    4. Error i2c adapter after upgrade of node.js version 22
      hschief last edited by
      Dear Folk,
      today I try to upgrade from Node.js 20 to Node.JS 22. After the upgrade I face some serious errors with the i2c adapter, which is a core functionality in my environment. I got the following log, maybe some face the same problem?
      2025-09-29 10:00:13.087 - error: host.node0 Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
      2025-09-29 10:00:13.088 - error: host.node0 Caught by controller[0]: throw err;
      2025-09-29 10:00:13.088 - error: host.node0 Caught by controller[0]: ^
      2025-09-29 10:00:13.089 - error: host.node0 Caught by controller[0]: Error: Could not locate the bindings file. Tried:
      2025-09-29 10:00:13.089 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/build/i2c.node
      2025-09-29 10:00:13.089 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/build/Debug/i2c.node
      2025-09-29 10:00:13.089 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node
      2025-09-29 10:00:13.090 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/out/Debug/i2c.node
      2025-09-29 10:00:13.090 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/Debug/i2c.node
      2025-09-29 10:00:13.090 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/out/Release/i2c.node
      2025-09-29 10:00:13.090 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/Release/i2c.node
      2025-09-29 10:00:13.090 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/build/default/i2c.node
      2025-09-29 10:00:13.091 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/compiled/22.20.0/linux/arm64/i2c.node
      2025-09-29 10:00:13.091 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/addon-build/release/install-root/i2c.node
      2025-09-29 10:00:13.091 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/addon-build/debug/install-root/i2c.node
      2025-09-29 10:00:13.092 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/addon-build/default/install-root/i2c.node
      2025-09-29 10:00:13.092 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/lib/binding/node-v127-linux-arm64/i2c.node
      2025-09-29 10:00:13.092 - error: host.node0 Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
      2025-09-29 10:00:13.092 - error: host.node0 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:4:32)
      2025-09-29 10:00:13.092 - error: host.node0 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
      2025-09-29 10:00:13.093 - error: host.node0 Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
      2025-09-29 10:00:13.093 - error: host.node0 Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
      2025-09-29 10:00:13.093 - error: host.node0 Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
      2025-09-29 10:00:13.094 - error: host.node0 Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
      2025-09-29 10:00:13.094 - error: host.node0 Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
      2025-09-29 10:00:13.094 - error: host.node0 Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
      2025-09-29 10:00:13.094 - error: host.node0 Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
      2025-09-29 10:00:13.095 - error: host.node0 Caught by controller[0]: tries: [
      2025-09-29 10:00:13.095 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/build/i2c.node',
      2025-09-29 10:00:13.096 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/build/Debug/i2c.node',
      2025-09-29 10:00:13.096 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node',
      2025-09-29 10:00:13.097 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/out/Debug/i2c.node',
      2025-09-29 10:00:13.097 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/Debug/i2c.node',
      2025-09-29 10:00:13.097 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/out/Release/i2c.node',
      2025-09-29 10:00:13.098 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/Release/i2c.node',
      2025-09-29 10:00:13.098 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/build/default/i2c.node',
      2025-09-29 10:00:13.098 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/compiled/22.20.0/linux/arm64/i2c.node',
      2025-09-29 10:00:13.099 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/addon-build/release/install-root/i2c.node',
      2025-09-29 10:00:13.099 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/addon-build/debug/install-root/i2c.node',
      2025-09-29 10:00:13.099 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/addon-build/default/install-root/i2c.node',
      2025-09-29 10:00:13.100 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/lib/binding/node-v127-linux-arm64/i2c.node'
      2025-09-29 10:00:13.100 - error: host.node0 Caught by controller[0]: ]
      2025-09-29 10:00:13.100 - error: host.node0 Caught by controller[0]: }
      2025-09-29 10:00:13.101 - error: host.node0 Caught by controller[0]: Node.js v22.20.0
      2025-09-29 10:00:13.101 - error: host.node0 instance system.adapter.i2c.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-09-29 10:03:55.148 - error: host.node0 Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:135
      2025-09-29 10:03:55.149 - error: host.node0 Caught by controller[0]: throw err;
      2025-09-29 10:03:55.149 - error: host.node0 Caught by controller[0]: ^
      2025-09-29 10:03:55.150 - error: host.node0 Caught by controller[0]: Error: Could not locate the bindings file. Tried:
      2025-09-29 10:03:55.150 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/build/i2c.node
      2025-09-29 10:03:55.150 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/build/Debug/i2c.node
      2025-09-29 10:03:55.150 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node
      2025-09-29 10:03:55.151 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/out/Debug/i2c.node
