    4. Backup Fehler nach Neuaufsetzung
      kg36304 last edited by
      ich habe mein System neu aufgesetzt, also Iobroker Master und zwei Slave´s jeweils auf Raspberry´s.
      Danch das Backup wieder eingespielt.
      Seit dem macht Backitup zicken mit InfluxDB (auf einer separaten Pi Büchse).
      Folgende Meldung kommt und ich kann nicht finde, wo der Fehler liegt.
      Danke.
      0:18:01.869
      INFO
      gui
      Backup gestartet ...
      10:18:23.655
      DEBUG
      iobroker
      host.raspberrypi 25677 objects saved
      10:18:27.230
      DEBUG
      iobroker
      host.raspberrypi 22307 states saved
      host.raspberrypi Validating backup ...
      10:18:27.272
      DEBUG
      iobroker
      host.raspberrypi "config.json" is valid
      10:18:27.279
      DEBUG
      iobroker
      host.raspberrypi "objects.jsonl" exists
      host.raspberrypi "states.jsonl" exists
      10:18:28.565
      DEBUG
      iobroker
      host.raspberrypi JSONL lines are valid
      10:18:29.673
      DEBUG
      iobroker
      host.raspberrypi The backup is valid!
      10:18:46.155
      DEBUG
      iobroker
      Backup created: /opt/iobroker/backups/iobroker_2025_09_06-10_18_02_backupiobroker.tar.gz
      10:18:46.163
      DEBUG
      iobroker
      This backup can only be restored with js-controller version 7.0 or higher
      10:18:47.215
      DEBUG
      iobroker
      done
      10:18:47.387
      DEBUG
      influxDB
      InfluxDB-Backup started ...
      10:18:47.396
      DEBUG
      influxDB
      Start InfluxDB Backup ...
      10:18:47.446
      DEBUG
      influxDB
      InfluxDB Backup tmp directory created
      10:18:47.450
      DEBUG
      influxDB
      Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker"
      10:18:47.457
      DEBUG
      influxDB
      InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker" successfully deleted
      [DEBUG] [influxDB] -
      10:18:47.506
      ERROR
      influxDB
      Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker"
      /bin/sh: 1: influxd: not found
      10:18:47.514
      DEBUG
      influxDB
      done
      10:18:48.652
      DEBUG
      grafana
      Start Grafana Backup ...
      10:18:48.657
      DEBUG
      grafana
      Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
      10:18:48.672
      DEBUG
      grafana
      Created dashboard directory
      10:18:48.751
      DEBUG
      grafana
      Created folder directory
      10:18:48.757
      DEBUG
      grafana
      Created dashboards_manually_restore directory
      10:18:48.760
      DEBUG
      grafana
      Created datasource directory
      10:18:48.765
      DEBUG
      grafana
      start Grafana request ...
      10:18:48.791
      DEBUG
      grafana
      Grafana is available ... Status: 200
      10:18:49.627
      DEBUG
      grafana
      found Dashboard: mein-dashboard
      10:18:49.745
      DEBUG
      grafana
      Saved dashboard-folder mapping
      10:18:50.031
      DEBUG
      grafana
      start Grafana backup compress ...
      10:18:55.060
      DEBUG
      grafana
      Backup created: /opt/iobroker/backups/grafana_2025_09_06-10_18_49_backupiobroker.tar.gz
      10:18:55.075
      DEBUG
      grafana
      Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
      10:18:55.130
      DEBUG
      grafana
      Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
      10:18:55.137
      DEBUG
      grafana
      done
      10:18:58.079
      DEBUG
      googledrive
      Google Drive: Copy iobroker_2025_09_06-10_18_02_backupiobroker.tar.gz...
      10:19:08.548
      ERROR
      googledrive
      Google Drive: File "/opt/iobroker/backups/influxDB_2025_09_06-10_18_47_backupiobroker.tar.gz" not found
      10:19:09.483
      DEBUG
      googledrive
      Google Drive: Copy grafana_2025_09_06-10_18_49_backupiobroker.tar.gz...
      10:19:11.043
      DEBUG
      googledrive
      done
      10:19:11.181
      ERROR
      clean
      Backup files not deleted from /opt/iobroker/backups because some errors.
