    4. eCharts - Nach update auf 2.0.7 startet Instanz nicht mehr
    • N
      Norb 0 @drapo last edited by Norb 0
      @drapo
      Nach dem update auf 2.0.7 startet die Instanz nicht mehr. Zurück auf 2.0.6 funktioniert auch nicht mehr.
      Adapter version: 2.0.7
      JS-Controller version: 7.0.7
      Node version: v20.19.4
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1651
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: ^
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1651:18)
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12)
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1298:19)
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at require (node:internal/modules/helpers:182:18)
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.echarts/node_modules/canvas/lib/bindings.js:3:18)
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1529:14)
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12) {
      2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
      2025-08-17 10:48:26.239 - error: host.raspberrypi Caught by controller[0]: }
      2025-08-17 10:48:26.239 - error: host.raspberrypi Caught by controller[0]: Node.js v20.19.4
      2025-08-17 10:48:26.239 - error: host.raspberrypi instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        Thomas Braun Most Active @Norb 0 last edited by
        @norb-0 sagte in eCharts - kein sendTo nach Upgrade auf Node.js 22.x:
        Wie sieht das System sonst aus? Alles aktuell?
        Mach das aber bitte in einem separaten Thread, zumal du ja auch kein nodejs@22 laufen hast...
        Die Ausgabe von
        iob diag
        hilft dann dort weiter.
        • mcm1957
          mcm1957 @Thomas Braun last edited by
          @Homoran
          Bitte ab
          https://forum.iobroker.net/topic/81902/echarts-kein-sendto-nach-upgrade-auf-node-js-22-x/6
          in neues Topic abspalten. Erspart duplizieren des existierenden Textes.
            Homoran Global Moderator Administrators @mcm1957 last edited by
            @mcm1957 erledigt!
            @Norb-0 bitte einen sinnvollen Threadtitel einfügen
            • N
              Norb 0 last edited by Homoran
              Nach dem update auf 2.0.7 startet die Instanz nicht mehr, alles andere funktioniert aber noch. Zurück auf 2.0.6 funktioniert auch nicht mehr.
              Das System ist up-to-date, iob diag zeigt keine Fehlermeldungen
              Tab Diagramme sowie Diagramme als solches funktionieren:
              LOG:
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1651
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: ^
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1651:18)
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12)
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1298:19)
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at require (node:internal/modules/helpers:182:18)
              2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.echarts/node_modules/canvas/lib/bindings.js:3:18)
              2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1529:14)
              2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
              2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
              2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12) {
              2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
              2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: }
              2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: Node.js v20.19.4
              2025-08-17 12:05:57.039 - error: host.raspberrypi instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              Gargano 1 Reply Last reply Reply Quote 0
              • Gargano
                Gargano @Norb 0 last edited by
                @norb-0 Den Fehler hab ich auch (NodeJS 20.19.4)
                  Thomas Braun Most Active @Gargano last edited by
                  @gargano
                  Dann solltest auch du die Ausgabe von
                  iob diag
                  bekannt geben. Ich hab da eine Vermutung.
                  • Gargano
                    Gargano @Thomas Braun last edited by Gargano
                    @thomas-braun Hier kommt der Diag:
                    Am Ende ist der Fehler mit der fehlenden Lib :
                    2025-08-17 13:04:27.534  - error: host.pi5 Caught by controller[0]: }
                    2025-08-17 13:04:27.534  - error: host.pi5 Caught by controller[0]: Node.js v20.19.4
                    2025-08-17 13:04:27.534  - error: host.pi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2025-08-17 13:04:27.534  - info: host.pi5 Restart adapter system.adapter.echarts.0 because enabled
                    2025-08-17 13:04:32.757  - info: host.pi5 instance system.adapter.openweathermap.0 having pid 1501 terminated with code 0 (NO_ERROR)
                    2025-08-17 13:04:58.016  - info: host.pi5 instance system.adapter.echarts.0 in version "2.0.7" started with pid 2023
                    2025-08-17 13:04:58.673  - error: host.pi5 Caught by controller[0]: node:internal/modules/cjs/loader:1651
                    2025-08-17 13:04:58.673  - error: host.pi5 Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                    2025-08-17 13:04:58.673  - error: host.pi5 Caught by controller[0]:                  ^
                    2025-08-17 13:04:58.673  - error: host.pi5 Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._extensions..node (node:internal/modules/cjs/loader:1651:18)
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1275:32)
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1096:12)
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1298:19)
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at require (node:internal/modules/helpers:182:18)
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1529:14)
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1096:12) {
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                    2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]: }
                    2025-08-17 13:04:58.675  - error: host.pi5 Caught by controller[0]: Node.js v20.19.4
                    2025-08-17 13:04:58.675  - error: host.pi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                    2025-08-17 13:04:58.675  - info: host.pi5 Restart adapter system.adapter.echarts.0 because enabled
                    Full Diag :
                    ========== Start marking the full check here ===========
                    ```bash
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                    cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
                    Hardware Vendor :
                    Kernel          : aarch64
                    Userland        : 64 bit
                    Docker          : v10.0.0
                    Virtualization  : docker
                    Kernel          : aarch64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     13:04:42 up  1:50,  0 user,  load average: 2.74, 2.92, 1.77
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'bookworm'!
