    4. npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie
    • meute
      meute last edited by
      ich habe nach der Top-Anleitung das Debian-Upgrade von 12 bookworm zu 13 trixie gemacht.
      Es hat soweit geklappt.
      Aber ich erhalte bei iob diag einen npm error.
      Wie kann ich den Fehler beheben?
      $ iob diag
      [sudo] Passwort für mf:
      *** iob diag is starting up, please wait ***
      npm error code ELSPROBLEMS
      npm error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
      npm error missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
      npm error missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
      npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
      npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
      npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
      npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
      npm error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      * Some output is masked. For full results please use 'iob diag --unmask' *
      Press any key to continue
      ========== Start marking the full check here ===========
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: iobroker84
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.14.11-3-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       11:42:36 up 3 min,  1 user,  load average: 0.80, 1.12, 1.01
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Sun 2025-10-12 11:42:36 CEST
                 Universal time: Sun 2025-10-12 09:42:36 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      mf
      HOME=/home/mf
      GROUPS=mf adm sudo users iobroker lxc_shares
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/mf
      GROUPS=iobroker tty dialout audio video plugdev lxc_shares
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            4.3G        1.3G        2.6G        3.9M        470M        3.0G
      Swap:           536M          0B        536M
      Total:          4.8G        1.3G        3.1G
      Active iob-Instances:   15
               4096 M total memory
               1203 M used memory
               1449 M active memory
                127 M inactive memory
               2446 M free memory
                  0 M buffer memory
                449 M swap cache
                512 M total swap
                  0 M used swap
                512 M free swap
      top - 11:42:37 up 3 min,  1 user,  load average: 0.80, 1.12, 1.01
      Tasks:  52 total,   1 running,  51 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  4.0 us,  4.0 sy,  0.0 ni, 88.0 id,  4.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   4096.0 total,   2445.0 free,   1205.2 used,    449.4 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2890.8 avail Mem
      *** FAILED SERVICES ***
        UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
      * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
      Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
              ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
              SUB    -> The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                                  Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--100--disk--0            ext4       12G  7.7G  3.5G  70% /
      //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs      467G   51G  416G  11% /mnt/nas8
      none                                        tmpfs     492K  4.0K  488K   1% /dev
      udev                                        devtmpfs  9.7G     0  9.7G   0% /dev/tty
      tmpfs                                       tmpfs     9.7G     0  9.7G   0% /dev/shm
      tmpfs                                       tmpfs     3.9G  3.3M  3.9G   1% /run
      tmpfs                                       tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs                                       tmpfs     9.7G  460K  9.7G   1% /tmp
      tmpfs                                       tmpfs     2.0G  8.0K  2.0G   1% /run/user/1000
      Show mounted filesystems:
      TARGET      SOURCE                                      FSTYPE OPTIONS
      /           /dev/mapper/pve-vm--100--disk--0            ext4   rw,relatime,stripe=16
      `-/mnt/nas8 //192.168.23.8/FRITZ.NAS/CT500MX5-00SSD1-01 cifs   rw,relatime,vers=3.0,cache=strict,upcall_target=app,username=fritznas,uid=100000,forceuid,gid=110000,forcegid,addr=192.168.23.8,file_mode=0770,dir_mode=0770,soft,nounix,mapposix,reparse=nfs,nativesocket,symlink=native,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      /var:
      2.7G    /var/
      1.3G    /var/log/journal
      1.3G    /var/log
      1.2G    /var/cache/apt
      1.2G    /var/cache
      Archived and active journals take up 1G in the file system.
