    4. Pflege des Betriebssystems
    5. Raspi Update - Hilfe (Close)
    • Yoda
      Yoda last edited by Yoda
      ich wollte eben mal ein update von meinem Raspi machen.
      Nun bekomme ich das hier angezeigt und weiß damit nichts anzufangen - was soll ich eingeben?
      login as: pi
      pi@192.168.178.118's password:
      Linux raspberrypi-5 6.12.25+rpt-rpi-2712 #1 SMP PREEMPT Debian 1:6.12.25-1+rpt1 (2025-04-30) aarch64
      The programs included with the Debian GNU/Linux system are free software;
      the exact distribution terms for each program are described in the
      individual files in /usr/share/doc/*/copyright.
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Mon Jun 30 11:12:36 2025 from 192.168.178.166
      Wi-Fi is currently blocked by rfkill.
      Use raspi-config to set the country before use.
      pi@raspberrypi-5:~ $ iob stop
      pi@raspberrypi-5:~ $ sudo apt update
      Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
      Get:3 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
      Get:4 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
      Get:5 http://archive.raspberrypi.com/debian bookworm InRelease [55.0 kB]
      Get:6 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [253 kB]
      Get:7 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [268 kB]
      Get:8 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [12.2 kB]
      Get:9 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages [11.9 kB]
      Get:10 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [551 kB]
      Get:11 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [554 kB]
      Fetched 1,821 kB in 1s (2,369 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      51 packages can be upgraded. Run 'apt list --upgradable' to see them.
      pi@raspberrypi-5:~ $ sudo apt full-upgrade
      Calculating upgrade... Done
      The following package was automatically installed and is no longer required:
        rpicam-apps-lite
      Use 'sudo apt autoremove' to remove it.
      The following NEW packages will be installed:
        libdtovl0 libgpiolib0 librpicam-app1 linux-headers-6.12.34+rpt-common-rpi
        linux-headers-6.12.34+rpt-rpi-2712 linux-headers-6.12.34+rpt-rpi-v8
        linux-image-6.12.34+rpt-rpi-2712 linux-image-6.12.34+rpt-rpi-v8
        linux-kbuild-6.12.34+rpt rpicam-apps-core
      The following packages will be upgraded:
        ca-certificates gir1.2-gdkpixbuf-2.0 icu-devtools initramfs-tools
        initramfs-tools-core libblockdev-crypto2 libblockdev-fs2 libblockdev-loop2
        libblockdev-part-err2 libblockdev-part2 libblockdev-swap2 libblockdev-utils2
        libblockdev2 libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dbg
        libc6-dev libcamera-ipa libcamera0.5 libgdk-pixbuf-2.0-0
        libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common
        libgnutls30 libicu-dev libicu72 libudisks2-0 libxml2 linux-headers-rpi-2712
        linux-headers-rpi-v8 linux-image-rpi-2712 linux-image-rpi-v8 linux-libc-dev
        locales nodejs pastebinit raspi-config raspi-firmware raspi-utils
        raspi-utils-core raspi-utils-dt raspi-utils-eeprom raspi-utils-otp raspinfo
        rpi-eeprom rpicam-apps-lite sudo udisks2
      51 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
      Need to get 176 MB of archives.
