    4. Gelöst: Raspberry 5 8GB hohe CPU Last
      michihorn last edited by michihorn
      Hallo, bis vor wenigen Tagen lief meine RP5 völlig Problemlos.
      Nun zeigt er mächtige CPU Auslastung, die ich mir nicht erklären kann. Es wurden keine neuen Adapter installiert, oder auf eine neue Version gehoben. Ich habe mal den DIAG angehangen, vielleicht sieht jemand was auffälliges.
      Bereits in Zeile 2 gibt es einen Hinweis, von dem ich nicht weiß wie ich damit umgehen soll.
      ioBroker Status
       Cannot read system.config: undefined (OK when migrating or restoring)
      /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
              throw e;
      Error: Connection is closed.
          at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
          at Redis.scan (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
          at ScanStream._read (/opt/iobroker/node_modules/ioredis/built/ScanStream.js:36:41)
          at Readable.read (node:internal/streams/readable:739:12)
          at resume_ (node:internal/streams/readable:1257:12)
          at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      Emitted 'error' event on ScanStream instance at:
          at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
          at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
          at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      Node.js v20.19.5
      Hosts:
       Cannot determine Set feature status: Connection is closed.
       Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
       Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
       Unable to subscribe to meta namespace "meta." changes: Connection is closed.
      No connection to databases possible ...
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     9.0.11
      nodejs modules from github:     5
      +-- esphome-b2500@0.1.0 (git+ssh://git@github.com/tomquist/esphome-b2500.git#ce2a7064dcf4e4aaf0fe4ef28ee6ec1b0c6634d0)
      +-- iobroker.onvif@1.1.4 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.onvif.git#618669c8cebb8b3fae6f1155131e3bbfa503fd27)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
      +-- iobroker.vis-owl@0.2.13 (git+ssh://git@github.com/gerbuchner/ioBroker.vis-owl.git#26f227f5d70d75b265c03bb40c3e400d90013b84)
      +-- iobroker.vis@1.5.6 (git+ssh://git@github.com/iobroker/ioBroker.vis.git#3265f32a4286763a723ba22bc9c0cbcb448002a8)
      Adapter State
      + system.adapter.admin.0                  : admin                 : rp5                                      -  enabled, compact disabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : rp5                                      -  enabled, compact disabled
      + system.adapter.ankersolix2.0            : ankersolix2           : rp5                                      -  enabled, compact disabled
      + system.adapter.backitup.0               : backitup              : rp5                                      -  enabled, compact disabled
        system.adapter.daswetter.0              : daswetter             : rp5                                      -  enabled, compact disabled
        system.adapter.daswetter.1              : daswetter             : rp5                                      -  enabled, compact disabled
        system.adapter.device-watcher.0         : device-watcher        : rp5                                      - disabled, compact disabled
        system.adapter.dwd.0                    : dwd                   : rp5                                      -  enabled, compact disabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: rp5                                      -  enabled, compact disabled
        system.adapter.feiertage.0              : feiertage             : rp5                                      - disabled, compact disabled
      + system.adapter.fritzbox.0               : fritzbox              : rp5                                      -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : rp5                                      -  enabled, compact disabled
      + system.adapter.ham.0                    : ham                   : rp5                                      -  enabled
      + system.adapter.history.0                : history               : rp5                                      -  enabled, compact disabled
      + system.adapter.hm-rega.0                : hm-rega               : rp5                                      -  enabled, compact enabled (group 0)
      + system.adapter.hm-rpc.0                 : hm-rpc                : rp5                                      -  enabled, compact disabled
      + system.adapter.hm-rpc.1                 : hm-rpc                : rp5                                      -  enabled, compact disabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : rp5                                      -  enabled, compact disabled, port: 0
      + system.adapter.hue.0                    : hue                   : rp5                                      -  enabled, compact disabled, port: 443
        system.adapter.ical.0                   : ical                  : rp5                                      -  enabled, compact disabled
        system.adapter.icons-material-png.0     : icons-material-png    : rp5                                      - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : rp5                                      - disabled
      + system.adapter.iot.0                    : iot                   : rp5                                      -  enabled, compact disabled
      + system.adapter.iot.1                    : iot                   : rp5                                      -  enabled, compact disabled
      + system.adapter.iot.2                    : iot                   : rp5                                      -  enabled, compact disabled
      + system.adapter.javascript.0             : javascript            : rp5                                      -  enabled, compact disabled
      + system.adapter.mqtt-client.1            : mqtt-client           : rp5                                      -  enabled, compact disabled, port: 3145
      + system.adapter.mqtt.1                   : mqtt                  : rp5                                      -  enabled, compact disabled, port: 3020, bind: 0.0.0.0
      + system.adapter.notificationforandroidtv.0: notificationforandroidtv: rp5                                      -  enabled, compact disabled