      /opt/iobroker/backups:
      69M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      369M    /opt/iobroker/iobroker-data/
      300M    /opt/iobroker/iobroker-data/files
      67M     /opt/iobroker/iobroker-data/files/echarts.admin
      61M     /opt/iobroker/iobroker-data/files/echarts
      53M     /opt/iobroker/iobroker-data/backup-objects
      26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
      26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
      18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.20.0
      /usr/bin/node           v22.20.0
      /usr/bin/npm            11.6.2
      /usr/bin/npx            11.6.2
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.20.0-1nodesource1
        Candidate: 22.20.0-1nodesource1
        Version table:
       *** 22.20.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      Checking for nodejs vulnerability:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker84          iobroker84 (version: 7.0.7, hostname: iobroker84    , alive, uptime: 183)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     8.9.2
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker84                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alias-manager.0          : alias-manager         : iobroker84                               - disabled
      + system.adapter.backitup.0               : backitup              : iobroker84                               -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker84                               -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker84                               -  enabled
        system.adapter.ical.0                   : ical                  : iobroker84                               -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker84                               -  enabled, port: 8086
      + system.adapter.iqontrol.0               : iqontrol              : iobroker84                               -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker84                               -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker84                               -  enabled
        system.adapter.ping.0                   : ping                  : iobroker84                               - disabled
      + system.adapter.shelly.0                 : shelly                : iobroker84                               -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : iobroker84                               -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : iobroker84                               -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker84                               -  enabled
      + system.adapter.web.0                    : web                   : iobroker84                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker84                               -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "discovery"    : 5.0.0    , installed 5.0.0
      Adapter    "echarts"      : 1.9.2    , installed 1.9.2
      Adapter    "ical"         : 1.17.0   , installed 1.17.0
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "shelly"       : 10.2.0   , installed 10.2.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        1346
      States:         1056
      W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://security.debian.org trixie-security InRelease
      Hit:4 https://repos.influxdata.com/debian stable InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30392745   277/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30392287   277/iobroker.js-con
      tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          30392581   264/smbd
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          30390652   1/init
      tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          30392580   264/smbd
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       30393200   450/io.sonoff.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       30392832   313/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30396478   525/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        30392118   192/influxd
      tcp6       0      0 :::139                  :::*                    LISTEN      0          30392579   264/smbd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          30390654   1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          30391102   1/init
      tcp6       0      0 :::445                  :::*                    LISTEN      0          30392578   264/smbd
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          30390653   1/init
      udp        0      0 192.168.23.255:137      0.0.0.0:*                           0          30392381   222/nmbd
      udp        0      0 192.168.23.84:137       0.0.0.0:*                           0          30392380   222/nmbd
      udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          30392368   222/nmbd
      udp        0      0 192.168.23.255:138      0.0.0.0:*                           0          30392383   222/nmbd
      udp        0      0 192.168.23.84:138       0.0.0.0:*                           0          30392382   222/nmbd
      udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          30392369   222/nmbd
      udp        0      0 192.168.23.84:5353      0.0.0.0:*                           1001       30396440   495/io.tr-064.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       30393134   430/io.shelly.0
      udp6       0      0 :::111                  :::*                                0          30390655   1/init
      2025-10-12 11:40:23.767  - info: host.iobroker84 instance system.adapter.web.0 in version "7.0.8" started with pid 525
      2025-10-12 11:40:25.537  - info: web.0 (525) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v22.20.0, js-controller: 7.0.7
      2025-10-12 11:40:25.795  - info: web.0 (525) socket.io server listening on port 8082
      2025-10-12 11:40:25.799  - info: web.0 (525) http server listening on port 8082
      2025-10-12 11:40:27.762  - info: host.iobroker84 instance system.adapter.iqontrol.0 in version "3.0.0" started with pid 540
      2025-10-12 11:40:29.125  - info: iqontrol.0 (540) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.iqontrol, node: v22.20.0, js-controller: 7.0.7
      2025-10-12 11:40:29.169  - info: iqontrol.0 (540) systemLanguage = de
      2025-10-12 11:40:29.170  - info: iqontrol.0 (540) Creating Passphrase...
      2025-10-12 11:40:29.217  - info: iqontrol.0 (540) Creating Popup States...
      2025-10-12 11:40:29.290  - info: iqontrol.0 (540) Creating Widget States...
      2025-10-12 11:40:29.291  - info: iqontrol.0 (540) Lists deactivated.
      2025-10-12 11:40:29.292  - info: iqontrol.0 (540) Deleting unused Objects...
      2025-10-12 11:40:29.292  - info: iqontrol.0 (540) Subscribing to states...
      2025-10-12 11:40:29.294  - info: iqontrol.0 (540) iQontrol ready.
      2025-10-12 11:40:31.715  - info: host.iobroker84 instance system.adapter.trashschedule.0 in version "3.3.0" started with pid 555
      2025-10-12 11:40:33.165  - info: trashschedule.0 (555) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v22.20.0, js-controller: 7.0.7
      2025-10-12 11:40:33.243  - info: trashschedule.0 (555) [onReady] starting with source "ical" -> ical
      2025-10-12 11:40:33.249  - info: trashschedule.0 (555) [ical] configured ical preview is 45 days (until 26.11.2025) - increase this value to find more events in the future
      2025-10-12 11:40:35.666  - info: host.iobroker84 instance system.adapter.echarts.0 in version "1.9.2" started with pid 570
      2025-10-12 11:40:36.881  - info: echarts.0 (570) starting. Version 1.9.2 in /opt/iobroker/node_modules/iobroker.echarts, node: v22.20.0, js-controller: 7.0.7
      2025-10-12 11:40:52.818  - info: sonoff.0 (450) Client [Steckdose01] connected with secret 1760262052812_6539
      2025-10-12 11:40:52.978  - info: sonoff.0 (450) Client [Steckdose02] connected with secret 1760262052977_7832
      2025-10-12 11:40:53.209  - info: sonoff.0 (450) Client [Stromzaehler] connected with secret 1760262053207_304
      2025-10-12 11:41:20.278  - info: admin.0 (313) ==> Connected system.user.admin from ::ffff:192.168.23.27
      2025-10-12 11:41:35.334  - info: admin.0 (313) <== Disconnect system.user.admin from ::ffff:192.168.23.27 admin
      iob diag has finished.