      After this operation, 110 MB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 http://deb.debian.org/debian-security bookworm-security/main arm64 sudo arm64 1.9.13p3-1+deb12u2 [1,827 kB]
      Get:2 http://archive.raspberrypi.com/debian bookworm/main arm64 libc6-dbg arm64 2.36-9+rpt2+deb12u12 [8,131 kB]
      Get:3 https://deb.nodesource.com/node_20.x nodistro/main arm64 nodejs arm64 20.19.4-1nodesource1 [31.1 MB]
      Get:4 http://deb.debian.org/debian-security bookworm-security/main arm64 libgnutls30 arm64 3.7.9-2+deb12u5 [1,314 kB]
      Get:5 http://deb.debian.org/debian bookworm-updates/main arm64 ca-certificates all 20230311+deb12u1 [155 kB]
      Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 libgdk-pixbuf2.0-common all 2.42.10+dfsg-1+deb12u2 [306 kB]
      Get:7 http://deb.debian.org/debian-security bookworm-security/main arm64 libgdk-pixbuf-2.0-dev arm64 2.42.10+dfsg-1+deb12u2 [51.7 kB]
      Get:8 http://deb.debian.org/debian-security bookworm-security/main arm64 libgdk-pixbuf-2.0-0 arm64 2.42.10+dfsg-1+deb12u2 [130 kB]
      Get:9 http://deb.debian.org/debian-security bookworm-security/main arm64 libgdk-pixbuf2.0-bin arm64 2.42.10+dfsg-1+deb12u2 [18.0 kB]
      Get:10 http://deb.debian.org/debian-security bookworm-security/main arm64 gir1.2-gdkpixbuf-2.0 arm64 2.42.10+dfsg-1+deb12u2 [13.4 kB]
      Get:11 http://deb.debian.org/debian-security bookworm-security/main arm64 libicu-dev arm64 72.1-3+deb12u1 [10.2 MB]
      Get:12 http://deb.debian.org/debian-security bookworm-security/main arm64 icu-devtools arm64 72.1-3+deb12u1 [192 kB]
      Get:13 http://deb.debian.org/debian-security bookworm-security/main arm64 libicu72 arm64 72.1-3+deb12u1 [9,202 kB]
      Get:14 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-utils2 arm64 2.28-2+deb12u1 [14.3 kB]
      Get:15 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-crypto2 arm64 2.28-2+deb12u1 [17.3 kB]
      Get:16 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-part-err2 arm64 2.28-2+deb12u1 [5,696 B]
      Get:17 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-fs2 arm64 2.28-2+deb12u1 [21.7 kB]
      Get:18 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-loop2 arm64 2.28-2+deb12u1 [8,392 B]
      Get:19 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-part2 arm64 2.28-2+deb12u1 [16.8 kB]
      Get:20 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev-swap2 arm64 2.28-2+deb12u1 [10.2 kB]
      Get:21 http://deb.debian.org/debian-security bookworm-security/main arm64 libblockdev2 arm64 2.28-2+deb12u1 [38.8 kB]
      Get:22 http://deb.debian.org/debian-security bookworm-security/main arm64 libudisks2-0 arm64 2.9.4-4+deb12u1 [137 kB]
      Get:23 http://deb.debian.org/debian-security bookworm-security/main arm64 libxml2 arm64 2.9.14+dfsg-1.3~deb12u2 [619 kB]
      Get:24 http://deb.debian.org/debian-security bookworm-security/main arm64 udisks2 arm64 2.9.4-4+deb12u1 [385 kB]
      Get:25 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-devtools arm64 2.36-9+rpt2+deb12u12 [61.4 kB]
      Get:26 http://archive.raspberrypi.com/debian bookworm/main arm64 libc6-dev arm64 2.36-9+rpt2+deb12u12 [2,102 kB]
      Get:27 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-dev-bin arm64 2.36-9+rpt2+deb12u12 [49.9 kB]
      Get:28 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-libc-dev all 1:6.12.34-1+rpt1~bookworm [2,314 kB]
      Get:29 http://archive.raspberrypi.com/debian bookworm/main arm64 libc6 arm64 2.36-9+rpt2+deb12u12 [5,001 kB]
      Get:30 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-bin arm64 2.36-9+rpt2+deb12u12 [753 kB]
      Get:31 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-firmware all 1:1.20250430-4~bookworm [12.8 MB]
      Get:32 http://archive.raspberrypi.com/debian bookworm/main arm64 libc-l10n all 2.36-9+rpt2+deb12u12 [1,541 kB]
      Get:33 http://archive.raspberrypi.com/debian bookworm/main arm64 locales all 2.36-9+rpt2+deb12u12 [5,086 kB]
