    4. [GELÖST]Node.js update will nicht wie es soll
    • Michael Schmitt
      Michael Schmitt last edited by Michael Schmitt
      mir wird ein Node.js update angezeigt, aber es will nicht updaten.
      Ich hab wie immer den Raspi geupdatet und dabei sollte das ja mitlaufen =
      sudo apt update
      sudo apt full-upgrade
      sudo reboot
      dann hab ich mal den fixer laufen lassen, aber auch nix.
      Wo ist der Fehler begraben ?
      Hier ein iob diag
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
      Operating System: Raspbian GNU/Linux 12 (bookworm)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
      OS is similar to: debian
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 32 bit
      Systemuptime and Load:
       11:14:14 up 4 days, 16:12,  2 users,  load average: 0.36, 0.36, 0.36
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2025-07-16 11:14:15 CEST
                 Universal time: Wed 2025-07-16 09:14:15 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth redis gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        1.4G        1.5G        1.1M        1.2G        2.6G
      Swap:           209M          0B        209M
      Total:          4.2G        1.4G        1.7G
      Active iob-Instances:   20
               3793 M total memory
               1299 M used memory
               1329 M active memory
                723 M inactive memory
               1463 M free memory
                261 M buffer memory
                845 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 11:14:15 up 4 days, 16:12,  2 users,  load average: 0.36, 0.36, 0.36
      Tasks: 155 total,   1 running, 154 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 71.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3793.3 total,   1462.2 free,   1300.6 used,   1106.9 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2492.8 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4      220G  9.1G  202G   5% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.1M  758M   1% /run
      tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
      /dev/sda1      vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Fri Jul 11 19:01:58 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:05:E3:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=fae45d57-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Fri Jul 11 19:02:01 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Jul 11 19:02:01 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Fri Jul 11 19:02:05 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      1.6G    /var/
      1.1G    /var/log/journal/17d80a2ed91e4fbcb19dfd9141eb79e6
      1.1G    /var/log
      241M    /var/cache
      Archived and active journals take up 1.0G in the file system.
      /opt/iobroker/backups:
      197M    /opt/iobroker/backups/
      908K    /opt/iobroker/backups/scripte
      904K    /opt/iobroker/backups/scripte/common
      124K    /opt/iobroker/backups/scripte/common/Licht_Wecker
      100K    /opt/iobroker/backups/scripte/common/Wichtig
      /opt/iobroker/iobroker-data:
      430M    /opt/iobroker/iobroker-data/
      243M    /opt/iobroker/iobroker-data/files
      140M    /opt/iobroker/iobroker-data/backup-objects
      48M     /opt/iobroker/iobroker-data/files/iot.admin
      47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      26M     /opt/iobroker/iobroker-data/objects.jsonl
      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
      8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2419780-if00
      *** ZigBee Settings ***
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.1
      /usr/bin/node           v20.19.1
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.1-1nodesource1
        Candidate: 20.19.1-1nodesource1
        Version table:
       *** 20.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2+rpi1 500
              500 http://raspbian.raspberrypi.org/raspbian bookworm/main armhf Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 319165)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.admin.1                  : admin                 : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
        system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi                              -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
      + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 192.168.178.42, run as: admin
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'stable'           │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 2       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "deconz"       : 1.6.4    , installed 1.6.4
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        5073
      States:         3901
      Hit:1 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
      Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
      Hit:3 https://phoscon.de/apt/deconz bookworm InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2162591    3021/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2162598    3021/iobroker.js-co
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        15484      549/redis-server 12
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       13906      397/deCONZ
      tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       2165641    3734/io.socketio.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12861      568/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       15483      397/deCONZ
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2167214    3656/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2164910    3076/io.admin.0
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2166557    3806/io.simple-api.