      EDIT:
      Hier der Inhalt vom npm-Log /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
      $ cat /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@11.6.2
      2 info using node@v22.20.0
      3 silly config load:file:/usr/lib/node_modules/npm/npmrc
      4 silly config load:file:/opt/iobroker/.npmrc
      5 silly config load:file:/home/mf/.npmrc
      6 silly config load:file:/usr/etc/npmrc
      7 verbose title npm ls
      8 verbose argv "ls" "--all"
      9 verbose logfile logs-max:10 dir:/home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-
      10 verbose logfile /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
      11 silly logfile start cleaning logs, removing 1 files
      12 silly packumentCache heap:2197815296 maxSize:549453824 maxEntrySize:274726912
      13 silly logfile done cleaning log files
      14 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.js-controller
      15 verbose stack Error: invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
      15 verbose stack missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
      15 verbose stack missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
      15 verbose stack missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
      15 verbose stack missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
      15 verbose stack missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
      15 verbose stack missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
      15 verbose stack     at LS.exec (/usr/lib/node_modules/npm/lib/commands/ls.js:206:9)
      15 verbose stack     at async Npm.exec (/usr/lib/node_modules/npm/lib/npm.js:208:9)
      15 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli/entry.js:67:5)
      16 error code ELSPROBLEMS
      17 error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
      17 error missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
      17 error missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
      17 error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
      17 error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
      17 error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
      17 error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
      18 verbose cwd /opt/iobroker
      19 verbose os Linux 6.14.11-3-pve
      20 verbose node v22.20.0
      21 verbose npm  v11.6.2
      22 verbose exit 1
      23 verbose code 1
      24 error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-12T09_42_27_454Z-debug-0.log
        Thomas Braun Most Active @meute last edited by
        @meute sagte in npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie:
        @csstools/css-calc
        Aus welcher Ecke kommt das denn?
        cd /opt/iobroker && npm ls @csstools/css-calc
        mal anschauen.
        OliverIO meute 2 Replies Last reply Reply Quote 0
        • OliverIO
          OliverIO @Thomas Braun last edited by
          @thomas-braun sagte in npm error bei "iob diag" nach Upgrade auf Debian 13 Trixie:
          csstools/css-calc
          der github suche nach vom webui adapter
          https://github.com/search?q=iobroker+csstools%2Fcss-calc&type=code
          • meute
            meute @Thomas Braun last edited by
            mal anschauen.
            Hier das Ergebnis:
            $ cd /opt/iobroker && npm ls @csstools/css-calc
            iobroker.inst@3.0.0 /opt/iobroker
            └─┬ iobroker.echarts@1.9.2
              └─┬ jsdom@25.0.1
                └─┬ cssstyle@4.6.0
                  └─┬ @asamuzakjp/css-color@3.2.0
                    ├── @csstools/css-calc@2.1.4
                    └─┬ @csstools/css-color-parser@3.1.0
                      └── @csstools/css-calc@2.1.4 deduped
              @meute
              Dann installier den echarts nochmal drüber oder versuch es mal mit der Beta 2.0.10.
              meute 1 Reply Last reply Reply Quote 1
              • meute
                meute @Thomas Braun last edited by meute
                @meute
                Ich habe iobroker install und iobroker upgrade ausgeführt.
                Reicht das? Oder wie muss man drüber installieren?
                $ iobroker install echarts
                adapter "echarts" already installed. Use "upgrade" to upgrade to a newer version.
                $ iobroker upgrade echarts
                Adapter "echarts"        is up to date.
                EDIT:
                Der npm error bei iob diag ist noch vorhanden.
                  @meute
                  iob upgrade iobroker.echarts@1.9.2 --debug
                  • meute
                    @meute
                    Ich habe den Adapter echarts nun drüber installiert:
                    $ iob upgrade iobroker.echarts@1.9.2 --debug
                    Would you like to reinstall version 1.9.2 of echarts now? [(y)es, (n)o]: y
                    Update echarts from @1.9.2 to @1.9.2
                    Uninstall npm packet "iobroker.echarts" for a clean re-installation
                    removed 37 packages in 6s
                    104 packages are looking for funding
                      run `npm fund` for details
                    NPM version: 11.6.2
                    Installing iobroker.echarts@1.9.2... (System call)
                    npm warn deprecated npmlog@5.0.1: This package is no longer supported.
                    npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
                    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                    npm warn deprecated are-we-there-yet@2.0.0: This package is no longer supported.
                    npm warn deprecated gauge@3.0.2: This package is no longer supported.
