobroker/iobroker-data/files/vis-2-beta
      545M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
      543M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
      106M    /opt/iobroker/iobroker-data/states.jsonl
      49M     /opt/iobroker/iobroker-data/objects.jsonl
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyACM0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.1
      /usr/bin/node           v20.19.1
      /usr/bin/npm            11.4.2
      /usr/bin/npx            11.4.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.1-1nodesource1
        Candidate: 20.19.1-1nodesource1
        Version table:
       *** 20.19.1-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           20.19.0-1nodesource1 600
           20.18.3-1nodesource1 600
           20.18.2-1nodesource1 600
           20.18.1-1nodesource1 600
           20.18.0-1nodesource1 600
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main armhf Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main armhf Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 1034)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     2
      +-- iobroker.euhome@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.euhome.git#084d3e93ea1dac3784775ef7f2e7b9a18b21f2eb)
      +-- iobroker.time-switch@2.2.1 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#f24abb3a0b416bc21e7315e7cfa10ba3261f4bfe)
      Adapter State
      + system.adapter.asterisk.0               : asterisk              : raspberrypi                              -  enabled, port: 5038
      + system.adapter.bshb.0                   : bshb                  : raspberrypi                              -  enabled
        system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
      + system.adapter.euhome.0                 : euhome                : raspberrypi                              -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              -  enabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      + system.adapter.fhem.0                   : fhem                  : raspberrypi                              -  enabled, port: 7072
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : raspberrypi                              -  enabled
      + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.1               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.influxdb.2               : influxdb              : raspberrypi                              -  enabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
      + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.mclighting.0             : mclighting            : raspberrypi                              - disabled, port: 81
      + system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
      + system.adapter.onvif.0                  : onvif                 : raspberrypi                              -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
        system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              -  enabled
        system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.sun2000.0                : sun2000               : raspberrypi                              - disabled, port: 502
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.time-switch.0            : time-switch           : raspberrypi                              -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
      + system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
        system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
      + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
      + system.adapter.xterm.0                  : xterm                 : raspberrypi                              -  enabled, port: 8099, bind: 0.0.0.0
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyACM0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "asterisk"     : 2.0.3    , installed 2.0.3
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Adapter    "bshb"         : 0.5.0    , installed 0.5.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "fb-checkpresence": 1.4.0 , installed 1.4.0
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fhem"         : 3.0.0    , installed 3.0.0
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "heatingcontrol": 2.12.14 , installed 2.12.14
      Adapter    "hue"          : 3.16.1   , installed 3.16.1
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mclighting"   : 0.2.0    , installed 0.2.0
      Adapter    "net-tools"    : 1.1.2    , installed 1.1.2
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "ph803w"       : 1.2.0    , installed 1.2.0
      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
      Adapter    "shelly"       : 10.0.0   , installed 10.0.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sun2000"      : 1.4.0    , installed 1.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "worx"         : 3.2.6    , installed 3.2.0  [Updatable]
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "xterm"        : 2.0.1    , installed 2.0.1
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Objects and States
      Objects:        36236
      States:         31146
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       11401402   22155/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12046      538/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14523      721/influxd
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          13675      985/exim4
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11403342   21614/io.shelly.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11399436   21558/io.sonoff.0
      tcp        0      0 0.0.0.0:44417           0.0.0.0:*               LISTEN      1001       11400545   21895/io.yahka.0
      tcp        0      0 0.0.0.0:41061           0.0.0.0:*               LISTEN      1001       11400543   21895/io.yahka.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11395832   21295/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11396289   21295/iobroker.js-c