      10:19:11.224
      DEBUG
      clean
      done
      10:19:11.468
      DEBUG
      historyHTML
      new history html values created
      10:19:11.765
      DEBUG
      historyHTML
      done
      10:19:11.987
      DEBUG
      historyJSON
      new history json values created
      10:19:12.037
      DEBUG
      historyJSON
      done
      10:19:13.293
      DEBUG
      telegram
      done
      10:19:14.519
      DEBUG
      notification
      Admin notification will be sent
      10:19:14.561
      DEBUG
      notification
      done
      10:19:14.663
      INFO
      gui
      Das Backup wurde erfolgreich erstellt!
        Thomas Braun Most Active @kg36304 last edited by
        @kg36304 sagte in Backup Fehler nach Neuaufsetzung:
        Da fehlt influx auf mindestens einer der Kisten. Es muss der passende influx-client installiert sein.
          Das heißt auf dem Master auf dem ich das Backup starte müsste quasi der client drauf?
          Hast Du den Befehl gerade greifbar?
          Vielen Dank
          Kai
            Thomas Braun Most Active @kg36304 last edited by Thomas Braun
            Nein, das Paket hängt davon ab, welche Version von influxdb da installiert ist.
            Bei mir wäre es wohl influxdb2-client oder sowas:
            echad@chet:~ $ apt policy influxdb
            influxdb              influxdb2-cli         influxdb3-core        influxdb-client
            influxdb2             influxdb2-client      influxdb3-enterprise  influxdb-python
            echad@chet:~ $
            Edit:
            echad@chet:~ $ dpkg -S /usr/bin/influxd
            influxdb: /usr/bin/influxd
            Kommt also aus dem Paket 'influxdb'. Ist das bei dir installiert? Check das mit
            sudo apt update
            apt policy influxdb
              kg36304 @Thomas Braun last edited by
              @thomas-braun said in Backup Fehler nach Neuaufsetzung:
              apt policy influxdb
              Also auf meinem Iobroker Master (Influxdb ist auf einem separaten Pi)
              kommt das:
              kai@raspberrypi:~ $ apt policy influxdb
              influxdb:
                Installed: (none)
                Candidate: 1.6.7~rc0-1+b13
                Version table:
                   1.6.7~rc0-1+b13 500
              und
              kai@raspberrypi:~ $ dpkg -S /usr/bin/influxd
              dpkg-query: no path found matching pattern /usr/bin/influxd
              Auf dem Influxdp pi kommt das:
              pi@raspberrypi:~ $ apt policy influxdb
              influxdb:
                Installed: 1.8.4-1
                Candidate: 1.8.4-1
                Version table:
               *** 1.8.4-1 500
                      500 https://repos.influxdata.com/debian buster/stable armhf Packages
                      100 /var/lib/dpkg/status
                   1.6.4-1+deb10u1 500
                      500 https://archive.raspbian.org/raspbian buster/main armhf Packages
              pi@raspberrypi:~ $
              Wie gesagt ich starte das Backup auf dem Iobroker Master und die die InfluxDB ist zusammen mit Grafana auf einem separaten Raspberry.
                @kg36304
                Da ist aber mit Sicherheit auch noch mehr krumm/falsch/veraltet.
                Buster ist läääääääääääängst abgekündigt.
                Stell die Kisten erstmal auf eine stabile Basis.
                Und zweimal der gleiche hostname in einem Netz ist auch Krampf.
                  die iobroker sind alle auf Bookworm umgestellt, daher kommen meine Probleme.
                  Der Pi wo Grafana und influxdb drauf laufen ist noch alt.
                  Hostname habe ich geändert, das war erstmal das einfachste.
                  InfluxDB und Grafana liefern auf jeden Fall Daten und Grafana wird auch gebackupt. Das ist schon mal was.
                  Leider geht das Backup von Influxdb nicht.
                  Muss mich jetzt wohl erst mal schlau machen wie ich das System auf Bookworm umhebe und alle daten wieder drauf bekomme.
                  Danke.
                    Gar nicht. Installier das neu. Das läuft ja auch als 32Bit-System. Will man nicht.
                      Also Neustes Betriebssystem drauf und InfluxDB und Grafana neu drauf installieren?
                      Und die gespeicherten Daten vom Backup wieder drauf?
                      Sehe ich das richtig?
                      Nochmal danke.