                    added 71 packages in 10s
                    108 packages are looking for funding
                    upload [17] echarts /opt/iobroker/node_modules/iobroker.echarts/www/asset-manifest.json asset-manifest.json application/json
                    upload [16] echarts /opt/iobroker/node_modules/iobroker.echarts/www/favicon.ico favicon.ico image/vnd.microsoft.icon
                    upload [15] echarts /opt/iobroker/node_modules/iobroker.echarts/www/index.html index.html text/html
                    upload [14] echarts /opt/iobroker/node_modules/iobroker.echarts/www/manifest.json manifest.json application/json
                    upload [13] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/asset-manifest.json preview/asset-manifest.json application/json
                    upload [12] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/favicon.ico preview/favicon.ico image/vnd.microsoft.icon
                    upload [11] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/index.html preview/index.html text/html
                    upload [10] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/manifest.json preview/manifest.json application/json
                    upload [9] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/css/main.e631bfb5.css preview/static/css/main.e631bfb5.css text/css
                    upload [8] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/css/main.e631bfb5.css.map preview/static/css/main.e631bfb5.css.map application/json
                    upload [7] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/js/main.5fe9c7da.js preview/static/js/main.5fe9c7da.js application/javascript
                    upload [6] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/js/main.5fe9c7da.js.LICENSE.txt preview/static/js/main.5fe9c7da.js.LICENSE.txt text/plain
                    upload [5] echarts /opt/iobroker/node_modules/iobroker.echarts/www/preview/static/js/main.5fe9c7da.js.map preview/static/js/main.5fe9c7da.js.map application/json
                    upload [4] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.e631bfb5.css static/css/main.e631bfb5.css text/css
                    upload [3] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/css/main.e631bfb5.css.map static/css/main.e631bfb5.css.map application/json
                    upload [2] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.41cee985.js static/js/main.41cee985.js application/javascript
                    upload [1] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.41cee985.js.LICENSE.txt static/js/main.41cee985.js.LICENSE.txt text/plain
                    upload [0] echarts /opt/iobroker/node_modules/iobroker.echarts/www/static/js/main.41cee985.js.map static/js/main.41cee985.js.map application/json
                    Updating objects from io-package.json for adapter "echarts" with version "1.9.2"
                    upload [16] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/asset-manifest.json chart/asset-manifest.json application/json
                    upload [15] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/favicon.ico chart/favicon.ico image/vnd.microsoft.icon
                    upload [14] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/index.html chart/index.html text/html
                    upload [13] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/manifest.json chart/manifest.json application/json
                    upload [12] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/css/main.e631bfb5.css chart/static/css/main.e631bfb5.css text/css
                    upload [11] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/css/main.e631bfb5.css.map chart/static/css/main.e631bfb5.css.map application/json
                    upload [10] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.41cee985.js chart/static/js/main.41cee985.js application/javascript
                    upload [9] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.41cee985.js.LICENSE.txt chart/static/js/main.41cee985.js.LICENSE.txt text/plain
                    upload [8] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/chart/static/js/main.41cee985.js.map chart/static/js/main.41cee985.js.map application/json
                    upload [7] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/echarts.png echarts.png image/png
                    upload [6] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/main.f21b47ed.css static/css/main.f21b47ed.css text/css
                    upload [5] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/css/main.f21b47ed.css.map static/css/main.f21b47ed.css.map application/json
                    upload [4] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.70a15e1f.js static/js/main.70a15e1f.js application/javascript
                    upload [3] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.70a15e1f.js.LICENSE.txt static/js/main.70a15e1f.js.LICENSE.txt text/plain
                    upload [2] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/static/js/main.70a15e1f.js.map static/js/main.70a15e1f.js.map application/json
                    upload [1] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/tab.html tab.html text/html
                    upload [0] echarts.admin /opt/iobroker/node_modules/iobroker.echarts/admin/vendor/socket.io.js vendor/socket.io.js application/javascript
                    Leider ist der npm error bei iob diag nun größer geworden.
                    $ iob diag
                    npm error extraneous: @mapbox/node-pre-gyp@1.0.11 /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                    npm error extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                    npm error extraneous: aproba@2.1.0 /opt/iobroker/node_modules/aproba
                    npm error extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                    npm error extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                    npm error extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                    npm error extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                    npm error extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                    npm error extraneous: detect-libc@2.1.2 /opt/iobroker/node_modules/detect-libc
                    npm error extraneous: gauge@3.0.2 /opt/iobroker/node_modules/gauge
                    npm error extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                    npm error extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                    npm error extraneous: mimic-response@2.1.0 /opt/iobroker/node_modules/mimic-response
                    npm error extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                    npm error extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                    npm error extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                    npm error extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                    npm error extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                    npm error extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                    npm error extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                    npm error extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                    npm error extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/agent-base
                    npm error extraneous: debug@4.4.3 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/debug
                    npm error extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/https-proxy-agent
                    npm error extraneous: ms@2.1.3 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/ms
                    npm error extraneous: node-fetch@2.7.0 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/node-fetch
                    npm error extraneous: tr46@0.0.3 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/tr46
                    npm error extraneous: webidl-conversions@3.0.1 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/webidl-conversions
                    npm error extraneous: whatwg-url@5.0.0 /opt/iobroker/node_modules/@mapbox/node-pre-gyp/node_modules/whatwg-url
                    npm error extraneous: semver@6.3.1 /opt/iobroker/node_modules/make-dir/node_modules/semver
                    npm error extraneous: brace-expansion@1.1.12 /opt/iobroker/node_modules/rimraf/node_modules/brace-expansion
                    npm error extraneous: glob@7.2.3 /opt/iobroker/node_modules/rimraf/node_modules/glob
                    npm error extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/rimraf/node_modules/minimatch
                    npm error extraneous: decompress-response@4.2.1 /opt/iobroker/node_modules/simple-get/node_modules/decompress-response
                    npm error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-13T09_23_31_389Z-debug-0.log
                      @meute
                      Dann zieh mal die Beta 2.0.10 rein.
