    4. [Gelöst] [Bug] ZWave stateChange number->string
      A Former User last edited by
      Hallo all,
      ich habe bei mir Fehler im zwave Adapter.
      Ich habe als controler den USB Stick Aeotec AEOEZW090-C Aeon Labs im Einsatz.
      Bei mehreren meiner Fibaro Sensoren habe ich Fehler bei numerischen Werten.
      1.
      Device: FIBARO System FGWPE/F Wall Plug Gen5
      ! "common": {
      ! "name": "FIBARO System FGWPE/F Wall Plug Gen5",
      ! "role": "state"
      ! "native": {
      ! "manufacturer": "FIBARO System",
      ! "manufacturerid": "0x010f",
      ! "product": "FGWPE/F Wall Plug Gen5",
      ! "producttype": "0x0602",
      ! "productid": "0x1001",
      ! "type": "On/Off Power Switch",
      ! "name": "",
      ! "loc": "",
      ! "nodeID": 8
      ! "acl": {
      ! "object": 1636,
      ! "owner": "system.user.admin",
      ! "ownerGroup": "system.group.administrator"
      ! "_id": "zwave.0.NODE8",
      ! "type": "device"
      State: zwave.0.NODE8.SENSOR_MULTILEVEL.Power_1
      ! "common": {
      ! "name": "Power",
      ! "type": "number",
      ! "role": "sensor",
      ! "read": true,
      ! "write": false
      ! "native": {
      ! "value_id": "8-49-1-4",
      ! "node_id": 8,
      ! "class_id": 49,
      ! "type": "decimal",
      ! "genre": "user",
      ! "instance": 1,
      ! "index": 4,
      ! "label": "Power",
      ! "units": "W",
      ! "help": "",
      ! "read_only": true,
      ! "write_only": false,
      ! "min": 0,
      ! "max": 0,
      ! "is_polled": false
      ! "type": "state",
      ! "_id": "zwave.0.NODE8.SENSOR_MULTILEVEL.Power_1",
      ! "acl": {
      ! "object": 1636,
      ! "state": 1636
      Die numerischen Werte werden als string auf den state geschrieben.
      Auszug aus den Events:
      stateChange zwave.0.NODE8.SENSOR_MULTILEVEL.Power_1 "157.1" true zwave.0 2017-10-27 21:03:45.555 2017-10-27 21:03:45.555
      Device: FIBARO System FGK10x Door Opening Sensor
      ! "common": {
      ! "name": "FIBARO System FGK10x Door Opening Sensor",
      ! "role": "state"
      ! "native": {
      ! "nodeID": 14,
      ! "product": "FGK10x Door Opening Sensor",
      ! "producttype": "0x0701",
      ! "type": "Access Control Sensor",
      ! "name": "",
      ! "loc": ""
      ! "type": "device",
      ! "_id": "zwave.0.NODE14",
      ! "acl": {
      ! "object": 1636
      Styte: zwave.0.NODE14.SENSOR_MULTILEVEL.Temperature_1
      ! "common": {
      ! "name": "Temperature",
      ! "type": "number",
      ! "role": "value.temperature",
      ! "read": true,
      ! "write": false
      ! "native": {
      ! "value_id": "14-49-1-1",
      ! "node_id": 14,
      ! "class_id": 49,
      ! "genre": "user",
      ! "instance": 1,
      ! "index": 1,
      ! "label": "Temperature",
      ! "units": "C",
      ! "help": "",
      ! "min": 0,
      ! "max": 0,
      ! "type": "state",
      ! "_id": "zwave.0.NODE14.SENSOR_MULTILEVEL.Temperature_1",
      ! "acl": {
      ! "object": 1636,
      ! "state": 1636
      stateChange zwave.0.NODE14.SENSOR_MULTILEVEL.Temperature_1 "23.12" true zwave.0 2017-10-27 21:03:33.544 2017-10-27 21:03:33.544
      Ein kleiner Test mithilfe des ergab:
      log (typeof getState("zwave.0.NODE14.SENSOR_MULTILEVEL.Temperature_1").val);
      21:15:37.784	[info]	javascript.1 script.js.test.zwave: string
      21:15:37.784	[info]	javascript.1 script.js.test.zwave: registered 0 subscriptions and 0 schedules
      Ist der Bug schon bekannt?
      Hat jemand den Bug bei sich auch?
      Folgende Versionen habe ich laufen:
      ioBroker.zwave: 0.8.0
      ioBroker.js-controller: 1.1.3
      ioBroker.admin: 2.0.9
      • AlCalzone
        Ist mir bei Aeotec-Multisensoren und Fibaro Relais noch nicht aufgefallen, aber schau ich mir morgen mal an.
        Das interessante dabei ist, dass die Werte und Typinformationen eigentlich 1:1 aus dem Treiber übernommen werden.
        Edit: Fibaro Relais (beides als number definiert):
        let x = getState("zwave.0.NODE2.SENSOR_MULTILEVEL.Power_1").val;
        log(typeof x); // => string
        x = getState("zwave.0.NODE2.SWITCH_MULTILEVEL.Level_1").val;
        log(typeof x); // => number
          Pman last edited by
          @AlCalzone:
          Das interessante dabei ist, dass die Werte und Typinformationen eigentlich 1:1 aus dem Treiber übernommen werden. `
          Ich konnte den Fehler bei mir jetzt auch feststellen, anscheinend kommen von OZW teilweise Strings statt Floats an, die dann auch im State landen. Ich habe einen Pull-Request erstellt, leider keine Zeit zum Testen :roll: .
          Gerne mal von hier installieren und testen:
          https://github.com/Pmant/ioBroker.zwave/tree/patch-1
          • AlCalzone
            Für existierende Objekte funktioniert der Fix (sie werden mit dem korrekten State aktualisiert). Neue Objekte werden noch falsch angelegt. Ich probiere mal, wie man das allgemeiner lösen kann.
            • AlCalzone
              Ursache gefunden:
              https://github.com/OpenZWave/node-openz … ils.cc#L90
              Für decimal-Werte gibt node-openzwave-shared strings zurück. Fixed in 0.9.0
                Fehler tritt mit Version 0.9.0 nicht mehr auf.
                -> Gelöst
                1.0k
                81.0k