                    *** TIME AND TIMEZONES ***
                    Sun Aug 17 11:04:42 UTC 2025
                    Sun Aug 17 13:04:42 CEST 2025
                    CEST +0200
                    Etc/UTC
                    *** Users and Groups ***
                    User that called 'iob diag':
                    root
                    HOME=/root
                    GROUPS=root
                    iobroker
                    HOME=/opt/iobroker
                    GROUPS=iobroker tty dialout audio video plugdev redis
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         false
                    System has not been booted with systemd as init system (PID 1). Can't operate.
                    Failed to connect to bus: Host is down
                    Display-Manager:
                    Desktop:
                    Session:
                    *** MEMORY ***
                    Mem:            8.4G        5.6G        1.2G        6.9M        1.8G        2.9G
                    Swap:           536M          0B        536M
                    Total:          9.0G        5.6G        1.7G
                    Active iob-Instances:   50
                             8052 M total memory
                             5333 M used memory
                             4276 M active memory
                             1922 M inactive memory
                             1117 M free memory
                              194 M buffer memory
                             1511 M swap cache
                              511 M total swap
                                0 M used swap
                              511 M free swap
                    top - 13:04:42 up  1:50,  0 user,  load average: 2.74, 2.92, 1.77
                    Tasks:  56 total,   1 running,  55 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   8052.2 total,   1116.0 free,   5335.5 used,   1706.0 buff/cache
                    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2716.8 avail Mem
                    *** DMESG CRITICAL ERRORS ***
                    dmesg: read kernel buffer failed: Operation not permitted
                    No critical errors detected
                    *** FILESYSTEM ***
                    Filesystem     Type     Size  Used Avail Use% Mounted on
                    overlay        overlay  235G   17G  206G   8% /
                    tmpfs          tmpfs     64M     0   64M   0% /dev
                    shm            tmpfs     64M     0   64M   0% /dev/shm
                    /dev/nvme0n1p2 ext4     235G   17G  206G   8% /opt/iobroker
                    tmpfs          tmpfs    4.0G     0  4.0G   0% /proc/asound
                    tmpfs          tmpfs    4.0G     0  4.0G   0% /sys/firmware
                    Show mounted filesystems:
                    TARGET           SOURCE        FSTYPE OPTIONS
                    /opt/iobroker    /dev/nvme0n1p2[/var/lib/docker/volumes/43efbba1a752f74678556bf2b0336400ef9e9d821f4a314275ce1b3711f60faa/_data]          ext4   rw,noatime
                    /etc/resolv.conf /dev/nvme0n1p2[/var/lib/docker/containers/4bc415f1011bbaef2ba529cd04d3c4cc883fc803d9515710b18ff1341372b4e0/resolv.conf] ext4   rw,noatime
                    /etc/hostname    /dev/nvme0n1p2[/var/lib/docker/containers/4bc415f1011bbaef2ba529cd04d3c4cc883fc803d9515710b18ff1341372b4e0/hostname]    ext4   rw,noatime
                    /etc/hosts       /dev/nvme0n1p2[/var/lib/docker/containers/4bc415f1011bbaef2ba529cd04d3c4cc883fc803d9515710b18ff1341372b4e0/hosts]       ext4   rw,noatime
                    /var:
                    40M     /var/
                    38M     /var/lib
                    19M     /var/lib/dpkg
                    19M     /var/lib/apt/lists
                    19M     /var/lib/apt
                    /opt/iobroker/backups:
                    864M    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    192M    /opt/iobroker/iobroker-data/
                    176M    /opt/iobroker/iobroker-data/files
                    158M    /opt/iobroker/iobroker-data/files/admin.admin
                    157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                    16M     /opt/iobroker/iobroker-data/objects.jsonl
                    7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/zigbee
                    *** ZigBee Settings ***
                    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v20.19.4
                    /usr/bin/node           v20.19.4
                    /usr/bin/corepack       0.32.0
                    nodejs:
                      Installed: 20.19.4-1nodesource1
                      Candidate: 20.19.4-1nodesource1
                      Version table:
                     *** 20.19.4-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                            100 /var/lib/dpkg/status
                         20.19.3-1nodesource1 1001
                         20.19.2-1nodesource1 1001
                         20.19.1-1nodesource1 1001
                         20.19.0-1nodesource1 1001
                         20.18.3-1nodesource1 1001
                         20.18.2-1nodesource1 1001
                         20.18.1-1nodesource1 1001
                         20.18.0-1nodesource1 1001
                         20.17.0-1nodesource1 1001
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         18.19.0+dfsg-6~deb12u2 500
                         18.19.0+dfsg-6~deb12u1 500
                    No problems detected
                    Errors in npm tree: 0
                    Checking for nodejs vulnerability:
                    *** ioBroker-Installation ***
                    ioBroker Status
                    At least one iobroker host is running.