                      Ich vermute, die Dependencies wurden da mittlerweile angepasst.
                      meute 1 Reply Last reply Reply Quote 0
                      • meute
                        @meute
                        Installiert man die Beta auch so?
                        iob upgrade iobroker.echarts@2.0.10 --debug
                        Thomas Braun meute 2 Replies Last reply Reply Quote 0
                          @meute
                          Ja, sollte funktionieren.
                          • meute
                            meute @meute last edited by meute
                            @meute
                            Die Installation hat funktioniert.
                            Aber der Adapter produziert eine Menge Fehler und startet nicht.
                            Log anbei.
                            logs - iobroker84.html
                            EDIT:
                            Ich installiere lieber wieder 1.9.2.
                            EDIT2:
                            Ich bin jetzt außer Haus kann mich erst später wieder melden, falls Du antwortest.
                              @meute
                              Das ist kein Log, das ist Quark.
                              Das log kann man sich per
                              iob logs
                              anschauen.
                              • meute
                                iob logs
                                anschauen.
                                Dann hier das richtige Log mit iob logs.
                                2025-10-13 12:08:50.391  - info: host.iobroker84 stopInstance system.adapter.echarts.0 (force=false, process=true)
                                2025-10-13 12:08:50.399  - info: echarts.0 (1850) Got terminate signal TERMINATE_YOURSELF
                                2025-10-13 12:08:50.441  - info: host.iobroker84 stopInstance system.adapter.echarts.0 send kill signal
                                2025-10-13 12:08:50.918  - info: echarts.0 (1850) terminating
                                2025-10-13 12:08:50.919  - info: echarts.0 (1850) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2025-10-13 12:08:51.441  - info: host.iobroker84 stopInstance timeout system.adapter.echarts.0 killing pid 1850
                                2025-10-13 12:08:51.478  - info: host.iobroker84 instance system.adapter.echarts.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2025-10-13 12:08:54.802  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 3802
                                2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                                2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]:   throw err;
                                2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]:   ^
                                2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                                2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: Require stack:
                                2025-10-13 12:08:55.727  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                                2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                                2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                                2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                                2025-10-13 12:08:55.728  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                                2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                                2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                                2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                                2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]:   ]
                                2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]: }
                                2025-10-13 12:08:55.729  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                                2025-10-13 12:08:55.729  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2025-10-13 12:08:55.729  - info: host.iobroker84 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
                                2025-10-13 12:08:55.730  - info: host.iobroker84 system.adapter.echarts.0 will be rebuilt
                                2025-10-13 12:08:55.730  - warn: host.iobroker84 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                2025-10-13 12:08:55.731  - info: host.iobroker84 iobroker rebuild
                                2025-10-13 12:08:56.624  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules ...
                                2025-10-13 12:09:14.147  - info: admin.0 (1598) ==> Connected system.user.admin from ::ffff:192.168.23.27
                                2025-10-13 12:09:20.769  - info: host.iobroker84 iobroker npm-rebuild: rebuilt dependencies successfully
                                2025-10-13 12:09:20.796  - info: host.iobroker84 iobroker npm-rebuild:
                                2025-10-13 12:09:20.797  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules done
                                2025-10-13 12:09:21.809  - info: host.iobroker84 iobroker npm-rebuild: exit 0
                                2025-10-13 12:09:22.198  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4060
                                2025-10-13 12:09:23.079  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:   throw err;
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:   ^
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]: Require stack:
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                2025-10-13 12:09:23.080  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]:   ]
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]: }
                                2025-10-13 12:09:23.081  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                                2025-10-13 12:09:23.081  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2025-10-13 12:09:23.081  - info: host.iobroker84 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
                                2025-10-13 12:09:23.082  - info: host.iobroker84 system.adapter.echarts.0 will be rebuilt
                                2025-10-13 12:09:23.082  - warn: host.iobroker84 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                2025-10-13 12:09:23.082  - info: host.iobroker84 iobroker rebuild
                                2025-10-13 12:09:23.972  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules ...
