    4. Wie IO-Broker reparieren?
      WolfgangFB last edited by
      Mein IO-Broker will auf einmal nicht mehr.
      ich habe mit iobroker fix versucht das ganze zu reparieren. Er startet auch kurz, ist dann aber nach kurzer Zeit nicht mehr erreichbar.
      Was kann man tun (außer Neuinstallation)?
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:/opt/iobroker $ iobroker start
      pi@raspberrypi:/opt/iobroker $ iobroker status
      Objects type: jsonl
      States  type: jsonl
      No connection to databases possible ...
       Cannot determine Set feature status: Connection is closed.
       Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
       Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
       Unable to subscribe to meta namespace "meta." changes: Connection is closed.
      alternativ kommt manchmal auch: (ich habe kein Multihost System)
      Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
          at Redis.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:488:23)
          at process.processTicksAndRejections (node:internal/process/task_queues:105:5)
        Thomas Braun Most Active @WolfgangFB last edited by
        @wolfgangfb
        Schau dir das Gesamtkonstrukt unter
        iob diag
        an.
          WolfgangFB @Thomas Braun last edited by
          nach iob diag kommt zuerst
          *** iob diag is starting up, please wait ***
          Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
              at Redis.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:477:23)
          dann nach einiger Zeit die "All good" Meldung, IO-Broker läuft jetzt auch, wenn auch unendlich zäh.
          ========== Start marking the full check here ===========
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.6.51+rpt-rpi-v8
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           13:58:17 up 58 min,  3 users,  load average: 2.51, 2.02, 2.03
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Fri 2025-09-26 13:58:17 CEST
                     Universal time: Fri 2025-09-26 11:58:17 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          *** DISPLAY-SERVER SETUP ***
          Display-Server:         false
          Display-Manager:        * lightdm.service - Light Display Manager
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:            8.2G        1.9G        5.0G         10M        1.4G        6.3G
          Swap:           209M          0B        209M
          Total:          8.4G        1.9G        5.2G
          Active iob-Instances:   0
                   7809 M total memory
                   1793 M used memory
                   1824 M active memory
                    779 M inactive memory
                   4789 M free memory
                    209 M buffer memory
                   1149 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 13:58:18 up 58 min,  3 users,  load average: 2.55, 2.04, 2.03
          Tasks: 189 total,   3 running, 186 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 33.3 us, 33.3 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7810.0 total,   4787.7 free,   1795.3 used,   1359.2 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6014.7 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     1.6G   11M  1.6G   1% /run
          /dev/mmcblk0p2 ext4       28G   23G  3.7G  87% /
          tmpfs          tmpfs     3.9G  8.0K  3.9G   1% /dev/shm
          /dev/mmcblk0p1 vfat      510M   76M  435M  15% /boot/firmware
          tmpfs          tmpfs     781M   36K  781M   1% /run/user/1000
          [Fri Sep 26 12:59:40 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:66:20:22 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3a1130ee-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
          [Fri Sep 26 12:59:41 2025] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add-4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
          [Fri Sep 26 12:59:43 2025] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab98-e9f0235e06b3 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET           SOURCE         FSTYPE OPTIONS
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          3.4G    /var/
          2.2G    /var/log/journal/d50066f22adb471e847d298aee84cf4e
          2.2G    /var/log
          752M    /var/cache
          Archived and active journals take up 2.1G in the file system.
