[gelöst] Zigbeestick nach Neuinstallation nicht ansprechbar
Ich habe seit geraumer Zeit probleme mit dem Zigbee Stick. Mein neustes:
Komplette Neuinstallation iob und backup eingepflegt. Der Stick wird nicht mehr im Adapter erkannt.
ls -l /dev/serial/by-id/ total 0 lrwxrwxrwx 1 root root 13 Sep 20 14:14 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f211ce48ec1bef11a50ba3d94909ffd0-if00-port0 -> ../../ttyUSB0iob diag zeigt mir den Stick an:
USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f211ce48ec1bef11a50ba3d94909ffd0-if00-port0 *** ZigBee Settings *** Your zigbee.0 COM-Port is matching 'by-id'. Very good! Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED ***Die logs beim start/wählen des Sticks in den Einstellungen sagen:
2025-09-22 11:55:13.171 - info: zigbee.0 (463319) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7 2025-09-22 11:55:13.222 - info: zigbee.0 (463319) Adapter ready - starting subsystems. Adapter is running in info mode. 2025-09-22 11:55:13.225 - info: zigbee.0 (463319) init localConfig 2025-09-22 11:55:13.241 - info: zigbee.0 (463319) --- creating device debug --- 2025-09-22 11:55:13.242 - warn: zigbee.0 (463319) Zigbee autostart option not set - omitting start of zigbee substystem! 2025-09-22 11:55:52.300 - info: admin.0 (457008) ==> Connected system.user.admin from ::ffff:192.168.178.35 2025-09-22 11:55:52.712 - info: zigbee.0 (463319) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"f211ce48ec1bef11a50ba3d94909ffd0","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f211ce48ec1bef11a50ba3d94909ffd0-if00-port0","vendorId":"10c4","productId":"ea60"}] 2025-09-22 11:55:58.949 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true) 2025-09-22 11:55:58.956 - info: zigbee.0 (463319) Got terminate signal TERMINATE_YOURSELF 2025-09-22 11:55:58.996 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal 2025-09-22 11:55:59.049 - info: admin.0 (457008) <== Disconnect system.user.admin from ::ffff:192.168.178.35 2025-09-22 11:55:58.959 - info: zigbee.0 (463319) Halting zigbee adapter. Restart delay is at least 30 seconds. 2025-09-22 11:55:58.963 - info: zigbee.0 (463319) cleaning everything up... 2025-09-22 11:55:58.971 - info: zigbee.0 (463319) Saved local configuration data 2025-09-22 11:55:59.103 - warn: zigbee.0 (463319) Failed to stop zigbee during startup 2025-09-22 11:55:59.103 - info: zigbee.0 (463319) cleanup successful 2025-09-22 11:55:59.104 - info: zigbee.0 (463319) terminating 2025-09-22 11:55:59.105 - info: zigbee.0 (463319) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-09-22 11:55:59.687 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)könnte mein stick auch hinüber sein?
@ianig-iro sagte in Zigbeestick nach Neuinstallation nicht ansprechbar:
Du musst die 'Startoption' im Adapter setzen.
@thomas-braun wo finde ich die? in den adaptereinstellungen habe ich nichts gesehen.
Hab gerade keinen graphischen Zugriff auf den Admin, kann es nicht nachschauen.
Auf der rechten Seite findet sich da was, wenn ich mich recht entsinne. -
@thomas-braun danke, ich habe es wirklich 10 mal übersehen.
jetzt:
2025-09-22 12:14:59.738 - info: zigbee.0 (466687) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7 2025-09-22 12:14:59.789 - info: zigbee.0 (466687) Adapter ready - starting subsystems. Adapter is running in info mode. 2025-09-22 12:14:59.791 - info: zigbee.0 (466687) init localConfig 2025-09-22 12:14:59.806 - info: zigbee.0 (466687) --- creating device debug --- 2025-09-22 12:14:59.807 - info: zigbee.0 (466687) Autostart Zigbee subsystem 2025-09-22 12:14:59.808 - info: zigbee.0 (466687) Starting Adapter npm ... 2025-09-22 12:14:59.823 - info: zigbee.0 (466687) Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1) 2025-09-22 12:14:59.825 - info: zigbee.0 (466687) configured transmit power : normal 2025-09-22 12:14:59.827 - info: zigbee.0 (466687) Starting Zigbee-Herdsman 2025-09-22 12:15:19.653 - info: zigbee.0 (466687) Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20210708 (2-1.2.7.1) 2025-09-22 12:15:19.665 - info: zigbee.0 (466687) Unable to disable LED, unsupported function. 2025-09-22 12:15:19.666 - info: zigbee.0 (466687) No devices are currently joined. 2025-09-22 12:15:19.670 - info: zigbee.0 (466687) Zigbee started 2025-09-22 12:15:19.671 - info: zigbee.0 (466687) Config value 0x585c41c0b20ee24b : Network value 0x00124b002f89898f 2025-09-22 12:15:19.675 - error: zigbee.0 (466687) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms 2025-09-22 12:15:19.747 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true) 2025-09-22 12:15:19.757 - info: zigbee.0 (466687) Got terminate signal TERMINATE_YOURSELF 2025-09-22 12:15:19.759 - info: zigbee.0 (466687) Halting zigbee adapter. Restart delay is at least 30 seconds. 2025-09-22 12:15:19.759 - info: zigbee.0 (466687) cleaning everything up... 2025-09-22 12:15:19.761 - info: zigbee.0 (466687) Saved local configuration data 2025-09-22 12:15:19.798 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal 2025-09-22 12:15:19.832 - error: zigbee.0 (466687) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups') 2025-09-22 12:15:20.001 - info: zigbee.0 (466687) Closing Zigbee network, 0 seconds remaining 2025-09-22 12:15:23.762 - info: zigbee.0 (466687) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-09-22 12:15:24.387 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) -
@ianig-iro Doku lesen soll da helfen ...
@arteck sagte in Zigbeestick nach Neuinstallation nicht ansprechbar:
Wie kommst du denn auf das dünne Brett ? Da müsste ja jemand Doku geschrieben haben.
Scherz beiseite - Du hast ein Problem mit deiner Netzwerk Konfiguration. Steht da auch. Lesen bildet ungemein:
2025-09-22 12:15:19.671 - info: zigbee.0 (466687) Config value 0x585c41c0b20ee24b : Network value 0x00124b002f89898f 2025-09-22 12:15:19.675 - error: zigbee.0 (466687) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms 2025-09-22 12:15:19.747 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true) 2025-09-22 12:15:19.757 - info: zigbee.0 (466687) Got terminate signal TERMINATE_YOURSELF 2025-09-22 12:15:19.759 - info: zigbee.0 (466687) Halting zigbee adapter. Restart delay is at least 30 seconds.@Ianig-Iro
Du hast jetzt 2 Optionen:Option A) wenn du sowieso alles neu anlernen musst: die ExtPanID aus dem Netzwerk in die Konfiguration übernehmen
Option B) wenn du das bestehende übernehmen willst: Alle Router im Netz vom Strom nehmen, eine ggf. vorhandene nvbackup.json löschen, den Adapter starten.A.
@asgothian danke option a hat es gelöst. den error habe ich gesehen, aber ich habe nicht verstanden, was genau das problem ist. ich wusste noch nichtmal, dass es mehrere IDs gibt.
