    4. Adapter lassen sich nicht updaten
      Feinfinger last edited by
      Ich habe das Problem das sich mehrer Adapter nicht mehr updaten lassen.
      Hie rmal exemplarisch der Goove Adapter, die Fehlermeldungen bei den anderen Adaptern sehen ähnlich aus. Sieht mir nach npm aus.
      Vielleicht hat ja jemand ne Idee, was man da machen kann.
      $ iobroker upgrade govee-local@0.2.9
      Update govee-local from @0.2.8 to @0.2.9
      NPM version: 10.9.3
      Installing iobroker.govee-local@0.2.9... (System call)
      npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:14998) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-18T05_32_13_126Z-debug-0.log
      host.ioBroker Cannot install iobroker.govee-local@0.2.9: 7
      ERROR: Process exited with code 25
      • haus-automatisierung
        haus-automatisierung Developer Most Active @Feinfinger last edited by
        @feinfinger sagte in Adapter lassen sich nicht updaten:
        Einmal den ioBroker Fixer laufen lassen und nochmal das Update anstoßen
          Feinfinger @haus-automatisierung last edited by
          Danke für die Antwort, leider bleibt der Fehler.
            Thomas Braun Most Active @Feinfinger last edited by
            @feinfinger
            Dann schau dir das ganze Konstrukt an. Per
            iob diag
            am besten.
              Feinfinger @Thomas Braun last edited by
              Guten Morgen,
              Hier die Ausgabe von iob diag.
              ========== Start marking the full check here ===========
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
              Operating System: Ubuntu 24.04.3 LTS
               Static hostname: ioBroker
                     Icon name: computer-container
                       Chassis: container ☐
                Virtualization: lxc
                        Kernel: Linux 6.14.11-1-pve
                  Architecture: x86-64
              OS is similar to: debian
              model name      : 13th Gen Intel(R) Core(TM) i5-1340P
              Docker          : false
              Virtualization  : lxc
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               06:45:07 up 23:05,  0 user,  load average: 0.46, 1.46, 1.10
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Operating System is the current Ubuntu LTS release codenamed 'noble'!
              *** TIME AND TIMEZONES ***
                             Local time: Fri 2025-09-19 06:45:07 CEST
                         Universal time: Fri 2025-09-19 04:45:07 UTC
                               RTC time: n/a
                            NTP service: inactive
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              smarthome
              HOME=/home/smarthome
              GROUPS=smarthome sudo iobroker
              js-controller is not running
              *** DISPLAY-SERVER SETUP ***
              Display-Server:         false
              Unit display-manager.service could not be found.
              Display-Manager:
              Desktop:
              Session:
              *** MEMORY ***
              Mem:            8.6G         47M        6.1G        139K        2.4G        8.5G
              Swap:             0B          0B          0B
              Total:          8.6G         47M        6.1G
              Active iob-Instances:   1
                       8192 M total memory
                         45 M used memory
                        156 M active memory
                       1938 M inactive memory
                       5833 M free memory
                          0 M buffer memory
                       2313 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              top - 06:45:08 up 23:05,  0 user,  load average: 0.46, 1.46, 1.10
              Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   8192.0 total,   5832.3 free,     46.7 used,   2313.1 buff/cache
              MiB Swap:      0.0 total,      0.0 free,      0.0 used.   8145.3 avail Mem
              *** FAILED SERVICES ***
                UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
              * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
              * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
              * iobroker.service        loaded failed failed ioBroker Server
              Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                      ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                      SUB    -> The low-level unit activation state, values depend on unit type.
              3 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              dmesg: read kernel buffer failed: Operation not permitted
              No critical errors detected
              *** FILESYSTEM ***
              Filesystem                       Type      Size  Used Avail Use% Mounted on
              /dev/mapper/pve-vm--114--disk--0 ext4       16G   12G  3.2G  79% /
              none                             tmpfs     492K  4.0K  488K   1% /dev
              efivarfs                         efivarfs  192K  113K   75K  60% /sys/firmware/efi/efivars
              tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
              tmpfs                            tmpfs     6.2G  132K  6.2G   1% /run
              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
              Show mounted filesystems:
              TARGET SOURCE                           FSTYPE OPTIONS
              /      /dev/mapper/pve-vm--114--disk--0 ext4   rw,relatime,stripe=16
              /var:
              3.2G    /var/
              1.6G    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
              1.6G    /var/log
              1.3G    /var/cache/apt
              Archived and active journals take up 90.2M in the file system.