          /opt/iobroker/backups:
          101M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          8.0G    /opt/iobroker/iobroker-data/
          4.2G    /opt/iobroker/iobroker-data/history
          2.8G    /opt/iobroker/iobroker-data/esphome.0/.esphome/build
          49M     /opt/iobroker/iobroker-data/history/20250603/history.javascript.0.Raum.Technik.S0Counter.Haushaltsstrom.VerbrauchteEnergie.Gestern.json
          46M     /opt/iobroker/iobroker-data/history/20250531/history.javascript.0.Raum.Technik.S0Counter.Haushaltsstrom.VerbrauchteEnergie.Gestern.json
          42M     /opt/iobroker/iobroker-data/history/20250624/history.javascript.0.Raum.Technik.S0Counter.Haushaltsstrom.VerbrauchteEnergie.Gestern.json
          42M     /opt/iobroker/iobroker-data/history/20250623/history.javascript.0.Raum.Technik.S0Counter.Haushaltsstrom.VerbrauchteEnergie.Gestern.json
          42M     /opt/iobroker/iobroker-data/history/20250622/history.javascript.0.Raum.Technik.S0Counter.Haushaltsstrom.VerbrauchteEnergie.Gestern.json
          USB-Devices by-id:
          No Devices found 'by-id'
          *** ZigBee Settings ***
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v22.18.0
          /usr/bin/node           v22.18.0
          /usr/bin/npm            10.9.3
          /usr/bin/npx            10.9.3
          /usr/bin/corepack       0.33.0
          nodejs:
            Installed: 22.18.0-1nodesource1
            Candidate: 22.20.0-1nodesource1
            Version table:
               22.20.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
               22.19.0-1nodesource1 1001
           *** 22.18.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               22.17.1-1nodesource1 1001
               22.17.0-1nodesource1 1001
               22.16.0-1nodesource1 1001
               22.15.1-1nodesource1 1001
               22.15.0-1nodesource1 1001
               22.14.0-1nodesource1 1001
               22.13.1-1nodesource1 1001
               22.13.0-1nodesource1 1001
               22.12.0-1nodesource1 1001
               22.11.0-1nodesource1 1001
               22.10.0-1nodesource1 1001
               22.9.0-1nodesource1 1001
               22.8.0-1nodesource1 1001
               22.7.0-1nodesource1 1001
               22.6.0-1nodesource1 1001
               22.5.1-1nodesource1 1001
               22.5.0-1nodesource1 1001
               22.4.1-1nodesource1 1001
               22.4.0-1nodesource1 1001
               22.3.0-1nodesource1 1001
               22.2.0-1nodesource1 1001
               22.1.0-1nodesource1 1001
               22.0.0-1nodesource1 1001
               18.20.4+dfsg-1~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          Checking for nodejs vulnerability:
          *** ioBroker-Installation ***
          ioBroker Status
          Hosts:
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.6.3
          javascript:     8.8.3
          nodejs modules from github:     1
          +-- iobroker.esphome@0.4.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.esphome.git#210a96eaad3122527b50f3262839d2060ed7adc5)
          Adapter State
           Unable to enable Expiry Keyspace events from Redis Server: Connection is closed.
          ioBroker-Repositories
          Installed ioBroker-Adapters
          Objects and States
          Objects:        2
          States:         2
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
          Reading package lists...
          Pending Updates: 132
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       28652      5536/python3
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       28630      5368/io.shelly.1
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2594       747/cupsd
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       27359      5224/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       27364      5224/iobroker.js-co
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          8569       821/smbd
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2585       756/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          8568       821/smbd
          tcp6       0      0 :::61991                :::*                    LISTEN      1001       28511      5367/io.harmony.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2593       747/cupsd
          tcp6       0      0 :::139                  :::*                    LISTEN      0          8567       821/smbd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          2587       756/sshd: /usr/sbin
          tcp6       0      0 :::445                  :::*                    LISTEN      0          8566       821/smbd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       29215      5242/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       28596      5412/io.web.0
          udp        0      0 0.0.0.0:54325           0.0.0.0:*                           104        2517       576/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       29837      5437/io.esphome.0
          udp        0      0 192.168.1.205:5353      0.0.0.0:*                           1001       29643      5536/python3
          udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       29642      5536/python3
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       29638      5536/python3
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2515       576/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       29818      5360/io.shelly.0
          udp        0      0 0.0.0.0:46807           0.0.0.0:*                           1001       38764      5360/io.shelly.0
          udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          2678       817/nmbd
          udp        0      0 192.168.1.205:137       0.0.0.0:*                           0          2677       817/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          2665       817/nmbd
          udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          2680       817/nmbd
          udp        0      0 192.168.1.205:138       0.0.0.0:*                           0          2679       817/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          2666       817/nmbd
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       28512      5367/io.harmony.0
          udp6       0      0 :::5353                 :::*                                104        2516       576/avahi-daemon: r
          udp6       0      0 :::50723                :::*                                104        2518       576/avahi-daemon: r
          2025-09-26 14:06:00.091  - warn: javascript.0 (5253)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
          2025-09-26 14:06:00.091  - warn: javascript.0 (5253)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
          2025-09-26 14:06:00.094  - warn: javascript.0 (5253)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
          2025-09-26 14:06:00.094  - warn: javascript.0 (5253)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
          2025-09-26 14:06:00.094  - warn: javascript.0 (5253)     at listOnTimeout (node:internal/timers:588:17)
          2025-09-26 14:06:00.095  - warn: javascript.0 (5253)     at process.processTimers (node:internal/timers:523:7)
          2025-09-26 14:06:01.718  - info: javascript.0 (5253) script.js.Licht.BewegungErfasst: Bewegung erfasst: alias.0.Raum.Hobby.Bewegung.Treppe.Zustand
          2025-09-26 14:06:04.172  - error: shelly.1 (5368) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-08b61fced0e0"
          2025-09-26 14:06:06.069  - info: shelly.1 (5368) [MQTT] Client Close: (shellypmmini / shellypmmini-543204832dbc / shellypmmini#543204832dbc#1) (false)
          2025-09-26 14:06:06.995  - info: shelly.1 (5368) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-08b61fced0e0 / shellyplus2pm#08b61fced0e0#1) (false)
          2025-09-26 14:06:13.578  - info: shelly.1 (5368) [MQTT] Device with client id "shellypmmini-543204a97b30" connected!
