    4. Proxmox
    5. Proxmox WebIf nicht erreichbar
    • Negalein
      Hallo
      Ich hab hier 2 Proxmox-Server, die nicht über https://IP:8006 erreichbar sind.
      SSH funktioniert.
      Kann mir bitte jemand weiterhelfen?
      ip addr liefert:
      1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
          link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
          inet 127.0.0.1/8 scope host lo
             valid_lft forever preferred_lft forever
          inet6 ::1/128 scope host
      2: enp0s31f6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master vmbr0 state UP group default qlen 1000
          link/ether 6c:4b:90:43:c9:19 brd ff:ff:ff:ff:ff:ff
      3: vmbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
          inet 10.0.1.206/24 scope global vmbr0
          inet6 fe80::6e4b:90ff:fe43:c919/64 scope link
      route -n liefert:
      Kernel IP routing table
      Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
      0.0.0.0         10.0.1.1        0.0.0.0         UG    0      0        0 vmbr0
      10.0.1.0        0.0.0.0         255.255.255.0   U     0      0        0 vmbr0
      netstat -an | grep LISTEN liefert:
      tcp        0      0 127.0.0.1:85            0.0.0.0:*               LISTEN
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
      tcp6       7      0 :::8006                 :::*                    LISTEN
      tcp6       0      0 :::111                  :::*                    LISTEN
      tcp6       0      0 :::22                   :::*                    LISTEN
      tcp6       0      0 ::1:25                  :::*                    LISTEN
      tcp6       0      0 :::3128                 :::*                    LISTEN
      unix  2      [ ACC ]     STREAM     LISTENING     25951    public/qmgr
      unix  2      [ ACC ]     STREAM     LISTENING     25955    private/tlsmgr
      unix  2      [ ACC ]     STREAM     LISTENING     25958    private/rewrite
      unix  2      [ ACC ]     STREAM     LISTENING     25961    private/bounce
      unix  2      [ ACC ]     STREAM     LISTENING     21823    /run/watchdog-mux.sock
      unix  2      [ ACC ]     STREAM     LISTENING     25964    private/defer
      unix  2      [ ACC ]     STREAM     LISTENING     25967    private/trace
      unix  2      [ ACC ]     STREAM     LISTENING     25970    private/verify
      unix  2      [ ACC ]     STREAM     LISTENING     25973    public/flush
      unix  2      [ ACC ]     STREAM     LISTENING     25976    private/proxymap
      unix  2      [ ACC ]     STREAM     LISTENING     25979    private/proxywrite
      unix  2      [ ACC ]     STREAM     LISTENING     25982    private/smtp
      unix  2      [ ACC ]     STREAM     LISTENING     25985    private/relay
      unix  2      [ ACC ]     STREAM     LISTENING     25988    public/showq
      unix  2      [ ACC ]     STREAM     LISTENING     25991    private/error
      unix  2      [ ACC ]     STREAM     LISTENING     53006    /run/user/0/systemd/private
      unix  2      [ ACC ]     STREAM     LISTENING     25994    private/retry
      unix  2      [ ACC ]     STREAM     LISTENING     25997    private/discard
      unix  2      [ ACC ]     STREAM     LISTENING     53012    /run/user/0/gnupg/S.dirmngr
      unix  2      [ ACC ]     STREAM     LISTENING     26000    private/local
      unix  2      [ ACC ]     STREAM     LISTENING     53014    /run/user/0/gnupg/S.gpg-agent.browser
      unix  2      [ ACC ]     STREAM     LISTENING     26003    private/virtual
      unix  2      [ ACC ]     STREAM     LISTENING     53016    /run/user/0/gnupg/S.gpg-agent.extra