                                2025-10-13 12:09:40.440  - info: host.iobroker84 iobroker npm-rebuild: rebuilt dependencies successfully
                                2025-10-13 12:09:40.469  - info: host.iobroker84 iobroker npm-rebuild:
                                2025-10-13 12:09:40.469  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules done
                                2025-10-13 12:09:41.482  - info: host.iobroker84 iobroker npm-rebuild: exit 0
                                2025-10-13 12:09:41.861  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4306
                                2025-10-13 12:09:42.771  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:   throw err;
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:   ^
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]: Require stack:
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                                2025-10-13 12:09:42.772  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                                2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                                2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                                2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                                2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                                2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]:   ]
                                2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]: }
                                2025-10-13 12:09:42.773  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                                2025-10-13 12:09:42.773  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2025-10-13 12:09:42.773  - info: host.iobroker84 Adapter system.adapter.echarts.0 needs rebuild and will be restarted afterwards.
                                2025-10-13 12:09:42.773  - info: host.iobroker84 system.adapter.echarts.0 will be rebuilt
                                2025-10-13 12:09:42.773  - warn: host.iobroker84 adapter "echarts" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
                                2025-10-13 12:09:42.774  - info: host.iobroker84 iobroker rebuild
                                2025-10-13 12:09:43.649  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules ...
                                2025-10-13 12:09:59.744  - info: host.iobroker84 iobroker npm-rebuild: rebuilt dependencies successfully
                                2025-10-13 12:09:59.773  - info: host.iobroker84 iobroker npm-rebuild:
                                2025-10-13 12:09:59.774  - info: host.iobroker84 iobroker npm-rebuild: Rebuilding native modules done
                                2025-10-13 12:10:00.790  - info: host.iobroker84 iobroker npm-rebuild: exit 0
                                2025-10-13 12:10:01.155  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4536
                                2025-10-13 12:10:02.102  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:   throw err;
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:   ^
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]: Require stack:
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                2025-10-13 12:10:02.103  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]:   ]
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]: }
                                2025-10-13 12:10:02.104  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                                2025-10-13 12:10:02.104  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2025-10-13 12:10:02.105  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                2025-10-13 12:10:06.604  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4543
                                2025-10-13 12:10:07.492  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                                2025-10-13 12:10:07.492  - error: host.iobroker84 Caught by controller[0]:   throw err;
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:   ^
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]: Require stack:
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                                2025-10-13 12:10:07.493  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                                2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                                2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                                2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                                2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]:   ]
                                2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]: }
                                2025-10-13 12:10:07.494  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                                2025-10-13 12:10:07.494  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2025-10-13 12:10:07.494  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                2025-10-13 12:10:17.295  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4550
                                2025-10-13 12:10:18.192  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                                2025-10-13 12:10:18.192  - error: host.iobroker84 Caught by controller[0]:   throw err;
                                2025-10-13 12:10:18.192  - error: host.iobroker84 Caught by controller[0]:   ^
                                2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                                2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]: Require stack:
                                2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                                2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                                2025-10-13 12:10:18.193  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                                2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                                2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                                2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                                2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                                2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                                2025-10-13 12:10:18.194  - error: host.iobroker84 Caught by controller[0]:   ]
                                2025-10-13 12:10:18.195  - error: host.iobroker84 Caught by controller[0]: }
                                2025-10-13 12:10:18.195  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                                2025-10-13 12:10:18.195  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2025-10-13 12:10:18.195  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                2025-10-13 12:10:18.526  - info: host.iobroker84 "system.adapter.echarts.0" disabled
                                2025-10-13 12:10:20.582  - info: host.iobroker84 "system.adapter.echarts.0" enabled
                                2025-10-13 12:10:21.027  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4557
                                2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                                2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]:   throw err;
                                2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]:   ^
                                2025-10-13 12:10:21.952  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                                2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]: Require stack:
                                2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                                2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                                2025-10-13 12:10:21.953  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                                2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                                2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                                2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                                2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                                2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                                2025-10-13 12:10:21.954  - error: host.iobroker84 Caught by controller[0]:   ]
                                2025-10-13 12:10:21.955  - error: host.iobroker84 Caught by controller[0]: }
                                2025-10-13 12:10:21.955  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                                2025-10-13 12:10:21.955  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2025-10-13 12:10:21.955  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                2025-10-13 12:11:04.014  - info: host.iobroker84 "system.adapter.echarts.0" disabled
                                2025-10-13 12:14:28.139  - info: host.iobroker84 "system.adapter.echarts.0" enabled
                                2025-10-13 12:14:28.607  - info: host.iobroker84 instance system.adapter.echarts.0 in version "2.0.10" started with pid 4570
                                2025-10-13 12:14:29.498  - error: host.iobroker84 Caught by controller[0]: node:internal/modules/cjs/loader:1386
                                2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:   throw err;
                                2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:   ^
                                2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]: Error: Cannot find module 'canvas'
                                2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]: Require stack:
                                2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js
                                2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:     at Function._resolveFilename (node:internal/modules/cjs/loader:1383:15)
                                2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:     at defaultResolveImpl (node:internal/modules/cjs/loader:1025:19)
                                2025-10-13 12:14:29.499  - error: host.iobroker84 Caught by controller[0]:     at resolveForCJSWithHooks (node:internal/modules/cjs/loader:1030:22)
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1192:37)
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:237:24)
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1463:12)
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at require (node:internal/modules/helpers:147:16)
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js:29:18)
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1706:14) {
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:   requireStack: [
                                2025-10-13 12:14:29.500  - error: host.iobroker84 Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.echarts/build-backend/main.js'
                                2025-10-13 12:14:29.501  - error: host.iobroker84 Caught by controller[0]:   ]
                                2025-10-13 12:14:29.501  - error: host.iobroker84 Caught by controller[0]: }
                                2025-10-13 12:14:29.501  - error: host.iobroker84 Caught by controller[0]: Node.js v22.20.0
                                2025-10-13 12:14:29.501  - error: host.iobroker84 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                2025-10-13 12:14:29.501  - info: host.iobroker84 Rebuild for adapter system.adapter.echarts.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
                                  Da kann ein Modul (vermutlich canvas) nicht richtig gebaut werden.