      2025-09-29 10:03:55.151 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/Debug/i2c.node
      2025-09-29 10:03:55.151 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/out/Release/i2c.node
      2025-09-29 10:03:55.151 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/Release/i2c.node
      2025-09-29 10:03:55.152 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/build/default/i2c.node
      2025-09-29 10:03:55.152 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/compiled/22.20.0/linux/arm64/i2c.node
      2025-09-29 10:03:55.152 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/addon-build/release/install-root/i2c.node
      2025-09-29 10:03:55.152 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/addon-build/debug/install-root/i2c.node
      2025-09-29 10:03:55.152 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/addon-build/default/install-root/i2c.node
      2025-09-29 10:03:55.153 - error: host.node0 Caught by controller[0]: → /opt/iobroker/node_modules/i2c-bus/lib/binding/node-v127-linux-arm64/i2c.node
      2025-09-29 10:03:55.153 - error: host.node0 Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:126:9)
      2025-09-29 10:03:55.153 - error: host.node0 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/i2c-bus/i2c-bus.js:4:32)
      2025-09-29 10:03:55.153 - error: host.node0 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1706:14)
      2025-09-29 10:03:55.153 - error: host.node0 Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1839:10)
      2025-09-29 10:03:55.154 - error: host.node0 Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1441:32)
      2025-09-29 10:03:55.154 - error: host.node0 Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1263:12)
      2025-09-29 10:03:55.154 - error: host.node0 Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
      2025-09-29 10:03:55.154 - error: host.node0 Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
      2025-09-29 10:03:55.155 - error: host.node0 Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1463:12)
      2025-09-29 10:03:55.155 - error: host.node0 Caught by controller[0]: at require (node:internal/modules/helpers:147:16) {
      2025-09-29 10:03:55.155 - error: host.node0 Caught by controller[0]: tries: [
      2025-09-29 10:03:55.155 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/build/i2c.node',
      2025-09-29 10:03:55.155 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/build/Debug/i2c.node',
      2025-09-29 10:03:55.156 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node',
      2025-09-29 10:03:55.156 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/out/Debug/i2c.node',
      2025-09-29 10:03:55.156 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/Debug/i2c.node',
      2025-09-29 10:03:55.156 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/out/Release/i2c.node',
      2025-09-29 10:03:55.157 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/Release/i2c.node',
      2025-09-29 10:03:55.157 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/build/default/i2c.node',
      2025-09-29 10:03:55.157 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/compiled/22.20.0/linux/arm64/i2c.node',
      2025-09-29 10:03:55.157 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/addon-build/release/install-root/i2c.node',
      2025-09-29 10:03:55.157 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/addon-build/debug/install-root/i2c.node',
      2025-09-29 10:03:55.158 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/addon-build/default/install-root/i2c.node',
      2025-09-29 10:03:55.158 - error: host.node0 Caught by controller[0]: '/opt/iobroker/node_modules/i2c-bus/lib/binding/node-v127-linux-arm64/i2c.node'
        Thomas Braun Most Active @hschief last edited by Thomas Braun
        @hschief
        No issue on my system:
        $ iobroker add i2c auto --host chet --debug
        NPM version: 11.6.0Installing iobroker.i2c@1.2.1... (System call)
        > node-gyp rebuild
        gyp info using node-gyp@11.2.0
        gyp info using node@24.9.0 | linux | arm64
        gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
        gyp http GET https://nodejs.org/download/release/v24.9.0/node-v24.9.0-headers.tar.gz
        gyp http 200 https://nodejs.org/download/release/v24.9.0/node-v24.9.0-headers.tar.gz
        gyp info spawn /usr/bin/python3
        gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/i2c-bus/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/24.9.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/24.9.0',gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/24.9.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/i2c-bus',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
        gyp info spawn makegyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        CXX(target) Release/obj.target/i2c/src/i2c.o
        SOLINK_MODULE(target) Release/obj.target/i2c.node
        COPY Release/i2c.node
        gyp info ok
        added 14 packages in 33s
        host.chet install adapter i2c
        upload [3] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/build/index.js build/index.js application/javascript
        upload [2] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/i2c.png i2c.png image/png
        upload [0] i2c.admin /opt/iobroker/node_modules/iobroker.i2c/admin/style.css style.css text/css
        host.chet object system.adapter.i2c created/updated
        Updating objects from io-package.json for adapter "i2c" with version "1.2.1"
        host.chet object system.adapter.i2c.0.outputCount created
        host.chet object system.adapter.i2c.0.logLevel created
        host.chet object system.adapter.i2c.0 created
        Process exited with code 0
        Check your environment. First overview with
        iob diag
          Homoran Global Moderator Administrators @hschief last edited by Homoran
          @hschief muss das im englischen Bereich sein?