                    Objects type: redis
                    States  type: redis
                    Hosts:
                    pi5                 pi5 (version: 7.0.7, hostname: pi5           , alive, uptime: 256)
                    Core adapters versions
                    js-controller:  7.0.7
                    admin:          7.7.2
                    javascript:     9.0.11
                    nodejs modules from github:     2
                    +-- iobroker.ap-systems-ez1@0.1.0 (git+ssh://git@github.com/exne-soptim/ioBroker.ap-systems-ez1.git#2092ad28047ec7e726de2169c1148c1a9a84ff42)
                    | `-- bluelinky@9.1.0 (git+ssh://git@github.com/arteck/bluelinky.git#1525bcfa8e98338406bd8ec207c95d19d8ac1ba8)
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : pi5                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.ap-systems-ez1.0         : ap-systems-ez1        : pi5                                      -  enabled, port: 8050
                    + system.adapter.backitup.0               : backitup              : pi5                                      -  enabled
                    + system.adapter.bluelink.0               : bluelink              : pi5                                      -  enabled
                    + system.adapter.broadlink2.0             : broadlink2            : pi5                                      -  enabled
                    + system.adapter.cloud.0                  : cloud                 : pi5                                      -  enabled
                    + system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : pi5                                      -  enabled
                      system.adapter.devices.0                : devices               : pi5                                      - disabled
                    + system.adapter.discovery.0              : discovery             : pi5                                      -  enabled
                    + system.adapter.e3dc-rscp.0              : e3dc-rscp             : pi5                                      -  enabled
                    + system.adapter.easee.0                  : easee                 : pi5                                      -  enabled
                      system.adapter.echarts.0                : echarts               : pi5                                      -  enabled
                    + system.adapter.fritzbox.0               : fritzbox              : pi5                                      -  enabled
                    + system.adapter.fullybrowser.0           : fullybrowser          : pi5                                      -  enabled
                    + system.adapter.heatingcontrol.0         : heatingcontrol        : pi5                                      -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : pi5                                      -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : pi5                                      -  enabled, port: 0
                    + system.adapter.hm-rpc.1                 : hm-rpc                : pi5                                      -  enabled, port: 0
                    + system.adapter.hm-rpc.2                 : hm-rpc                : pi5                                      -  enabled, port: 0
                    + system.adapter.hm-rpc.3                 : hm-rpc                : pi5                                      -  enabled, port: 0
                      system.adapter.ical.0                   : ical                  : pi5                                      -  enabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: pi5                                      - disabled
                      system.adapter.icons-icons8.0           : icons-icons8          : pi5                                      - disabled
                      system.adapter.icons-material-png.0     : icons-material-png    : pi5                                      - disabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : pi5                                      - disabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pi5                                      - disabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : pi5                                      - disabled
                    + system.adapter.influxdb.0               : influxdb              : pi5                                      -  enabled, port: 8086
                    + system.adapter.javascript.0             : javascript            : pi5                                      -  enabled
                    + system.adapter.javascript.1             : javascript            : pi5                                      -  enabled
                    + system.adapter.javascript.2             : javascript            : pi5                                      -  enabled
                    + system.adapter.javascript.3             : javascript            : pi5                                      -  enabled
                    + system.adapter.javascript.4             : javascript            : pi5                                      -  enabled
                    + system.adapter.lgtv.0                   : lgtv                  : pi5                                      -  enabled
                      system.adapter.meteoalarm.0             : meteoalarm            : pi5                                      -  enabled
                    + system.adapter.mielecloudservice.0      : mielecloudservice     : pi5                                      -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : pi5                                      -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.mqtt.1                   : mqtt                  : pi5                                      -  enabled, port: 1884, bind: 0.0.0.0
                    + system.adapter.mqtt.2                   : mqtt                  : pi5                                      - disabled, port: 1885, bind: 0.0.0.0
                    + system.adapter.mqtt.3                   : mqtt                  : pi5                                      -  enabled, port: 1890, bind: 0.0.0.0
                    + system.adapter.mqtt.4                   : mqtt                  : pi5                                      -  enabled, port: 1892, bind: 192.168.178.35
                    + system.adapter.mqtt.5                   : mqtt                  : pi5                                      -  enabled, port: 1889, bind: 0.0.0.0
                      system.adapter.mqtt.6                   : mqtt                  : pi5                                      - disabled, port: 1895, bind: 0.0.0.0
                    + system.adapter.onvif.0                  : onvif                 : pi5                                      -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                      system.adapter.openweathermap.0         : openweathermap        : pi5                                      -  enabled
                    + system.adapter.pushover.0               : pushover              : pi5                                      -  enabled
                    + system.adapter.pushover.1               : pushover              : pi5                                      -  enabled
                    + system.adapter.resol.0                  : resol                 : pi5                                      -  enabled
                    + system.adapter.rest-api.0               : rest-api              : pi5                                      -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                    + system.adapter.rpi2.0                   : rpi2                  : pi5                                      -  enabled
                    + system.adapter.scenes.0                 : scenes                : pi5                                      -  enabled