      Get:34 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools all 0.142+rpt4+deb12u3 [17.4 kB]
      Get:35 http://archive.raspberrypi.com/debian bookworm/main arm64 initramfs-tools-core all 0.142+rpt4+deb12u3 [53.6 kB]
      Get:36 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera0.5 arm64 0.5.1+rpt20250722-1 [692 kB]
      Get:37 http://archive.raspberrypi.com/debian bookworm/main arm64 libcamera-ipa arm64 0.5.1+rpt20250722-1 [877 kB]
      Get:38 http://archive.raspberrypi.com/debian bookworm/main arm64 libdtovl0 arm64 20250514-1~bookworm [28.0 kB]
      Get:39 http://archive.raspberrypi.com/debian bookworm/main arm64 libgpiolib0 arm64 20250514-1~bookworm [37.0 kB]
      Get:40 http://archive.raspberrypi.com/debian bookworm/main arm64 librpicam-app1 arm64 1.8.1-1~bookworm [270 kB]
      Get:41 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.34+rpt-common-rpi all 1:6.12.34-1+rpt1~bookworm [8,753 kB]
      Get:42 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.12.34+rpt-rpi-2712 arm64 1:6.12.34-1+rpt1~bookworm [32.6 MB]
      Get:43 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-kbuild-6.12.34+rpt arm64 1:6.12.34-1+rpt1~bookworm [1,193 kB]
      Get:44 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.34+rpt-rpi-2712 arm64 1:6.12.34-1+rpt1~bookworm [1,346 kB]
      Get:45 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-6.12.34+rpt-rpi-v8 arm64 1:6.12.34-1+rpt1~bookworm [32.6 MB]
      Get:46 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-6.12.34+rpt-rpi-v8 arm64 1:6.12.34-1+rpt1~bookworm [1,346 kB]
      Get:47 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-2712 arm64 1:6.12.34-1+rpt1~bookworm [1,168 B]
      Get:48 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-headers-rpi-v8 arm64 1:6.12.34-1+rpt1~bookworm [1,164 B]
      Get:49 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-2712 arm64 1:6.12.34-1+rpt1~bookworm [1,436 B]
      Get:50 http://archive.raspberrypi.com/debian bookworm/main arm64 linux-image-rpi-v8 arm64 1:6.12.34-1+rpt1~bookworm [1,436 B]
      Get:51 http://archive.raspberrypi.com/debian bookworm/main arm64 pastebinit all 1.6.2-1+rpt2 [53.2 kB]
      Get:52 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-core arm64 20250514-1~bookworm [39.3 kB]
      Get:53 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom all 28.3-1 [1,544 kB]
      Get:54 http://archive.raspberrypi.com/debian bookworm/main arm64 raspinfo all 20250514-1~bookworm [8,106 B]
      Get:55 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-otp all 20250514-1~bookworm [8,422 B]
      Get:56 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-eeprom arm64 20250514-1~bookworm [25.4 kB]
      Get:57 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils-dt arm64 20250514-1~bookworm [50.9 kB]
      Get:58 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-utils all 20250514-1~bookworm [6,008 B]
      Get:59 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-config all 20250707 [37.8 kB]
      Get:60 http://archive.raspberrypi.com/debian bookworm/main arm64 rpicam-apps-lite all 1.8.1-1~bookworm [3,758 B]
      Get:61 http://archive.raspberrypi.com/debian bookworm/main arm64 rpicam-apps-core arm64 1.8.1-1~bookworm [257 kB]
      Fetched 176 MB in 18s (9,532 kB/s)
      Reading changelogs... Done
      Extracting templates from packages: 100%
      Preconfiguring packages ...
      (Reading database ... 69032 files and directories currently installed.)
      Preparing to unpack .../0-libc6-dbg_2.36-9+rpt2+deb12u12_arm64.deb ...
      Unpacking libc6-dbg:arm64 (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
      Preparing to unpack .../1-libc-devtools_2.36-9+rpt2+deb12u12_arm64.deb ...
      Unpacking libc-devtools (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
      Preparing to unpack .../2-libc6-dev_2.36-9+rpt2+deb12u12_arm64.deb ...
      Unpacking libc6-dev:arm64 (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
      Preparing to unpack .../3-libc-dev-bin_2.36-9+rpt2+deb12u12_arm64.deb ...
