    4. Pflege des Betriebssystems
    5. Speicherplatz Influx
      Smartuser_1 last edited by
      ich habe leider die Meldung bekommen, daß mein Speicherplatz nicht mehr ausreicht. "Your system has only 0.19 % of disk space left."
      Ich habe iob diag ausgeführt und unten angehängte Rückmeldung bekommen. Wenn ich das richtig sehe, habe ich ein Problem mit Influx.
      Sind da irgendwelche Kopien abgelegt bzw. was könnte ich optimieren?
      Danke & Vg
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: raspberrypi5
             Icon name: computer
                Kernel: Linux 6.6.74+rpt-rpi-2712
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       13:02:40 up  1:11,  2 users,  load average: 0.07, 0.09, 0.33
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      ~ Throttling has occurred
      ~ Soft temperature limit has occurred
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-07-27 13:02:40 CEST
                 Universal time: Sun 2025-07-27 11:02:40 UTC
                       RTC time: Sun 2025-07-27 11:02:40
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      uld
      HOME=/home/uld
      GROUPS=uld adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.4G        1.9G        4.4G        7.5M        2.2G        6.5G
      Swap:           268M          0B        268M
      Total:          8.7G        1.9G        4.7G
      Active iob-Instances:   20
               8052 M total memory
               1846 M used memory
               2423 M active memory
               1143 M inactive memory
               4210 M free memory
                111 M buffer memory
               1987 M swap cache
                255 M total swap
                  0 M used swap
                255 M free swap
      top - 13:02:40 up  1:11,  2 users,  load average: 0.07, 0.09, 0.33
      Tasks: 187 total,   1 running, 186 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8052.2 total,   4209.5 free,   1846.9 used,   2099.9 buff/cache
      MiB Swap:    255.7 total,    255.7 free,      0.0 used.   6205.3 avail Mem
      *** FAILED SERVICES ***
        UNIT         LOAD   ACTIVE SUB    DESCRIPTION
      * nmbd.service loaded failed failed Samba NMB Daemon
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                  Type      Size  Used Avail Use% Mounted on
      udev                        devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs                       tmpfs     806M  7.2M  799M   1% /run
      /dev/mmcblk0p2              ext4       59G   55G   95M 100% /
      tmpfs                       tmpfs     4.0G     0  4.0G   0% /dev/shm
      tmpfs                       tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/mmcblk0p1              vfat      510M   55M  456M  11% /boot/firmware
      //wdmycloudmirror/Smarthome cifs      1.8T  578G  1.3T  32% /home/uld/Backup/share
      tmpfs                       tmpfs     806M     0  806M   0% /run/user/1000
      [Sun Jul 27 11:50:59 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:8B:D1:73 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=73e40d05-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Jul 27 11:51:08 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
      [Sun Jul 27 11:51:09 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET                   SOURCE                      FSTYPE OPTIONS
      /                        /dev/mmcblk0p2              ext4   rw,noatime,commit=600
      |-/boot/firmware         /dev/mmcblk0p1              vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/home/uld/Backup/share //wdmycloudmirror/Smarthome cifs   rw,relatime,vers=default,cache=strict,username=uld,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.27,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,reparse=nfs,rsize=262144,wsize=262144,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      /var:
      50G     /var/
      48G     /var/lib/influxdb/.influxdbv2/engine/data/480e4f14b6a11871/autogen
      Archived and active journals take up 1.6G in the file system.