                    + system.adapter.simple-api.0             : simple-api            : pi5                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      system.adapter.tapo.0                   : tapo                  : pi5                                      - disabled
                    + system.adapter.telegram.0               : telegram              : pi5                                      -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.tibberlink.0             : tibberlink            : pi5                                      -  enabled
                    + system.adapter.tr-064.0                 : tr-064                : pi5                                      -  enabled
                    + system.adapter.trashschedule.0          : trashschedule         : pi5                                      -  enabled
                      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: pi5                                      - disabled
                      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : pi5                                      - disabled
                      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : pi5                                      - disabled
                      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: pi5                                      - disabled
                      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: pi5                                      - disabled
                      system.adapter.vis-2-widgets-ovarious.0 : vis-2-widgets-ovarious: pi5                                      - disabled
                      system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: pi5                                      - disabled
                    + system.adapter.vis-2.0                  : vis-2                 : pi5                                      -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : pi5                                      - disabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : pi5                                      - disabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : pi5                                      -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pi5                                      - disabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : pi5                                      - disabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pi5                                      - disabled
                      system.adapter.vis-justgage.0           : vis-justgage          : pi5                                      - disabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : pi5                                      - disabled
                      system.adapter.vis-material.0           : vis-material          : pi5                                      - disabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : pi5                                      - disabled
                      system.adapter.vis-metro.0              : vis-metro             : pi5                                      - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : pi5                                      - disabled
                      system.adapter.vis.0                    : vis                   : pi5                                      -  enabled
                    + system.adapter.web.0                    : web                   : pi5                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.wiffi-wz.0               : wiffi-wz              : pi5                                      -  enabled
                    + system.adapter.worx.0                   : worx                  : pi5                                      -  enabled
                    + system.adapter.zigbee.0                 : zigbee                : pi5                                      -  enabled, port: /dev/serial/by-id/zigbee
                    + instance is alive
                    ioBroker-Repositories
                    │ (index) │ name               │ url                                                     │ auto upgrade │
                    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                    │ 2       │ 'Live (stable)'    │ 'http://repo.iobroker.live/sources-dist.json'           │ false        │
                    │ 3       │ 'Live (latest)'    │ 'http://repo.iobroker.live/sources-dist-latest.json'    │ false        │
                    Active repo(s): Beta (latest)
                    Upgrade policy: none
                    Installed ioBroker-Adapters
                    Used repository: Beta (latest)
                    Adapter    "admin"        : 7.7.2    , installed 7.7.2
                    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                    Adapter    "bluelink"     : 3.1.20   , installed 3.1.20
                    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                    Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                    Adapter    "cloudless-homeconnect": 1.6.2, installed 1.6.2
                    Adapter    "devices"      : 1.2.8    , installed 1.2.8
                    Adapter    "discovery"    : 5.0.0    , installed 5.0.0
                    Adapter    "e3dc-rscp"    : 1.4.2    , installed 1.4.2
                    Adapter    "easee"        : 1.0.10   , installed 1.0.10
                    Adapter    "echarts"      : 2.0.7    , installed 2.0.7
                    Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                    Adapter    "heatingcontrol": 2.12.15 , installed 2.12.15
                    Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                    Adapter    "ical"         : 1.16.2   , installed 1.16.2
                    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                    Controller "js-controller": 7.0.7    , installed 7.0.7
                    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                    Adapter    "meteoalarm"   : 4.0.1    , installed 4.0.1
                    Adapter    "mielecloudservice": 6.5.11, installed 6.5.11
                    Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                    Adapter    "openweathermap": 1.4.0   , installed 1.4.0
                    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                    Adapter    "resol"        : 1.5.1    , installed 1.5.1
                    Adapter    "rest-api"     : 3.0.1    , installed 3.0.1
                    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                    Adapter    "scenes"       : 4.0.3    , installed 4.0.3
                    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                    Adapter    "tapo"         : 0.4.8    , installed 0.4.8
                    Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                    Adapter    "tibberlink"   : 5.0.1    , installed 5.0.1
                    Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                    Adapter    "trashschedule": 4.0.1    , installed 4.0.1
                    Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
                    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
                    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                    Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
                    Adapter    "vis-2-widgets-inventwo": 0.3.5, installed 0.3.5
                    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                    Adapter    "vis-2-widgets-ovarious": 1.0.0, installed 1.0.0
                    Adapter    "vis-2-widgets-weather-and-heating": 1.1.1, installed 1.1.1