          Du hast doch sonst alles auf deutsch geschrieben
            hschief @Thomas Braun last edited by
            @thomas-braun thanks, for the fast feedback. Good to know, that it will work in general. I will record an iob diag, I need a few days to do so because I have to upgrade again and I need a time window for this.
            I checked already for node-gyp and this isn't available on my system. Maybe it's not installed by the iob.
            Overall, I checked also the /opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node file. This is available with iobroker permission. Interesting is here that adapter start shows in the log that the file is searched without success.
            Thomas Braun H 2 Replies Last reply Reply Quote 0
              hschief @Homoran last edited by
              @homoran Interessante Frage, ich habe ehrlich gesagt über die Sprache/Forum nicht nachgedacht. Derzeit tendiere ich halt dazu, nur noch in den englischen Foren diese Art von Fragen zu stellen.
              Ganz offen - gibt es eine Empfehlung wann Deutsch und wann Englisch?
                @hschief sagte in Error i2c adapter after upgrade of node.js version 22:
                Deutsch: wenn du (schnell) eine Antwort willst 😂
                99,9% der Posts befinden sich im deutschen Teil.
                und entsprechend wenige lesen den englischen
                  Das ist in einer sauberen Installation von nodejs mit an Bord.
                  Da müsste man halt mal die Ausgabe von
                  iob diag
                  sehen, ob und wo es da klemmen könnte.
                  • mcm1957
                    mcm1957 @Homoran last edited by
                    ABER wenn hier schon auf deutsch gewechselt wird, bitte in den deutschen Bereich verschieben.
                      Homoran Global Moderator Administrators @mcm1957 last edited by
                      @mcm1957 aye!
                        hschief @hschief last edited by
                        @hschief Nun habe ich mal getestet. Zwei einfache Fragen vorweg:
                        1. Muss/Kann ich den Beitrag in den deutschen Zweig verschieben oder macht dies ein Admin?
                        2. Wenn ich hier was gepostet habe, dann kann ich für n-Stunden keinen weiteren Beitrag schreiben. Ich erhalte dann immer Denied. Liegt dies daran, dass ich neu im Forum bin?
                        Nun zu dem Problem. Ich habe nochmals auf Node.JS umgestellt. Dies habe ich mit folgendem Befehl gemacht:
                        iob nodejs-update 22. Der Befehl: node-gyp ist weder unter node.js 20 noch unter 22 zu finden. Alle Aktivitäten führe ich als user: iobroker aus. Der i2c Adapter startet danach nicht (siehe auch log). Als Grund vermute ich, dass er die Datei: i2c.node nicht findet.
                        Im Log finde ich beim boot den folgenden Hinweis, der mit dem Problem evtl. in Zusammenhabg steht: "iobroker npm-rebuild: Rebuilding native modules failed". Dies ist im iob diag nicht zu finden, da der diag wohl nur die letzten 25 Zeilen aus dem Log holt.
                        Wenn ich mit dem Befehl iob nodejs-update 20 auf die node.js zurück gehen, dann ist i2c.node im filesystem zu finden und der Start des Adapters läuft Problemlos.
                        Nun meine Diag Ausgabe:
                        ========== Start marking the full check here ===========
                        ```bash
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                         Static hostname: node0
                               Icon name: computer
                                  Kernel: Linux 6.12.47+rpt-rpi-v8
                            Architecture: arm64
                        OS is similar to:
                        Model		: Raspberry Pi 4 Model B Rev 1.4
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         11:51:02 up 3 min,  4 users,  load average: 2.79, 1.45, 0.57
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** TIME AND TIMEZONES ***
                                       Local time: Tue 2025-09-30 11:51:02 CEST
                                   Universal time: Tue 2025-09-30 09:51:02 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c iotnodes
                        iobroker
                        HOME=/home/iobroker
                        A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                        A root login is not required in most Linux Distributions.
