    4. Backitup CIFS Fehlermeldung, obwohl kein CIFS verwendet wird
      wg last edited by Homoran
      Moin
      Nach (manuellem) ausführen eines Backups - hier CCU (aber auch bei iobroker backup) - kommt zum Ende des Backups die Fehlermeldung
      "ERROR cifs The storage path "/opt/iobroker/backups" for copying is not configured correctly". Die gewünschten Backups sind bereits ausgeführt.
      Konfiguriert ist "lokal kopieren". CIFS ist nicht konfiguriert.
      Das Ganze seit Umzug auf neue Hardware, upgrade influxdb 1->2, Neuinstallation iobroker und restore iobroker backup vom alten System.
      Eigentlich nur kosmetisch, da die geforderten Backup durchgeführt werden, und jeweils zum Edne dieser Fehler ausgeworfen wird.
      Logfile des Backups:
      *14:20:01.582
      INFO
      gui
      Backup gestartet ...
      14:20:03.430
      DEBUG
      ccu
      CCU-Backup started ...
      [DEBUG] [ccu] start with {"type":"creator","time":"01:36","cronjob":"00 36 01 */3 * *","ownCron":false,"debugging":true,"everyXDays":3,"deleteBackupAfter":0,"signedCertificates":true,"ignoreErrors":false,"cifs":{"enabled":true,"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":25,"wolPort":9,"wolExtra":false,"smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/opt/iobroker/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false},"historyHTML":{"enabled":true,"type":"message","entriesNumber":44,"ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":44,"ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"email.0","NoticeType":"longEmailNotice","emailReceiver":"root@mimimi.fritz.box","emailSender":"root@mimimi.fritz.box","onlyError":false,"emailWaiting":1000,"hostName":"","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"whatsapp-cmb.0","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"gotify.0","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"signal-cmb.0","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"matrix-org.0","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"E-Mail","type":"message","instance":"discord.0","NoticeType":"longDiscordNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":44,"systemLang":"de"},"host":"172.16.7.123","user":"Admin","usehttps":false,"pass":"****","ccuEvents":[],"ccuMulti":false,"backupDir":"/opt/iobroker/backups","timestamp":1754223601625}
      14:20:03.681
      DEBUG
      ccu
      Requesting backup from CCU
      14:20:13.887
      DEBUG
      ccu
      CCU-Backup is finish
      14:20:13.916
      DEBUG
      ccu
      done
      14:20:14.965
      DEBUG
      cifs
      used copy path: /opt/iobroker/backups
      14:20:14.969
      ERROR
      cifs
      [DEBUG] [cifs] start with {"mountType":"Copy","type":"storage","source":"local","mount":"","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":25,"wolPort":9,"wolExtra":false,"smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":false,"ownDir":false,"dir":"/opt/iobroker/backups","dirMinimal":"sharename/backupDir","user":"","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"deleteBackupAfter":0}*
      mcm1957 W 2 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @wg last edited by
        @wg said in Backitup CIFS Fehlermeldung, obwohl kein CIFS verwendet wird:
        Moin
        *14:20:01.582
        INFO
        gui
        14:20:03.430
        DEBUG
        ccu
        14:20:03.681
        DEBUG
        ccu
        14:20:13.887
        DEBUG
        ccu
        14:20:13.916
        DEBUG
        ccu
        done
        14:20:14.965
        DEBUG
        cifs
        14:20:14.969
        ERROR
        cifs
        Wen hier kein Feedback von @simatec kommt erstell bitte ein Issue im Adapterrepository. Hier geht das ggF unter.
          wg @wg last edited by
          @wg Das "Problem" hat sich erledigt: der eingebene Pfad benötigt einen slash am Ende, also /opt/iobroker/backups/ und nicht /opt/iobroker/backups
          • dann ist Ruhe.
          Thomas Braun simatec 2 Replies Last reply Reply Quote 0
            Thomas Braun Most Active @wg last edited by
            @wg sagte in Backitup CIFS Fehlermeldung, obwohl kein CIFS verwendet wird:
            dann ist Ruhe.
            Ja, denn Verzeichnisse werden mit dem / am Ende gekennzeichnet, ohne ist es eine Datei.
              wg @Thomas Braun last edited by
              @thomas-braun ... komisch: alle Backups werden (auch ohne trailing slash) trotzdem in ein Verzeichnis geschrieben und nicht in eine Datei diesen Namens
                @wg
                Dann wird das halt abgefangen. Ändert aber nichts daran, das die Aussage
                formal korrekt ist.
                • simatec
                  simatec Developer Most Active @wg last edited by
                  Das kann nicht funktionieren... Du kannst doch nicht in den Quellpfad kopieren. /opt/iobroker/backups ist das lokale Verzeichnis für alle Backups