                    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                    Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
                    Adapter    "web"          : 7.0.9    , installed 7.0.9
                    Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
                    Adapter    "worx"         : 3.2.7    , installed 3.2.7
                    Adapter    "ws"           : 3.0.19   , installed 3.0.19
                    Adapter    "zigbee"       : 3.0.3    , installed 3.0.3
                    Objects and States
                    Objects:        16625
                    States:         13444
                    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                    Hit:4 https://repos.influxdata.com/debian stable InRelease
                    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      0          8484       -
                    tcp        0      0 192.168.178.35:2001     0.0.0.0:*               LISTEN      1000       107648     -
                    tcp        0      0 192.168.178.35:2000     0.0.0.0:*               LISTEN      1000       107668     -
                    tcp        0      0 192.168.178.35:2010     0.0.0.0:*               LISTEN      1000       106491     -
                    tcp        0      0 192.168.178.35:1892     0.0.0.0:*               LISTEN      1000       109716     -
                    tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          8395       -
                    tcp        0      0 192.168.178.35:8701     0.0.0.0:*               LISTEN      1000       107743     -
                    tcp        0      0 0.0.0.0:8086            0.0.0.0:*               LISTEN      0          9448       -
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      0          8449       -
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5017       -
                    tcp        0      0 192.168.178.35:8181     0.0.0.0:*               LISTEN      1000       109317     -
                    tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1000       107428     -
                    tcp        0      0 0.0.0.0:1891            0.0.0.0:*               LISTEN      1000       107429     -
                    tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1000       107495     -
                    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       108745     -
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       107869     -
                    tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          8397       -
                    tcp6       0      0 :::3000                 :::*                    LISTEN      1000       107126     -
                    tcp6       0      0 :::6379                 :::*                    LISTEN      0          8485       -
                    tcp6       0      0 :::8000                 :::*                    LISTEN      0          8396       -
                    tcp6       0      0 :::8095                 :::*                    LISTEN      1000       108332     -
                    tcp6       0      0 :::8093                 :::*                    LISTEN      1000       109192     -
                    tcp6       0      0 :::8086                 :::*                    LISTEN      0          9449       -
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       108390     -
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       110330     -
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       103915     -
                    tcp6       0      0 :::9001                 :::*                    LISTEN      0          8450       -
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          5019       -
                    tcp6       0      0 :::8554                 :::*                    LISTEN      0          6504       -
                    tcp6       0      0 :::8555                 :::*                    LISTEN      0          6524       -
                    tcp6       0      0 :::1984                 :::*                    LISTEN      0          9416       -
                    tcp6       0      0 :::9443                 :::*                    LISTEN      0          8398       -
                    udp        0      0 0.0.0.0:57160           0.0.0.0:*                           1000       104231     -
                    udp        0      0 192.168.178.35:8555     0.0.0.0:*                           0          6536       -
                    udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       110883     -
                    udp        0      0 172.18.0.1:5353         0.0.0.0:*                           1000       110882     -
                    udp        0      0 192.168.178.35:5353     0.0.0.0:*                           1000       110881     -
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5730       -
                    udp        0      0 0.0.0.0:54812           0.0.0.0:*                           104        5732       -
                    udp        0      0 0.0.0.0:46994           0.0.0.0:*                           1000       104227     -
                    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       104225     -
                    udp6       0      0 fe80::2f63:151f:218:546 :::*                                0          8592       -
                    udp6       0      0 :::53860                :::*                                104        5733       -
                    udp6       0      0 :::5353                 :::*                                104        5731       -
                    iob diag has finished.
                    root@pi5:/opt/iobroker#
                      @gargano sagte in eCharts - Nach update auf 2.0.7 startet Instanz nicht mehr:
                      Docker : v10.0.0
                      Da bin ich raus. Gibt es nicht mittlerweile v11.x.y ?
                      • Gargano
                        @thomas-braun Wie erklärst Du Dir den Fehler am Schluss ?
                          Keine Ahnung. Von Docker lass ich die Finger.
                          • Gargano
                            @thomas-braun sagte in eCharts - Nach update auf 2.0.7 startet Instanz nicht mehr:
                            Ok, Danke trotzdem.
                            Ich vermute mal , es liegt am etwas älteren Nodejs. (V20.x)
                            Mal schauen, ob ich auf Docker V11 wechseln muß.
                              CommanderXXL @Gargano last edited by
                              @gargano Ich nutze kein Docker und habe das gleiche Problem mit meinem echarts. Es ist zum ersten mal aufgetreten nach meinem Update auf 2.0.7 NACHDEM ich auf das neue Node 22 upgedatet habe. Seitdem hat nichts geholfen. Downgrade auf 2.0.6 bringt selben Fehler. Upgrade auf 2.0.8 hat selbes Problem. Und Node will ich nicht auf 20 downgraden. Ich habe beim Adapter einen Bug eingestellt (oder eher mich einem Bug angschlossen 😉 ) https://github.com/ioBroker/ioBroker.echarts/issues/927)
                              Bisher ist mein Workaround das ECharts in den Instanzen abzuschalten um nicht alle 30 Sekunden den Log vollzuspamen. Die Diagramme im Broker selbst gehen noch, nur kein Rendering per SendTo und vielleicht andere Sachen.
                              Norb1204 created this issue in ioBroker/ioBroker.echarts
                              open Instance does not start after update 2.0.7 #927
                              Eduard77 1 Reply Last reply Reply Quote 0
                              • Eduard77
                                Eduard77 @CommanderXXL last edited by Eduard77
                                @commanderxxl
                                hast du Canvas nach Node.js update neu gebaut?