                        Run 'iobroker fix' or use the system tools to create a user.
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server: 	false
                        Unit display-manager.service could not be found.
                        Display-Manager:
                        Desktop:
                        Session: 		tty
                        *** MEMORY ***
                        Mem:            8.2G        1.9G        5.5G         20M        890M        6.3G
                        Swap:           209M          0B        209M
                        Total:          8.4G        1.9G        5.7G
                        Active iob-Instances: 	19
                                 7819 M total memory
                                 1814 M used memory
                                 1957 M active memory
                                  425 M inactive memory
                                 5270 M free memory
                                   81 M buffer memory
                                  767 M swap cache
                                  199 M total swap
                                    0 M used swap
                                  199 M free swap
                        top - 11:51:02 up 3 min,  4 users,  load average: 2.79, 1.45, 0.57
                        Tasks: 220 total,   1 running, 219 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   7819.8 total,   5269.7 free,   1815.0 used,    849.4 buff/cache
                        MiB Swap:    200.0 total,    200.0 free,      0.0 used.   6004.9 avail Mem
                        *** FAILED SERVICES ***
                          UNIT          LOAD   ACTIVE SUB    DESCRIPTION
                        * snmpd.service loaded failed failed Simple Network Management Protocol (SNMP) Daemon.
                        1 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        [sudo] password for iobroker:
                        No critical errors detected
                        *** FILESYSTEM ***
                        udev           devtmpfs  3.6G     0  3.6G   0% /dev
                        tmpfs          tmpfs     1.6G  916K  1.6G   1% /run
                        /dev/sda2      ext4      229G   11G  209G   5% /
                        tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                        /dev/sda1      vfat      253M   87M  166M  35% /boot/firmware
                        log2ram        tmpfs     100M   19M   82M  19% /var/log
                        tmpfs          tmpfs     782M     0  782M   0% /run/user/0
                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
                        tmpfs          tmpfs     782M     0  782M   0% /run/user/1001
                        [Tue Sep 30 11:47:43 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:75:41:3E vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=26bf3cd6-02 rootfstype=ext4 fsck.repair=yes rootwait
                        [Tue Sep 30 11:47:47 2025] EXT4-fs (sda2): mounted filesystem 6a932c1f-7335-42d9-9351-1b1b2ca538d4 ro with ordered data mode. Quota mode: none.
                        [Tue Sep 30 11:47:48 2025] EXT4-fs (sda2): re-mounted 6a932c1f-7335-42d9-9351-1b1b2ca538d4 r/w.
                        Show mounted filesystems:
                        TARGET           SOURCE              FSTYPE OPTIONS
                        /                /dev/sda2           ext4   rw,noatime
                        |-/boot/firmware /dev/sda1           vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                        `-/var/hdd.log   /dev/sda2[/var/log] ext4   rw,noatime
                        /var:
                        1.9G	/var/
                        1.2G	/var/cache/apt
                        1.2G	/var/cache
                        1.1G	/var/cache/apt/archives
                        496M	/var/lib
                        Archived and active journals take up 1.2M in the file system.