                                  cd /opt/iobroker && npm ls canvas
                                  mal anschauen.
                                  Und dann vielleicht im Verzeichnis des Adapters
                                  npm install --omit=dev
                                  ausführen.
                                  • meute
                                    mal anschauen.
                                    Ergebnis:
                                    $ cd /opt/iobroker && npm ls canvas
                                    └── (empty)
                                    ausführen.
                                    Meinst Du diesen Ordner?
                                    $ ls -lh /opt/iobroker/iobroker-data/files/echarts
                                    insgesamt 152K
                                    -rw-rw-r--+ 1 iobroker iobroker  11K 13. Okt 12:15 asset-manifest.json
                                    drwxrwxr-x+ 2 iobroker iobroker 4,0K 13. Okt 12:15 assets
                                    -rw-rw-r--+ 1 iobroker iobroker 4,0K 13. Okt 12:15 _data.json
                                    -rw-rw-r--+ 1 iobroker iobroker 115K 13. Okt 12:15 favicon.ico
                                    -rw-rw-r--+ 1 iobroker iobroker  690 13. Okt 12:15 index.html
                                    -rw-rw-r--+ 1 iobroker iobroker  313 13. Okt 12:15 manifest.json
                                    drwxrwxr-x+ 4 iobroker iobroker 4,0K 13. Okt 12:15 preview
                                    drwxrwxr-x+ 4 iobroker iobroker 4,0K  3. Okt 15:03 static
                                    Hier soll ich npm install --omit=dev ausführen.
                                    Kann ich mir damit was kaputt machen?
                                    EDIT:
                                    Aber eigentlich müsste der npm error doch bei jedem vorhanden sein, der den Adapter echarts installiert hat.
                                    Oder verstehe ich hier was falsch?
                                      @meute
                                      Das richtige Verzeichnis ist
                                      Nein, wenn der Adapter bzw. das Modul gebaut werden kann dann hat man auch keinen Fehler.
                                      Bei mir ist der Adapter z. B. sauber installiert worden.
                                        Thomas Braun Most Active @meute last edited by Thomas Braun
                                        @meute
                                        Da sollte so ähnlich eigentlich aussehen:
                                        echad@chet:/opt/iobroker $ node -v
                                        v24.10.0
                                        echad@chet:/opt/iobroker $ npm ls canvas
                                        ├─┬ iobroker.echarts@2.0.10
                                        │ ├── canvas@3.2.0
                                        │ └─┬ jsdom@26.1.0
                                        │   └── canvas@3.2.0 deduped
                                        ├─┬ iobroker.mihome-vacuum@5.3.0
                                        └─┬ iobroker.parcel@0.2.10
                                          └─┬ jsdom@25.0.1
                                            └── canvas@3.2.0 deduped invalid: "^2.11.2" from node_modules/iobroker.parcel/node_modules/jsdom
                                        npm error invalid: canvas@3.2.0 /opt/iobroker/node_modules/canvas
                                        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-13T16_27_05_147Z-debug-0.log
                                        Der Error bei parcel ist was anderes. Aber hier baut canvas sogar mit nodejs@24. Würde aber mit nodejs@22 auch nicht anders aussehen.
                                        • meute
                                          Ich habe npm install --omit=dev ausgeführt.
                                          $ cd /opt/iobroker/node_modules/iobroker.echarts/
                                          /opt/iobroker/node_modules/iobroker.echarts $ npm install --omit=dev
                                          npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
                                          added 128 packages, and audited 129 packages in 2m
                                          18 packages are looking for funding
                                          found 0 vulnerabilities
                                          Ergebnis cd /opt/iobroker && npm ls canvas:
                                            ├── canvas@2.11.2
                                            └─┬ jsdom@25.0.1
                                              └── canvas@2.11.2 deduped
                                          Der npm error bei iob diag ist noch größer geworden.
