    4. js Controler auf 7.07 geht nicht Fehlermeldung iOb
    • marcel-drzal
      marcel-drzal last edited by marcel-drzal
      2025-08-22 15:13:55.721 - error: host.iobroker iobroker npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Not compatible with your version of node/npm: @homebridge/ciao@1.2.0npm error notsup Required: {"node":"^18 || ^20"}npm error notsup Actual: {"npm":"10.9.3","node":"v22.18.0"}npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-08-22T13_13_53_260Z-debug-0.log
      2025-08-22 15:13:55.721 - error: host.iobroker iobroker host.iobroker Cannot install iobroker.myuplink@0.8.4: 1
      2025-08-22 15:13:56.732 - info: host.iobroker iobroker exit 25
      2025-08-22 15:14:49.833 - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T14:14:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-22 15:14:50.069 - info: host.iobroker Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
      2025-08-22 15:14:58.547 - info: host.iobroker iobroker upgrade yahka@1.1.5 --debug
      2025-08-22 15:14:59.206 - info: host.iobroker iobroker Update yahka from @1.0.3 to @1.1.5
      2025-08-22 15:14:59.275 - info: host.iobroker iobroker NPM version: 10.9.3
      2025-08-22 15:14:59.275 - info: host.iobroker iobroker Installing iobroker.yahka@1.1.5... (System call)
      2025-08-22 15:15:05.132 - info: host.iobroker iobroker added 1 package, removed 1 package, and changed 19 packages in 6s408 packages are looking for funding run `npm fund` for details
      2025-08-22 15:15:06.399 - error: host.iobroker iobroker Cannot install "pam-devel": WARNING: apt does not have a stable CLI interface. Use with caution in scripts.E: Unable to locate package pam-devel
      2025-08-22 15:15:06.399 - error: host.iobroker iobroker The following apt packages could not be installed: pam-devel. Please install them manually.
      Myuplink adapter installieren geht nicht und
      hoffe ihr könnt mir helfen und bitte nachsichtig bin nicht so fitt hier,
      • Adaptername: ... myuplink
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: ...
      • js-controller Version: ...
      • Admin Version: ...
      • Hardwaresystem: NUC, Pi4 ...
      • Arbeitsspeicher: ...xGB
      • Festplattenart: SD-Karte, SSD, HDD, ...
      • Betriebssystem: ...
      • Nodejs-Version: ...v22.18.0
      • NPM-Version: ...10.9.3
      • Installationsart: Skript oder Manuell ?
      • Image, Docker genutzt: Ja - Nein
      • Ort, Name der Imagedatei: ...
      ========== Start marking the full check here ===========
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 11 (bullseye)
         Static hostname: iobroker
               Icon name: computer-container
                 Chassis: container
          Virtualization: lxc
                  Kernel: Linux 6.8.12-13-pve
            Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i7-10710U CPU @ 1.10GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       14:54:39 up 59 min,  1 user,  load average: 0.81, 0.67, 0.45
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2025-08-22 14:54:39 CEST
                 Universal time: Fri 2025-08-22 12:54:39 UTC
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      marcel
      HOME=/home/marcel
      GROUPS=marcel sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            6.1G        1.7G        3.3G        0.0K        1.1G        4.5G
      Swap:           512M          0B        512M
      Total:          6.7G        1.7G        3.8G
      Active iob-Instances:   22
               6144 M total memory
               1687 M used memory
               1552 M active memory
                963 M inactive memory
               3322 M free memory
                  0 M buffer memory
               1134 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 14:54:39 up 59 min,  1 user,  load average: 0.81, 0.67, 0.45
      Tasks:  51 total,   2 running,  49 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 12.1 us,  6.1 sy,  0.0 ni, 81.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   6144.0 total,   3322.1 free,   1687.8 used,   1134.1 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   4456.0 avail Mem
      *** FAILED SERVICES ***
        UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
      * influxdb.service              loaded failed failed InfluxDB is an open-source, distributed, time series database
      * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
      4 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--160--disk--0 ext4       30G   11G   17G  39% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs   32G     0   32G   0% /dev/tty
      tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
      tmpfs                            tmpfs      13G  108K   13G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                            tmpfs     6.3G     0  6.3G   0% /run/user/1001
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--160--disk--0 ext4   rw,relatime,stripe=16
      /var:
      1.7G    /var/
      709M    /var/cache
      704M    /var/cache/apt
      670M    /var/log
      665M    /var/log/journal/fe2dcc346dde445a9e95482e37c85663
      Archived and active journals take up 33.3M in the file system.