      Unpacking libc-dev-bin (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
      Preparing to unpack .../4-linux-libc-dev_1%3a6.12.34-1+rpt1~bookworm_all.deb ...
      Unpacking linux-libc-dev (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
      Preparing to unpack .../5-libc6_2.36-9+rpt2+deb12u12_arm64.deb ...
      Unpacking libc6:arm64 (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
      Setting up libc6:arm64 (2.36-9+rpt2+deb12u12) ...
      (Reading database ... 69031 files and directories currently installed.)
      Preparing to unpack .../libc-bin_2.36-9+rpt2+deb12u12_arm64.deb ...
      Unpacking libc-bin (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
      Setting up libc-bin (2.36-9+rpt2+deb12u12) ...
      Preparing to unpack .../raspi-firmware_1%3a1.20250430-4~bookworm_all.deb ...
      Unpacking raspi-firmware (1:1.20250430-4~bookworm) over (1:1.20250430-1) ...
      Preparing to unpack .../sudo_1.9.13p3-1+deb12u2_arm64.deb ...
      Unpacking sudo (1.9.13p3-1+deb12u2) over (1.9.13p3-1+deb12u1) ...
      Preparing to unpack .../libgnutls30_3.7.9-2+deb12u5_arm64.deb ...
      Unpacking libgnutls30:arm64 (3.7.9-2+deb12u5) over (3.7.9-2+deb12u4) ...
      Setting up libgnutls30:arm64 (3.7.9-2+deb12u5) ...
      Preparing to unpack .../00-ca-certificates_20230311+deb12u1_all.deb ...
      Unpacking ca-certificates (20230311+deb12u1) over (20230311) ...
      Preparing to unpack .../01-libc-l10n_2.36-9+rpt2+deb12u12_all.deb ...
      Unpacking libc-l10n (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
      Preparing to unpack .../02-locales_2.36-9+rpt2+deb12u12_all.deb ...
      Unpacking locales (2.36-9+rpt2+deb12u12) over (2.36-9+rpt2+deb12u10) ...
      Preparing to unpack .../03-libgdk-pixbuf2.0-common_2.42.10+dfsg-1+deb12u2_all.deb ...
      Unpacking libgdk-pixbuf2.0-common (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
      Preparing to unpack .../04-libgdk-pixbuf-2.0-dev_2.42.10+dfsg-1+deb12u2_arm64.deb ...
      Unpacking libgdk-pixbuf-2.0-dev:arm64 (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
      Preparing to unpack .../05-libgdk-pixbuf-2.0-0_2.42.10+dfsg-1+deb12u2_arm64.deb ...
      Unpacking libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
      Preparing to unpack .../06-libgdk-pixbuf2.0-bin_2.42.10+dfsg-1+deb12u2_arm64.deb ...
      Unpacking libgdk-pixbuf2.0-bin (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
      Preparing to unpack .../07-gir1.2-gdkpixbuf-2.0_2.42.10+dfsg-1+deb12u2_arm64.deb ...
      Unpacking gir1.2-gdkpixbuf-2.0:arm64 (2.42.10+dfsg-1+deb12u2) over (2.42.10+dfsg-1+deb12u1) ...
      Preparing to unpack .../08-libicu-dev_72.1-3+deb12u1_arm64.deb ...
      Unpacking libicu-dev:arm64 (72.1-3+deb12u1) over (72.1-3) ...
      Preparing to unpack .../09-icu-devtools_72.1-3+deb12u1_arm64.deb ...
      Unpacking icu-devtools (72.1-3+deb12u1) over (72.1-3) ...
      Preparing to unpack .../10-libicu72_72.1-3+deb12u1_arm64.deb ...
      Unpacking libicu72:arm64 (72.1-3+deb12u1) over (72.1-3) ...
      Preparing to unpack .../11-initramfs-tools_0.142+rpt4+deb12u3_all.deb ...
      Unpacking initramfs-tools (0.142+rpt4+deb12u3) over (0.142+rpt3+deb12u3) ...
      Preparing to unpack .../12-initramfs-tools-core_0.142+rpt4+deb12u3_all.deb ...
