    4. Shellys (Gen1) nicht mehr auffindbar nach Update
    • Fichtendickicht
      Fichtendickicht last edited by Fichtendickicht
      Re: Shelly Adapter - genereller Support
      Darf ich mich hier bitte anhängen, ich will aber nicht den Thread kapern.
      Seit dem letzten Update des IO-Brokers und des SHelly-adapters kann ich meine SHellys (Gen1) nicht mehr erreichen.
      Ich habe eine alte Version der Shelly Adapters (6.7.7) installiert aber leider ohne Erfolg.
      Ich erlaube mir hier das "iob diag" zu posten und bitte um Unterstützung.
      The ioBroker diag script is not specifically designed to run in Docker.
      Although it is generally safe to use, use it at your own risk.
      *** iob diag is starting up, please wait ***
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      * Some output is masked. For full results please use 'iob diag --unmask' *
      Press any key to continue
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Hardware Vendor : Synology
      Kernel          : x86_64
      Userland        : 64 bit
      Docker          : v11.0.0
      Virtualization  : docker
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       14:29:21 up 16 days, 20:28,  0 user,  load average: 4.80, 3.79, 3.30
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
      Thu Aug 14 12:29:21 UTC 2025
      Thu Aug 14 14:29:21 CEST 2025
      CEST +0200
      Etc/UTC
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/opt/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: 	false
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
      Mem:             10G        5.5G        735M        273M        4.7G        4.8G
      Swap:           8.3G        1.7G        6.6G
      Total:           18G        7.2G        7.4G
      Active iob-Instances: 	16
               9806 M total memory
               5210 M used memory
               3967 M active memory
               3260 M inactive memory
                701 M free memory
                850 M buffer memory
               3608 M swap cache
               7931 M total swap
               1609 M used swap
               6322 M free swap
      top - 14:29:22 up 16 days, 20:28,  0 user,  load average: 4.97, 3.84, 3.32
      Tasks:  23 total,   1 running,  22 sleeping,   0 stopped,   0 zombie
      %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   9806.1 total,    699.0 free,   5212.9 used,   4459.1 buff/cache
      MiB Swap:   7931.9 total,   6322.5 free,   1609.4 used.   4593.1 avail Mem
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem        Type   Size  Used Avail Use% Mounted on
      none              aufs   2.7T  1.9T  868G  69% /
      tmpfs             tmpfs   64M     0   64M   0% /dev
      tmpfs             tmpfs  4.8G     0  4.8G   0% /sys/fs/cgroup
      shm               tmpfs   64M     0   64M   0% /dev/shm
      /dev/vg1/volume_1 ext4   2.7T  1.9T  868G  69% /opt/iobroker
      tmpfs             tmpfs  4.8G     0  4.8G   0% /proc/acpi
      tmpfs             tmpfs  4.8G     0  4.8G   0% /proc/scsi
      tmpfs             tmpfs  4.8G     0  4.8G   0% /sys/firmware
      Show mounted filesystems:
      TARGET             SOURCE        FSTYPE OPTIONS
      /                  none        aufs   rw,relatime,si=9b9cd6e224b287b0,dio,dirperm1
      |-/opt/iobroker    /dev/vg1/volume_1[/docker/iobroker_data]        ext4   rw,nodev,relatime,relatime_period=30,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
      |-/etc/resolv.conf /dev/vg1/volume_1[/@docker/containers/f87e07a00d569225757d33e646c3cbf5906f5e420f2dc1cfffa3fb327276a7b5/resolv.conf] ext4   rw,nodev,relatime,relatime_period=30,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
      |-/etc/hostname    /dev/vg1/volume_1[/@docker/containers/f87e07a00d569225757d33e646c3cbf5906f5e420f2dc1cfffa3fb327276a7b5/hostname]    ext4   rw,nodev,relatime,relatime_period=30,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
      `-/etc/hosts       /dev/vg1/volume_1[/@docker/containers/f87e07a00d569225757d33e646c3cbf5906f5e420f2dc1cfffa3fb327276a7b5/hosts]       ext4   rw,nodev,relatime,relatime_period=30,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
      /var:
      35M	/var/
      33M	/var/lib
      19M	/var/lib/apt/lists
      19M	/var/lib/apt
      14M	/var/lib/dpkg
      /opt/iobroker/backups:
      1.1G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      347M	/opt/iobroker/iobroker-data/
      211M	/opt/iobroker/iobroker-data/files
      74M	/opt/iobroker/iobroker-data/backup-objects
      47M	/opt/iobroker/iobroker-data/files/admin.admin
      46M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      38M	/opt/iobroker/iobroker-data/objects.jsonl
      22M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js.map
      19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      13M	/opt/iobroker/iobroker-data/sqlite/sqlite.db
      8.8M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.578d79d9.js
