    4. [gelöst] backup error von influxdb2 remote
      tklein last edited by tklein
      hi,
      bei meinen neuen proxmox containern kann ich gerade von dem iobroker container via iobroker backup leider kein db backup vom remote influxdb2 container machen:
      2025-07-14 09:31:38.837	error	[iobroker/clean] Backup files not deleted from /opt/iobroker/backups because some errors.
      2025-07-14 09:31:35.663	error	[iobroker] Error: Command failed: "/usr/bin/influx" backup --bucket iobroker --host http://192.168.0.23:8086 -t token "/opt/iobroker/backups/influxDB_2025_07_14-09_31_35_backupiobroker" /bin/sh: 1: /usr/bin/influx: not found
      2025-07-14 09:31:35.663	error	[iobroker/influxDB] /bin/sh: 1: /usr/bin/influx: not found
      in der kommandozeile auf dem iobroker klappt es:
      iobroker@iobroker:/opt/iobroker/backups$ influx backup --bucket iobroker --host http://192.168.0.23:8086 -t token "/opt/iobroker/backups/influxDB_2025_07_14-09_19_09_backupiobroker_1"
      was kann ich ändern bzw mache was falsch?
        Homoran Global Moderator Administrators @tklein last edited by
        @tklein bitte keine Screenshots von Logs oder Konsoleltext!
          tklein @Homoran last edited by
          @homoran sorry, update done
            das ergab leider auch keine veränderung:
            iobroker@iobroker:/opt/iobroker/backups$ sudo apt remove influxdb-client
            Reading package lists... Done
            Building dependency tree... Done
            Package 'influxdb-client' is not installed, so not removed
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            • Marc Berg
              Marc Berg Most Active @tklein last edited by
              @tklein sagte in backup error von influxdb2 remote:
              sudo apt install influxdb2-client
                @marc-berg brauche ich den denn?
                hatte das hier gelesen:
                https://forum.iobroker.net/topic/68847/gelöst-backitup-bin-sh-1-influx-not-found/46?_=1752478919614
                • Marc Berg
                  ja.
                    tklein @Marc Berg last edited by
                    @marc-berg obwohl es per console geht?
                    iobroker@iobroker:/opt/iobroker/backups$ influx backup --bucket iobroker --host http://192.168.0.23:8086 -t token "/opt/iobroker/backups/influxDB_2025_07_14-09_19_09_backupiobroker_2"
                    2025/07/14 09:45:52 INFO: Downloading metadata snapshot
                    2025/07/14 09:45:52 INFO: Backing up TSM for shard 1
                    2025/07/14 09:45:52 INFO: Backing up TSM for shard 2
                    • Marc Berg
                      Console im Container?
                      Dann ist vielleicht der Pfad in Backitup falsch? Was steht da drin?
                      Was sagt
                      which influx
                        @marc-berg
                        ja in der console im iobroker container
                        iobroker@iobroker:/opt/iobroker/backups$ which influx
                        /usr/local/bin/influx
                        • Marc Berg
                          Marc Berg Most Active @tklein last edited by Marc Berg
                          @tklein sagte in [backup
                          error von influxdb2 remote](/post/1283150):
                          Richtig:
                          Falsch:
                          /usr/bin/influx
                          EDIT: oder einfach das Feld in backitup leer lassen
                            @marc-berg oh man danke. das war es. da hätte ich selbst drauf kommen können/müssen
                            526