      Unpacking initramfs-tools-core (0.142+rpt4+deb12u3) over (0.142+rpt3+deb12u3) ...
      Preparing to unpack .../13-libblockdev-utils2_2.28-2+deb12u1_arm64.deb ...
      Unpacking libblockdev-utils2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
      Preparing to unpack .../14-libblockdev-crypto2_2.28-2+deb12u1_arm64.deb ...
      Unpacking libblockdev-crypto2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
      Preparing to unpack .../15-libblockdev-part-err2_2.28-2+deb12u1_arm64.deb ...
      Unpacking libblockdev-part-err2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
      Preparing to unpack .../16-libblockdev-fs2_2.28-2+deb12u1_arm64.deb ...
      Unpacking libblockdev-fs2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
      Preparing to unpack .../17-libblockdev-loop2_2.28-2+deb12u1_arm64.deb ...
      Unpacking libblockdev-loop2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
      Preparing to unpack .../18-libblockdev-part2_2.28-2+deb12u1_arm64.deb ...
      Unpacking libblockdev-part2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
      Preparing to unpack .../19-libblockdev-swap2_2.28-2+deb12u1_arm64.deb ...
      Unpacking libblockdev-swap2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
      Preparing to unpack .../20-libblockdev2_2.28-2+deb12u1_arm64.deb ...
      Unpacking libblockdev2:arm64 (2.28-2+deb12u1) over (2.28-2) ...
      Preparing to unpack .../21-libcamera0.5_0.5.1+rpt20250722-1_arm64.deb ...
      Unpacking libcamera0.5:arm64 (0.5.1+rpt20250722-1) over (0.5.0+rpt20250429-1) ...
      Preparing to unpack .../22-libcamera-ipa_0.5.1+rpt20250722-1_arm64.deb ...
      Unpacking libcamera-ipa:arm64 (0.5.1+rpt20250722-1) over (0.5.0+rpt20250429-1) ...
      Selecting previously unselected package libdtovl0:arm64.
      Preparing to unpack .../23-libdtovl0_20250514-1~bookworm_arm64.deb ...
      Unpacking libdtovl0:arm64 (20250514-1~bookworm) ...
      Selecting previously unselected package libgpiolib0:arm64.
      Preparing to unpack .../24-libgpiolib0_20250514-1~bookworm_arm64.deb ...
      Unpacking libgpiolib0:arm64 (20250514-1~bookworm) ...
      Selecting previously unselected package librpicam-app1:arm64.
      Preparing to unpack .../25-librpicam-app1_1.8.1-1~bookworm_arm64.deb ...
      Unpacking librpicam-app1:arm64 (1.8.1-1~bookworm) ...
      Preparing to unpack .../26-libudisks2-0_2.9.4-4+deb12u1_arm64.deb ...
      Unpacking libudisks2-0:arm64 (2.9.4-4+deb12u1) over (2.9.4-4) ...
      Preparing to unpack .../27-libxml2_2.9.14+dfsg-1.3~deb12u2_arm64.deb ...
      Unpacking libxml2:arm64 (2.9.14+dfsg-1.3~deb12u2) over (2.9.14+dfsg-1.3~deb12u1) ...
      Selecting previously unselected package linux-headers-6.12.34+rpt-common-rpi.
      Preparing to unpack .../28-linux-headers-6.12.34+rpt-common-rpi_1%3a6.12.34-1+rpt1~bookworm_all.deb ...
      Unpacking linux-headers-6.12.34+rpt-common-rpi (1:6.12.34-1+rpt1~bookworm) ...
      Selecting previously unselected package linux-image-6.12.34+rpt-rpi-2712.
      Preparing to unpack .../29-linux-image-6.12.34+rpt-rpi-2712_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
      Unpacking linux-image-6.12.34+rpt-rpi-2712 (1:6.12.34-1+rpt1~bookworm) ...
      Selecting previously unselected package linux-kbuild-6.12.34+rpt.
      Preparing to unpack .../30-linux-kbuild-6.12.34+rpt_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
      Unpacking linux-kbuild-6.12.34+rpt (1:6.12.34-1+rpt1~bookworm) ...