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v22.18.0
      /usr/bin/node 		v22.18.0
      /usr/bin/npm 		10.9.3
      /usr/bin/npx 		10.9.3
      /usr/bin/corepack 	0.33.0
      nodejs:
        Installed: 22.18.0-1nodesource1
        Candidate: 22.18.0-1nodesource1
        Version table:
       *** 22.18.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      buanet-iobroker-1   buanet-iobroker-1 (version: 7.0.6, hostname: buanet-iobroker-1, alive, uptime: 23015)
      Core adapters versions
      js-controller: 	7.0.6
      admin: 		7.6.17
      javascript: 	8.9.2
      nodejs modules from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : buanet-iobroker-1                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : buanet-iobroker-1                        -  enabled
      + system.adapter.backitup.0               : backitup              : buanet-iobroker-1                        -  enabled
      + system.adapter.discovery.0              : discovery             : buanet-iobroker-1                        -  enabled
      + system.adapter.fronius-solarweb.0       : fronius-solarweb      : buanet-iobroker-1                        -  enabled
      + system.adapter.fronius.0                : fronius               : buanet-iobroker-1                        -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : buanet-iobroker-1                        -  enabled
      + system.adapter.info.0                   : info                  : buanet-iobroker-1                        -  enabled
      + system.adapter.javascript.0             : javascript            : buanet-iobroker-1                        -  enabled
      + system.adapter.modbus.0                 : modbus                : buanet-iobroker-1                        -  enabled
      + system.adapter.onvif.0                  : onvif                 : buanet-iobroker-1                        -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899,443
      + system.adapter.pid.0                    : pid                   : buanet-iobroker-1                        -  enabled
      + system.adapter.shelly.0                 : shelly                : buanet-iobroker-1                        -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : buanet-iobroker-1                        -  enabled, port: 3307
      + system.adapter.telegram.0               : telegram              : buanet-iobroker-1                        -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : buanet-iobroker-1                        -  enabled
        system.adapter.vis-bars.0               : vis-bars              : buanet-iobroker-1                        -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : buanet-iobroker-1                        -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : buanet-iobroker-1                        -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : buanet-iobroker-1                        -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : buanet-iobroker-1                        -  enabled
        system.adapter.vis.0                    : vis                   : buanet-iobroker-1                        -  enabled
      + system.adapter.web.0                    : web                   : buanet-iobroker-1                        -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "fronius"      : 2.1.1    , installed 2.1.1
      Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "modbus"       : 6.3.2    , installed 6.1.0  [Updatable]
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "pid"          : 1.1.3    , installed 1.1.3
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Objects and States
      Objects: 	4077
      States: 	3645
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       355613479  -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       355613473  -
      tcp        0      0 127.0.0.11:33515        0.0.0.0:*               LISTEN      0          355599950  -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       355616483  -
      tcp6       0      0 :::8083                 :::*                    LISTEN      1000       355635954  -
      udp        0      0 127.0.0.11:54668        0.0.0.0:*                           0          355599949  -
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       361116839  -
      2025-08-14 14:17:13.156  - info: host.buanet-iobroker-1 stopInstance system.adapter.shelly.0 send kill signal
      2025-08-14 14:17:13.329  - info: host.buanet-iobroker-1 iobroker upload [16] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/de/translations.json i18n/de/translations.json application/json
      2025-08-14 14:17:13.339  - info: host.buanet-iobroker-1 iobroker upload [15] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/en/translations.json i18n/en/translations.json application/json
