    4. Viessmann neueAPI Endpoints / keine Aktualisierung der Daten
    • Klepper1976
      Klepper1976 last edited by Samson71
      Hallo Zusammen,
      seit Anfang August werden die Daten von meiner Wärmepumpe nicht mehr im iobroker über die Viessmann API übertragen.
      Laut dem Change Log wurden die API Endpoints aktualisiert. In meinem Logbuch im Developer Portal wird auch kein Zugriff mehr dokumentiert.
      Muss jetzt der Adapter im iobroker angepasst werden?
      LG
      Klepper
      July 2025
      Domain Change for the Viessmann API
      As part of the continuous optimization and modernization of our services, we are currently in the process of switching our applications and websites to the new domain viessmann-climatesolutions.com. This change will also affect the domains for resources such as the Developer Portal and the API Documentation.
      For your integrations, this requires the following technical updates:
      1. API Endpoints:
      The base URI for all API calls is changing. You need to update your code to use the new domain.
      Old: https: //​ api.​viessmann.​com/...
      New: https: //​ api.​viessmann-climatesolutions.​com/...
      2. Identity and Access Management (IAM):
      The domain for our identity services will also be updated. This needs to be updated in your application to ensure authorization continues to function correctly.
      Old: https: //​ iam.​viessmann.​com
      New: https: //​ iam.​viessmann-climatesolutions.​com
      3. API Response Body:
      The uri value within the JSON response from the Features API (/iot/v2/features/...) will reflect the new viessmann​-​climatesolutions.​com domain in the future.
      The API endpoints under the new domain are already available, and we ask you to please use the new addresses with immediate effect. The old viessmann​. com domain will be deactivated during Q4/2025, by the end of the year at the latest.
      We understand that these changes may require adjustments to your existing code. To assist you in this process, we recommend referring to the API documentation.
      • Samson71
        Samson71 Global Moderator @Klepper1976 last edited by
        @klepper1976
        Was soll der Doppelpost? Bitte unterlasse so etwas!
        Du hast Dich doch bereits hier schon drangehängt:
        https://forum.iobroker.net/topic/81877/viessmannapi-seit-5-8-keine-datenaktualisierung/15
        Also da weiter. Ich mache hier dann mal zu.