      unix  2      [ ACC ]     STREAM     LISTENING     26006    private/lmtp
      unix  2      [ ACC ]     STREAM     LISTENING     53018    /run/user/0/gnupg/S.gpg-agent.ssh
      unix  2      [ ACC ]     STREAM     LISTENING     26009    private/anvil
      unix  2      [ ACC ]     STREAM     LISTENING     53020    /run/user/0/gnupg/S.gpg-agent
      unix  2      [ ACC ]     STREAM     LISTENING     26012    private/scache
      unix  2      [ ACC ]     STREAM     LISTENING     26018    private/maildrop
      unix  2      [ ACC ]     STREAM     LISTENING     26021    private/uucp
      unix  2      [ ACC ]     STREAM     LISTENING     26024    private/ifmail
      unix  2      [ ACC ]     STREAM     LISTENING     26027    private/bsmtp
      unix  2      [ ACC ]     STREAM     LISTENING     26030    private/scalemail-backend
      unix  2      [ ACC ]     STREAM     LISTENING     26033    private/mailman
      unix  2      [ ACC ]     STREAM     LISTENING     21981    @lxc/ad055575fe28ddd5//var/lib/lxc
      unix  2      [ ACC ]     STREAM     LISTENING     13201    /run/systemd/private
      unix  2      [ ACC ]     STREAM     LISTENING     13203    /run/systemd/userdb/io.systemd.DynamicUser
      unix  2      [ ACC ]     STREAM     LISTENING     13204    /run/systemd/io.system.ManagedOOM
      unix  2      [ ACC ]     STREAM     LISTENING     26884    /var/run/rrdcached.sock
      unix  2      [ ACC ]     STREAM     LISTENING     13214    /run/lvm/lvmpolld.socket
      unix  2      [ ACC ]     STREAM     LISTENING     13216    /run/rpcbind.sock
      unix  2      [ ACC ]     STREAM     LISTENING     13230    /run/systemd/fsck.progress
      unix  2      [ ACC ]     STREAM     LISTENING     13238    /run/systemd/journal/stdout
      unix  2      [ ACC ]     SEQPACKET  LISTENING     13240    /run/udev/control
      unix  2      [ ACC ]     STREAM     LISTENING     15200    /run/systemd/journal/io.systemd.journal
      unix  2      [ ACC ]     STREAM     LISTENING     25824    @ISCSIADM_ABSTRACT_NAMESPACE
      unix  2      [ ACC ]     STREAM     LISTENING     21743    /run/dbus/system_bus_socket
      unix  2      [ ACC ]     STREAM     LISTENING     26725    /var/run/qmeventd.sock
      unix  2      [ ACC ]     SEQPACKET  LISTENING     26731    /run/pve/lxc-syscalld.sock
      unix  2      [ ACC ]     STREAM     LISTENING     25944    public/pickup
      unix  2      [ ACC ]     STREAM     LISTENING     25948    public/cleanup
      netstat -an | grep -e "tcp" liefert:
      tcp        0      0 10.0.1.206:22           10.0.1.31:36908         ESTABLISHED
      tcp        0     48 10.0.1.206:22           10.0.1.31:36907         ESTABLISHED
      tcp6    1798      0 10.0.1.206:8006         10.0.1.31:11184         CLOSE_WAIT
      tcp6    1702      0 10.0.1.206:8006         10.0.1.31:60025         CLOSE_WAIT
      tcp6    1702      0 10.0.1.206:8006         10.0.1.31:60024         CLOSE_WAIT
      tcp6    1798      0 10.0.1.206:8006         10.0.1.31:53190         CLOSE_WAIT
      tcp6    1766      0 10.0.1.206:8006         10.0.1.31:11179         CLOSE_WAIT
      tcp6    1798      0 10.0.1.206:8006         10.0.1.31:11178         CLOSE_WAIT
      tcp6    1798      0 10.0.1.206:8006         10.0.1.31:53189         CLOSE_WAIT
      pveversion
      pve-manager/7.2-3/c743d6c1 (running kernel: 5.15.30-2-pve)
      uweklatt 1 Reply Last reply Reply Quote 0
      • uweklatt
        uweklatt @Negalein last edited by
        @negalein
        Zumindest mit IPv6 sollte es klappen.