      Selecting previously unselected package linux-headers-6.12.34+rpt-rpi-2712.
      Preparing to unpack .../31-linux-headers-6.12.34+rpt-rpi-2712_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
      Unpacking linux-headers-6.12.34+rpt-rpi-2712 (1:6.12.34-1+rpt1~bookworm) ...
      Selecting previously unselected package linux-image-6.12.34+rpt-rpi-v8.
      Preparing to unpack .../32-linux-image-6.12.34+rpt-rpi-v8_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
      Unpacking linux-image-6.12.34+rpt-rpi-v8 (1:6.12.34-1+rpt1~bookworm) ...
      Selecting previously unselected package linux-headers-6.12.34+rpt-rpi-v8.
      Preparing to unpack .../33-linux-headers-6.12.34+rpt-rpi-v8_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
      Unpacking linux-headers-6.12.34+rpt-rpi-v8 (1:6.12.34-1+rpt1~bookworm) ...
      Preparing to unpack .../34-linux-headers-rpi-2712_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
      Unpacking linux-headers-rpi-2712 (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
      Preparing to unpack .../35-linux-headers-rpi-v8_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
      Unpacking linux-headers-rpi-v8 (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
      Preparing to unpack .../36-linux-image-rpi-2712_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
      Unpacking linux-image-rpi-2712 (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
      Preparing to unpack .../37-linux-image-rpi-v8_1%3a6.12.34-1+rpt1~bookworm_arm64.deb ...
      Unpacking linux-image-rpi-v8 (1:6.12.34-1+rpt1~bookworm) over (1:6.12.25-1+rpt1) ...
      Preparing to unpack .../38-nodejs_20.19.4-1nodesource1_arm64.deb ...
      Detected old npm client, removing...
      Unpacking nodejs (20.19.4-1nodesource1) over (20.19.2-1nodesource1) ...
      Preparing to unpack .../39-pastebinit_1.6.2-1+rpt2_all.deb ...
      Unpacking pastebinit (1.6.2-1+rpt2) over (1.6.2-1+rpt1) ...
      Preparing to unpack .../40-raspi-utils-core_20250514-1~bookworm_arm64.deb ...
      Unpacking raspi-utils-core (20250514-1~bookworm) over (20250314-1) ...
      Preparing to unpack .../41-rpi-eeprom_28.3-1_all.deb ...
      Unpacking rpi-eeprom (28.3-1) over (28.2-1) ...
      Preparing to unpack .../42-raspinfo_20250514-1~bookworm_all.deb ...
      Unpacking raspinfo (20250514-1~bookworm) over (20250314-1) ...
      Preparing to unpack .../43-raspi-utils-otp_20250514-1~bookworm_all.deb ...
      Unpacking raspi-utils-otp (20250514-1~bookworm) over (20250314-1) ...
      Preparing to unpack .../44-raspi-utils-eeprom_20250514-1~bookworm_arm64.deb ...
      Unpacking raspi-utils-eeprom (20250514-1~bookworm) over (20250314-1) ...
      Preparing to unpack .../45-raspi-utils-dt_20250514-1~bookworm_arm64.deb ...
      Unpacking raspi-utils-dt (20250514-1~bookworm) over (20250314-1) ...
      Preparing to unpack .../46-raspi-utils_20250514-1~bookworm_all.deb ...
      Unpacking raspi-utils (20250514-1~bookworm) over (20250314-1) ...
      Preparing to unpack .../47-raspi-config_20250707_all.deb ...
      Unpacking raspi-config (20250707) over (20250605) ...
      Preparing to unpack .../48-rpicam-apps-lite_1.8.1-1~bookworm_all.deb ...
      Unpacking rpicam-apps-lite (1.8.1-1~bookworm) over (1.7.0-1) ...
      Selecting previously unselected package rpicam-apps-core.
      Preparing to unpack .../49-rpicam-apps-core_1.8.1-1~bookworm_arm64.deb ...
      Unpacking rpicam-apps-core (1.8.1-1~bookworm) ...