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       2164443    3111/io.admin.1
      tcp6       0      0 ::1:6379                :::*                    LISTEN      109        15485      549/redis-server 12
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12863      568/sshd: /usr/sbin
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       2163664    3341/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       13915      397/deCONZ
      udp        0      0 0.0.0.0:43889           0.0.0.0:*                           108        12758      392/avahi-daemon: r
      udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       2166347    3424/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12756      392/avahi-daemon: r
      udp6       0      0 :::40518                :::*                                108        12759      392/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       2163667    3341/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       2163666    3341/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       2163665    3341/io.deconz.0
      udp6       0      0 fe80::f396:6d7a:b9a:546 :::*                                0          15613      515/NetworkManager
      udp6       0      0 :::5353                 :::*                                108        12757      392/avahi-daemon: r
      2025-07-16 11:01:36.167  - info: host.raspberrypi iobroker upload [12] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/notifications.jsonConfig.json5 notifications.jsonConfig.json5 application/json5
      2025-07-16 11:01:36.177  - info: host.raspberrypi iobroker upload [11] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/onedrive.jsonConfig.json5 onedrive.jsonConfig.json5 application/json5
      2025-07-16 11:01:36.185  - info: host.raspberrypi iobroker upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/pgsql.jsonConfig.json5 pgsql.jsonConfig.json5 application/json5
      2025-07-16 11:01:36.193  - info: host.raspberrypi iobroker upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/redis.jsonConfig.json5 redis.jsonConfig.json5 application/json5
      2025-07-16 11:01:36.201  - info: host.raspberrypi iobroker upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/restore.jsonConfig.json5 restore.jsonConfig.json5 application/json5
      2025-07-16 11:01:36.210  - info: host.raspberrypi iobroker upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/sqlite.jsonConfig.json5 sqlite.jsonConfig.json5 application/json5
      2025-07-16 11:01:36.218  - info: host.raspberrypi iobroker upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      2025-07-16 11:01:36.226  - info: host.raspberrypi iobroker upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      2025-07-16 11:01:36.234  - info: host.raspberrypi iobroker upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      2025-07-16 11:01:36.242  - info: host.raspberrypi iobroker upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      2025-07-16 11:01:36.250  - info: host.raspberrypi iobroker upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/webdav.jsonConfig.json5 webdav.jsonConfig.json5 application/json5
      2025-07-16 11:01:36.258  - info: host.raspberrypi iobroker upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      2025-07-16 11:01:36.269  - info: host.raspberrypi iobroker upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/zigbee2mqtt.jsonConfig.json5 zigbee2mqtt.jsonConfig.json5 application/json5
      2025-07-16 11:01:36.277  - info: host.raspberrypi iobroker host.raspberrypi Adapter "system.adapter.backitup.0" is started
      2025-07-16 11:01:36.357  - info: host.raspberrypi "system.adapter.backitup.0" enabled
      2025-07-16 11:01:37.604  - info: host.raspberrypi instance system.adapter.backitup.0 in version "3.3.5" started with pid 748
      2025-07-16 11:01:37.674  - info: host.raspberrypi iobroker exit 0
      2025-07-16 11:01:40.540  - info: javascript.0 (3147) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram['Michael']: backitup.0 is connected
      false
      Adapter NICHT erreichbar
      2025-07-16 11:01:41.044  - info: backitup.0 (748) starting. Version 3.3.5 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.1, js-controller: 7.0.6
      2025-07-16 11:01:41.151  - info: backitup.0 (748) [iobroker] backup will be activated at 03:35 every 1 day(s)
      2025-07-16 11:02:26.108  - info: javascript.0 (3147) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram['Michael']: backitup.0 is connected
      true
      Adapter ist wieder erreichbar
      haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
      • haselchen
        haselchen Most Active @Michael Schmitt last edited by
        @michael-schmitt
        Von Deiner Frage mal abgesehen.
        Wieso hast Du 2 Admin Instanzen?
        Michael Schmitt 1 Reply Last reply Reply Quote 0
        • Michael Schmitt
          Michael Schmitt @haselchen last edited by Michael Schmitt
          @haselchen wenn ich mich recht erinnere war dass wegen iobroker cloud einmal mit https und einmal http
          • haselchen
            @michael-schmitt
            Benutzt Du die Cloud?
            Fernzugriff?
            • Michael Schmitt
              @haselchen ab und zu, aber nicht zum updaten oder so
                Thomas Braun Most Active @Michael Schmitt last edited by
                @michael-schmitt sagte in Node.js update will nicht wie es soll:
                Userland : 32 bit
                Nicht direkt Problemursache, aber bring das auf ein reines 64Bit-System -> Neuinstallation, dann wird auch die Boot-Partition richtig eingehängt. Bei dir werden im Moment die aktuellen Kernel nicht geladen...