        Tschau
        Uwe
        • Negalein
          Negalein Global Moderator @uweklatt last edited by
          @uweklatt sagte in Proxmox WebIf nicht erreichbar:
          gibts bei mir nicht 😉
          uweklatt BananaJoe 2 Replies Last reply Reply Quote 0
          • uweklatt
            @negalein
            vmbr0 hat eine IPv6 Adresse unter der Du die Weboberfläche ansprechen kannst...
            Tschau
            Uwe
            • BananaJoe
              BananaJoe Most Active @Negalein last edited by
              @negalein zeig mal den Inhalt deiner Netzwerkkonfigurationsdatei, per ssh per
              cat /etc/network/interfaces
              • BananaJoe
                und wenn du vorher an nichts herumgefummelt hattest, z.B. am Netzwerk, kann es reichen den Dienst dafür einmal neu zu starten:
                systemctl restart pveproxy.service
                Zufällig komme ich frisch vom Proxmox-Kursus ...
                crunchip 1 Reply Last reply Reply Quote 1
                • Negalein
                  Negalein Global Moderator @BananaJoe last edited by
                  @bananajoe sagte in Proxmox WebIf nicht erreichbar:
                  auto lo
                  iface lo inet loopback
                  iface enp0s31f6 inet manual
                  auto vmbr0
                  iface vmbr0 inet static
                          address 10.0.1.206/24
                          gateway 10.0.1.1
                          bridge-ports enp0s31f6
                          bridge-stp off
                          bridge-fd 0
                  nur das Netzwerk von 255.255.255.0 auf 255.255.254.0 erweitert
                  keine Besserung
                  • BananaJoe
                    @negalein
                    255.255.254.0
                    Das wäre ja 10.0.0.1 - 10.0.1.254
                    Du hattest auch auf übernehmen geklickt?
                    Gibt es zufällig auch eine
                    cat /etc/network/interfaces.new
                    ? Die würde er beim nächsten Neustart erst übernehmen (oder du klickst auf in der GUI auf Übernehmen oder per CLI Befehl den ich erst raussuchen müsste)
                    Was für eine IP hat dein Rechner? Was du gepostet hast läuft noch mit der 24 Maske.
                    • Negalein
                      ja
                      wo?
                      In der Fritz ist 255.255.254.0 schon länger eingerichtet.
                      Copy to Clipboardcat /etc/network/interfaces.new
                      nein
                      cat: /etc/network/interfaces.new: No such file or directory
                      10.0.1.206
                      • BananaJoe
                        @negalein sagte in Proxmox WebIf nicht erreichbar:
                        ja
                        wo?
                        In Proxmox bei der Netzwerkkonfiguration.
                        Deine Server sind jedenfalls noch auf /24
                        Dienst neu starten hat nichts gebracht?
                        Negalein 2 Replies Last reply Reply Quote 0
                        • Negalein
                          ah, ok.
                          ich komm nicht in die GUI.
                          Bildschirm hab ich keinen.
                          Geht das auch per CLI?
                          nein, leider nicht.
                          richtig wärre /32?
                          • Negalein
                            Negalein Global Moderator @BananaJoe last edited by Negalein
                            würde es reichen, mit nano /etc/network/interfaces die IP zu ändern? In /??
                            auto lo
                            auto vmbr0
                                    gateway 10.0.1.1
                                    bridge-stp off
                                    bridge-fd 0
                            gerade gefunden.
                            müsste /23 lauten?
                            https://www.calculator.net/ip-subnet-calculator.html?cclass=any&csubnet=23&cip=10.0.0.1&ctype=ipv4&x=Calculate
                            • BananaJoe
                              @negalein neustart des dienstes geht auch per ssh, mach das erst einmal und schau ob es dann wieder geht-
                              Dann die maske ändern auf 23 und auf übernehmen klicken (per gui)
                              • Negalein
                                mit systemctl restart pveproxy.service Dienst neu gestartet.