                        Mit wie vielen Systemen auf welchem Stand jonglierst du denn da eigentlich herum?
                        Für mal auf allen Kisten ein
                        iob diag
                        aus (sofern verfügbar).
                          ========== Start marking the full check here ===========
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                           Static hostname: raspberrypi
                                 Icon name: computer
                                    Kernel: Linux 6.12.34+rpt-rpi-v8
                              Architecture: arm64
                          OS is similar to:
                          Model		: Raspberry Pi 4 Model B Rev 1.1
                          Docker          : false
                          Virtualization  : none
                          Kernel          : aarch64
                          Userland        : 64 bit
                          Systemuptime and Load:
                           12:59:46 up 2 days, 23:10,  2 users,  load average: 1.53, 1.38, 1.38
                          CPU threads: 4
                          *** LIFE CYCLE STATUS ***
                          Operating System is the current Debian stable version codenamed 'bookworm'!
                          *** RASPBERRY THROTTLING ***
                          Current issues:
                          Previously detected issues:
                          *** TIME AND TIMEZONES ***
                                         Local time: Sat 2025-09-06 12:59:47 CEST
                                     Universal time: Sat 2025-09-06 10:59:47 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          *** Users and Groups ***
                          User that called 'iob diag':
                          kai
                          HOME=/home/kai
                          GROUPS=kai adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                          iobroker
                          HOME=/home/iobroker
                          *** DISPLAY-SERVER SETUP ***
                          Display-Server: 	false
                          Unit display-manager.service could not be found.
                          Display-Manager:
                          Desktop:
                          Session: 		tty
                          *** MEMORY ***
                          Mem:            4.0G        3.2G        264M        2.3M        583M        747M
                          Swap:           1.1G        1.0G         32M
                          Total:          5.1G        4.3G        296M
                          Active iob-Instances: 	55
                                   3795 M total memory
                                   3083 M used memory
                                   2082 M active memory
                                   1257 M inactive memory
                                    251 M free memory
                                     39 M buffer memory
                                    516 M swap cache
                                   1023 M total swap
                                    993 M used swap
                                     30 M free swap
                          top - 12:59:47 up 2 days, 23:10,  2 users,  load average: 1.53, 1.38, 1.38
                          Tasks: 225 total,   1 running, 224 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  9.1 us,  9.1 sy,  0.0 ni, 72.7 id,  9.1 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   3795.9 total,    251.7 free,   3083.1 used,    556.8 buff/cache
                          MiB Swap:   1024.0 total,     30.9 free,    993.1 used.    712.8 avail Mem
                          *** FAILED SERVICES ***
                          0 loaded units listed.
                          *** DMESG CRITICAL ERRORS ***
                          No critical errors detected
                          *** FILESYSTEM ***
                          udev           devtmpfs  1.6G     0  1.6G   0% /dev
                          tmpfs          tmpfs     380M  5.9M  374M   2% /run
                          /dev/sda2      ext4      117G  6.1G  106G   6% /
                          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                          /dev/sda1      vfat      510M   58M  453M  12% /boot/firmware
                          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                          [Wed Sep  3 13:49:20 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:50:A2:AC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=1d815a5d-02 rootfstype=ext4 fsck.repair=yes rootwait
                          [Wed Sep  3 13:49:22 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                          [Wed Sep  3 13:49:23 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
                          Show mounted filesystems:
                          TARGET           SOURCE    FSTYPE OPTIONS
                          /                /dev/sda2 ext4   rw,noatime
                          `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          1.4G	/var/
                          210M	/var/cache
                          204M	/var/cache/apt
                          168M	/var/lib
                          135M	/var/lib/apt/lists
                          Archived and active journals take up 4.7M in the file system.
