    4. SONOFF NSPanel mit Lovelace UI 4.7.12 --> 5.0.0.1
      mschmidt last edited by mschmidt
      SONOFF NSPanel mit Lovelace UI - Scriptupdate 4.7.12 --> 5.0.0.1
      Hi, nachdem ja Accuwetter keinen free Account mehr anbietet, wollte ich auch das Script auf die aktuelle Version anpassen.
      Nach einigen Schwierigkeiten mit der TFT Firmware sehe ich am Panel wieder die Serviceseite. Nachdem Start des Scripts läuft einstmal der MQTT Check:
      javascript.0 12:13:03.650 info Compiling TypeScript source script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001
      javascript.0 12:13:04.605 info source code did not change, using cached compilation result...
      javascript.0 12:13:04.960 info --- start of NsPanelTs: 0_userdata.0.NSPanels.NSPanel-UG-KZ. ---
      javascript.0 12:13:05.067 info setObjects enabled - create Alias Channels possible
      javascript.0 12:13:05.069 info weather alias for pirate-weather.0. already exists
      javascript.0 12:13:05.097 info registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      javascript.0 12:13:05.100 info No Updates for NSPanel available
      javascript.0 12:13:05.303 info Desired TFT Firmware: 59 / v5.0.0
      javascript.0 12:13:05.303 info Installed TFT Firmware: 59 / v5.0.0
      javascript.0 12:13:05.467 info Debug mode disabled
      javascript.0 12:13:06.548 info Desired TFT Firmware: 59 / v5.0.0
      javascript.0 12:13:06.549 info Installed TFT Firmware: 59 / v5.0.0
      javascript.0 12:13:06.673 info hidden Cards disabled
      javascript.0 12:13:08.286 info Start MQTT-Port-Check -------------------------------------
      javascript.0 12:13:08.286 info -- admin.0 - 8081
      javascript.0 12:13:08.286 info -- hm-rpc.0 - 1870
      javascript.0 12:13:08.286 info -- hm-rpc.1 - 1200
      javascript.0 12:13:08.286 info -- hm-rpc.2 - 1201
      javascript.0 12:13:08.286 info -- hue.0 - 443
      javascript.0 12:13:08.286 info -- influxdb.0 - 8086
      javascript.0 12:13:08.286 info -- mqtt.0 - 1887
      javascript.0 12:13:08.286 info -- node-red.0 - 1880
      javascript.0 12:13:08.286 info -- shelly.0 - 1886
      javascript.0 12:13:08.286 info -- telegram.0 - 8443
      javascript.0 12:13:08.286 info -- web.0 - 8082
      javascript.0 12:13:08.287 info - MQTT-Port-Check OK: Instance of Adapter: mqtt.0 is running on Port:1887
      javascript.0 12:13:08.287 info End MQTT-Port-Check ---------------------------------------
      Leider kommen dann nach einer kurzen Pause jede Menge Warnungen:
      javascript.0 12:13:35.143 warn at HandleScreensaverUpdate (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:14315:31)
      javascript.0 12:13:35.143 warn at Object.<anonymous> (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:4226:17)
      javascript.0 12:13:35.143 warn at step (script.js.NSPANELS.NSPanel-UG-KZ.NSPanel-UG-KZv5001:33:23)
      usw.
      Ich habe dann versucht noch meine Pages aus dem alten Script wieder einzufügen. Leider ohne Erfolg! Wird nur das Servicemenü angezeigt.
      Bin für jeden Hinweis dankbar.
      VG MS
        TT-Tom @mschmidt last edited by
        @mschmidt
        Bitte log Ausgabe in Code-Tags packen.
        Das Script ohne deine Seiten lief sauber?
        Hast du den Screensaver angepasst bzw. geändert.
        Zeige mal deine Konfiguration.
          TT-Tom last edited by
          @Homoran
          Wir können das hier schließen, wird im offiziellen Thread bearbeitet.