                        /opt/iobroker/backups:
                        92M	/opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        516M	/opt/iobroker/iobroker-data/
                        386M	/opt/iobroker/iobroker-data/files
                        97M	/opt/iobroker/iobroker-data/backup-objects
                        67M	/opt/iobroker/iobroker-data/files/echarts.admin
                        61M	/opt/iobroker/iobroker-data/files/echarts
                        28M	/opt/iobroker/iobroker-data/objects.jsonl
                        27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                        26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                        26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                        24M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
                        USB-Devices by-id:
                        No Devices found 'by-id'
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs 	v22.20.0
                        /usr/bin/node 		v22.20.0
                        /usr/bin/npm 		10.9.3
                        /usr/bin/npx 		10.9.3
                        /usr/bin/corepack 	0.34.0
                        nodejs:
                          Installed: 22.20.0-1nodesource1
                          Candidate: 22.20.0-1nodesource1
                          Version table:
                         *** 22.20.0-1nodesource1 1001
                                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                100 /var/lib/dpkg/status
                             22.19.0-1nodesource1 1001
                             22.18.0-1nodesource1 1001
                             22.17.1-1nodesource1 1001
                             22.17.0-1nodesource1 1001
                             22.16.0-1nodesource1 1001
                             22.15.1-1nodesource1 1001
                             22.15.0-1nodesource1 1001
                             22.14.0-1nodesource1 1001
                             22.13.1-1nodesource1 1001
                             22.13.0-1nodesource1 1001
                             22.12.0-1nodesource1 1001
                             22.11.0-1nodesource1 1001
                             22.10.0-1nodesource1 1001
                             22.9.0-1nodesource1 1001
                             22.8.0-1nodesource1 1001
                             22.7.0-1nodesource1 1001
                             22.6.0-1nodesource1 1001
                             22.5.1-1nodesource1 1001
                             22.5.0-1nodesource1 1001
                             22.4.1-1nodesource1 1001
                             22.4.0-1nodesource1 1001
                             22.3.0-1nodesource1 1001
                             22.2.0-1nodesource1 1001
                             22.1.0-1nodesource1 1001
                             22.0.0-1nodesource1 1001
                             18.20.4+dfsg-1~deb12u1 500
                                500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        Checking for nodejs vulnerability:
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        node0               node0 (version: 7.0.7, hostname: node0         , alive, uptime: 200)
                        Core adapters versions
                        js-controller: 	7.0.7
                        admin: 		7.7.2
                        javascript: 	8.9.2
                        nodejs modules from github: 	0
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : node0                                    -  enabled, port: 443, bind: X.X.X.X (SSL), run as: admin
                        + system.adapter.backitup.0               : backitup              : node0                                    -  enabled
                        + system.adapter.echarts.0                : echarts               : node0                                    -  enabled
                        + system.adapter.email.0                  : email                 : node0                                    -  enabled
                          system.adapter.fahrplan.0               : fahrplan              : node0                                    - disabled
                          system.adapter.flot.0                   : flot                  : node0                                    -  enabled
                        + system.adapter.fullybrowser.0           : fullybrowser          : node0                                    -  enabled
                          system.adapter.i2c.0                    : i2c                   : node0                                    -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : node0                                    -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : node0                                    -  enabled
                        + system.adapter.javascript.0             : javascript            : node0                                    -  enabled
                          system.adapter.logparser.0              : logparser             : node0                                    - disabled
                        + system.adapter.mqtt-client.1            : mqtt-client           : node0                                    -  enabled, port: 1883
                        + system.adapter.nina.0                   : nina                  : node0                                    -  enabled
                        + system.adapter.nut.0                    : nut                   : node0                                    -  enabled
                          system.adapter.openweathermap.0         : openweathermap        : node0                                    -  enabled
                          system.adapter.ring.0                   : ring                  : node0                                    - disabled
                        + system.adapter.rpi2.0                   : rpi2                  : node0                                    -  enabled
                        + system.adapter.simple-api.0             : simple-api            : node0                                    -  enabled, port: 8090, bind: X.X.X.X, run as: admin
                        + system.adapter.sma-em.0                 : sma-em                : node0                                    -  enabled
                        + system.adapter.sql.0                    : sql                   : node0                                    -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : node0                                    -  enabled
                        + system.adapter.tibberlink.0             : tibberlink            : node0                                    -  enabled
                          system.adapter.vesync.0                 : vesync                : node0                                    - disabled
                          system.adapter.vis-bars.0               : vis-bars              : node0                                    -  enabled
                          system.adapter.vis-history.0            : vis-history           : node0                                    -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : node0                                    -  enabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : node0                                    -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : node0                                    -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : node0                                    -  enabled
                          system.adapter.vis-justgage.0           : vis-justgage          : node0                                    -  enabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : node0                                    -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : node0                                    -  enabled
                          system.adapter.vis-players.0            : vis-players           : node0                                    -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : node0                                    -  enabled
                          system.adapter.vis-weather.0            : vis-weather           : node0                                    -  enabled