      + system.adapter.onvif.0                  : onvif                 : rp5                                      -  enabled, compact disabled
      + system.adapter.ping.0                   : ping                  : rp5                                      -  enabled, compact disabled
        system.adapter.pollenflug.0             : pollenflug            : rp5                                      - disabled, compact disabled
        system.adapter.reolink.0                : reolink               : rp5                                      - disabled, compact disabled
      + system.adapter.simple-api.0             : simple-api            : rp5                                      -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartgarden.0            : smartgarden           : rp5                                      -  enabled, compact disabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : rp5                                      -  enabled, compact disabled
      + system.adapter.tahoma.0                 : tahoma                : rp5                                      -  enabled, compact disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : rp5                                      -  enabled, compact disabled
        system.adapter.telegram.0               : telegram              : rp5                                      - disabled, compact disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tuya.1                   : tuya                  : rp5                                      -  enabled, compact disabled
      + system.adapter.vaillant.0               : vaillant              : rp5                                      -  enabled, compact disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : rp5                                      - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : rp5                                      - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : rp5                                      - disabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : rp5                                      -  enabled, compact disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : rp5                                      - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : rp5                                      -  enabled, compact disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : rp5                                      - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : rp5                                      - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : rp5                                      - disabled
        system.adapter.vis-metro.0              : vis-metro             : rp5                                      - disabled
        system.adapter.vis-owl.0                : vis-owl               : rp5                                      - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : rp5                                      - disabled
        system.adapter.vis.0                    : vis                   : rp5                                      -  enabled, compact disabled
      + system.adapter.web.0                    : web                   : rp5                                      -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : rp5                                      -  enabled, compact disabled
      + system.adapter.zigbee.0                 : zigbee                : rp5                                      -  enabled, compact disabled, port: tcp://192.168.178.68:3334
      + system.adapter.zigbee.1                 : zigbee                : rp5                                      -  enabled, compact disabled, port: tcp://192.168.178.151:3333
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "ankersolix2"  : 2.3.0    , installed 2.3.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.6
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "device-watcher": 2.12.6  , installed 2.13.1
      Adapter    "energiefluss-erweitert": 0.7.7, installed 0.7.8
      Adapter    "espresense"   : 0.6.3    , installed 0.6.3
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "hue"          : 3.16.2   , installed 3.16.2
      Adapter    "ical"         : 1.16.2   , installed 1.16.2
      Adapter    "iot"          : 3.3.0    , installed 3.5.0
      Adapter    "javascript"   : 8.9.2    , installed 9.0.11
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
      Adapter    "mqtt-client"  : 3.0.0    , installed 2.1.0  [Updatable]
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "ping"         : 1.6.2    , installed 1.7.9
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
      Adapter    "simple-api"   : 2.8.0    , installed 3.0.7
      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "tahoma"       : 0.10.4   , installed 0.11.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "telegram-menu": 2.4.4    , installed 3.0.6
      Adapter    "tuya"         : 3.16.0   , installed 3.17.0
      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "web"          : 7.0.8    , installed 7.0.9
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "zigbee"       : 3.0.5    , installed 3.0.5
      Objects and States
      Objects:        41329
      States:         1
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 https://repos.influxdata.com/debian stable InRelease
      Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 6
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:3020            0.0.0.0:*               LISTEN      1001       55994      5593/io.mqtt.1
      tcp        0      0 192.168.178.43:2010     0.0.0.0:*               LISTEN      1001       55281      5427/io.hm-rpc.2
      tcp        0      0 192.168.178.43:2001     0.0.0.0:*               LISTEN      1001       55629      5382/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       55381      5141/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       55386      5141/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1716       799/sshd: /usr/sbin
      tcp        0      0 192.168.178.43:8701     0.0.0.0:*               LISTEN      1001       2126540    112471/io.hm-rpc.1
      tcp6       0      0 :::3001                 :::*                    LISTEN      1001       55156      5336/io.fullybrowse
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       57951      5844/io.simple-api.