                Zum Problem: Die 20.19.3 ist ganz frisch veröffentlicht und noch nicht von nodesource gepackt worden. Abwarten, kann bei der 32Bit-Version ein paar Tage dauern, da ist kein Fokus mehr drauf.
                Michael Schmitt Thomas Braun 2 Replies Last reply Reply Quote 1
                • Michael Schmitt
                  Michael Schmitt @Thomas Braun last edited by
                  @thomas-braun ok THX
                    Thomas Braun Most Active @Thomas Braun last edited by
                    @thomas-braun sagte in Node.js update will nicht wie es soll:
                    Die 64Bit-Version ist nämlich schon als 20.19.4-1nodesource1 vorhanden:
                    echad@chet:~ $ apt policy nodejs
                    nodejs:
                      Installed: 24.4.1-1nodesource1
                      Candidate: 20.19.4-1nodesource1
                      Version table:
                     *** 24.4.1-1nodesource1 100
                         20.19.4-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                         20.19.3-1nodesource1 1001
                    usw...
                    • Michael Schmitt
                      @thomas-braun Erledigt 🙂
                      Hatte ein wenig bammel, aber ich hab das einfach auf einer neuen SSD probiert. Da noch Deconz mit dabei war, aber so wie es aussieht hat dass mit Iobroker neu und Backup einspielen + Deconz neu und Backup einspielen alles funktioniert. Schau mal bitte ob noch was zu tun ist !!
                      Hier mal ein aktuelles iob diag
                      ```bash
                      Script v.2025-03-08
                      *** BASE SYSTEM ***
                             Icon name: computer
                                Kernel: Linux 6.12.34+rpt-rpi-v8
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                       15:22:50 up  1:08,  2 users,  load average: 1.24, 1.12, 0.80
                      CPU threads: 4
                      Current issues:
                                     Local time: Wed 2025-07-16 15:22:50 CEST
                                 Universal time: Wed 2025-07-16 13:22:50 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            4.0G        1.7G        587M        6.2M        1.8G        2.3G
                      Swap:           536M          0B        536M
                      Total:          4.5G        1.7G        1.1G
                               3795 M total memory
                               1593 M used memory
                               1551 M active memory
                               1379 M inactive memory
                                561 M free memory
                                112 M buffer memory
                               1634 M swap cache
                                511 M total swap
                                  0 M used swap
                                511 M free swap
                      top - 15:22:51 up  1:08,  2 users,  load average: 1.24, 1.12, 0.80
                      Tasks: 192 total,   1 running, 191 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3795.9 total,    561.6 free,   1593.2 used,   1746.9 buff/cache
                      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2202.7 avail Mem
                      *** FILESYSTEM ***
                      udev           devtmpfs  1.6G     0  1.6G   0% /dev
                      tmpfs          tmpfs     380M  5.9M  374M   2% /run
                      /dev/sda2      ext4      220G  4.6G  204G   3% /
                      /dev/sda1      vfat      510M   57M  454M  11% /boot/firmware
                      [Wed Jul 16 14:14:26 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:05:E3:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=e74f749d-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Wed Jul 16 14:14:28 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                      [Wed Jul 16 14:14:29 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
                      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      891M    /var/
                      205M    /var/cache
                      200M    /var/cache/apt
                      174M    /var/lib
                      135M    /var/lib/apt/lists
                      Archived and active journals take up 4.7M in the file system.