                          /opt/iobroker/backups:
                          218M	/opt/iobroker/backups/
                          /opt/iobroker/iobroker-data:
                          739M	/opt/iobroker/iobroker-data/
                          593M	/opt/iobroker/iobroker-data/files
                          112M	/opt/iobroker/iobroker-data/backup-objects
                          74M	/opt/iobroker/iobroker-data/files/vis.0
                          74M	/opt/iobroker/iobroker-data/files/vis-2.0
                          38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
                          35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                          27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                          26M	/opt/iobroker/iobroker-data/objects.jsonl
                          24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                          USB-Devices by-id:
                          No Devices found 'by-id'
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          *** NodeJS-Installation ***
                          /usr/bin/nodejs 	v22.19.0
                          /usr/bin/node 		v22.19.0
                          /usr/bin/npm 		10.9.3
                          /usr/bin/npx 		10.9.3
                          /usr/bin/corepack 	0.34.0
                          nodejs:
                            Installed: 22.19.0-1nodesource1
                            Candidate: 22.19.0-1nodesource1
                            Version table:
                           *** 22.19.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                               22.18.0-1nodesource1 1001
                               22.17.1-1nodesource1 1001
                               22.17.0-1nodesource1 1001
                               22.16.0-1nodesource1 1001
                               22.15.1-1nodesource1 1001
                               22.15.0-1nodesource1 1001
                               22.14.0-1nodesource1 1001
                               22.13.1-1nodesource1 1001
                               22.13.0-1nodesource1 1001
                               22.12.0-1nodesource1 1001
                               22.11.0-1nodesource1 1001
                               22.10.0-1nodesource1 1001
                               22.9.0-1nodesource1 1001
                               22.8.0-1nodesource1 1001
                               22.7.0-1nodesource1 1001
                               22.6.0-1nodesource1 1001
                               22.5.1-1nodesource1 1001
                               22.5.0-1nodesource1 1001
                               22.4.1-1nodesource1 1001
                               22.4.0-1nodesource1 1001
                               22.3.0-1nodesource1 1001
                               22.2.0-1nodesource1 1001
                               22.1.0-1nodesource1 1001
                               22.0.0-1nodesource1 1001
                               18.20.4+dfsg-1~deb12u1 500
                               18.19.0+dfsg-6~deb12u2 500
                          No problems detected
                          Errors in npm tree: 0
                          Checking for nodejs vulnerability:
                          *** ioBroker-Installation ***
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          Slave               Slave (version: 7.0.7, hostname: Slave         , alive, uptime: 265791)
                          iobrokergarten      iobrokergarten (version: 7.0.7, hostname: iobrokergarten, alive, uptime: 332732)
                          raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 72640)
                          Core adapters versions
                          js-controller: 	7.0.7
                          admin: 		7.6.17
                          javascript: 	8.9.2
                          nodejs modules from github: 	2
                          | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
                          +-- iobroker.tuya@3.17.0 (git+ssh://git@github.com/Apollon77/ioBroker.tuya.git#640df7360a877f37764a31d628e4d6de3ed1f6e3)
                          Adapter State
                          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                          + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                            system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                          + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
                          + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                            system.adapter.devices.0                : devices               : raspberrypi                              - disabled
                          + system.adapter.ds18b20.0                : ds18b20               : Slave                                    -  enabled
                          + system.adapter.ds18b20.1                : ds18b20               : iobrokergarten                           -  enabled
                            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
                            system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                          + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                          + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
                          + system.adapter.govee-local.0            : govee-local           : raspberrypi                              -  enabled
                          + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
                          + system.adapter.hm-rega.1                : hm-rega               : raspberrypi                              -  enabled
                          + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                          + system.adapter.hm-rpc.3                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                          + system.adapter.hm-rpc.4                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi                              - disabled
                            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                          + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                          + system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
                          + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                            system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                          + system.adapter.mqtt.0                   : mqtt                  : Slave                                    -  enabled, port: 1886, bind: 0.0.0.0
                          + system.adapter.octoprint.0              : octoprint             : Slave                                    -  enabled
                          + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
                          + system.adapter.openligadb.1             : openligadb            : raspberrypi                              -  enabled
                          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                          + system.adapter.rpi2.1                   : rpi2                  : Slave                                    -  enabled
                          + system.adapter.rpi2.2                   : rpi2                  : iobrokergarten                           -  enabled
                          + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