                                cd /opt/iobroker/node_modules/canvas/
                                sudo -u iobroker npm install --omit=dev
                                bei mir hat es geholfen.
                                A C 2 Replies Last reply Reply Quote 0
                                  amgxda @Eduard77 last edited by
                                  @eduard77
                                  Bei mir tritt auch der oben beschriebene Fehler auf (nach Update auf node 22). Habe schon verschiedenes versucht (eCharts komplett neu installiert (2.0.6 bis 2.0.8), libcairo2 aus Quellen gebaut, canvas neu gebaut), bisher alles ohne Erfolg.
                                    CommanderXXL @Eduard77 last edited by
                                    @eduard77 Ja, habe ich getan. Hat aber keine Besserung gebracht. Im Ticket https://github.com/ioBroker/ioBroker.echarts/issues/927 hatte xdaamg noch einen anderen Tip mit komplette Lib von Cairo neu erstellen. Das hat er aber ausprobiert und hat ebenfalls keine Besserung gebracht.
                                    • Eduard77
                                      Eduard77 @amgxda last edited by Eduard77
                                      @amgxda
                                      Dann gib uns die Ausgabe von
                                      iob diag
                                      Edit: hast du die Code oben ausprobiert?
                                        Hier mal mein "iob diag" output:
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                         Static hostname: IObrokerPi5
                                               Icon name: computer
                                                  Kernel: Linux 6.12.34+rpt-rpi-2712
                                            Architecture: arm64
                                        OS is similar to:
                                        Model           : Raspberry Pi 5 Model B Rev 1.0
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                         11:55:24 up  3:44,  2 users,  load average: 0.36, 0.69, 0.48
                                        CPU threads: 4
                                        *** RASPBERRY THROTTLING ***
                                        Current issues:
                                        Previously detected issues:
                                        ~ Under-voltage has occurred
                                        ~ Arm frequency capping has occurred
                                                       Local time: Fri 2025-08-22 11:55:24 CEST
                                                   Universal time: Fri 2025-08-22 09:55:24 UTC
                                                         RTC time: Fri 2025-08-22 09:55:24
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        admin
                                        HOME=/home/admin
                                        GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        Unit display-manager.service could not be found.
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:            8.5G        2.3G        4.9G        5.5M        1.3G        6.1G
                                        Swap:           209M          0B        209M
                                        Total:          8.7G        2.3G        5.1G
                                        Active iob-Instances:   24
                                                 8063 M total memory
                                                 2218 M used memory
                                                 2010 M active memory
                                                  834 M inactive memory
                                                 4675 M free memory
                                                  261 M buffer memory
                                                 1001 M swap cache
                                                  199 M total swap
                                                    0 M used swap
                                                  199 M free swap
                                        top - 11:55:24 up  3:44,  2 users,  load average: 0.36, 0.69, 0.48
                                        Tasks: 213 total,   1 running, 212 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   8063.2 total,   4674.1 free,   2219.9 used,   1262.3 buff/cache
                                        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5843.2 avail Mem
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        151 CRITICAL ERRORS DETECTED!
                                        Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                                        *** FILESYSTEM ***
                                        udev           devtmpfs  3.9G     0  3.9G   0% /dev
                                        tmpfs          tmpfs     1.6G  5.3M  1.6G   1% /run
                                        /dev/mmcblk0p2 ext4       59G   17G   39G  31% /
                                        tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                        /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
                                        tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
                                        [Fri Aug 22 08:10:26 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:33:7E:48 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1773a755-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                        [Fri Aug 22 08:10:29 2025] EXT4-fs (mmcblk0p2): mounted filesystem 7909438b-2884-423e-aa05-577fdea75c97 ro with ordered data mode. Quota mode: none.
                                        [Fri Aug 22 08:10:30 2025] EXT4-fs (mmcblk0p2): re-mounted 7909438b-2884-423e-aa05-577fdea75c97 r/w.
                                        /                /dev/mmcblk0p2 ext4   rw,noatime
                                        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                        /var:
                                        1.2G    /var/
                                        613M    /var/log
                                        612M    /var/log/journal/e004c5c494f24635be857afd2b9c7aee
                                        221M    /var/cache
                                        Archived and active journals take up 611.9M in the file system.