      Preparing to unpack .../50-udisks2_2.9.4-4+deb12u1_arm64.deb ...
      Unpacking udisks2 (2.9.4-4+deb12u1) over (2.9.4-4) ...
      Setting up libc-l10n (2.36-9+rpt2+deb12u12) ...
      Setting up raspi-utils-eeprom (20250514-1~bookworm) ...
      Setting up libicu72:arm64 (72.1-3+deb12u1) ...
      Setting up raspi-utils-otp (20250514-1~bookworm) ...
      Setting up libdtovl0:arm64 (20250514-1~bookworm) ...
      Setting up raspi-utils-dt (20250514-1~bookworm) ...
      Setting up libgdk-pixbuf2.0-common (2.42.10+dfsg-1+deb12u2) ...
      Setting up linux-libc-dev (1:6.12.34-1+rpt1~bookworm) ...
      Setting up pastebinit (1.6.2-1+rpt2) ...
      Setting up locales (2.36-9+rpt2+deb12u12) ...
      Generating locales (this might take a while)...
        en_GB.UTF-8... done
      Generation complete.
      Setting up linux-headers-6.12.34+rpt-common-rpi (1:6.12.34-1+rpt1~bookworm) ...
      Setting up libc6-dbg:arm64 (2.36-9+rpt2+deb12u12) ...
      Setting up ca-certificates (20230311+deb12u1) ...
      Updating certificates in /etc/ssl/certs...
      rehash: warning: skipping ca-certificates.crt,it does not contain exactly one certificate or CRL
      2 added, 0 removed; done.
      Setting up libblockdev-utils2:arm64 (2.28-2+deb12u1) ...
      Setting up raspi-firmware (1:1.20250430-4~bookworm) ...
      Installing new version of config file /etc/initramfs/post-update.d/z50-raspi-firmware ...
      Installing new version of config file /etc/kernel/postinst.d/z50-raspi-firmware ...
      '/boot/vmlinuz-6.12.34+rpt-rpi-2712' -> '/boot/firmware/kernel_2712.img'
      '/boot/vmlinuz-6.12.34+rpt-rpi-v8' -> '/boot/firmware/kernel8.img'
      Setting up libgpiolib0:arm64 (20250514-1~bookworm) ...
      Setting up icu-devtools (72.1-3+deb12u1) ...
      Setting up sudo (1.9.13p3-1+deb12u2) ...
      Setting up linux-kbuild-6.12.34+rpt (1:6.12.34-1+rpt1~bookworm) ...
      Setting up libblockdev-part-err2:arm64 (2.28-2+deb12u1) ...
      Setting up libgdk-pixbuf-2.0-0:arm64 (2.42.10+dfsg-1+deb12u2) ...
      Setting up initramfs-tools-core (0.142+rpt4+deb12u3) ...
      Configuration file '/etc/initramfs-tools/initramfs.conf'
       ==> Modified (by you or by a script) since installation.
       ==> Package distributor has shipped an updated version.
         What would you like to do about it ?  Your options are:
          Y or I  : install the package maintainer's version
          N or O  : keep your currently-installed version
            D     : show the differences between the versions
            Z     : start a shell to examine the situation
       The default action is to keep your current version.
      *** initramfs.conf (Y/I/N/O/D/Z) [default=N] ?
      Progress: [ 68%] [#######################################...................]
      • wendy2702
        wendy2702 @Yoda last edited by wendy2702
        @yoda die möglichen Optionen stehen doch da.
        Wenn du dir unsicher bist lass es bei „default“ oder schau dir die Unterschiede an.
        Yoda 2 Replies Last reply Reply Quote 1
        • Yoda
          Yoda @wendy2702 last edited by
          @wendy2702 ich bin mir unsicher 😉
          keine Ahnung welche Auswirkung das hat, habe die Abfrage hier das erste mal....
          oki dann mache ich mal "N" - in 5 Minuten wen keiner was dagegen sagt 😊
          • Yoda
            @wendy2702 Danke dir, ich hätte vermutlich "Y" gemacht, scheint nun wieder alles an zu laufen, sieht soweit ok aus.
            1.0k
            81.1k