                                          $ iob diag
                                          npm error extraneous: @asamuzakjp/css-color@3.2.0 /opt/iobroker/node_modules/@asamuzakjp/css-color
                                          npm error extraneous: @csstools/color-helpers@5.1.0 /opt/iobroker/node_modules/@csstools/color-helpers
                                          npm error extraneous: @csstools/css-calc@2.1.4 /opt/iobroker/node_modules/@csstools/css-calc
                                          npm error extraneous: @csstools/css-color-parser@3.1.0 /opt/iobroker/node_modules/@csstools/css-color-parser
                                          npm error extraneous: cssstyle@4.6.0 /opt/iobroker/node_modules/cssstyle
                                          npm error extraneous: data-urls@5.0.0 /opt/iobroker/node_modules/data-urls
                                          npm error extraneous: decimal.js@10.6.0 /opt/iobroker/node_modules/decimal.js
                                          npm error extraneous: echarts@5.6.0 /opt/iobroker/node_modules/echarts
                                          npm error extraneous: html-encoding-sniffer@4.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                          npm error extraneous: http-proxy-agent@7.0.2 /opt/iobroker/node_modules/http-proxy-agent
                                          npm error extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                          npm error extraneous: jsdom@25.0.1 /opt/iobroker/node_modules/jsdom
                                          npm error extraneous: nwsapi@2.2.22 /opt/iobroker/node_modules/nwsapi
                                          npm error extraneous: parse5@7.3.0 /opt/iobroker/node_modules/parse5
                                          npm error extraneous: rrweb-cssom@0.7.1 /opt/iobroker/node_modules/rrweb-cssom
                                          npm error extraneous: saxes@6.0.0 /opt/iobroker/node_modules/saxes
                                          npm error extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                          npm error extraneous: tldts-core@6.1.86 /opt/iobroker/node_modules/tldts-core
                                          npm error extraneous: tldts@6.1.86 /opt/iobroker/node_modules/tldts
                                          npm error extraneous: tr46@5.1.1 /opt/iobroker/node_modules/tr46
                                          npm error extraneous: w3c-xmlserializer@5.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                          npm error extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                          npm error extraneous: whatwg-encoding@3.1.1 /opt/iobroker/node_modules/whatwg-encoding
                                          npm error extraneous: whatwg-mimetype@4.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                          npm error invalid: whatwg-url@14.2.0 /opt/iobroker/node_modules/whatwg-url
                                          npm error extraneous: whatwg-url@14.2.0 /opt/iobroker/node_modules/whatwg-url
                                          npm error extraneous: xml-name-validator@5.0.0 /opt/iobroker/node_modules/xml-name-validator
                                          npm error extraneous: xmlchars@2.2.0 /opt/iobroker/node_modules/xmlchars
                                          npm error extraneous: zrender@5.6.1 /opt/iobroker/node_modules/zrender
                                          npm error missing: @csstools/css-parser-algorithms@^3.0.4, required by @asamuzakjp/css-color@3.2.0
                                          npm error missing: @csstools/css-tokenizer@^3.0.3, required by @asamuzakjp/css-color@3.2.0
                                          npm error extraneous: lru-cache@10.4.3 /opt/iobroker/node_modules/@asamuzakjp/css-color/node_modules/lru-cache
                                          npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-calc@2.1.4
                                          npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-calc@2.1.4
                                          npm error missing: @csstools/css-parser-algorithms@^3.0.5, required by @csstools/css-color-parser@3.1.0
                                          npm error missing: @csstools/css-tokenizer@^3.0.4, required by @csstools/css-color-parser@3.1.0
                                          npm error extraneous: rrweb-cssom@0.8.0 /opt/iobroker/node_modules/cssstyle/node_modules/rrweb-cssom
                                          npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/echarts/node_modules/tslib
                                          npm error extraneous: debug@4.4.3 /opt/iobroker/node_modules/http-proxy-agent/node_modules/debug
                                          npm error extraneous: ms@2.1.3 /opt/iobroker/node_modules/http-proxy-agent/node_modules/ms
                                          npm error extraneous: tough-cookie@5.1.2 /opt/iobroker/node_modules/jsdom/node_modules/tough-cookie
                                          npm error extraneous: iconv-lite@0.6.3 /opt/iobroker/node_modules/whatwg-encoding/node_modules/iconv-lite
                                          npm error extraneous: tslib@2.3.0 /opt/iobroker/node_modules/zrender/node_modules/tslib
                                          npm error invalid: buffer@5.7.1 /opt/iobroker/node_modules/buffer
                                          npm error A complete log of this run can be found in: /home/mf/.npm/_logs/2025-10-13T16_46_12_186Z-debug-0.log
                                          *** ioBroker Diagnosis ***
                                          Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                                            @meute
                                            Die Einträge mir extraneous sollten mit einem
                                            npm prune
                                            verschwinden.
                                            81.0k
                                            578