                                        76M     /opt/iobroker/backups/
                                        803M    /opt/iobroker/iobroker-data/
                                        456M    /opt/iobroker/iobroker-data/history
                                        252M    /opt/iobroker/iobroker-data/files
                                        79M     /opt/iobroker/iobroker-data/backup-objects
                                        52M     /opt/iobroker/iobroker-data/files/vis-2
                                        19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                        15M     /opt/iobroker/iobroker-data/objects.jsonl
                                        9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                                        8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CjzUbllv.js
                                        8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                                        USB-Devices by-id:
                                        /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        /usr/bin/nodejs         v22.18.0
                                        /usr/bin/node           v22.18.0
                                        /usr/bin/npm            11.5.2
                                        /usr/bin/npx            11.5.2
                                        /usr/bin/corepack       0.33.0
                                        nodejs:
                                          Installed: 22.18.0-1nodesource1
                                          Candidate: 22.18.0-1nodesource1
                                          Version table:
                                         *** 22.18.0-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                             22.17.1-1nodesource1 1001
                                             22.17.0-1nodesource1 1001
                                             22.16.0-1nodesource1 1001
                                             22.15.1-1nodesource1 1001
                                             22.15.0-1nodesource1 1001
                                             22.14.0-1nodesource1 1001
                                             22.13.1-1nodesource1 1001
                                             22.13.0-1nodesource1 1001
                                             22.12.0-1nodesource1 1001
                                             22.11.0-1nodesource1 1001
                                             22.10.0-1nodesource1 1001
                                             22.9.0-1nodesource1 1001
                                             22.8.0-1nodesource1 1001
                                             22.7.0-1nodesource1 1001
                                             22.6.0-1nodesource1 1001
                                             22.5.1-1nodesource1 1001
                                             22.5.0-1nodesource1 1001
                                             22.4.1-1nodesource1 1001
                                             22.4.0-1nodesource1 1001
                                             22.3.0-1nodesource1 1001
                                             22.2.0-1nodesource1 1001
                                             22.1.0-1nodesource1 1001
                                             22.0.0-1nodesource1 1001
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        IObrokerPi5         IObrokerPi5 (version: 7.0.7, hostname: IObrokerPi5   , alive, uptime: 376)
                                        admin:          7.7.2
                                        javascript:     9.0.11
                                        nodejs modules from github:     1
                                        +-- iobroker.deconz@2.0.7 (git+ssh://git@github.com/Jey-Cee/ioBroker.deconz.git#8af7464adc2de2241a4d0136e2189a9825d38105)
                                        Adapter State
                                        + system.adapter.admin.0                  : admin                 : IObrokerPi5                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.alexa2.0                 : alexa2                : IObrokerPi5                              -  enabled
                                        + system.adapter.backitup.0               : backitup              : IObrokerPi5                              -  enabled
                                        + system.adapter.cloud.0                  : cloud                 : IObrokerPi5                              -  enabled
                                        + system.adapter.deconz.0                 : deconz                : IObrokerPi5                              -  enabled, port: 80
                                          system.adapter.devices.0                : devices               : IObrokerPi5                              - disabled
                                        + system.adapter.discovery.0              : discovery             : IObrokerPi5                              -  enabled
                                          system.adapter.echarts.0                : echarts               : IObrokerPi5                              - disabled
                                          system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IObrokerPi5                              - disabled
                                        + system.adapter.email.0                  : email                 : IObrokerPi5                              -  enabled
                                        + system.adapter.energiefluss.0           : energiefluss          : IObrokerPi5                              -  enabled
                                          system.adapter.eusec.0                  : eusec                 : IObrokerPi5                              - disabled
                                          system.adapter.feiertage.0              : feiertage             : IObrokerPi5                              -  enabled
                                        + system.adapter.history.0                : history               : IObrokerPi5                              -  enabled
                                        + system.adapter.hmip.0                   : hmip                  : IObrokerPi5                              -  enabled
                                          system.adapter.ical.0                   : ical                  : IObrokerPi5                              -  enabled
                                        + system.adapter.iot.0                    : iot                   : IObrokerPi5                              -  enabled
                                        + system.adapter.javascript.0             : javascript            : IObrokerPi5                              -  enabled
                                        + system.adapter.matter.0                 : matter                : IObrokerPi5                              -  enabled
                                        + system.adapter.mielecloudservice.0      : mielecloudservice     : IObrokerPi5                              -  enabled
                                        + system.adapter.mqtt.0                   : mqtt                  : IObrokerPi5                              -  enabled, port: 1883, bind: 0.0.0.0
                                        + system.adapter.pvforecast.0             : pvforecast            : IObrokerPi5                              -  enabled
                                        + system.adapter.shelly.0                 : shelly                : IObrokerPi5                              -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.smartmeter.0             : smartmeter            : IObrokerPi5                              -  enabled
                                        + system.adapter.telegram.0               : telegram              : IObrokerPi5                              -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.text2command.0           : text2command          : IObrokerPi5                              -  enabled
                                        + system.adapter.tr-064.0                 : tr-064                : IObrokerPi5                              -  enabled
                                          system.adapter.twinkly.0                : twinkly               : IObrokerPi5                              - disabled
                                        + system.adapter.vis-2.0                  : vis-2                 : IObrokerPi5                              -  enabled
                                          system.adapter.weatherunderground.0     : weatherunderground    : IObrokerPi5                              -  enabled
                                        + system.adapter.web.0                    : web                   : IObrokerPi5                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        + instance is alive
                                        Active repo(s): beta
                                        Used repository: beta
                                        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                                        Adapter    "deconz"       : 1.6.4    , installed 2.0.7
                                        Adapter    "echarts"      : 2.0.8    , installed 2.0.8
                                        Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