                          system.adapter.vis.0                    : vis                   : node0                                    -  enabled
                        + system.adapter.web.0                    : web                   : node0                                    -  enabled, port: 8080, bind: X.X.X.X (SSL), run as: admin
                        + system.adapter.web.1                    : web                   : node0                                    -  enabled, port: 80, bind: X.X.X.X, run as: web
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Adapters
                        Used repository: stable
                        Adapter    "admin"        : 7.7.2    , installed 7.7.2
                        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                        Adapter    "email"        : 2.0.4    , installed 2.0.4
                        Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
                        Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                        Adapter    "i2c"          : 1.2.1    , installed 1.2.1
                        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                        Controller "js-controller": 7.0.7    , installed 7.0.7
                        Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                        Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                        Adapter    "nut"          : 1.6.0    , installed 1.6.0
                        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                        Adapter    "ring"         : 6.4.0    , installed 6.4.0
                        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                        Adapter    "sma-em"       : 1.3.0    , installed 1.3.0
                        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                        Adapter    "sql"          : 3.0.1    , installed 3.0.1
                        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                        Adapter    "tibberlink"   : 5.0.2    , installed 5.0.2
                        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                        Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                        Adapter    "web"          : 7.0.8    , installed 7.0.8
                        Adapter    "ws"           : 2.6.2    , installed 2.6.2
                        Objects and States
                        Objects: 	4528
                        States: 	3626
                        Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                        Hit:3 http://archive.raspberrypi.org/debian bookworm InRelease
                        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        640        834/mariadbd
                        tcp        0      0 X.X.X.X:22              0.0.0.0:*               LISTEN      0          5815       778/sshd: /usr/sbin
                        tcp        0      0 X.X.X.X:8090       	0.0.0.0:*               LISTEN      1001       10726      1352/io.simple-api.
                        tcp        0      0 X.X.X.X:80           0.0.0.0:*               LISTEN      1001       11364      1337/io.web.1
                        tcp        0      0 X.X.X.X:443          0.0.0.0:*               LISTEN      1001       6004       944/io.admin.0
                        tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      116        791        912/mosquitto
                        tcp        0      0 X.X.X.X:1883         0.0.0.0:*               LISTEN      116        790        912/mosquitto
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1913       713/iobroker.js-con
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1918       713/iobroker.js-con
                        tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          608        743/upsd
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          5826       778/sshd: /usr/sbin
                        tcp6       0      0 :::6329                 :::*                    LISTEN      0          11828      2045/node
                        tcp6       0      0 :::8080                 :::*                    LISTEN      1001       9956       1222/io.web.0
                        udp        0      0 0.0.0.0:41288           0.0.0.0:*                           108        442        556/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        440        556/avahi-daemon: r
                        udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       7419       1177/io.sma-em.0
                        udp6       0      0 :::48065                :::*                                108        443        556/avahi-daemon: r
                        udp6       0      0 :::5353                 :::*                                108        441        556/avahi-daemon: r
                        2025-09-30 11:50:24.953  - error: host.node0 Caught by controller[0]:     at Object..js (node:internal/modules/cjs/loader:1839:10)
                        2025-09-30 11:50:24.953  - error: host.node0 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1441:32)
                        2025-09-30 11:50:24.953  - error: host.node0 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1263:12)
                        2025-09-30 11:50:24.954  - error: host.node0 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                        2025-09-30 11:50:24.954  - error: host.node0 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                        2025-09-30 11:50:24.954  - error: host.node0 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                        2025-09-30 11:50:24.954  - error: host.node0 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16) {
                        2025-09-30 11:50:24.954  - error: host.node0 Caught by controller[0]:   tries: [
                        2025-09-30 11:50:24.955  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/build/i2c.node',
                        2025-09-30 11:50:24.955  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/build/Debug/i2c.node',
                        2025-09-30 11:50:24.955  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/build/Release/i2c.node',
                        2025-09-30 11:50:24.955  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/out/Debug/i2c.node',
                        2025-09-30 11:50:24.956  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/Debug/i2c.node',
                        2025-09-30 11:50:24.956  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/out/Release/i2c.node',
                        2025-09-30 11:50:24.956  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/Release/i2c.node',
                        2025-09-30 11:50:24.956  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/build/default/i2c.node',
                        2025-09-30 11:50:24.957  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/compiled/22.20.0/linux/arm64/i2c.node',
                        2025-09-30 11:50:24.957  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/addon-build/release/install-root/i2c.node',
                        2025-09-30 11:50:24.958  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/addon-build/debug/install-root/i2c.node',
                        2025-09-30 11:50:24.958  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/addon-build/default/install-root/i2c.node',
                        2025-09-30 11:50:24.958  - error: host.node0 Caught by controller[0]:     '/opt/iobroker/node_modules/i2c-bus/lib/binding/node-v127-linux-arm64/i2c.node'
                        2025-09-30 11:50:24.959  - error: host.node0 Caught by controller[0]:   ]
                        2025-09-30 11:50:24.959  - error: host.node0 Caught by controller[0]: }
                        2025-09-30 11:50:24.959  - error: host.node0 Caught by controller[0]: Node.js v22.20.0
                        2025-09-30 11:50:24.960  - error: host.node0 instance system.adapter.i2c.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                          Ist so nicht vorgesehen, leg dir einen User abseits davon an. Oder log dich als user mit der UID=1000 ein. Den gibt es ja laut Log.
