    4. Update Error MQTT 6.1.2 - 6.1.4
      Feinfinger last edited by Feinfinger
      Bekomme folgenden Error wenn ich versuche, den MQTT Adapter zu aktualisieren.
      iobroker npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:8332) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-17T04_38_16_298Z-debug-0.log
      • Adaptername: mqtt
      • Link zu Adapterrepository: www.github.com...
      • Adapterversion: 6.1.4
      • js-controller Version: 7.0.7
      • Admin Version: 7.7.2
      • Hardwaresystem: LXC mit Ubuntu 24.04.3 LTS
      • Arbeitsspeicher: 8 GB
      • Festplattenart: SSD
      • Betriebssystem: Ubuntu 24.04.3 LTS
      • Nodejs-Version: 22.19.0
      • NPM-Version: 10.9.3
      • Installationsart: Update aus iobroker
      • Image, Docker genutzt: nein
      • Ort, Name der Imagedatei: ...
      Linux User bitte hier den Output von iob diag einfügen.
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Ubuntu 24.04.3 LTS
       Static hostname: ioBroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.14.11-1-pve
          Architecture: x86-64
      OS is similar to: debian
      model name      : 13th Gen Intel(R) Core(TM) i5-1340P
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       06:46:50 up 13:54,  0 user,  load average: 0.58, 0.94, 0.75
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Ubuntu LTS release codenamed 'noble'!
      *** TIME AND TIMEZONES ***
                     Local time: Wed 2025-09-17 06:46:50 CEST
                 Universal time: Wed 2025-09-17 04:46:50 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      smarthome
      HOME=/home/smarthome
      GROUPS=smarthome sudo iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
      Mem:            8.6G        2.6G        4.5G        131K        1.5G        6.0G
      Swap:             0B          0B          0B
      Total:          8.6G        2.6G        4.5G
      Active iob-Instances:   29
               8192 M total memory
               2482 M used memory
               2602 M active memory
               1128 M inactive memory
               4280 M free memory
                  0 M buffer memory
               1429 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      top - 06:46:50 up 13:54,  0 user,  load average: 0.58, 0.94, 0.75
      Tasks:  57 total,   1 running,  56 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  7.3 us,  4.9 sy,  0.0 ni, 87.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8192.0 total,   4279.6 free,   2483.1 used,   1429.4 buff/cache
      MiB Swap:      0.0 total,      0.0 free,      0.0 used.   5708.9 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--114--disk--0 ext4       16G   12G  3.4G  78% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      efivarfs                         efivarfs  192K  113K   75K  60% /sys/firmware/efi/efivars
      tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
      tmpfs                            tmpfs     6.2G  124K  6.2G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--114--disk--0 ext4   rw,relatime,stripe=16
      /var:
      3.1G    /var/
      1.5G    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
      1.5G    /var/log
      1.3G    /var/cache/apt
      Archived and active journals take up 82.9M in the file system.
      /opt/iobroker/backups:
      353M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      715M    /opt/iobroker/iobroker-data/
      386M    /opt/iobroker/iobroker-data/files
      236M    /opt/iobroker/iobroker-data/backup-objects
      48M     /opt/iobroker/iobroker-data/files/iot.admin
      47M     /opt/iobroker/iobroker-data/files/vis-2
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      34M     /opt/iobroker/iobroker-data/objects.jsonl
      30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      22M     /opt/iobroker/iobroker-data/objects.json.migrated
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.19.0
      /usr/bin/node           v22.19.0
      /usr/bin/npm            10.9.3
      /usr/bin/npx            10.9.3
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.19.0-1nodesource1
        Candidate: 22.19.0-1nodesource1
        Version table:
       *** 22.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           18.19.1+dfsg-6ubuntu5 500
              500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 50073)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     8.9.2
      nodejs modules from github:     2
      |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
      | +-- syno@3.0.0 invalid: "git+https://git@github.com/MeisterTR/syno.git" from node_modules/iobroker.synology
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      + system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
      + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
      + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
      + system.adapter.govee-local.0            : govee-local           : ioBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
        system.adapter.homekit-controller.0     : homekit-controller    : ioBroker                                 - disabled
      + system.adapter.husqvarna-automower.0    : husqvarna-automower   : ioBroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
      + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
      + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
      + system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
      + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1883, bind: 192.168.178.61
      + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
      + system.adapter.tado.0                   : tado                  : ioBroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
      + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "ems-esp"      : 6.0.0    , installed 6.0.0
      Adapter    "fhem"         : 3.0.0    , installed 3.0.0
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "govee-local"  : 0.2.8    , installed 0.2.8
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homekit-controller": 0.5.11, installed 0.5.11
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "notification-manager": 1.3.0, installed 1.3.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "radar2"       : 2.4.0    , installed 2.4.0
      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tado"         : 0.7.10   , installed 0.7.10
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "web"          : 7.0.8    , installed 7.0.9
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
      Objects and States
      Objects:        14247
      States:         12251
      Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
      Hit:2 https://deb.nodesource.com/node_22.x nodistro InRelease
      Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
      Hit:4 http://archive.ubuntu.com/ubuntu noble-updates InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 192.168.178.61:42010    0.0.0.0:*               LISTEN      1000       117632817  712/io.hm-rpc.0
      tcp        0      0 192.168.178.61:42001    0.0.0.0:*               LISTEN      1000       117633892  789/io.hm-rpc.1
      tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        117629714  231/systemd-resolve
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       117631422  242/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       117632168  242/iobroker.js-con
      tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      102        117629716  231/systemd-resolve
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          117631279  1/init
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          117622140  1/init
      tcp        0      0 0.0.0.0:33533           0.0.0.0:*               LISTEN      1000       117633527  682/io.yahka.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       117633574  697/io.shelly.0
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          117632045  439/master
      tcp        0      0 127.0.0.1:40541         0.0.0.0:*               LISTEN      1000       117631611  682/io.yahka.0
      tcp        0      0 192.168.178.61:8082     0.0.0.0:*               LISTEN      1000       117640790  913/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          117631280  1/init
      tcp6       0      0 :::111                  :::*                    LISTEN      0          117622142  1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          117632046  439/master
      tcp6       0      0 :::3000                 :::*                    LISTEN      1000       117633424  616/io.fullybrowser
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       117633184  475/io.admin.0
      udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1000       117631763  836/io.govee-local.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        117631367  237/avahi-daemon: r
      udp        0      0 0.0.0.0:41598           0.0.0.0:*                           108        117631369  237/avahi-daemon: r
      udp        0      0 127.0.0.54:53           0.0.0.0:*                           102        117629715  231/systemd-resolve
      udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        117629713  231/systemd-resolve
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       117632677  646/io.radar2.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          117622141  1/init
      udp6       0      0 :::5353                 :::*                                108        117631368  237/avahi-daemon: r
      udp6       0      0 :::60726                :::*                                108        117631370  237/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          117622143  1/init
      2025-09-17 06:40:23.446  - error: host.ioBroker iobroker npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:8332) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-17T04_38_16_298Z-debug-0.log
      2025-09-17 06:40:23.449  - error: host.ioBroker iobroker host.ioBroker Cannot install iobroker.mqtt@6.1.4: 7
      1.3k