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       53169      5163/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57830      5783/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          1718       799/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5850       683/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1990031    105107/io.tuya.1
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1990032    105107/io.tuya.1
      udp        0      0 0.0.0.0:43698           0.0.0.0:*                           104        5852       683/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        5851       683/avahi-daemon: r
      udp6       0      0 :::51764                :::*                                104        5853       683/avahi-daemon: r
      udp6       0      0 fe80::2a6a:9336:56b:546 :::*                                0          1369246    762/NetworkManager
      udp6       0      0 fe80::504:bc77:ac3a:546 :::*                                0          834        762/NetworkManager
      2025-09-19 11:26:15.895  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:16.346  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:16.827  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:17.248  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:17.758  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:17.956  - info: javascript.0 (5188) script.js.HAUS.Rolladen.Status_Rolladen: 02 WZ Rechts 01 OBEN
      2025-09-19 11:26:18.040  - debug: tahoma.0 (103621) Starting state polling
      2025-09-19 11:26:18.040  - debug: tahoma.0 (103621) POST request on https://192.168.178.63:8443/enduser-mobile-web/1/enduserAPI/events/d4cc8d60-c55a-437c-85c4-296f6d3afb20/fetch with payload:{}
      2025-09-19 11:26:18.081  - debug: tahoma.0 (103621) Response: []
      2025-09-19 11:26:18.081  - debug: tahoma.0 (103621) events/d4cc8d60-c55a-437c-85c4-296f6d3afb20/fetchFetched Data []
      2025-09-19 11:26:18.463  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:18.854  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:19.631  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:20.079  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:20.550  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:21.146  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:21.378  - info: fullybrowser.0 (5336) 🗸 192.168.178.200: Command stopScreensaver successfully set to true
      2025-09-19 11:26:21.540  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:22.249  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:22.666  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:23.124  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:23.587  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:23.986  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      2025-09-19 11:26:24.092  - info: javascript.0 (5188) script.js.HAUS.Rolladen.Status_Rolladen: 04 EZ 01 OBEN
      2025-09-19 11:26:24.603  - info: javascript.0 (5188) script.js.Garten.Teich.Teichpumpe_Abschaltungen: 1
      Ich vermute mal das sich eins meiner Scripte tot läuft. Habe mal zum testen meine letzten Änderungen ausgeschaltet.
      EDIT: Es war die TUYA-Instance.
      Gelöscht, neu installiert.
      Seit zwei Tagen wieder um die 4-8% CPU Last.
      Michael
        Homoran Global Moderator Administrators @michihorn last edited by
        @michihorn sagte in Raspberry 5 8GB hohe CPU Last:
        da fehlt der gesamte Systemteil!
        hast du den nur "vergessen" zu kopieren?
        wenn nein, bitte erst einmal Screenshot von top
          michihorn @Homoran last edited by michihorn
          pi@rp5:~ $ top
          top - 11:57:41 up 2 days,  4:13,  1 user,  load average: 2.16, 2.20, 2.24
          Tasks: 197 total,   3 running, 194 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 42.8 us,  5.4 sy,  0.0 ni, 49.6 id,  0.1 wa,  0.0 hi,  2.2 si,  0.0 st
          MiB Mem :   8063.2 total,   2278.0 free,   3993.2 used,   1949.1 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4070.0 avail Mem
              PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
             5141 iobroker  20   0 5736784 585200  45776 R 100.7   7.1     28,30 iobroker.js-con
           105107 iobroker  20   0 5512608 373280  45872 S  71.1   4.5  74:26.96 io.tuya.1
             5188 iobroker  20   0 5642112 495456  44880 R  22.3   6.0      8,50 io.javascript.0
           116262 iobroker  20   0 5187584 136368  46256 S   2.3   1.7   0:19.83 io.web.0
             5163 iobroker  20   0 5366608 276896  45824 S   1.0   3.4   5:28.51 io.admin.0
             5254 iobroker  20   0 5019952 102032  39408 S   1.0   1.2   4:52.77 io.mqtt-client.