                          Was ist denn da los?
                          • snmpd.service loaded failed failed Simple Network Management Protocol (SNMP) Daemon.
                          Und lösch da nix eigenhändig aus den Ausgaben raus. Auch keine IP-Adressen, mit privaten Adressen kann eh niemand was 'böses' anfangen. Man kann aber ggfls. Fehlkonfigurationen sehen.
                          Dann liefer die Ausgabe aus dem vollen Log. Findet sich unter
                          iob logs
                          Ich würde den Adapter mal komplett deinstallieren und dann neu draufwerfen.
                            hab ich, du kannst das nicht.
                            nein, liegt an deinem Browser. Neu laden mit F5 und es geht sofort
                              @thomas-braun .. dann mache ich das morgen nochmals um den vollen Log zu kopieren. Wenn ich den Adapter löschen und neu installieren, verliere ich aber die komplette I2C config richtig? Das sind rund 40 Devices, gibt es eine einfache Möglichkeit die Config zu retten?
                              Homoran mcm1957 2 Replies Last reply Reply Quote 0
                                üblicherweise gibt es in der Instanzenkonfiguration einen Button dafür.
                                ich habe den Adapter nicht.
                                EDIT:
                                2 Buttons! Sorry!
                                • mcm1957
                                  mcm1957 @hschief last edited by mcm1957
                                  @hschief said in Error i2c adapter after upgrade of node.js version 22:
                                  Wenn du den Adapter NICHT löschst sondern nur REINSTALLIERST dann bleibt die Config meines Wissens nach erhalten. Sicher die Konfiguration aber jedenfalls. Reinstallation sollte passieren wenn du auf der Commandline iob url iobroker.i2c@<version> mit der derzeit installierten Version eintipselst. Bei einer Reinstallation erden nur die Codeteile entfernt und neu installiert.
                                    Thomas Braun Most Active @mcm1957 last edited by
                                    @mcm1957
                                    Alternativ:
                                    iob upgrade iobroker.i2c@AKTUELLE_VERSION
                                      @thomas-braun Vielen Dank, ich probiere und melde mich, wird wahrscheinlich am Feiertag passieren. Danke euch allen.
                                        @hschief So, habe gerade nochmal 2 Dinge probiert. Einfach drüber installieren mit iob url iobroker.i2c@1.2.1 zeigt leider das gleiche Ergebnis/gleicher Fehler
                                        Dann habe ich noch node-gyp installiert, mich auf den folder /opt/iobroker/node_modules/i2c-bus/ gesetzt und node-gyp rebuild ausgeführt (war ja etwas weiter oben aufgelistet, keine Ahnung was das macht) Wenn ich das Kommando ausführe, kommen folgende Meldungen: Vielleicht kann einer damit was anfangen. Im nächsten Schritt werde ich den Adapter morgen mal komplett deinstallieren und neu installieren.