                      5.0M    /opt/iobroker/backups/
                      219M    /opt/iobroker/iobroker-data/
                      200M    /opt/iobroker/iobroker-data/files
                      47M     /opt/iobroker/iobroker-data/files/admin.admin
                      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                      18M     /opt/iobroker/iobroker-data/objects.jsonl
                      8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                      4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/nodejs         v20.19.4
                      /usr/bin/node           v20.19.4
                      /usr/bin/corepack       0.32.0
                      nodejs:
                        Installed: 20.19.4-1nodesource1
                        Version table:
                       *** 20.19.4-1nodesource1 1001
                           20.19.2-1nodesource1 1001
                           18.19.0+dfsg-6~deb12u2 500
                           18.19.0+dfsg-6~deb12u1 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 379)
                      admin:          7.6.17
                      javascript:     8.9.2
                      Adapter State
                        system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                      + instance is alive
                      Adapter    "iot"          : 3.3.0    , installed 3.6.0
                      Adapter    "ws"           : 2.6.2    , installed 3.0.19
                      Objects and States
                      Objects:        5073
                      States:         3980
                      Hit:3 http://phoscon.de/apt/deconz generic InRelease
                      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       64792      16532/iobroker.js-c
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       64797      16532/iobroker.js-c
                      tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       66341      16990/io.socketio.0
                      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       50859      14146/deCONZ
                      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       50840      14146/deCONZ
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5323       609/sshd: /usr/sbin
                      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       63963      16561/io.admin.1
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       62933      16550/io.admin.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       63474      17031/io.web.0
                      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       65463      16975/io.simple-api
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          5325       609/sshd: /usr/sbin
                      udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       65417      16809/io.tr-064.0
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5271       470/avahi-daemon: r
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       64183      16760/io.deconz.0
                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       50862      14146/deCONZ
                      udp        0      0 0.0.0.0:57216           0.0.0.0:*                           104        5273       470/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                104        5272       470/avahi-daemon: r
                      udp6       0      0 :::1900                 :::*                                1001       64186      16760/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       64185      16760/io.deconz.0
                      udp6       0      0 :::1900                 :::*                                1001       64184      16760/io.deconz.0
                      udp6       0      0 fe80::62d5:ebcd:e5c:546 :::*                                0          690        548/NetworkManager
                      udp6       0      0 :::35718                :::*                                104        5274       470/avahi-daemon: r
                        @michael-schmitt
                        Ja, jetzt passt es.
                          Homoran Global Moderator Administrators @Michael Schmitt last edited by
                          da ist ein Repo zuviel.
                          Hast du ggf. auch eine Host-Leiche unter system.host. (im Expertenmodus)?
                          • Michael Schmitt
                            Michael Schmitt @Homoran last edited by
                            @homoran das hatte ich da mal reingemacht weil irgendwas mit dem update nicht funktioniert hatt (ist scho eeeeewig her)
                              hat aber den selben Pfad hinterlegt.
                              Dann brauchst du es nicht
                              Michael Schmitt 1 Reply Last reply Reply Quote 1
                              • Michael Schmitt
                                @homoran ich hab jetzt mal den Haken beim zweiten rein gemacht und wenn damit auch alles läuft werde ich das doppelte löschen 😉
                                • bergjet
                                  bergjet last edited by
                                  Inzwischen gibt es node.js 20.19.4 Aber ich bekomm das auch nicht drauf. Es bleibt bei 20.19.1
                                  Ich habe das Update nach jeder neuen Version versucht.
                                    Thomas Braun Most Active @bergjet last edited by Thomas Braun
                                    @bergjet sagte in Node.js update will nicht wie es soll:
                                    sudo apt update
                                    apt policy nodejs
                                    liefert?
                                    Edit: Wird aber vermutlich mit einem 32Bit-System zusammenhängen. In wenigen Wochen wird wohl Debian/RaspberryOS 13 'Trixie' veröffentlicht werden. Ich würde dann darauf per Neuinstallation umsatteln.
                                    bergjet 1 Reply Last reply Reply Quote 0
                                    • bergjet
                                      bergjet @Thomas Braun last edited by
                                      pi@pi4:~ $ apt policy nodejs
                                      nodejs:
                                        Installiert:           20.19.1-1nodesource1
                                        Installationskandidat: 20.19.1-1nodesource1
                                        Versionstabelle:
                                           12.22.12~dfsg-1~deb11u7 500
                                      pi@pi4:~ $
                                        @bergjet
                                        Ja, also eine 32Bit-Kiste.
                                        Bring das per NEUINSTALLATION auf die 64Bit-Lite-Basis.
                                        • G
                                          Gerhardptl @Thomas Braun last edited by
                                          Hallo Thomas, habe das gleiche Problem - gibt es eine Anleitung wie man das System auf 64 bit umstellt?
                                            Thomas Braun Most Active @Gerhardptl last edited by Thomas Braun
                                            @gerhardptl sagte in [GELÖST]Node.js update will nicht wie es soll:
                                            Installier es NEU.
                                            Ich würde jetzt aber noch die paar Tage abwarten, bis Debian 13 'Trixie' veröffentlicht wird.
                                            1373