      /opt/iobroker/backups:
      2.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      664M    /opt/iobroker/iobroker-data/
      388M    /opt/iobroker/iobroker-data/files
      176M    /opt/iobroker/iobroker-data/backup-objects
      49M     /opt/iobroker/iobroker-data/files/vis.0
      48M     /opt/iobroker/iobroker-data/files/iot.admin
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      21M     /opt/iobroker/iobroker-data/objects.jsonl
      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.*
      Extended Pan ID:
      grep: /opt/iobroker/iobroker-data/zigbee_*/nvbackup.json: No such file or directory
      Pan ID:
      /home/iobroker/.diag.sh: line 713: printf: 0x: invalid hex number
      0
      Channel:
      Network Key:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.18.0
      /usr/bin/node           v22.18.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.33.0
      nodejs:
        Installed: 22.18.0-1nodesource1
        Candidate: 22.18.0-1nodesource1
        Version table:
       *** 22.18.0-1nodesource1 600
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.17.1-1nodesource1 600
           22.17.0-1nodesource1 600
           22.16.0-1nodesource1 600
           22.15.1-1nodesource1 600
           22.15.0-1nodesource1 600
           22.14.0-1nodesource1 600
           22.13.1-1nodesource1 600
           22.13.0-1nodesource1 600
           22.12.0-1nodesource1 600
           22.11.0-1nodesource1 600
           22.10.0-1nodesource1 600
           22.9.0-1nodesource1 600
           22.8.0-1nodesource1 600
           22.7.0-1nodesource1 600
           22.6.0-1nodesource1 600
           22.5.1-1nodesource1 600
           22.5.0-1nodesource1 600
           22.4.1-1nodesource1 600
           22.4.0-1nodesource1 600
           22.3.0-1nodesource1 600
           22.2.0-1nodesource1 600
           22.1.0-1nodesource1 600
           22.0.0-1nodesource1 600
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 136)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     1
      +-- iobroker.luxtronik2@0.3.0 (git+ssh://git@github.com/UncleSamSwiss/ioBroker.luxtronik2.git#e3a8b912a68cdb84c808a91c6a2250ae4f7ec1b9)
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.denon.0                  : denon                 : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.judoisoft.0              : judoisoft             : iobroker                                 -  enabled
      + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 10.10.50.16
        system.adapter.luxtronik2.0             : luxtronik2            : iobroker                                 - disabled, port: 8214
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.16
      + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name               │ url                                                     │ auto upgrade │
      │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
      │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
      Upgrade policy: none
      Installed ioBroker-Adapters
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "cloud"        : 5.0.1    , installed 5.0.1
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "homekit-controller": 0.5.11, installed 0.5.11
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
      Adapter    "judoisoft"    : 1.1.2    , installed 1.1.2
      Adapter    "klf200"       : 1.3.5    , installed 1.3.5
      Adapter    "knx"          : 2.0.30   , installed 2.0.30
      Adapter    "lg-thinq"     : 1.1.0    , installed 1.1.0
      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-icontwo"  : 1.12.0   , installed 1.12.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.1.5    , installed 1.0.3  [Updatable]
      Objects and States
      Objects:        8605
      States:         6325
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/buster/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (3.224.76.162). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (54.164.204.90). - connect (111: Connection refused)
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://security.debian.org/debian-security trixie-security InRelease
      Hit:2 http://deb.debian.org/debian trixie InRelease
      Get:3 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
      Hit:4 http://deb.debian.org/debian trixie-updates InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Err:3 https://repos.influxdata.com/debian buster InRelease
      Err:6 https://dl.yarnpkg.co m/debian InRelease
        Could not connect to dl.yarnpkg.co:443 (54.164.204.90). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (3.224.76.162). - connect (111: Connection refused)
      Fetched 12.9 kB in 0s (46.6 kB/s)
      Reading package lists...