             5890 iobroker  20   0 5246304  90096  40480 S   1.0   1.1  10:38.52 io.ankersolix2.
             5272 iobroker  20   0 5078048  94544  39424 S   0.7   1.1   5:16.21 io.history.0
             5844 iobroker  20   0 5016992 104832  39936 S   0.7   1.3   4:47.47 io.simple-api.0
             5305 iobroker  20   0 5196944 106912  46448 S   0.3   1.3   0:47.50 io.backitup.0
             5689 iobroker  20   0 5250080  92544  40992 S   0.3   1.1   0:55.39 io.smartgarden.
             5707 iobroker  20   0 5011536  99072  44288 S   0.3   1.2   6:22.95 io.sourceanalyt
             5817 iobroker  20   0 9252752 100544  39808 S   0.3   1.2  15:55.37 io.onvif.0
           105123 iobroker  20   0 5132544 111456  40512 S   0.3   1.3   0:09.51 io.zigbee.1
                1 root      20   0  169504  11392   7904 S   0.0   0.1   2:23.20 systemd
                2 root      20   0       0      0      0 S   0.0   0.0   0:00.11 kthreadd
                3 root      20   0       0      0      0 S   0.0   0.0   0:00.00 pool_workqueue_release
                4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-kvfree_rcu_reclaim
                5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_gp
                6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-sync_wq
                7 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-slub_flushwq
                8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-netns
               10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
               12 root      20   0       0      0      0 I   0.0   0.0   0:00.01 kworker/u16:0-ipv6_addrconf
               13 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-mm_percpu_wq
               14 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
               15 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
               16 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
               17 root      20   0       0      0      0 S   0.0   0.0   0:13.64 ksoftirqd/0
               18 root      20   0       0      0      0 I   0.0   0.0   1:03.24 rcu_preempt
               19 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_exp_par_gp_kthread_worker/0
               20 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_exp_gp_kthread_worker
               21 root      rt   0       0      0      0 S   0.0   0.0   0:00.04 migration/0
               22 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
               23 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
               24 root      rt   0       0      0      0 S   0.0   0.0   0:00.04 migration/1
               25 root      20   0       0      0      0 S   0.0   0.0   0:09.59 ksoftirqd/1
               27 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/1:0H-events_highpri
               28 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/2
               29 root      rt   0       0      0      0 S   0.0   0.0   0:00.04 migration/2
               30 root      20   0       0      0      0 S   0.0   0.0   0:09.46 ksoftirqd/2
               32 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/2:0H-events_highpri
               33 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/3
               34 root      rt   0       0      0      0 S   0.0   0.0   0:00.04 migration/3
               35 root      20   0       0      0      0 S   0.0   0.0   0:09.49 ksoftirqd/3
               37 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/3:0H-events_highpri
               42 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kdevtmpfs
               43 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-inet_frag_wq
               44 root      20   0       0      0      0 S   0.0   0.0   0:00.00 kauditd
               45 root      20   0       0      0      0 S   0.0   0.0   0:00.11 khungtaskd
               46 root      20   0       0      0      0 S   0.0   0.0   0:00.00 oom_reaper
               48 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-writeback
               49 root      20   0       0      0      0 S   0.0   0.0   0:03.90 kcompactd0
               50 root      20   0       0      0      0 S   0.0   0.0   0:03.77 kcompactd1
               51 root      20   0       0      0      0 S   0.0   0.0   0:03.33 kcompactd2
               52 root      20   0       0      0      0 S   0.0   0.0   0:04.70 kcompactd3
            Homoran Global Moderator Administrators @michihorn last edited by Homoran
            @michihorn schalt msl den tuya-adapter ab!
            die Instanz tuya.1 !!