                          + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                          + system.adapter.smartgarden.0            : smartgarden           : raspberrypi                              -  enabled
                          + system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                          + system.adapter.sonoff.0                 : sonoff                : Slave                                    -  enabled, port: 1884, bind: 0.0.0.0
                          + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
                          + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
                          + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                          + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                          + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                          + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                            system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
                            system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                          + system.adapter.worx.0                   : worx                  : Slave                                    -  enabled
                          + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Upgrade policy: none
                          Installed ioBroker-Adapters
                          Used repository: stable
                          Adapter    "admin"        : 7.6.17   , installed 7.6.17
                          Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                          Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                          Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                          Adapter    "cloud"        : 5.0.1    , installed 5.0.1
                          Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                          Adapter    "deconz"       : 1.6.4    , installed 1.6.4
                          Adapter    "denon"        : 1.15.12  , installed 1.15.12
                          Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.7
                          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                          Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                          Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                          Adapter    "govee-local"  : 0.2.8    , installed 0.2.8
                          Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                          Adapter    "ical"         : 1.16.2   , installed 1.16.2
                          Adapter    "iot"          : 3.3.0    , installed 3.3.0
                          Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                          Controller "js-controller": 7.0.7    , installed 7.0.7
                          Adapter    "kodi"         : 3.1.0    , installed 3.1.0
                          Adapter    "linux-control": 1.1.5    , installed 1.1.5
                          Adapter    "meross"       : 1.17.0   , installed 1.17.0
                          Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                          Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                          Adapter    "openligadb"   : 1.9.0    , installed 1.9.0
                          Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                          Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                          Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
                          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                          Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
                          Adapter    "tado"         : 0.7.10   , installed 0.7.10
                          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                          Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                          Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                          Adapter    "tuya"         : 3.16.0   , installed 3.17.0
                          Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
                          Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                          Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                          Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                          Adapter    "web"          : 7.0.8    , installed 7.0.8
                          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                          Adapter    "wled"         : 0.7.2    , installed 0.7.2
                          Adapter    "ws"           : 2.6.2    , installed 3.0.19
                          Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                          Objects and States
                          Objects: 	25864
                          States: 	22325
                          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                          Reading package lists...
                          Pending Updates: 0
                          *** Listening Ports ***
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       5126439    254861/iobroker.js-
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       5125608    254861/iobroker.js-
                          tcp        0      0 0.0.0.0:37009           0.0.0.0:*               LISTEN      1001       5128832    255829/io.yahka.0
                          tcp        0      0 192.168.62.93:8701      0.0.0.0:*               LISTEN      1001       5127136    255452/io.hm-rpc.4
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          769        619/sshd: /usr/sbin
                          tcp        0      0 192.168.62.93:2010      0.0.0.0:*               LISTEN      1001       5129564    255441/io.hm-rpc.3
                          tcp        0      0 192.168.62.93:12001     0.0.0.0:*               LISTEN      1001       5127692    255400/io.hm-rpc.2
                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       5130924    255685/io.shelly.1
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          771        619/sshd: /usr/sbin
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5123984    254984/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6609596    329621/io.web.0
                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       5130725    256040/io.socketio.
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       5131273    256008/io.simple-ap
                          tcp6       0      0 :::8089                 :::*                    LISTEN      1001       5130022    256101/io.terminal.
                          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       5128896    255703/io.sonos.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       5129240    255214/io.deconz.0
                          udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       5127522    255360/io.govee-loc
                          udp        0      0 0.0.0.0:49092           0.0.0.0:*                           104        5483       460/avahi-daemon: r
                          udp        0      0 0.0.0.0:45197           0.0.0.0:*                           1001       5126777    255181/io.broadlink