      /opt/iobroker/backups:
      3.5M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      342M    /opt/iobroker/iobroker-data/
      206M    /opt/iobroker/iobroker-data/files
      95M     /opt/iobroker/iobroker-data/backup-objects
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      32M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      14M     /opt/iobroker/iobroker-data/files/vis-2.0/Haus_1.png
      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
      8.6M    /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.2
      /usr/bin/node           v20.18.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.2-1nodesource1
        Candidate: 20.19.4-1nodesource1
        Version table:
           20.19.4-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.19.3-1nodesource1 1001
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
       *** 20.18.2-1nodesource1 1001
              100 /var/lib/dpkg/status
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi5        raspberrypi5 (version: 7.0.7, hostname: raspberrypi5  , alive, uptime: 2251)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     9.0.9
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
      + system.adapter.bshb.0                   : bshb                  : raspberrypi5                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
      + system.adapter.followthesun.0           : followthesun          : raspberrypi5                             -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : raspberrypi5                             -  enabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi5                             -  enabled, port: 8086
      + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
      + system.adapter.kecontact.0              : kecontact             : raspberrypi5                             -  enabled
      + system.adapter.modbus.0                 : modbus                : raspberrypi5                             -  enabled
      + system.adapter.modbus.1                 : modbus                : raspberrypi5                             -  enabled
        system.adapter.modbus.2                 : modbus                : raspberrypi5                             - disabled
      + system.adapter.pvforecast.0             : pvforecast            : raspberrypi5                             -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.smartthings.0            : smartthings           : raspberrypi5                             -  enabled
      + system.adapter.tibberlink.0             : tibberlink            : raspberrypi5                             -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi5                             - disabled
      + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.yamaha.0                 : yamaha                : raspberrypi5                             -  enabled
      + instance is alive
      ioBroker-Repositories
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
      │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │ true         │
      Active repo(s): beta
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: beta
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "bshb"         : 0.5.2    , installed 0.5.2
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "followthesun" : 0.5.2    , installed 0.5.2
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "javascript"   : 9.0.9    , installed 9.0.9
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "kecontact"    : 3.2.0    , installed 3.2.0
      Adapter    "modbus"       : 6.4.0    , installed 6.4.0
      Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "smartthings"  : 0.2.2    , installed 0.2.2
      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
      Adapter    "tibberlink"   : 5.0.0    , installed 5.0.0
      Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
      Adapter    "web"          : 7.0.9    , installed 7.0.9
      Adapter    "ws"           : 3.0.19   , installed 3.0.19
      Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
      Objects and States
      Objects:        3367
      States:         2801
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://repos.influxdata.com/debian bookworm InRelease
      Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 136
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          1953       779/smbd
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3752       669/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          1954       779/smbd
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       17640      3258/io.shelly.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15177      3048/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15172      3048/iobroker.js-co
      tcp6       0      0 :::445                  :::*                    LISTEN      0          1951       779/smbd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          3754       669/sshd: /usr/sbin
      tcp6       0      0 :::139                  :::*                    LISTEN      0          1952       779/smbd
      tcp6       0      0 :::3000                 :::*                    LISTEN      107        8354       946/grafana
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17421      3067/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17771      3398/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      106        4783       731/influxd
      udp        0      0 0.0.0.0:38718           0.0.0.0:*                           104        6066       537/avahi-daemon: r
      udp        0      0 0.0.0.0:56114           0.0.0.0:*                           1001       16136      3209/io.kecontact.0
      udp        0      0 0.0.0.0:7090            0.0.0.0:*                           1001       17614      3209/io.kecontact.0
      udp        0      0 0.0.0.0:7092            0.0.0.0:*                           1001       17615      3209/io.kecontact.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6064       537/avahi-daemon: r
      udp6       0      0 :::48879                :::*                                104        6067       537/avahi-daemon: r
      udp6       0      0 fe80::cef1:bbf1:e04:546 :::*                                0          6205       627/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        6065       537/avahi-daemon: r
      2025-07-27 12:46:01.802  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601890.energy_stats.datatimed" has value "1753613161802" greater than max "2147483648"
      2025-07-27 12:51:00.898  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300219902.energy_stats.datatimem" has value "1753613460896" greater than max "2147483648"