                                https://10.0.1.206:8006 geht noch nicht
                                Auf die GUI komm ich nicht 😞
                                • crunchip
                                  crunchip Forum Testing Most Active @BananaJoe last edited by
                                  @bananajoe oder generell mal den status abrufen
                                  systemctl status pveproxy.service
                                  beide so aus heiterem Himmel?
                                  • Negalein
                                    Negalein Global Moderator @crunchip last edited by
                                    @crunchip sagte in Proxmox WebIf nicht erreichbar:
                                    ● pveproxy.service - PVE API Proxy Server
                                         Loaded: loaded (/lib/systemd/system/pveproxy.service; enabled; vendor preset: enabled)
                                         Active: active (running) since Sat 2025-10-11 23:22:10 CEST; 20min ago
                                        Process: 24072 ExecStartPre=/usr/bin/pvecm updatecerts --silent (code=exited, status=111)
                                        Process: 24074 ExecStart=/usr/bin/pveproxy start (code=exited, status=0/SUCCESS)
                                       Main PID: 24075 (pveproxy)
                                          Tasks: 4 (limit: 18839)
                                         Memory: 132.5M
                                            CPU: 21.903s
                                         CGroup: /system.slice/pveproxy.service
                                                 ├─24075 pveproxy
                                                 ├─25151 pveproxy worker
                                                 ├─25152 pveproxy worker
                                                 └─25153 pveproxy worker
                                    Oct 11 23:42:38 pve pveproxy[24075]: worker 25143 finished
                                    Oct 11 23:42:38 pve pveproxy[24075]: worker 25151 started
                                    Oct 11 23:42:38 pve pveproxy[25151]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                    Oct 11 23:42:38 pve pveproxy[25144]: worker exit
                                    Oct 11 23:42:38 pve pveproxy[24075]: worker 25144 finished
                                    Oct 11 23:42:38 pve pveproxy[24075]: starting 2 worker(s)
                                    Oct 11 23:42:38 pve pveproxy[24075]: worker 25152 started
                                    Oct 11 23:42:38 pve pveproxy[24075]: worker 25153 started
                                    Oct 11 23:42:38 pve pveproxy[25152]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                    Oct 11 23:42:38 pve pveproxy[25153]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                    Nein, die lagen Monate (vor der Erweiterung auf 255.255.254.0) in der Schublade.
                                    Heute wollte ich sie wieder in Betrieb nehmen.
                                    • crunchip
                                      crunchip Forum Testing Most Active @Negalein last edited by
                                      möglicherweise ist das dein Problem
                                      https://web-wilke.de/fix-proxmox-error-after-hostname-ip-change
                                      • Negalein
                                        ich werde das probieren.
                                        komisch, da es mit 255.255.255.0 ging.
                                        • crunchip
                                          crunchip Forum Testing Most Active @Negalein last edited by crunchip
                                          Ja das kommt durch deine Änderung, sollte aber wieder verschwinden. Wenn...