                                        iobroker@node0:/opt/iobroker/node_modules/i2c-bus $ node-gyp rebuild
                                        gyp info it worked if it ends with ok
                                        gyp info using node-gyp@11.4.2
                                        gyp info using node@22.20.0 | linux | arm64
                                        gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
                                        gyp info spawn args '/usr/lib/node_modules/node-gyp/gyp/gyp_main.py',
                                        gyp info spawn args 'binding.gyp',
                                        gyp info spawn args '-f',
                                        gyp info spawn args 'make',
                                        gyp info spawn args '/usr/lib/node_modules/node-gyp/addon.gypi',
                                        gyp info spawn args '/home/iobroker/.cache/node-gyp/22.20.0/include/node/common.gypi',
                                        gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.20.0',
                                        gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/node-gyp',
                                        gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.20.0/<(target_arch)/node.lib',
                                        gyp info spawn make
                                        make: Entering directory '/opt/iobroker/node_modules/i2c-bus/build'
                                        In file included from ../src/i2c.cc:2:
                                        ../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, imp::Sig)’:
                                        ../../nan/nan.h:2548:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’
                                         2548 |   tpl->SetAccessor(
                                         2549 |       name
                                         2550 |     , getter_
                                         2551 |     , setter_
                                         2552 |     , obj
                                         2553 |     , settings
                                         2554 |     , attribute
                                         2555 | #if (NODE_MODULE_VERSION < NODE_16_0_MODULE_VERSION)
                                         2556 |     , signature
                                         2557 | #endif
                                         2558 |   );
                                        In file included from /home/iobroker/.cache/node-gyp/22.20.0/include/node/v8-function.h:15,
                                                         from /home/iobroker/.cache/node-gyp/22.20.0/include/node/v8.h:33,
                                                         from /home/iobroker/.cache/node-gyp/22.20.0/include/node/node.h:74,
                                                         from ../src/i2c.cc:1:
                                        /home/iobroker/.cache/node-gyp/22.20.0/include/node/v8-template.h:1049:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’
                                         1049 |   void SetAccessor(
                                        /home/iobroker/.cache/node-gyp/22.20.0/include/node/v8-template.h:1052:61: note:   no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’
                                         1052 |       Local<Value> data = Local<Value>(), PropertyAttribute attribute = None,
                                        /home/iobroker/.cache/node-gyp/22.20.0/include/node/v8-template.h:1055:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’
                                         1055 |   void SetAccessor(
                                        /home/iobroker/.cache/node-gyp/22.20.0/include/node/v8-template.h:1058:61: note:   no known conversion for argument 5 from ‘v8::AccessControl’ to ‘v8::PropertyAttribute’
                                         1058 |       Local<Value> data = Local<Value>(), PropertyAttribute attribute = None,
                                        ../../nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, GetterCallback, SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute)’:
                                        ../../nan/nan.h:2594:19: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&)’
                                         2594 |   tpl->SetAccessor(
                                         2595 |       name
                                         2596 |     , getter_
                                         2597 |     , setter_
                                         2598 |     , obj
                                         2599 |     , settings
                                         2600 |     , attribute
                                         2601 |   );
                                        make: *** [i2c.target.mk:112: Release/obj.target/i2c/src/i2c.o] Error 1
                                        make: Leaving directory '/opt/iobroker/node_modules/i2c-bus/build'
                                        gyp ERR! build error
                                        gyp ERR! stack Error: `make` failed with exit code: 2
                                        gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/node-gyp/lib/build.js:219:23)
                                        gyp ERR! System Linux 6.12.47+rpt-rpi-v8
                                        gyp ERR! command "/usr/bin/node" "/usr/bin/node-gyp" "rebuild"
                                        gyp ERR! cwd /opt/iobroker/node_modules/i2c-bus
                                        gyp ERR! node -v v22.20.0
                                        gyp ERR! node-gyp -v v11.4.2
                                        gyp ERR! not ok
                                          @hschief
                                          Warum nicht mit dem Befehl von mir?
                                            @thomas-braun Hi, der node-gyp rebuild war doch von Dir. Ich habe nur das "add i2c" nicht gemacht, da der Adapter ja schon da ist. Somit hatte ich die Hoffnung das dies reicht.
                                            Ich habe gerade eben den Fehler auch mal einfach ChatGPT vorgeworfen und da kam eine recht interessante Antwort zurück:
                                            Die SetAccessor-Funktion in v8 hat sich mit Node.js 22 stark geändert.
                                            nan versucht, einen alten Funktionsaufruf zu verwenden, der in Node 22 nicht mehr kompatibel ist.
                                            Konkret: v8::ObjectTemplate::SetAccessor akzeptiert jetzt kein v8::AccessControl mehr; nur noch PropertyAttribute und SideEffectType.
                                            Ich bin daher verblüft, dass dies bei Dir unter Node22 läuft. Ich suche morgen mal weiter .... Danke für deine Hilfe, hab ein tollen Abend
                                            1.0k
                                            468