              /opt/iobroker/backups:
              353M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              699M    /opt/iobroker/iobroker-data/
              386M    /opt/iobroker/iobroker-data/files
              236M    /opt/iobroker/iobroker-data/backup-objects
              48M     /opt/iobroker/iobroker-data/files/iot.admin
              47M     /opt/iobroker/iobroker-data/files/vis-2
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
              28M     /opt/iobroker/iobroker-data/objects.jsonl
              24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
              22M     /opt/iobroker/iobroker-data/objects.json.migrated
              USB-Devices by-id:
              No Devices found 'by-id'
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v22.19.0
              /usr/bin/node           v22.19.0
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              /usr/bin/corepack       0.34.0
              nodejs:
                Installed: 22.19.0-1nodesource1
                Candidate: 22.19.0-1nodesource1
                Version table:
               *** 22.19.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   22.18.0-1nodesource1 1001
                   22.17.1-1nodesource1 1001
                   22.17.0-1nodesource1 1001
                   22.16.0-1nodesource1 1001
                   22.15.1-1nodesource1 1001
                   22.15.0-1nodesource1 1001
                   22.14.0-1nodesource1 1001
                   22.13.1-1nodesource1 1001
                   22.13.0-1nodesource1 1001
                   22.12.0-1nodesource1 1001
                   22.11.0-1nodesource1 1001
                   22.10.0-1nodesource1 1001
                   22.9.0-1nodesource1 1001
                   22.8.0-1nodesource1 1001
                   22.7.0-1nodesource1 1001
                   22.6.0-1nodesource1 1001
                   22.5.1-1nodesource1 1001
                   22.5.0-1nodesource1 1001
                   22.4.1-1nodesource1 1001
                   22.4.0-1nodesource1 1001
                   22.3.0-1nodesource1 1001
                   22.2.0-1nodesource1 1001
                   22.1.0-1nodesource1 1001
                   22.0.0-1nodesource1 1001
                   18.19.1+dfsg-6ubuntu5 500
                      500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
              No problems detected
              Errors in npm tree: 0
              Checking for nodejs vulnerability:
              *** ioBroker-Installation ***
              ioBroker Status
              iobroker is not running on this host.
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 481)
              Core adapters versions
              js-controller:  7.0.7
              admin:          7.7.2
              javascript:     8.9.2
              nodejs modules from github:     2
              |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
              | +-- syno@3.0.0 invalid: "git+https://git@github.com/MeisterTR/syno.git" from node_modules/iobroker.synology
              Adapter State
                system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
                system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
                system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
                system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
                system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
                system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
                system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
                system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
                system.adapter.govee-local.0            : govee-local           : ioBroker                                 -  enabled
                system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
                system.adapter.homekit-controller.0     : homekit-controller    : ioBroker                                 - disabled
                system.adapter.husqvarna-automower.0    : husqvarna-automower   : ioBroker                                 -  enabled
                system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
                system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
                system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
                system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
                system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
                system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
                system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
                system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
                system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
                system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
                system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1883, bind: 192.168.178.61
                system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
                system.adapter.tado.0                   : tado                  : ioBroker                                 -  enabled
                system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
                system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
                system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
                system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
                system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
                system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
                system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Adapters
              Used repository: stable
              Adapter    "admin"        : 7.7.2    , installed 7.7.2
              Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
              Adapter    "alias-manager": 2.0.0    , installed 2.0.0
              Adapter    "backitup"     : 3.3.5    , installed 3.3.5
              Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
              Adapter    "discovery"    : 5.0.0    , installed 5.0.0
              Adapter    "ems-esp"      : 6.0.0    , installed 6.0.0
              Adapter    "fhem"         : 3.0.0    , installed 3.0.0
              Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
              Adapter    "govee-local"  : 0.2.9    , installed 0.2.8  [Updatable]
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "homekit-controller": 0.5.11, installed 0.5.11
              Adapter    "ical"         : 1.16.2   , installed 1.16.2
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.9.2    , installed 8.9.2
              Controller "js-controller": 7.0.7    , installed 7.0.7
              Adapter    "linux-control": 1.1.5    , installed 1.1.5
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
              Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
              Adapter    "notification-manager": 1.3.0, installed 1.3.0
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "radar2"       : 2.4.0    , installed 2.4.0
              Adapter    "shelly"       : 10.1.0   , installed 10.1.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
              Adapter    "synology"     : 3.1.0    , installed 3.1.0
              Adapter    "tado"         : 0.7.10   , installed 0.7.10
              Adapter    "telegram"     : 4.1.0    , installed 4.1.0
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
              Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
              Adapter    "web"          : 7.0.8    , installed 7.0.9
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "yahka"        : 1.1.5    , installed 1.1.5
              Objects and States
              Objects:        14243
              States:         11994
              Hit:1 https://deb.nodesource.com/node_22.x nodistro InRelease
              Hit:2 http://security.ubuntu.com/ubuntu noble-security InRelease
              Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
              Hit:4 http://archive.ubuntu.com/ubuntu noble-updates InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      102        133591972  231/systemd-resolve
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          133592326  441/master
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        133591970  231/systemd-resolve
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          133581801  1/init
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          133587946  1/init
              tcp6       0      0 :::111                  :::*                    LISTEN      0          133581803  1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          133587947  1/init
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          133592327  441/master
              udp        0      0 127.0.0.54:53           0.0.0.0:*                           102        133591971  231/systemd-resolve
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        133591969  231/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          133581802  1/init
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        133594148  237/avahi-daemon: r
              udp        0      0 0.0.0.0:46786           0.0.0.0:*                           108        133594150  237/avahi-daemon: r
              udp6       0      0 :::47825                :::*                                108        133594151  237/avahi-daemon: r
              udp6       0      0 :::111                  :::*                                0          133581804  1/init
              udp6       0      0 :::5353                 :::*                                108        133594149  237/avahi-daemon: r
              2025-09-19 06:44:03.909  - info: discovery.0 (18819) Terminated (NO_ERROR): Without reason
              2025-09-19 06:44:03.910  - info: ems-esp.0 (18695) terminating
              2025-09-19 06:44:03.909  - info: notification-manager.0 (18757) Terminated (NO_ERROR): Without reason
              2025-09-19 06:44:03.910  - info: trashschedule.0 (18896) Terminated (NO_ERROR): Without reason
              2025-09-19 06:44:03.908  - info: govee-local.0 (18789) terminating
              2025-09-19 06:44:03.909  - info: govee-local.0 (18789) Terminated (NO_ERROR): Without reason
              2025-09-19 06:44:03.911  - info: ems-esp.0 (18695) Terminated (NO_ERROR): Without reason
              2025-09-19 06:44:03.909  - info: vis-2.0 (18881) Terminated (NO_ERROR): Without reason
              2025-09-19 06:44:04.325  - info: backitup.0 (18539) terminating
              2025-09-19 06:44:04.326  - info: pushover.0 (18506) terminating
              2025-09-19 06:44:04.327  - info: pushover.0 (18506) Terminated (NO_ERROR): Without reason
              2025-09-19 06:44:04.327  - info: synology.0 (18712) terminating
              2025-09-19 06:44:04.328  - info: modbus.0 (18680) terminating
              2025-09-19 06:44:04.328  - info: yahka.0 (18635) terminating
              2025-09-19 06:44:04.328  - info: modbus.1 (18727) terminating
              2025-09-19 06:44:04.329  - info: govee-local.0 (18789) terminating
              2025-09-19 06:44:04.329  - info: notification-manager.0 (18757) terminating
              2025-09-19 06:44:04.330  - info: vis-2.0 (18881) terminating
              2025-09-19 06:44:04.330  - info: discovery.0 (18819) terminating
              2025-09-19 06:44:04.331  - info: trashschedule.0 (18896) terminating
              2025-09-19 06:44:04.332  - info: radar2.0 (18599) terminating
              2025-09-19 06:44:04.338  - info: iot.0 (18834) terminating
              2025-09-19 06:44:04.338  - info: tado.0 (18944) terminating
              2025-09-19 06:44:04.935  - warn: host.ioBroker instance system.adapter.pushover.0 terminated due to SIGKILL
              2025-09-19 06:44:04.953  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGKILL
              iob diag has finished.
              Wenn ich dann versuche, einen Adapter upzudaten, kommt dieses raus bei iob diag.
              Script v.2025-08-09
              *** BASE SYSTEM ***
                Virtualization: lxc
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
               06:51:59 up 23:12,  0 user,  load average: 2.50, 1.44, 1.13
              CPU threads: 4
                             Local time: Fri 2025-09-19 06:51:59 CEST
                         Universal time: Fri 2025-09-19 04:51:59 UTC
                               RTC time: n/a
                        RTC in local TZ: no
              smarthome
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev bluetooth
              Display-Manager:
              Desktop:
              Session:
              *** MEMORY ***
              Mem:            8.6G        2.3G        4.3G        143K        2.1G        6.3G
              Swap:             0B          0B          0B
              Total:          8.6G        2.3G        4.3G
              Active iob-Instances:   29
                       8192 M total memory
                       2146 M used memory
                       2214 M active memory
                       1557 M inactive memory
                       4090 M free memory
                          0 M buffer memory
                       1955 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              top - 06:51:59 up 23:12,  0 user,  load average: 2.50, 1.44, 1.13
              Tasks:  59 total,   1 running,  58 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 97.5 id,  0.0 wa,  0.0 hi,  2.5 si,  0.0 st
              MiB Mem :   8192.0 total,   4089.5 free,   2147.1 used,   1955.5 buff/cache
              MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6044.9 avail Mem
              2 loaded units listed.