      W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (54.164.204.90). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (3.224.76.162). - connect (111: Connection refused)
      Pending Updates: 125
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       55537724   24434/iobroker.js-c
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       55537735   24434/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          55289997   168/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          55287579   325/master
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          55287088   1/init
      tcp6       0      0 :::8087                 :::*                    LISTEN      1000       55538522   24776/io.simple-api
      tcp6       0      0 :::8082                 :::*                    LISTEN      1000       55538613   24821/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       55534315   24457/io.admin.0
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          55287580   325/master
      tcp6       0      0 :::22                   :::*                    LISTEN      0          55289999   168/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          55287090   1/init
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          55287203   76/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          55287089   1/init
      udp        0      0 10.10.50.16:123         0.0.0.0:*                           0          55287468   237/ntpd
      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          55287466   237/ntpd
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          55287462   237/ntpd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       55539535   24856/io.wled.0
      udp        0      0 10.10.50.16:48468       0.0.0.0:*                           1000       55538332   24671/io.knx.0
      udp6       0      0 :::111                  :::*                                0          55287091   1/init
      udp6       0      0 fd48:3919:e463:2897:123 :::*                                109        55288262   237/ntpd
      udp6       0      0 fe80::7435:b2ff:fe7:123 :::*                                109        55290215   237/ntpd
      udp6       0      0 ::1:123                 :::*                                0          55287470   237/ntpd
      udp6       0      0 :::123                  :::*                                0          55287459   237/ntpd
      2025-08-22 14:53:37.880  - info: host.iobroker instance system.adapter.web.0 in version "7.0.8" started with pid 24821
      2025-08-22 14:53:38.575  - info: web.0 (24821) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.18.0, js-controller: 7.0.6
      2025-08-22 14:53:38.680  - info: web.0 (24821) socket.io server listening on port 8082
      2025-08-22 14:53:38.681  - info: web.0 (24821) http server listening on port 8082
      2025-08-22 14:53:41.873  - info: host.iobroker instance system.adapter.iot.0 in version "3.3.0" started with pid 24841
      2025-08-22 14:53:42.487  - info: iot.0 (24841) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v22.18.0, js-controller: 7.0.6
      2025-08-22 14:53:42.507  - info: iot.0 (24841) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2025-08-22 14:53:42.833  - info: iot.0 (24841) Connection changed: connect "marcel-drzal_arcor_de"
      2025-08-22 14:53:45.879  - info: host.iobroker instance system.adapter.wled.0 in version "0.7.2" started with pid 24856
      2025-08-22 14:53:46.446  - info: wled.0 (24856) starting. Version 0.7.2 in /opt/iobroker/node_modules/iobroker.wled, node: v22.18.0, js-controller: 7.0.6
      2025-08-22 14:53:46.569  - info: wled.0 (24856) Try to contact 3 known devices
      2025-08-22 14:53:46.569  - info: wled.0 (24856) Try to contact : "WLEDJayson" on IP : 172.16.0.206
      2025-08-22 14:53:49.577  - info: wled.0 (24856) Try to contact : "WLED-SoundReactive" on IP : 172.16.0.205
      2025-08-22 14:53:49.868  - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T13:42:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-22 14:53:49.868  - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T13:53:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      2025-08-22 14:53:49.876  - info: host.iobroker instance system.adapter.info.0 in version "2.0.0" started with pid 24871
      2025-08-22 14:53:50.608  - info: cloud.0 (24641) Trying to connect as system.user.admin to cloud
      2025-08-22 14:53:50.639  - info: info.0 (24871) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.info, node: v22.18.0, js-controller: 7.0.6
      2025-08-22 14:53:50.688  - info: info.0 (24871) Reading/updating systemdata.