      2025-07-27 12:51:00.989  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300219902.energy_stats.datatimed" has value "1753613460988" greater than max "2147483648"
      2025-07-27 12:51:01.178  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300218605.energy_stats.datatimem" has value "1753613461176" greater than max "2147483648"
      2025-07-27 12:51:01.273  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300218605.energy_stats.datatimed" has value "1753613461272" greater than max "2147483648"
      2025-07-27 12:51:01.458  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601680.energy_stats.datatimem" has value "1753613461456" greater than max "2147483648"
      2025-07-27 12:51:01.549  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601680.energy_stats.datatimed" has value "1753613461549" greater than max "2147483648"
      2025-07-27 12:51:01.734  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601890.energy_stats.datatimem" has value "1753613461733" greater than max "2147483648"
      2025-07-27 12:51:01.829  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601890.energy_stats.datatimed" has value "1753613461828" greater than max "2147483648"
      2025-07-27 12:56:00.895  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300219902.energy_stats.datatimem" has value "1753613760893" greater than max "2147483648"
      2025-07-27 12:56:00.985  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300219902.energy_stats.datatimed" has value "1753613760985" greater than max "2147483648"
      2025-07-27 12:56:01.165  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300218605.energy_stats.datatimem" has value "1753613761164" greater than max "2147483648"
      2025-07-27 12:56:01.213  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300218605.energy_stats.datatimed" has value "1753613761213" greater than max "2147483648"
      2025-07-27 12:56:01.398  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601680.energy_stats.datatimem" has value "1753613761396" greater than max "2147483648"
      2025-07-27 12:56:01.489  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601680.energy_stats.datatimed" has value "1753613761489" greater than max "2147483648"
      2025-07-27 12:56:01.666  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601890.energy_stats.datatimem" has value "1753613761664" greater than max "2147483648"
      2025-07-27 12:56:01.756  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601890.energy_stats.datatimed" has value "1753613761756" greater than max "2147483648"
      2025-07-27 13:01:00.887  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300219902.energy_stats.datatimem" has value "1753614060885" greater than max "2147483648"
      2025-07-27 13:01:00.978  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300219902.energy_stats.datatimed" has value "1753614060978" greater than max "2147483648"
      2025-07-27 13:01:01.164  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300218605.energy_stats.datatimem" has value "1753614061161" greater than max "2147483648"
      2025-07-27 13:01:01.259  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116300218605.energy_stats.datatimed" has value "1753614061258" greater than max "2147483648"
      2025-07-27 13:01:01.443  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601680.energy_stats.datatimem" has value "1753614061439" greater than max "2147483648"
      2025-07-27 13:01:01.539  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601680.energy_stats.datatimed" has value "1753614061538" greater than max "2147483648"
      2025-07-27 13:01:01.725  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601890.energy_stats.datatimem" has value "1753614061723" greater than max "2147483648"
      2025-07-27 13:01:01.819  - warn: fritzdect.0 (3333) State value to set for "fritzdect.0.DECT_116570601890.energy_stats.datatimed" has value "1753614061818" greater than max "2147483648"
      iob diag has finished.
      Ro75 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @Smartuser_1 last edited by
        @smartuser_1 sagte in Speicherplatz Influx:
        Nein, keine Kopien. Du könntest die Aufbewahrungsdauer anpassen. Das muss in Influx selbst und auch im Adapter angepasst werden. Also statt unendlich auf 1 Jahr oder kürzer.
        Wenn einige Daten kürzer und ander länger aufbewahrt werden sollen, mussen mehrere Buckets erstellt und genutzt werden.
        Ro75.
          Smartuser_1 @Ro75 last edited by Smartuser_1
          @ro75
          so richtig komme ich nicht weiter. Die Aufbewahrungsdauer habe ich angepasst. Hat jemand weitere Ideen?
          In der Influxdb habe ich noch die unten angehängte Abfrage hinterlegt und sehe welche Kanäle wie viele Datenpunkte besitzen.
          from(bucket: "iobroker")
            |> range(start: -2y)
            |> filter(fn: (r) => r["_field"] == "value")
            |> count()
            |> group()
            |> keep(columns: ["_measurement", "_value"])
            |> sort(columns: ["_value"], desc: true)
            |> rename(columns: {_value: "Anzahl"})
          Ein Löschen gelingt mir allerdings nicht, was läuft da schief, ich bekomme auch keine Fehlermeldung in der Powershell (also Befehl läuft durch).
          sudo influx delete --*mein token*  --org Team_ULD --bucket iobroker --start 2024-05-28T10:00:00.000Z --stop 2025-07-20T10:30:00.000Z --predicate '_measurement="modbus.0.holdingRegisters.57722_Batterie_Lifetime_EXp"'
            Thomas Braun Most Active @Smartuser_1 last edited by
            @smartuser_1
            Von deinem Einstellungsproblem mit influxdb abgesehen musst du das System regelmäßig auf Stand halten...
              Smartuser_1 @Thomas Braun last edited by
              beim updaten ist es leider aufgefallen und jetzt hänge ich, weil der freie Speicher leider begrenzt ist ...
                @smartuser_1
                Das ist klar. Deswegen musst du zuerst deine Datenhalde aufräumen.
                Du solltest aber künftig regelmäßiger Systempflege betreiben, bei aufgelaufenen 136 Updates und einigen ausgelassenen nodejs-Updates machst du das offenbar zu selten.
                  Die Influx DB Habe ich jetzt aufgeräumt bekommen. Das Problem lag in einen anderen Bucket (wie auch immer da Daten hineingekommen sind). Mit iob diag wurde der File inkl. der ID Nummer des Buckets angezeigt, diese ID Nummer steht auch in der Web Oberfläche von Influxdb unter buckets.
                  Zum Update habe ich jetzt einfach
                  sudo apt update && sudo apt full-upgrade
                  ausgeführt und nochmal neu gestartet. Das ist alles oder fehlt noch was?
                  Danke & Vg
                    Schau ob noch Updates angezeigt werden. Neustart gemacht?
                    81.1k