              *** FILESYSTEM ***
              tmpfs                            tmpfs     6.2G  136K  6.2G   1% /run
              /var:
              3.2G    /var/
              1.6G    /var/log
              1.3G    /var/cache/apt
              703M    /opt/iobroker/iobroker-data/
              31M     /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 286)
              admin:          7.7.2
              javascript:     8.9.2
              Adapter State
              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
              + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
              + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
              + system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
              + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
              + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
              + system.adapter.govee-local.0            : govee-local           : ioBroker                                 -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
              + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
              + system.adapter.husqvarna-automower.0    : husqvarna-automower   : ioBroker                                 -  enabled
              + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
              + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
              + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
              + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
              + system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
              + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
              + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
              + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
              + system.adapter.tado.0                   : tado                  : ioBroker                                 -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
              + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
              + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
              + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
              + instance is alive
              Objects and States
              Objects:        14243
              States:         12281
              Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
              Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
              Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
              Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
              Pending Updates: 0
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       142103452  22357/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       142127229  22357/iobroker.js-c
              tcp        0      0 192.168.178.61:42010    0.0.0.0:*               LISTEN      1000       142127710  22615/io.hm-rpc.0
              tcp        0      0 192.168.178.61:42001    0.0.0.0:*               LISTEN      1000       142129503  22695/io.hm-rpc.1
              tcp        0      0 0.0.0.0:37287           0.0.0.0:*               LISTEN      1000       142127662  22585/io.yahka.0
              tcp        0      0 127.0.0.1:36251         0.0.0.0:*               LISTEN      1000       142132584  22585/io.yahka.0
              tcp        0      0 192.168.178.61:8082     0.0.0.0:*               LISTEN      1000       142134977  22819/io.web.0
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       142129315  22600/io.shelly.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       142123634  22376/io.admin.0
              tcp6       0      0 :::3000                 :::*                    LISTEN      1000       142129231  22519/io.fullybrows
              udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       142127596  22549/io.radar2.0
              udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1000       142128073  22742/io.govee-loca
              2025-09-19 06:51:43.283  - error: host.ioBroker iobroker npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:23128) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-19T04_49_25_414Z-debug-0.loghost.ioBroker Cannot install iobroker.govee-local@0.2.9: 7
                @feinfinger
                cd /opt/iobroker && npm ls noble
                  @thomas-braun sagte in Adapter lassen sich nicht updaten:
                  smarthome@ioBroker:~$ cd /opt/iobroker && npm ls noble
                  [sudo] password for smarthome:
                  iobroker.inst@2.0.3 /opt/iobroker
                  `-- (empty)
                  smarthome@ioBroker:/opt/iobroker$
                    @feinfinger
                    Sorry, mein Fehler:
                    cd /opt/iobroker && npm ls @stoprocent/noble
                      Was heißt hier sorry, ich bin so froh das es dich hier im Forum gibt 😃
                      smarthome@ioBroker:/opt/iobroker$ cd /opt/iobroker && npm ls @stoprocent/noble
                      +-- iobroker.homekit-controller@0.5.11
                      | `-- hap-controller@0.10.2
                      |   `-- @stoprocent/noble@1.19.1 deduped
                      `-- iobroker.radar2@2.4.0
                        homekit-controller
                        radar2
                        installier die beiden Adapter mal neu.
                        F 2 Replies Last reply Reply Quote 0
                          Radar2 lies sich ohne Probleme installieren, wenn ich den homekit-controller installieren möchte kommt dieser Fehler:
                          Weniger Protokolle
                          Detailliert
                          $ iobroker add homekit-controller --host ioBroker
                          Installing iobroker.homekit-controller@0.5.11... (System call)
                          npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:26743) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-19T06_33_43_583Z-debug-0.log
                          host.ioBroker Cannot install iobroker.homekit-controller@0.5.11: 7
                            Dafür lassen sich jetzt die anderen Adapter updaten.
                              @feinfinger
                              Dann mach mal ein Issue drüben bei github für den homekit-controller auf.
                                Ok, hab ich gemacht.
                                Danke dir erstmal für deine Hilfe!
                                81.0k
                                441