          2025-09-26 14:06:13.924  - warn: esphome.0 (5437) Client 192.168.1.158 not yet ready to connect, will try again!
          2025-09-26 14:06:16.871  - warn: esphome.0 (5437) Client 192.168.1.190 not yet ready to connect, will try again!
          2025-09-26 14:06:16.974  - info: shelly.1 (5368) [MQTT] Device with client id "shellyplus2pm-ecc9ff5f6214" connected!
          2025-09-26 14:06:18.830  - warn: esphome.0 (5437) Client 192.168.1.90 not yet ready to connect, will try again!
          2025-09-26 14:06:19.206  - info: shelly.1 (5368) [MQTT] Device with client id "shellyplus2pm-b8d61a87768c" connected!
          2025-09-26 14:06:21.992  - error: shelly.1 (5368) [MQTT] Unable to get mqttprefix of client with id "shellypmmini-543204a97b30"
          2025-09-26 14:06:21.993  - error: shelly.1 (5368) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-ecc9ff5f6214"
          2025-09-26 14:06:23.589  - info: shelly.1 (5368) [MQTT] Client Close: (shellypmmini / shellypmmini-543204a97b30 / shellypmmini#543204a97b30#1) (false)
          2025-09-26 14:06:26.963  - info: shelly.1 (5368) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-ecc9ff5f6214 / shellyplus2pm#ecc9ff5f6214#1) (false)
          2025-09-26 14:06:29.234  - info: shelly.1 (5368) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-b8d61a87768c / shellyplus2pm#b8d61a87768c#1) (false)
          2025-09-26 14:06:29.684  - error: shelly.1 (5368) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b8d61a87768c"
          2025-09-26 14:06:44.049  - warn: esphome.0 (5437) Client 192.168.1.158 not yet ready to connect, will try again!
          2025-09-26 14:06:46.977  - warn: esphome.0 (5437) Client 192.168.1.190 not yet ready to connect, will try again!
          2025-09-26 14:06:48.986  - warn: esphome.0 (5437) Client 192.168.1.90 not yet ready to connect, will try again!
            @wolfgangfb sagte in Wie IO-Broker reparieren?:
            Ich überlege, die wieder rauszunehmen...
            Das bezieht sich nur auf den kleinen Aspekt, ob deine nodejs-Installation aktuell ist und keine bekannten Sicherheitslücken in der derzeitig installierten Version enthalten sind.
            Aber schalt den Desktop aus. Offenbar läuft da Light DM:
            Bring die Basis auf Stand:
            sind 132 Updates zu viel in der Pipeline.
              Alle Updates sind durchgeführt, geändert hat sich nichts (IOB startet zwar, ist aber träge und langsam jund unbedienbar).
                  at Redis.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:475:23)
              und
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                        Kernel: Linux 6.12.47+rpt-rpi-v8
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
               17:20:09 up 3 min,  4 users,  load average: 3.22, 1.47, 0.58
              CPU threads: 4
              Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
              Current issues:
                             Local time: Fri 2025-09-26 17:20:09 CEST
                         Universal time: Fri 2025-09-26 15:20:09 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Unit display-manager.service could not be found.
