    4. Backit Up Fehler bei Grafana Backup
      toki1973 last edited by
      Ich verwende Grafana V8 und bekomme nach dem Update einen Zugriffsfehler. Ich habe nichts geändert. Wurde am Adapter etwas geändert?
      Backitup:
      Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
      grafana: {"message":"Request failed with status code 403","name":"AxiosError","stack":"AxiosError: Request failed with status code 403\n    at settle (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:2053:12)\n    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:3170:11)\n    at IncomingMessage.emit (node:events:536:35)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at process.processTicksAndRejections (node:internal/process/task_queues:82:21)\n    at Axios.request (/opt/iobroker/node_modules/iobroker.backitup/node_modules/axios/dist/node/axios.cjs:4280:41)\n    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n    at async /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:42:44","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer eyJrIjoiSWxxxxx0lxxxxLCJuIjoiR3JhZmFuYUtleSIsImlkIjoxxx==","User-Agent":"axios/1.10.0","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.0.xx:3000/api/datasources","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}},"allowAbsoluteUrls":true},"code":"**ERR_BAD_REQUEST","status":403**}
      • simatec
        simatec Developer Most Active @toki1973 last edited by
        @toki1973 sagte in Backit Up Fehler bei Grafana Backup:
        Grafana V8
        Bei dieser alten Version kann es durchaus sein, dass diese nicht mehr kompatibel ist. Grafana ist aktuell bei v12.1
          toki1973 @simatec last edited by
          Ohje sehe gerade das Influx und Grafana noch auf Buster VM läuft. Dann wohl am besten alles neu und mal schauen wie ich meine Grafana und Influxdaten migriere 😲
          81.0k