                                          Zitat perplexity
                                          Nach einer Änderung des Netzwerks auf die Subnetzmaske 255.255.254.0 (statt bisher 255.255.255.0) im Bereich von Proxmox ist die Weboberfläche nicht erreichbar – das Problem bleibt bestehen, selbst nach Neustart des pveproxy-Dienstes�.Ursache: Netzwerkbereich und RoutingDie Änderung auf 255.255.254.0 bedeutet ein Subnetz von 10.0.0.1 bis 10.0.1.254�. Die Ausgabe von ip addr und der Inhalt von /etc/network/interfaces zeigen aber weiterhin die Konfiguration mit /24 (also 255.255.255.0) für die IP-Adresse auf vmbr0:address 10.0.1.206/24Die Routingtabelle (route -n) zeigt Netze mit Maske /24 und Gateway im Netz 10.0.1.1�.Dadurch passt die Netzmaske der Proxmox-Konfiguration nicht zum neuen Bereich, den das restliche Netzwerk (z.B. FritzBox) vorgibt.Lösung: Netzmaske und NeustartDie Netzwerkkonfiguration in /etc/network/interfaces muss an die neue Subnetzmaske angepasst werden:Ändern von address 10.0.1.206/24 auf address 10.0.1.206/23/23 entspricht 255.255.254.0
                                          Beispiel für /etc/network/interfaces:auto vmbr0
                                          gateway 10.0.1.1
                                          bridge-stp off
                                          bridge-fd 0
                                          Danach Netzwerkdienst neu starten:systemctl restart networking
                                          systemctl restart pveproxy.serviceAlternativ kann der Server einmal neu gestartet werden�.Zusätzliche HinweiseNach Änderung der Netzwerkkonfiguration muss die Änderung übernommen werden – per CLI geht das direkt nach Editieren und Dienst-Neustart�.Prüfe, ob die neue Konfiguration tatsächlich aktiv ist mit ip addr und route -n (dort sollte die neue Maske zu sehen sein)�.Stelle sicher, dass die eigene Workstation/PC ebenfalls eine IP im Bereich 10.0.0.x oder 10.0.1.x mit Maske 255.255.254.0 hat.ZusammenfassungDas Problem liegt darin, dass die Proxmox-Netzwerkkonfiguration noch mit 255.255.255.0 läuft, während im restlichen Netzwerk bereits 255.255.254.0 genutzt wird. Die Lösung ist die Anpassung der Netzmaske in /etc/network/interfaces auf /23 und ein Neustart des Netzwerkdienstes, damit die Weboberfläche wieder erreichbar wird�.
                                          Negalein 2 Replies Last reply Reply Quote 1
                                          • Negalein
                                            ich hab mit nano /etc/network/interfaces das File editiert.
                                            auto lo
                                            auto vmbr0
                                                    gateway 10.0.1.1
                                                    bridge-stp off
                                                    bridge-fd 0
                                            dann mit systemctl restart pveproxy.service den Service neu gestartet.
                                                 Active: active (running) since Sun 2025-10-12 13:34:15 CEST; 7min ago
                                                Process: 69400 ExecStartPre=/usr/bin/pvecm updatecerts --silent (code=exited, status=111)
                                                Process: 69402 ExecStart=/usr/bin/pveproxy start (code=exited, status=0/SUCCESS)
                                               Main PID: 69403 (pveproxy)
                                                 Memory: 132.8M
                                                    CPU: 9.075s
                                                         ├─69403 pveproxy
                                                         ├─69820 pveproxy worker
                                                         ├─69821 pveproxy worker
                                                         └─69822 pveproxy worker
                                            Oct 12 13:42:03 pve pveproxy[69403]: starting 2 worker(s)
                                            Oct 12 13:42:03 pve pveproxy[69403]: worker 69820 started
                                            Oct 12 13:42:03 pve pveproxy[69403]: worker 69821 started
                                            Oct 12 13:42:03 pve pveproxy[69818]: worker exit
                                            Oct 12 13:42:03 pve pveproxy[69820]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                            Oct 12 13:42:03 pve pveproxy[69821]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                            Oct 12 13:42:03 pve pveproxy[69403]: worker 69818 finished
                                            Oct 12 13:42:03 pve pveproxy[69403]: starting 1 worker(s)
                                            Oct 12 13:42:03 pve pveproxy[69403]: worker 69822 started
                                            Oct 12 13:42:03 pve pveproxy[69822]: /etc/pve/local/pve-ssl.key: failed to load local private key (key_file or key) at /usr/share/perl5/PVE/APIServer/AnyEvent.pm line 1917.
                                            ip addr & route -n zeiigt aber noch
                                            81.1k
                                            1340