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:            8.2G        1.8G        5.8G        3.2M        607M        6.4G
              Swap:           209M          0B        209M
              Total:          8.4G        1.8G        6.1G
              Active iob-Instances:   4
                       7820 M total memory
                       1755 M used memory
                       1825 M active memory
                        258 M inactive memory
                       5575 M free memory
                         69 M buffer memory
                        510 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              top - 17:20:10 up 3 min,  4 users,  load average: 3.22, 1.47, 0.58
              Tasks: 221 total,   6 running, 215 sleeping,   0 stopped,   0 zombie
              %Cpu(s): 63.6 us, 27.3 sy,  0.0 ni,  0.0 id,  9.1 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   7820.8 total,   5573.6 free,   1756.6 used,    580.0 buff/cache
              MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6064.2 avail Mem
              *** FILESYSTEM ***
              tmpfs          tmpfs     1.6G  3.0M  1.6G   1% /run
              /dev/mmcblk0p2 ext4       28G   22G  4.5G  84% /
              /dev/mmcblk0p1 vfat      510M   78M  433M  16% /boot/firmware
              tmpfs          tmpfs     783M   40K  783M   1% /run/user/1000
              [Fri Sep 26 17:16:53 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:66:20:22 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=3a1130ee-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
              [Fri Sep 26 17:16:55 2025] EXT4-fs (mmcblk0p2): mounted filesystem cb6f0e18-5add-4177-ab98-e9f0235e06b3 ro with ordered data mode. Quota mode: none.
              [Fri Sep 26 17:16:57 2025] EXT4-fs (mmcblk0p2): re-mounted cb6f0e18-5add-4177-ab98-e9f0235e06b3 r/w.
              /var:
              3.2G    /var/
              2.1G    /var/log/journal/d50066f22adb471e847d298aee84cf4e
              2.1G    /var/log
              752M    /var/cache
              Archived and active journals take up 2.0G in the file system.
              7.4G    /opt/iobroker/iobroker-data/
              USB-Devices by-id:
              HINT:
              Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
              /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f4ed968b2c3bec118bb49c957a0af07f-if00-port0
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/nodejs         v22.20.0
              /usr/bin/node           v22.20.0
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              /usr/bin/corepack       0.34.0
              nodejs:
                Installed: 22.20.0-1nodesource1
                Version table:
               *** 22.20.0-1nodesource1 1001
              ioBroker Status
                  at Redis.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/build/esm/lib/objects/objectsInRedisClient.js:504:23)
              Hosts:
              js-controller:  7.0.7
              admin:          7.7.2
              javascript:     8.9.2
              Adapter State
                system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                system.adapter.backitup.0               : backitup              : raspberrypi                              - disabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
                system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                system.adapter.esphome.0                : esphome               : raspberrypi                              -  enabled
                system.adapter.ham.0                    : ham                   : raspberrypi                              - disabled
                system.adapter.ham.1                    : ham                   : raspberrypi                              - disabled
                system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
                system.adapter.meross.0                 : meross                : raspberrypi                              - disabled
                system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                system.adapter.mqtt.1                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              - disabled
                system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1886, bind: 0.0.0.0
                system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              -  enabled
                system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
                system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
                system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
                system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
                system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.webui.0                  : webui                 : raspberrypi                              - disabled
                system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_f4ed968b2c3bec118bb49c957a0af07f-if00-port0
              + instance is alive
              /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                      throw e;
              Error: Connection is closed.
                  at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                  at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                  at Object.onceWrapper (node:events:634:26)
                  at Socket.emit (node:events:519:28)
                  at TCP.<anonymous> (node:net:346:12)
              Emitted 'error' event on ScanStream instance at:
                  at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                  at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                  at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
              Node.js v22.20.0
              Objects and States
              Objects:        0
              States:         0
              Pending Updates: 0
              tcp        0      0 0.0.0.0:6052            0.0.0.0:*               LISTEN      1001       11908      1388/python3
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       774        712/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2883       712/iobroker.js-con
              tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       11625      1043/io.shelly.1
              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          604        711/cupsd
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          720        786/smbd