      2025-08-22 14:53:50.711  - info: cloud.0 (24641) Connection changed: connect
      2025-08-22 14:53:50.992  - info: info.0 (24871) cpu Temp res = {"main":60,"cores":[57,56,57,63,55,59],"max":63,"socket":[],"chipset":null}
      2025-08-22 14:53:52.578  - info: wled.0 (24856) Try to contact : "WLED-SoundReactive" on IP : 10.10.50.205
      2025-08-22 14:53:55.581  - info: wled.0 (24856) Bonjour service started, new  devices  will  be detected automatically
      2025-08-22 14:54:05.583  - info: wled.0 (24856) WLED initialisation finalized, ready to do my job have fun !
      2025-08-22 14:54:49.819  - info: influxdb.0 (24581) Do not store value "{"Time":"2025-08-22T13:54:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10418.5469,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
      iob diag has finished.Bitte in der nachfolgenden Übersicht die mit ... bzw x gekennzeichneten Felder ausfüllen und im Anschluss an die Tabelle auf Linux Systemen den Output des Commands iob diag einfügen.
      Hinweis: Das Eröffnen eines Issues hier ersetzt NICHT das Anlegen eine Issues im Repository des Adapters. Fehlerbehebungen werden ausschließlich über Issues getrackt.
      DANKE
      Bitte ausfüllen:
      • Adaptername: ...
      • NPM-Version: ...
      Linux User bitte hier den Output von iob diag einfügen.Myuplink adapter installieren geht nicht und
      Script v.2025-08-09
      *** BASE SYSTEM ***
                 Chassis: container
          Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      marcel
      HOME=/home/marcel
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           512M          0B        512M
               6144 M total memory
               1687 M used memory
               3322 M free memory
                  0 M buffer memory
               1134 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      *** FILESYSTEM ***
      /var:
      1.7G    /var/
      709M    /var/cache
      704M    /var/cache/apt
      670M    /var/log
      USB-Devices by-id:
      zigbee.*
      Extended Pan ID:
      Pan ID:
      0
      Channel:
      Network Key:
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.17
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        8605
      States:         6325
        Thomas Braun Most Active @marcel-drzal last edited by Thomas Braun
        @marcel-drzal
        Und dann sind da 125 Updates in der Pipeline...
        Und deine Paketquellen sind 'Kraut-und-Rüben'.
        Setz da einen frischen, konsistenten Container neu auf.
        marcel-drzal 2 Replies Last reply Reply Quote 1
        • marcel-drzal
          marcel-drzal @Thomas Braun last edited by marcel-drzal
          @thomas-braun habe ich versucht aber nicht hin bekommen
          bleibt immer hängen
          login as: root
          root@10.10.50.16's password:
          Linux iobroker 6.8.12-13-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-13 (2025-07-22T10:00Z) x86_64
          The programs included with the Debian GNU/Linux system are free software;
          the exact distribution terms for each program are described in the
          individual files in /usr/share/doc/*/copyright.
          Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
          permitted by applicable law.
          You have mail.
          Last login: Fri Aug 22 14:37:59 2025 from 10.10.10.166
          root@iobroker:~# sudo apt update
          Hit:1 http://deb.debian.org/debian trixie InRelease
          Hit:2 http://security.debian.org/debian-security trixie-security InRelease
          Hit:3 http://deb.debian.org/debian trixie-updates InRelease
          Get:4 https://repos.influxdata.com/debian buster InRelease [12.9 kB]
          Err:4 https://repos.influxdata.com/debian buster InRelease
          Fetched 12.9 kB in 0s (47.0 kB/s)
          Reading package lists... Done
          Building dependency tree... Done
          470 packages can be upgraded. Run 'apt list --upgradable' to see them.
          apt-listchanges: News
          openssh (1:10.0p1-1) unstable; urgency=medium
            OpenSSH 10.0p1 includes a number of changes that may affect existing
            configurations:
             * This release removes support for the weak DSA signature algorithm,
               completing the deprecation process that began in 2015 (when DSA was
               disabled by default) and repeatedly warned over the last 12 months.
             * scp(1), sftp(1): pass "ControlMaster no" to ssh when invoked by scp &
               sftp. This disables implicit session creation by these tools when
               ControlMaster was set to yes/auto by configuration, which some users
               found surprising. This change will not prevent scp/sftp from using an
               existing multiplexing session if one had already been created.