              @homoran ich habe nur die Instanz 1. Gibt keine Andere.
              Ich habe ein Script in Verdacht hier Stress zu machen. Ich hab das mal deaktiviert. Aktuell bin ich stabil bai 8% CPU
                Thomas Braun Most Active @michihorn last edited by Thomas Braun
                @michihorn
                Du sollst die abschalten, damit man sieht wo es da klemmt.
                Edith: Benutzt das Skript Objekte aus dem tuya-Adapter?
                  und wie sieht top dann aus?
                    top - 14:20:42 up 2 days,  6:36,  1 user,  load average: 0.81, 1.17, 0.95
                    Tasks: 200 total,   2 running, 198 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  5.6 us,  0.9 sy,  0.0 ni, 93.4 id,  0.0 wa,  0.0 hi,  0.1 si,  0.0 st
                    MiB Mem :   8063.2 total,   2789.4 free,   3374.3 used,   2056.6 buff/cache
                    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4688.8 avail Mem
                    117169 iobroker  20   0 5751728 578064  46512 S   3.0   7.0  29:03.13 iobroker.js-con
                    117725 iobroker  20   0 4984512  95712  40976 S   1.3   1.2   0:39.14 io.hue.0
                    117341 iobroker  20   0 5550288 418032  44816 S   0.7   5.1  14:23.19 io.javascript.0
                    117141 pi        20   0   20496   6800   4688 S   0.3   0.1   0:00.06 sshd
                    117240 iobroker  20   0 5046464  83984  39952 S   0.3   1.0   0:20.85 io.history.0
                    117306 iobroker  20   0 5383584 315344  45856 S   0.3   3.8   1:07.94 io.admin.0
                    118619 iobroker  20   0 5314448 139376  46928 S   0.3   1.7   1:53.24 io.web.0
                    119011 iobroker  20   0 5188256  94352  40496 S   0.3   1.1   0:20.99 io.telegram.0
                    121869 root      20   0       0      0      0 I   0.3   0.0   0:00.46 kworker/0:2-events_freezable_pwr_efficient
                         1 root      20   0  169504  11392   7904 S   0.0   0.1   2:29.63 systemd
                        12 root      20   0       0      0      0 I   0.0   0.0   0:00.02 kworker/u16:0-ipv6_addrconf
                        17 root      20   0       0      0      0 S   0.0   0.0   0:14.01 ksoftirqd/0
                        18 root      20   0       0      0      0 I   0.0   0.0   1:05.72 rcu_preempt
                        21 root      rt   0       0      0      0 S   0.0   0.0   0:00.05 migration/0
                        25 root      20   0       0      0      0 S   0.0   0.0   0:09.84 ksoftirqd/1
                        30 root      20   0       0      0      0 S   0.0   0.0   0:09.70 ksoftirqd/2
                        35 root      20   0       0      0      0 S   0.0   0.0   0:09.74 ksoftirqd/3
                        45 root      20   0       0      0      0 S   0.0   0.0   0:00.12 khungtaskd
                        49 root      20   0       0      0      0 S   0.0   0.0   0:04.41 kcompactd0
                        50 root      20   0       0      0      0 S   0.0   0.0   0:04.21 kcompactd1
                        51 root      20   0       0      0      0 S   0.0   0.0   0:03.67 kcompactd2
                        52 root      20   0       0      0      0 S   0.0   0.0   0:05.31 kcompactd3
                        53 root      20   0       0      0      0 S   0.0   0.0   0:03.80 kcompactd4
                        54 root      20   0       0      0      0 S   0.0   0.0   0:03.87 kcompactd5
                        55 root      20   0       0      0      0 S   0.0   0.0   0:04.04 kcompactd6
                        56 root      20   0       0      0      0 S   0.0   0.0   0:04.00 kcompactd7
                        57 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-kintegrityd
                      @michihorn so soll es aussehen!
                      aber anscheinend hast du noch weiteres verändert!
                      davon hatte ich nichts gesagt.
                      Umso wichtiger wäre jetzt die fehlende Antwort
                      @thomas-braun sagte in Raspberry 5 8GB hohe CPU Last:
                      Außerdem solltest du das Skript zeigen