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          721        786/smbd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7810       722/sshd: /usr/sbin
              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          603        711/cupsd
              tcp6       0      0 :::61991                :::*                    LISTEN      1001       11575      1132/io.harmony.0
              tcp6       0      0 :::445                  :::*                    LISTEN      0          718        786/smbd
              tcp6       0      0 :::139                  :::*                    LISTEN      0          719        786/smbd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          7812       722/sshd: /usr/sbin
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11610      1153/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8325       902/io.admin.0
              udp        0      0 192.168.1.255:137       0.0.0.0:*                           0          660        782/nmbd
              udp        0      0 192.168.1.205:137       0.0.0.0:*                           0          659        782/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          647        782/nmbd
              udp        0      0 192.168.1.255:138       0.0.0.0:*                           0          662        782/nmbd
              udp        0      0 192.168.1.205:138       0.0.0.0:*                           0          661        782/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          648        782/nmbd
              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       11576      1132/io.harmony.0
              udp        0      0 0.0.0.0:46182           0.0.0.0:*                           104        2713       591/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11064      1165/io.esphome.0
              udp        0      0 127.0.0.1:5353          0.0.0.0:*                           1001       11916      1388/python3
              udp        0      0 192.168.1.205:5353      0.0.0.0:*                           1001       11915      1388/python3
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11911      1388/python3
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2711       591/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       8590       1004/io.shelly.0
              udp6       0      0 :::50329                :::*                                104        2714       591/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        2712       591/avahi-daemon: r
              2025-09-26 17:23:00.228  - warn: javascript.0 (914)     at Object.<anonymous> (script.js.Sicherungen.DaiylNeu:136:5)
              2025-09-26 17:23:00.228  - warn: javascript.0 (914)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
              2025-09-26 17:23:00.229  - warn: javascript.0 (914)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
              2025-09-26 17:23:00.229  - warn: javascript.0 (914)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
              2025-09-26 17:23:00.229  - warn: javascript.0 (914)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
              2025-09-26 17:23:00.230  - warn: javascript.0 (914)     at listOnTimeout (node:internal/timers:588:17)
              2025-09-26 17:23:00.230  - warn: javascript.0 (914)     at process.processTimers (node:internal/timers:523:7)
              2025-09-26 17:23:00.232  - warn: javascript.0 (914) getState "alias.0.Raum.Kueche.Verbrauch.SteckdoseKuehlschrank.Energie" not found (3) states[id]=null
              2025-09-26 17:23:00.240  - warn: javascript.0 (914)     at EineMinute (script.js.Sicherungen.DaiylNeu:145:28)
              2025-09-26 17:23:00.241  - warn: javascript.0 (914)     at Object.<anonymous> (script.js.Sicherungen.DaiylNeu:136:5)
              2025-09-26 17:23:00.241  - warn: javascript.0 (914)     at Job.job (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1876:34)
              2025-09-26 17:23:00.241  - warn: javascript.0 (914)     at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/Job.js:171:15)
              2025-09-26 17:23:00.242  - warn: javascript.0 (914)     at /opt/iobroker/node_modules/node-schedule/lib/Invocation.js:268:28
              2025-09-26 17:23:00.242  - warn: javascript.0 (914)     at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/Invocation.js:228:7)
              2025-09-26 17:23:00.243  - warn: javascript.0 (914)     at listOnTimeout (node:internal/timers:588:17)
              2025-09-26 17:23:00.243  - warn: javascript.0 (914)     at process.processTimers (node:internal/timers:523:7)
              2025-09-26 17:23:00.713  - info: shelly.1 (1043) [MQTT] Device with client id "shellyplus2pm-08b61fced0e0" connected from 192.168.1.100!
              2025-09-26 17:23:01.320  - info: shelly.1 (1043) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-ecc9ff5f6214 / shellyplus2pm#ecc9ff5f6214#1) (false)
              2025-09-26 17:23:08.326  - warn: esphome.0 (1165) State "esphome.0.C8C9A36467F4.Sensor.255889109.state" has no existing object, this might lead to an error in future versions
              2025-09-26 17:23:09.207  - warn: esphome.0 (1165) Client 192.168.1.158 not yet ready to connect, will try again!
              2025-09-26 17:23:09.797  - warn: esphome.0 (1165) Client 192.168.1.90 not yet ready to connect, will try again!
              2025-09-26 17:23:10.708  - info: shelly.1 (1043) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-08b61fced0e0 / shellyplus2pm#08b61fced0e0#1) (false)
              2025-09-26 17:23:11.791  - warn: esphome.0 (1165) Client 192.168.1.190 not yet ready to connect, will try again!
              2025-09-26 17:23:15.763  - warn: esphome.0 (1165) State "esphome.0.C8C9A36467F4.Sensor.255889109.state" has no existing object, this might lead to an error in future versions
              2025-09-26 17:23:16.628  - info: shelly.1 (1043) [MQTT] Device with client id "shellyplus2pm-a0dd6c4f8134" connected from 192.168.1.178!
                Doch, deine Basis ist jetzt aktuell.
                Dein root-FS läuft dir voll:
                Was sagt
                systemctl status iobroker.service
                  Homoran Global Moderator Administrators @WolfgangFB last edited by
                  klar!
                  der ist auch fast am Anschlag seiner Leistungsfähigkeit
                  mal mit top nachsehen wer da die Leistung frisst, oder ob das nur durch das hochfahren klemmte.