             * sshd(8): this release disables finite field (a.k.a modp) Diffie-Hellman
               key exchange in sshd by default. Specifically, this removes the
               "diffie-hellman-group*" and "diffie-hellman-group-exchange-*" methods
               from the default KEXAlgorithms list. The client is unchanged and
               continues to support these methods by default.
             * sshd(8): this release removes the implicit fallback to compiled-in
               groups for Diffie-Hellman Group Exchange KEX when the moduli file
               exists but does not contain moduli within the client-requested range.
               The fallback behaviour remains for the case where the moduli file does
               not exist at all. This allows administrators more explicit control over
               which DH groups will be selected, but can lead to connection failures
               if the moduli file is edited incorrectly.
           -- Colin Watson <cjwatson@debian.org>  Fri, 11 Apr 2025 11:16:19 +0100
          openssh (1:9.9p1-1) unstable; urgency=medium
            OpenSSH 9.9p1 includes a number of changes that may affect existing
            configurations:
             * ssh(1): remove support for pre-authentication compression.  OpenSSH has
          wie geht es hier weiter??
            @marcel-drzal
            Und wie immer: NIE, NIE, NIE als root herumkaspern.
            marcel-drzal 1 Reply Last reply Reply Quote 1
            • marcel-drzal
              auch als user geht es nicht
                configurations:
              hängt an der Stelle, was muss ich hier machen?
                @marcel-drzal sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                Mit q aus der Nachricht raus...
                marcel-drzal 1 Reply Last reply Reply Quote 0
                • marcel-drzal
                  @thomas-braun said in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                  470 upgraded, 165 newly installed, 34 to remove and 0 not upgraded.
                  Need to get 0 B/341 MB of archives.
                  After this operation, 743 MB of additional disk space will be used.
                  Do you want to continue? [Y/n] Y
                  Reading changelogs... Done
                  apt-listchanges: Mailing root: apt-listchanges: news for iobroker
                  Extracting templates from packages: 100%
                  Preconfiguring packages ...
                  (Reading database ... 43860 files and directories currently installed.)
                  Preparing to unpack .../base-files_13.8_amd64.deb ...
                  * The base-files package cannot be installed because
                  * /bin is a directory, but should be a symbolic link.
                  * Please install the usrmerge package to convert this system to merged-/usr.
                  * For more information please read https://wiki.debian.org/UsrMerge.
                  dpkg: error processing archive /var/cache/apt/archives/base-files_13.8_amd64.deb (--unpack):
                   new base-files package pre-installation script subprocess returned error exit status 1
                  Errors were encountered while processing:
                  E: Sub-process /usr/bin/dpkg returned an error code (1)
                  marcel@iobroker:~$
                  was ist das noch für ein error?
                  Jetzt hat sich auch der js-controler auf 7.0.7 geändert Danke dir das hat schon mal geklappt 👏
                  Installieren von Adapter myuplink gibt unten noch Fehlermeldungen, kannst du mir da helfen. Danke dir
                  $ iobroker add myuplink auto --host iobroker --debug
                  NPM version: 10.9.3
                  Installing iobroker.myuplink@0.8.4... (System call)
                  added 1 package in 4s
                  host.iobroker install adapter myuplink
                  upload [12] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/de/translations.json i18n/de/translations.json application/json
                  upload [11] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/en/translations.json i18n/en/translations.json application/json
                  upload [10] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/es/translations.json i18n/es/translations.json application/json
                  upload [9] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                  upload [8] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/it/translations.json i18n/it/translations.json application/json
                  upload [6] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                  upload [5] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                  upload [4] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                  upload [3] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                  upload [2] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                  upload [1] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/jsonConfig.json jsonConfig.json application/json
                  upload [0] myuplink.admin /opt/iobroker/node_modules/iobroker.myuplink/admin/myuplink.png myuplink.png image/png
                  host.iobroker object system.adapter.myuplink created/updatedUpdating objects from io-package.json for adapter "myuplink" with version "0.8.4"
                  host.iobroker object system.adapter.myuplink.0.compactMode created
                  host.iobroker object system.adapter.myuplink.0.cpu created
                  host.iobroker object system.adapter.myuplink.0.cputime created
                  host.iobroker object system.adapter.myuplink.0.memHeapUsed created
                  host.iobroker object system.adapter.myuplink.0.memHeapTotal created
                  host.iobroker object system.adapter.myuplink.0.memRss created
                  host.iobroker object system.adapter.myuplink.0.uptime created
                  host.iobroker object system.adapter.myuplink.0.inputCount created