                                        Adapter    "email"        : 2.0.4    , installed 2.0.4
                                        Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                                        Adapter    "eusec"        : 1.3.3    , installed 1.3.3
                                        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                                        Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                                        Adapter    "iot"          : 3.6.0    , installed 3.6.0
                                        Adapter    "matter"       : 0.5.2    , installed 0.5.2
                                        Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
                                        Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                                        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                        Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                        Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
                                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                        Objects and States
                                        Objects:        7118
                                        States:         5656
                                        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                        Pending Updates: 0
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       94899      5398/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       94905      5398/iobroker.js-co
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6392       795/sshd: /usr/sbin
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       98428      5744/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       100534     6160/io.shelly.0
                                        tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       98429      5744/io.mqtt.0
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96036      5416/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       102630     7035/io.web.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          6394       795/sshd: /usr/sbin
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105124     7067/io.matter.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105114     7067/io.matter.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105109     7067/io.matter.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6127       664/avahi-daemon: r
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       102576     6970/io.deconz.0
                                        udp        0      0 0.0.0.0:44612           0.0.0.0:*                           1001       105120     7067/io.matter.0
                                        udp        0      0 0.0.0.0:49878           0.0.0.0:*                           104        6129       664/avahi-daemon: r
                                        udp6       0      0 :::5353                 :::*                                1001       105125     7067/io.matter.0
                                        udp6       0      0 :::5353                 :::*                                1001       105115     7067/io.matter.0
                                        udp6       0      0 :::5353                 :::*                                1001       105110     7067/io.matter.0
                                        udp6       0      0 :::5353                 :::*                                104        6128       664/avahi-daemon: r
                                        udp6       0      0 :::1900                 :::*                                1001       102579     6970/io.deconz.0
                                        udp6       0      0 :::1900                 :::*                                1001       102578     6970/io.deconz.0
                                        udp6       0      0 :::1900                 :::*                                1001       102577     6970/io.deconz.0
                                        udp6       0      0 :::56347                :::*                                104        6130       664/avahi-daemon: r
                                        udp6       0      0 :::44612                :::*                                1001       105119     7067/io.matter.0
                                        udp6       0      0 fe80::e5be:3ac1:ac2:546 :::*                                0          6476       755/NetworkManager
                                        2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.erdgeschoss.command.rollosrauf"
                                        2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.hobbyraum.dimmer.licht"
                                        2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.schrank.switch.licht"
                                        2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.bastelzimmer.switch.licht"
                                        2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.gästebad.dimmer.licht"
                                        2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.gästebad.dimmer.spiegellicht"
                                        2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]: node:internal/modules/cjs/loader:1846
                                        2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                        2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]:                  ^
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object..node (node:internal/modules/cjs/loader:1846:18)
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1423:32)
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1246:12)
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1445:12)
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at require (node:internal/modules/helpers:135:16)
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1688:14)
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object..js (node:internal/modules/cjs/loader:1820:10) {
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: }
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: Node.js v22.18.0
                                        2025-08-22 11:54:20.396  - error: host.IObrokerPi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        2025-08-22 11:54:20.396  - info: host.IObrokerPi5 Do not restart adapter system.adapter.echarts.0 because disabled or deleted
                                          @eduard77
                                          Die Befehle von dir habe ich eingegeben, es hat sich aber nichts geändert. iob diag erspar ich uns jetzt mal (CommanderXXL hat seins schon gepostet), da ist nichts spannendes drin (Raspberry Pi OS Debian Bookworm, alles up-to-date, iobroker latest up-to-date, keine anderen Fehler im Protokoll), nur der e-Charts-Adapter wirft seit dem Upgrade auf Node 22 und Update von 2.0.6 auf 2.0.7/2.0.8 Fehler. Ein Downgrade auf 2.0.6 behebt den Fehler nicht mehr. CoPilot hat diverse Vorschläge zur Korrektur geliefert, die aber letztendlich nichts gebracht haben (Neubauen der libcairo2, canvas).
                                          Ich musste den Adapter deaktivieren und belasse es erst mal dabei, weil die Charts trotzdem angezeigt werden. Wahrscheinlich läuft es ohnehin darauf hinaus, dass mit Debian 13 das System neu aufgesetzt wird.
                                          2025-08-22 11:20:04.481 - info: host.pi5 instance system.adapter.echarts.0 in version "2.0.8" started with pid 336084
                                          2025-08-22 11:20:05.007 - error: host.pi5 Caught by controller[0]: node:internal/modules/cjs/loader:1846
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: ^
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Object..node (node:internal/modules/cjs/loader:1846:18)
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1423:32)
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1246:12)
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1445:12)
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at require (node:internal/modules/helpers:135:16)
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1688:14)
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1820:10) {
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: }
                                          2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: Node.js v22.18.0
                                          2025-08-22 11:20:05.008 - error: host.pi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                          • Eduard77
                                            @commanderxxl
                                            na da hast du ein paar Baustellen, aber dazu kann @Thomas-Braun mehr sagen.
                                            ein paar davon:
                                            1.
                                            1. Wieso hast du bei NPM Version 11?
                                            /usr/bin/npm            11.5.2
                                            /usr/bin/npx            11.5.2
                                            28
                                            1284