      2025-08-14 14:17:13.347  - info: host.buanet-iobroker-1 iobroker upload [14] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/es/translations.json i18n/es/translations.json application/json
      2025-08-14 14:17:13.357  - info: host.buanet-iobroker-1 iobroker upload [13] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      2025-08-14 14:17:13.365  - info: host.buanet-iobroker-1 iobroker upload [12] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/it/translations.json i18n/it/translations.json application/json
      2025-08-14 14:17:13.373  - info: host.buanet-iobroker-1 iobroker upload [11] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      2025-08-14 14:17:13.381  - info: host.buanet-iobroker-1 iobroker upload [10] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      2025-08-14 14:17:13.390  - info: host.buanet-iobroker-1 iobroker upload [9] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      2025-08-14 14:17:13.398  - info: host.buanet-iobroker-1 iobroker upload [8] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      2025-08-14 14:17:13.407  - info: host.buanet-iobroker-1 iobroker upload [7] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      2025-08-14 14:17:13.417  - info: host.buanet-iobroker-1 iobroker upload [6] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      2025-08-14 14:17:13.425  - info: host.buanet-iobroker-1 iobroker upload [5] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/mqttGen1.png img/mqttGen1.png image/png
      2025-08-14 14:17:13.479  - info: host.buanet-iobroker-1 iobroker upload [4] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/mqttGen2.png img/mqttGen2.png image/png
      2025-08-14 14:17:13.523  - info: host.buanet-iobroker-1 iobroker upload [3] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen1.png img/restrictedLoginGen1.png image/png
      2025-08-14 14:17:13.566  - info: host.buanet-iobroker-1 iobroker upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/img/restrictedLoginGen2.png img/restrictedLoginGen2.png image/png
      2025-08-14 14:17:13.578  - info: host.buanet-iobroker-1 iobroker upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/jsonConfig.json jsonConfig.json application/json
      2025-08-14 14:17:13.587  - info: host.buanet-iobroker-1 iobroker upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
      2025-08-14 14:17:13.619  - info: shelly.0 (19623) terminating
      2025-08-14 14:17:13.731  - info: host.buanet-iobroker-1 instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-08-14 14:17:14.621  - info: host.buanet-iobroker-1 iobroker exit 0
      2025-08-14 14:17:17.127  - info: host.buanet-iobroker-1 instance system.adapter.shelly.0 in version "10.1.0" started with pid 19720
      2025-08-14 14:17:20.703  - info: shelly.0 (19720) starting. Version 10.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v22.18.0, js-controller: 7.0.6
      2025-08-14 14:17:20.867  - info: shelly.0 (19720) Starting in CoAP mode. Listening on 0.0.0.0:5683
      2025-08-14 14:17:20.931  - info: shelly.0 (19720) [CoAP Server] Listening for packets in the network
      iob diag has finished.
      Danke!
      da_Woody mcm1957 2 Replies Last reply Reply Quote 0
      • da_Woody
        da_Woody @Fichtendickicht last edited by
        @fichtendickicht sagte in
        Shellys (Gen1) nicht mehr auffindbar nach Update:
        • system.adapter.shelly.0 : shelly : buanet-iobroker-1 - enabled, port: 1882, bind: 0.0.0.0
        laut dem biste auf mqtt unterwegs. 6.7.7 ist schon brutal alt.
        ohne infos über die config wirds schwierig.
        kenn mich allerdings mit dem buanet dingens nicht aus, sollte aber keinen unterschied machen.
        Fichtendickicht 1 Reply Last reply Reply Quote 0
        • mcm1957
          mcm1957 @Fichtendickicht last edited by
          @fichtendickicht
          Du hast lt. diag 10.1.0 installiert das wär ok.
          Bei GEN 1 check mal deine coap Settings am Shelly. Da darf NICHT mcast eingestrllt sein. Siehe Adapter Doku.
          Ansonsten bin ich bei Docker draussen.
          • Fichtendickicht
            Fichtendickicht @da_Woody last edited by Fichtendickicht
            @da_woody
            6.7.7 war nur testweise. Jetzt ist da lt. diag 10.1.0 drauf.
            Welche iobroker Distro verwendest Du?
            Welche Infos über die Config brauchst Du noch?
            Hier die Docker Config:
            Die IP-Adresse des Cotainers stimmt mit der Adresse im Shelly überein
            • Fichtendickicht
              Fichtendickicht @mcm1957 last edited by
              Das ist die Einstellung auf der Shelly.
              Früher stand da mcast drin und hat funktioniert.
              • haselchen
                haselchen Most Active @Fichtendickicht last edited by
                @fichtendickicht
                Warum betreibst Du den Container als "bridge"?
                Da musste jeden Port einzeln freigeben.