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5130160    255788/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5130161    255788/io.tuya.0
                          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       5126770    255181/io.broadlink
                          udp        0      0 0.0.0.0:58518           0.0.0.0:*                           1001       7156864    255181/io.broadlink
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       5131303    256180/io.wled.0
                          udp        0      0 192.168.62.93:5353      0.0.0.0:*                           1001       5130579    255732/io.tr-064.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5481       460/avahi-daemon: r
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       5128982    255610/io.shelly.0
                          udp6       0      0 :::1900                 :::*                                1001       5129243    255214/io.deconz.0
                          udp6       0      0 :::1900                 :::*                                1001       5129242    255214/io.deconz.0
                          udp6       0      0 :::1900                 :::*                                1001       5129241    255214/io.deconz.0
                          udp6       0      0 fe80::ec38:3d4e:49e:546 :::*                                0          5618       549/NetworkManager
                          udp6       0      0 :::5353                 :::*                                104        5482       460/avahi-daemon: r
                          udp6       0      0 :::44360                :::*                                104        5484       460/avahi-daemon: r
                          2025-09-06 13:01:31.598  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6 with null  {"type":"channel","common":{"common":{"name":"Hour 6","role":"weather"}}}
                          2025-09-06 13:01:31.601  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.hour_value with 17:00
                          2025-09-06 13:01:31.610  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.temp_value with 18 °C
                          2025-09-06 13:01:31.619  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_desc2 with Bewölkt mit stürmischen Regenschauern
                          2025-09-06 13:01:31.636  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_value2 with 12
                          2025-09-06 13:01:31.655  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_desc with Bewölkt mit mäßigem Regen
                          2025-09-06 13:01:31.673  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.symbol_value with 9
                          2025-09-06 13:01:31.686  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.iconURL with /adapter/daswetter/icons/tiempo-weather/galeria1/9.png
                          2025-09-06 13:01:31.696  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_symbolB with 26
                          2025-09-06 13:01:31.705  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_symbol with 2
                          2025-09-06 13:01:31.714  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_dir with NE
                          2025-09-06 13:01:31.725  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.wind_value with 4 km/h
                          2025-09-06 13:01:31.737  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/26.png
                          2025-09-06 13:01:31.746  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.windgusts_value with 14 km/h
                          2025-09-06 13:01:31.754  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.rain_value with 3.3 mm
                          2025-09-06 13:01:31.763  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.humidity_value with 87
                          2025-09-06 13:01:31.771  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.pressure_value with 1014 mb
                          2025-09-06 13:01:31.780  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.clouds_value with 66%
                          2025-09-06 13:01:31.787  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.snowline_value with 3400 m
                          2025-09-06 13:01:31.796  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.windchill_value with 18 °C
                          2025-09-06 13:01:31.804  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_6.uv_index_value with 1
                          2025-09-06 13:01:31.813  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7 with null  {"type":"channel","common":{"common":{"name":"Hour 7","role":"weather"}}}
                          2025-09-06 13:01:31.817  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7.hour_value with 20:00
                          2025-09-06 13:01:31.825  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7.temp_value with 16 °C
                          2025-09-06 13:01:31.835  - debug: daswetter.0 (358180) insert NextDaysDetailed.Location_1.Day_4.Hour_7.symbol_desc2 with Bewölkt
                          iob diag has finished.
                          kai@raspberrypi:~ $
                            also ich habe aktuell umgestellt. Mein Master läuft jetzt auf Proxmox und das deutlich schneller als auf dem Raspberry.
                            Leider habe ich immernoch das Problem, dass die Backups alle gezogen werden ausser von Influxdb (ist noch die 1er Version. Laufen tut alles nur halt nicht das Backup und bevor ich umziehe bzw. neu aufsetze möchte ich die Daten halt speichern.
                            Muss ich auf dem Master auch influxdb installieren obwohl es schon auf dem anderen Raspberry läuft?
                            Auf dem Master kommt das
                            kai@iobrokerMaster:~$ apt policy influxdb
                            influxdb:
                              Installed: (none)
                              Version table:
                                 1.6.7~rc0-1+b13 500
                                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                            und auf dem Infludb Pi das
                            pi@InfluxGrafana:~ $ apt policy influxdb
                            influxdb:
                              Installed: 1.8.4-1
                              Candidate: 1.8.4-1
                              Version table:
                             *** 1.8.4-1 500
                                 1.6.4-1+deb10u1 500
                            Ich weiß das der Buster überfällig ist aber ohne Backup kann ich nicht neu aufsetzen. Würde dann gerne auf Proxmox eine separate Umgebung für Influxdb und Grafana erstellen. In dem Zusammenhang die Frage, ob ich gleich auf die Influxdb2 gehe, geht das?
                            Vielen Dank
                            liebe Grüße
                            Kai
                              @kg36304
                              Typischer Fall von: 'So lange updates/upgrades herauszögern weil es zu 'kompliziert' ist um dann festzustellen, dass es dadurch erst recht kompliziert wurde...'
                              Der Buster ist jetzt schon wie lange EndOfLife?
                              Du musst für Backups auf beiden Kisten influxdb installiert haben. Auf dem client reichen die entsprechenden client-Pakete aus. Das ganze nach Möglichkeit in gleicher Version, mindestens aber gleiche Major-Version.
                              1.1k
                              81.1k
                              401