                  host.iobroker object system.adapter.myuplink.0.outputCount created
                  host.iobroker object system.adapter.myuplink.0.eventLoopLag created
                  host.iobroker object system.adapter.myuplink.0.sigKill created
                  host.iobroker object system.adapter.myuplink.0.logLevel created
                  host.iobroker object myuplink.0.info created
                  host.iobroker object myuplink.0.info.connection created
                  host.iobroker object myuplink.0.info.currentError created
                  host.iobroker object myuplink.0.info.updateTime created
                  host.iobroker object myuplink.0.info.lastError created
                  host.iobroker Set default value of myuplink.0.info.currentError:
                  host.iobroker Set default value of myuplink.0.info.updateTime:
                  host.iobroker Set default value of myuplink.0.info.lastErrorTime:
                  host.iobroker object system.adapter.myuplink.0 created
                  Process exited with code 0
                  haselchen Thomas Braun 2 Replies Last reply Reply Quote 0
                  • haselchen
                    haselchen Most Active @marcel-drzal last edited by
                    @marcel-drzal
                    Zeig nochmal bitte nen aktuelles
                    iob diag
                      ZUERST musst du die windschiefe Basis in Ordnung bringen. Auf das wackelige Fundament setzt man doch keinen Dienst drauf.
                      • mcm1957
                        mcm1957 last edited by
                        @marcel-drzal
                        Die deinem Problem zugrunde liegende Fehlermeldung ist folgende:
                        Oder extrahiert:
                        Diese wird (oder wurde?) durch YAHKA in einer Version älter als 1.1.5 ausgelöst. Da du anscheinend zwischenzeitlich yahka auf 1.1.5 gebracht hast sollte sich das primäre Problem behoben haben.
                        Was sonst noch zu sanieren wäre hat die @Thomas-Braun schon geschieben,
                        • marcel-drzal
                          @marcel-drzal
                          wie kann ich die Packetquellen sauber ziehen
                          Linux iobroker 6.8.12-13-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-13 (2025-07-22T10                                             :00Z) x86_64
                          Last login: Fri Aug 22 15:54:52 2025 from 10.10.10.166
                          marcel@iobroker:~$   iobroker repo show
                          │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json                                             '        │ false        │
                          │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-late                                             st.json' │ false        │
                          marcel@iobroker:~$
                          • marcel-drzal
                            marcel-drzal @haselchen last edited by marcel-drzal
                            @haselchen
                            ich hoffe ihr könnt mir helfen. Versuche es nun erst einmal Sauber zu ziehen und dann Updaten.
                            ```bash
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                                       Chassis: container
                                Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                             11:54:07 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
                            CPU threads: 2
                                           Local time: Sun 2025-08-24 11:54:07 CEST
                                       Universal time: Sun 2025-08-24 09:54:07 UTC
                                             RTC time: n/a
                                          NTP service: n/a
                                      RTC in local TZ: no
                            marcel
                            HOME=/home/marcel
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Mem:            6.1G        1.9G        3.6G        0.0K        633M        4.3G
                            Swap:           512M          0B        512M
                            Total:          6.7G        1.9G        4.1G
                            Active iob-Instances:   23
                                     6144 M total memory
                                     1892 M used memory
                                     1886 M active memory
                                      493 M inactive memory
                                     3618 M free memory
                                        0 M buffer memory
                                      633 M swap cache
                                      512 M total swap
                                        0 M used swap
                                      512 M free swap
                            top - 11:54:08 up 16:14,  1 user,  load average: 0.43, 0.23, 0.23
                            Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
                            %Cpu(s):  6.2 us,  0.0 sy,  0.0 ni, 93.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   6144.0 total,   3617.9 free,   1892.3 used,    633.8 buff/cache
                            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   4251.6 avail Mem
                            *** FILESYSTEM ***
                            /var:
                            1.7G    /var/
                            709M    /var/cache
                            704M    /var/cache/apt
                            669M    /var/log
                            670M    /opt/iobroker/iobroker-data/
                            377M    /opt/iobroker/iobroker-data/files
                            26M     /opt/iobroker/iobroker-data/objects.jsonl
                            19M     /opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.9.3
                            /usr/bin/npx            10.9.3
                            nodejs:
                              Version table:
                                 20.19.2+dfsg-1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 58433)
                            js-controller:  7.0.7
                            admin:          7.6.17
                            javascript:     8.9.2
                            Adapter State
                            + system.adapter.myuplink.0               : myuplink              : iobroker                                 -  enabled
                            + instance is alive
                            Controller "js-controller": 7.0.7    , installed 7.0.7
                            Adapter    "myuplink"     : 0.8.4    , installed 0.8.4
                            Objects and States
                            Objects:        8765
                            States:         6459
                            W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused)
                              Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
                            Fetched 12.9 kB in 0s (46.8 kB/s)
                            W: Failed to fetch https://dl.yarnpkg.co/dists/m/debian/InRelease  Could not connect to dl.yarnpkg.co:443 (52.203.127.137). - connect (111: Connection refused) Could not connect to dl.yarnpkg.co:443 (107.22.244.154). - connect (111: Connection refused)
                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       22058      140/iobroker.js-con
                            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       17359      140/iobroker.js-con
                            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11038      1/init
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          21672      193/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          21795      320/master
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       32747      712/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       22163      342/io.admin.0
                            tcp6       0      0 :::8087                 :::*                    LISTEN      1000       27465      667/io.simple-api.0
                            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          21796      320/master
                            tcp6       0      0 :::111                  :::*                    LISTEN      0          11040      1/init
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          21674      193/sshd: /usr/sbin
                            udp        0      0 10.10.50.16:50137       0.0.0.0:*                           1000       435218     547/io.knx.0
                            udp        0      0 10.10.50.16:55244       0.0.0.0:*                           1000       1650387    547/io.knx.0
                            udp        0      0 10.10.50.16:57540       0.0.0.0:*                           1000       56405      547/io.knx.0
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16336      75/dhclient
                            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          11039      1/init
                            udp        0      0 10.10.50.16:123         0.0.0.0:*                           0          21644      172/ntpd
                            udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          21642      172/ntpd
                            udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          21638      172/ntpd
                            udp        0      0 10.10.50.16:33034       0.0.0.0:*                           1000       766879     547/io.knx.0
                            udp        0      0 10.10.50.16:33292       0.0.0.0:*                           1000       42281      547/io.knx.0
                            udp        0      0 10.10.50.16:33516       0.0.0.0:*                           1000       796516     547/io.knx.0
                            udp        0      0 10.10.50.16:35890       0.0.0.0:*                           1000       2015188    547/io.knx.0
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       34914      742/io.wled.0
                            udp        0      0 10.10.50.16:38368       0.0.0.0:*                           1000       27253      547/io.knx.0
                            udp        0      0 10.10.50.16:42227       0.0.0.0:*                           1000       144075     547/io.knx.0
                            udp        0    960 10.10.50.16:43259       0.0.0.0:*                           1000       2062242    547/io.knx.0
                            udp        0      0 10.10.50.16:43538       0.0.0.0:*                           1000       2015226    547/io.knx.0
                            udp        0      0 10.10.50.16:47107       0.0.0.0:*                           1000       1431661    547/io.knx.0
                            udp6       0      0 :::111                  :::*                                0          11041      1/init
                            udp6       0      0 fe80::7435:b2ff:fe7:123 :::*                                109        22015      172/ntpd
                            udp6       0      0 fd48:3919:e463:2897:123 :::*                                109        22013      172/ntpd
                            udp6       0      0 ::1:123                 :::*                                0          21646      172/ntpd
                            udp6       0      0 :::123                  :::*                                0          21635      172/ntpd
                            2025-08-24 11:42:49.822  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:42:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:42:56.387  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
                            2025-08-24 11:42:56.430  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
                            2025-08-24 11:42:56.518  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