                • Fichtendickicht
                  Fichtendickicht @haselchen last edited by Fichtendickicht
                  @haselchen
                  Weil unter host viele Ports bereits belegt sind und ich das gar nicht gestartet bekomme.
                  Welche Ports muss ich denn freigeben?
                  Die habe ich freigegeben:
                  • haselchen
                    haselchen Most Active @Fichtendickicht last edited by haselchen
                    @fichtendickicht
                    Dann hast Du den Unterschied aber nicht verstanden.
                    Unter der IP des Iobroker können die Ports nicht schon vergeben sein.
                    Das erledigt der Container von selbst.
                    Ein Container (im Host Modus) aufsetzen bzw. starten, da gibt es drölftausend Anleitungen.
                    • Fichtendickicht
                      @haselchen
                      Aha, danke für die Info, muss mich da erst schlau machen. Hab nur die Info dass das nicht geht wegen doppelt verwendeter Ports, und gleichzeitig ist bei EInstellung "host" der Container nach 15 Sekunden abgestürzt und hat neu gebootet.
                        Homoran Global Moderator Administrators @Fichtendickicht last edited by
                        @fichtendickicht
                        Eine Frage aus echter Neugier: Warum nutzst du Container, wenn dir anscheinend die Grundlagen fehlen?
                        mcm1957 Fichtendickicht 2 Replies Last reply Reply Quote 0
                        • mcm1957
                          mcm1957 @Homoran last edited by
                          @fichtendickicht
                          https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/de/protocol-coap.md#coap-coiot
                          An shelly fw 1.9.4 geht mcast nicht mehr.
                          • Fichtendickicht
                            Fichtendickicht @Homoran last edited by
                            Ich verwende Container seit die DS218+ erschienen ist (nocodb, grafana, iobroker, jenkins, duplicati etc.) und da sind meine Kenntnisse ausreichend gewesen.
                            • Fichtendickicht
                              @mcm1957
                              Danke da steht´s ja laut und deutlich:
                              "Docker
                              Falls Du ioBroker in einem Docker-Container laufen hast, muss der Container im Netzwerkmodus host oder macvlan konfiguriert sein. Sollte der Docker-Container im Netzwerkmodus bridge laufen, werden keine Shelly-Geräte gefunden."
                              • Fichtendickicht
                                @mcm1957
                                Ich bekomme den COntainer unter "host" nicht zum Laufen. Der rebootet nach spätestens 60 Sek.
                                • Fichtendickicht
                                  @mcm1957
                                  Verwende diese Firmware:
                                  und
                                  und habe den Container nun als "iob_public" konfiguriert, was scheinbar den Treiber "mcvlan" verwendet und nun habe ich 2 von 6 Shellys wieder am Adapter sichtbar.
                                  Die anderen sind auch so nicht auffindbar, da hats scheinbar was anderes.
                                    @fichtendickicht sagte in Shellys (Gen1) nicht mehr auffindbar nach Update:
                                    aber warum du Container und z.b. keine VMs nutzst hast du mir nicht beantwortet.
                                    Ich hatte immer nur VMs, weil mir Container zu tricky waren.
                                    EDIT
                                    Docker
                                    du nutzst Docker?
                                    das muss ich wohl überlesen haben
                                    • Fichtendickicht
                                      Oh, tut mir Leid, das habe ich nicht explizit im Anfangspost Preis gegeben.
                                      Ja ich nutze Docker auf einer Synology DS218+
                                      Homoran haselchen 2 Replies Last reply Reply Quote 0
                                        @fichtendickicht Eben weil Docker so seine Eigenheiten hat, sollte das immer zu Beginn erwähnt werden
                                        suehe auch
                                        • haselchen
                                          @fichtendickicht
                                          Hab genau Dein Setup.
                                          DS218+ und Docker ( Container Manager).
                                          Das Aufsetzen dauerte keine 2 min.
                                          Und wie ich schon schrieb, da gibt es Unmengen von Anleitungen im Netz .
                                          Ich brauche kein MCVlan und hab es auch nicht .
                                          Meine Shellys sind 1. , 2. und 3. Generation.
                                          Läuft alles wie am Schnürchen.
                                          • Fichtendickicht
                                            @haselchen
                                            SUper , könntest Du bitte Deine Konfiguration teilen?
                                            Speziell mit dem SQL-Adapter gibts Probleme, der hat nun keinen Zugriff mehr auf MySql unter <NAS-IP>:3307
                                            2445