                    @thomas-braun sagte in Wie IO-Broker reparieren?:
                    Was sagt
                    Sorry für die späte Antwort, waR IN uRLAUB:;
                    pi@raspberrypi:~ $ systemctl status iobroker.service
                    * iobroker.service - ioBroker Server
                         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; preset: enabled)
                         Active: active (running) since Fri 2025-09-26 17:16:39 CEST; 1 week 1 day ago
                           Docs: http://iobroker.net
                       Main PID: 712 (iobroker.js-con)
                          Tasks: 149 (limit: 8743)
                            CPU: 1w 1d 9h 49min 12.652s
                         CGroup: /system.slice/iobroker.service
                                 |-  712 iobroker.js-controller
                                 |-  902 io.admin.0
                                 |-  942 io.history.0
                                 |- 1004 io.shelly.0
                                 |- 1011 io.shuttercontrol.0
                                 |- 1043 io.shelly.1
                                 |- 1114 io.echarts.0
                                 |- 1132 io.harmony.0
                                 |- 1133 io.denon.0
                                 |- 1146 io.vis-inventwo.0
                                 |- 1153 io.web.0
                                 |- 1165 io.esphome.0
                                 |- 1388 /home/iobroker/.cache/autopy/venv/esphome/bin/python3 /home/iobroker/.cache/autopy/venv/esphome/bi>
                                 |- 2779 io.mqtt.0
                                 `-52026 /home/iobroker/.cache/autopy/venv/esphome/bin/python3 /home/iobroker/.cache/autopy/venv/esphome/bi>
                    Okt 05 01:10:47 raspberrypi sudo[42166]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                    Okt 05 01:10:47 raspberrypi sudo[42166]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                    Okt 05 01:10:48 raspberrypi sudo[42166]: pam_unix(sudo:session): session closed for user root
                    Okt 05 02:15:54 raspberrypi bash[712]: Send diag info: {"uuid":"eecc0736-e425-7db6-5dde-90171b2147fe","language":"de",">
                    Okt 05 02:15:56 raspberrypi sudo[50236]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
                    Okt 05 02:15:56 raspberrypi sudo[50236]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                    Okt 05 02:15:56 raspberrypi sudo[50236]: pam_unix(sudo:session): session closed for user root
                    Okt 05 02:15:56 raspberrypi sudo[50241]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                    Okt 05 02:15:56 raspberrypi sudo[50241]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                    Okt 05 02:15:58 raspberrypi sudo[50241]: pam_unix(sudo:session): session closed for user root
                    pi@raspberrypi:~ $
                    Hier nachdem das System eine Woche nur vor sich hin gewerkelt hat.
                    top - 13:48:17 up 8 days, 20:31,  2 users,  load average: 1,13, 1,38, 1,53
                    Tasks: 193 total,   2 running, 191 sleeping,   0 stopped,   0 zombie
                    %CPU(s): 40,0 us, 20,0 sy,  0,0 ni, 40,0 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
                    MiB Spch:   7820,8 total,   4550,0 free,   1874,2 used,   1491,5 buff/cache
                    MiB Swap:    200,0 total,    200,0 free,      0,0 used.   5946,6 avail Spch
                        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                      60024 pi        20   0    9476   5100   2928 R 100,0   0,1   0:00.07 top
                        712 iobroker  20   0   11,3g 415680  52684 R 200,0   5,2     5d+1h iobroker.js-con
                       1165 iobroker  20   0   11,2g 232812  49628 S 200,0   2,9     36,22 io.esphome.0
                          1 root      20   0  168972  12068   8596 S   0,0   0,2   0:08.31 systemd
                          2 root      20   0       0      0      0 S   0,0   0,0   0:01.05 kthreadd
                          3 root      20   0       0      0      0 S   0,0   0,0   0:00.00 pool_workqueue_release
                          4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/R-kvfree_rcu_reclaim
                          5 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/R-rcu_gp
                          6 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/R-sync_wq
                          7 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/R-slub_flushwq
                          8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/R-netns
                         12 root      20   0       0      0      0 I   0,0   0,0   0:00.00 kworker/u16:0-ipv6_addrconf
                         13 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 kworker/R-mm_percpu_wq
                         14 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_tasks_kthread
                      Hängt der io.esphome.0 dauerhaft mit 200% Auslastung rum?
                        esphome schwankt zwischen 20% und 100%, iobroker.js-con zwischen 50% und 200%. Javascript ist deaktiviert, wenn ich Javascript aktiviere ist io.javascript.0 bei ca. 20% und iobroker.js-con bei ziemlich konstant 100%
                        81.0k
                        402