                            2025-08-24 11:43:49.845  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:43:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:44:49.836  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:44:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:45:10.007  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 3952
                            2025-08-24 11:45:10.613  - info: dwd.0 (3952) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.18.0, js-controller: 7.0.7
                            2025-08-24 11:45:10.805  - info: dwd.0 (3952) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                            2025-08-24 11:45:11.314  - info: host.iobroker instance system.adapter.dwd.0 having pid 3952 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2025-08-24 11:45:49.834  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:45:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:46:49.854  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:46:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:47:49.843  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:47:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:47:56.999  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
                            2025-08-24 11:47:57.042  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
                            2025-08-24 11:47:57.134  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
                            2025-08-24 11:48:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:48:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:49:49.839  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:49:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:50:49.820  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:50:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:51:49.850  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:51:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:52:49.858  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:52:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            2025-08-24 11:52:57.648  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.52" has to be type "number" but received type "string"
                            2025-08-24 11:52:57.690  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.58" has to be type "number" but received type "string"
                            2025-08-24 11:52:57.782  - info: myuplink.0 (592) State value to set for "myuplink.0.d1976750-145f-4fff-bd5c-dfbe6a1c62f5.hp24-r-20250814-00-09-82-21-7d-11.40011" has to be type "number" but received type "string"
                            2025-08-24 11:53:49.823  - info: influxdb.0 (442) Do not store value "{"Time":"2025-08-24T10:53:48","Haus":{"Tariflos":0.0000,"Energy":332,"Power_p1":23,"Power_p2":95,"Power_p3":214},"Heizung":{"Tariflos":10422.5612,"Energy":0,"Power_p1":0,"Power_p2":0,"Power_p3":0}}" for StromHaus because no number
                            • marcel-drzal
                              marcel-drzal @mcm1957 last edited by
                              @mcm1957
                              Danke für deine Hilfe.
                              Yahkara nutze ich nicht mehr. hatte ich eigendlich gelöscht
                              • mcm1957
                                mcm1957 @marcel-drzal last edited by mcm1957
                                @marcel-drzal
                                Zum Zeitpunkt der Fehlermeldung war yahka aber installiert.Bist du sicher, dass du den ADAPTER und nicht nur die INSTANZ gelöscht hast?
                                EDIT:
                                Lt iob diag in commentar https://forum.iobroker.net/topic/81995/js-controler-auf-7-07-geht-nicht-fehlermeldung-iob/12 hast du jetzt yahka 1.1.5 installiert - allerdings ohne aktive instanz.
                                Du hast also offensichtlich nur die Instanz gelöscht 🙂
                                @Thomas-Braun
                                Anregung für iob diag: Warnung bei Adaptern die installiert sind aber keine Instanz besitzen wär zu überlegen.
                                marcel-drzal Thomas Braun 3 Replies Last reply Reply Quote 0
                                • marcel-drzal
                                  @mcm1957
                                  • mcm1957
                                    @marcel-drzal
                                    Yep ist installiert. Wenn du ihn nicht mehr benutzt solltest du ihn deinstallieren.
                                      Thomas Braun Most Active @mcm1957 last edited by Thomas Braun
                                      @mcm1957 sagte in js Controler auf 7.07 geht nicht Fehlermeldung iOb:
                                      Schwierig zu checken. Können ja auch Adapter ohne Instanz sein oder die Nummerierung ist instanz.3 oder so.
                                      • mcm1957
                                        mcm1957 @Thomas Braun last edited by
                                        Also zu checken of die Instanz .0 oder .99 ist wär sicher trivial machbar.
                                        Hast du Beispiele für Adapter ohne Instanz? Da gibts sicher ein Kriterium dazu.
                                        • marcel-drzal
                                          marcel-drzal @mcm1957 last edited by marcel-drzal
                                          @mcm1957 Adapter habe ich gelöscht
                                          habe nun einen error:
                                          dpkg: error
                                           new base-files package pre-installation script subprocess returned error exit s              tatus 1
                                            @marcel-drzal
                                            dpkg ist aber das Paketmanagement auf OS-Ebene. Da ist also eine Etage tiefer schon was schief.
                                            sudo apt update
                                            sagt?
                                            1987