      tcp        0      0 127.0.0.1:36877         0.0.0.0:*               LISTEN      1001       11402568   21895/io.yahka.0
      tcp        0      0 127.0.0.1:34319         0.0.0.0:*               LISTEN      1001       11402572   21895/io.yahka.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11396368   21313/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11401317   21747/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        14573      721/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12048      538/sshd: /usr/sbin
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       11401346   21976/io.simple-api
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          13676      985/exim4
      tcp6       0      0 :::8099                 :::*                    LISTEN      1001       11399662   21677/io.xterm.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       11400211   21441/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       11400212   21441/io.tuya.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11972      370/avahi-daemon: r
      udp        0      0 0.0.0.0:54104           0.0.0.0:*                           108        11974      370/avahi-daemon: r
      udp6       0      0 fe80::d118:265b:8cb:546 :::*                                0          14375      495/NetworkManager
      udp6       0      0 :::5353                 :::*                                108        11973      370/avahi-daemon: r
      udp6       0      0 :::35153                :::*                                108        11975      370/avahi-daemon: r
      2025-07-13 08:50:32.541  - info: dwd.0 (22819) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.1, js-controller: 7.0.6
      2025-07-13 08:50:33.853  - info: dwd.0 (22819) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-07-13 08:50:34.336  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
      2025-07-13 08:50:34.337  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
      2025-07-13 08:50:34.387  - info: host.raspberrypi instance system.adapter.dwd.0 having pid 22819 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-07-13 08:51:11.670  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
      2025-07-13 08:51:11.673  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
      2025-07-13 08:51:34.847  - info: shelly.0 (21614) [MQTT] Client Error: 192.168.89.59 (shellyswitch25 / shellyswitch25-E8DB84ABDD39 / SHSW-25#E8DB84ABDD39#1) (Error: read ECONNRESET)
      2025-07-13 08:51:36.812  - info: shelly.0 (21614) [MQTT] Device with client id "shellyswitch25-E8DB84ABDD39" connected from 192.168.89.59!
      2025-07-13 08:51:41.692  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
      2025-07-13 08:51:41.693  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
      2025-07-13 08:52:12.801  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
      2025-07-13 08:52:12.802  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
      2025-07-13 08:52:42.824  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
      2025-07-13 08:52:42.827  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
      2025-07-13 08:53:12.931  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
      2025-07-13 08:53:12.932  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
      2025-07-13 08:53:44.128  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
      2025-07-13 08:53:44.130  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
      2025-07-13 08:54:01.944  - info: shelly.0 (21614) [MQTT] Client Error: 192.168.89.59 (shellyswitch25 / shellyswitch25-E8DB84ABDD39 / SHSW-25#E8DB84ABDD39#1) (Error: read ECONNRESET)
      2025-07-13 08:54:04.088  - info: shelly.0 (21614) [MQTT] Device with client id "shellyswitch25-E8DB84ABDD39" connected from 192.168.89.59!
      2025-07-13 08:54:21.296  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
      2025-07-13 08:54:21.298  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
      2025-07-13 08:54:58.497  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetOut)
      2025-07-13 08:54:58.498  - error: fhem.0 (21470) Error: connect ECONNREFUSED 192.168.89.36:7072 (telnetIn)
      iob diag has finished.
      Danke für die Unterstützung.
      Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Powertrain01 last edited by Thomas Braun
        @powertrain01
        Das Betriebssystem ist falsch aufgesetzt. Haste von einer Vorversion versucht per 'inline'-Update auf 'Bookworm zu hieven.
        Funktioniert aber nicht.
        Installier da komplett neu das aktuelle RaspberryOS-Lite-64Bit.
        • mcm1957
          mcm1957 @Powertrain01 last edited by
          @powertrain01
          Du hast lt. iob diag worx 3.2.0 installiert.
          Bitte zeig wann du welche Fehlermeldung bezüglich axios erhälts, also bei der Installation oder beim Adapterstart oder ,.. Gib auch an von wo du installierst (github, nom, latest / stable Repo ...)
          Und zeig die vollständigen Fehlerinformatione / Logfile dazu.
          worx verlangt übrigends axios >= 1.10.0. Insofern ist deine Angabe 1.9.0 nicht auf Anhieb nachvollziehbar.
            Homoran Global Moderator Administrators @mcm1957 last edited by
            @mcm1957 sagte in Update Adapter Worx Landroid v3.2.0 auf 3.2.6 Axios Fehler:
            https://forum.iobroker.net/post/1282831
              Powertrain01 @Thomas Braun last edited by Powertrain01
              das habe ich fast schon befürchtet das das wohl der weg sein wird.
              würdest du in diesem Zusammenhang dann gleich auf docker wechseln?
              hab hier noch einen neuen Raspberry dann werde ich den wohl nächste Woche mal Installieren.
                @powertrain01
                Dann kannst du auch gleich die anderen Kinken angehehn.
                Stromversorgung, Zigbee-Gerät usw.
                81.1k
